查看: 178|回复: 0
[allegro16.3][6层] SENSOR-PS5510参考板(SENSOR-PS5510+SCHUBERT+MX25L12835FM2...
发表于 2020-2-10 19:01 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
6 Y- z# S! r* g( C. |6 O9 L
[allegro16.3][6层] SENSOR-PS5510参考板(SENSOR-PS5510+SCHUBERT+MX25L12835FM2I-10G)pcb文件) v4 @1 v' v2 Z: t
3 K3 w' z1 g% P* D% l) N* S8 a7 E文件描述:
% U, p5 D' S: F/ n+ s3 y1 g# E" t1 i) h  x: X
1. 作品用途:SENSOR-PS5510参考板
2 O& |( Z" W1 h* U2. 软件版本:allegro16.3/ @) G0 H+ i% u0 R- Z/ d* W6 u- a
3. 层数:6层
+ F1 c4 X" T# A# y: C  n4. 用到的主要芯片:SENSOR-PS5510+SCHUBERT+MX25L12835FM2I-10G# G0 Y! c9 E9 J/ i1 N. {3 D
5. pcb尺寸: 1496*1496 MIL% x1 A' H, H# C1 A, m
, ?2 k. h7 U. ?& n  \: u) e
作品截图如下:
) [6 X( v# u+ i# Z6 [
0 `* ?& Y& t' Y3 `- U顶层截图:
$ T2 D. y' z1 _9 v # q! S# s! c1 e# K1 B
底层截图:
. C7 U! n0 E9 s! Y " R# A3 p' q5 K; }! t" m
9 B; c+ {/ @6 e9 z& z. p
全层截图:
; C$ `" f8 d' v+ E9 x( k# Z 1 Q+ {; x  R8 j8 H: X) N$ G
" `+ [: O) @2 ]9 h
BOM:- k$ L! E7 D6 D5 Y  t# L
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
C157D79C157D79MOUNT_HOLEIC2HG1; HG2
C0201C02011uF,6.3VIC26CG3; CG4; CG6; CG7; CG11; CG12; CG17; CG28; CG29; CG31; CG38; CG45; CG48; CG57; CG58; CG59; CG60; CG72; CG75; CG76; CG77; CG79; CG85; CG131; CG132; CG133
C0201C02010.1uF,6.3VIC54CG5; CG8; CG13; CG14; CG15; CG16; CG18; CG19; CG21; CG25; CG30; CG35; CG36; CG39; CG43; CG44; CG47; CG49; CG50; CG52; CG61; CG62; CG63; CG64; CG65; CG66; CG67; CG68; CG69; CG84; CG86; CG88; CG90; CG92; CG99; CG103; CG105; CG109; CG110; CG112; CG113; CG116; CG117; CG118; CG119; CG120; CG121; CG122; CG125; CG126; CG127; CG129; CG130; CG134
C0201C02010.01uF,6.3VIC4CG81; CG83; CG100; CG106
C0402C04020.1uF,16VIC4CG2; CG73; CG93; CG94
C0402C040210uF,6.3VIC21CG10; CG22; CG27; CG46; CG51; CG53; CG55; CG56; CG80; CG82; CG87; CG91; CG97; CG107; CG108; CG111; CG114; CG115; CG123; CG124; CG128
C0402C040222pF,50VIC3CG23; CG32; CG40
C0402C040227pF,50VIC2CG70; CG71
C0402C0402220pF,50VIC1CG78
C0402C0402XX_10pF,50VIC1CG89
C0402C040215pF,50VIC2CG96; CG101
C0603C060310uF,10VIC7CG1; CG20; CG33; CG37; CG41; CG74; CG102
C0603C060322uF,6.3VIC8CG9; CG24; CG26; CG34; CG42; CG54; CG98; CG104
C1206C12061000pF,2KVIC1CG95
DFN6-2X2P065DFN6-2X2P065XCA201A06BCRIC1UG3
L0402L0402FBM-11-100505-121TIC3LG1; LG5; LG7
L0402L0402SBY100505T-121Y-NIC1LG6
L-25201BL-25201B2.2uH, 2AIC2LG2; LG4
Q-SOT23-6Q-SOT23-6TPS79301,200mA,ADJIC2UG10; UG11
QFN32-4X4P04QFN32-4X4P04IP101GRIC1UG9
R0402R04022.7KIC2RG1; RG7
R0402R040210KIC4RG2; RG40; RG50; RG53
R0402R040275K,1%IC1RG3
R0402R0402100K,1%IC1RG4
R0402R040210K, 1%IC2RG5; RG6
R0402R0402105K,1%IC1RG8
R0402R040223.7K,1%IC1RG9
R0402R04024.7KIC11RG10; RG17; RG18; RG32; RG35; RG36; RG37; RG38; RG39; RG51; RG52
R0402R0402240,1%IC2RG11; RG12
R0402R04021K,1%IC2RG13; RG14
R0402R0402XX_0IC3RG15; RG21; RG24
R0402R04020IC9RG16; RG26; RG27; RG28; RG29; RG41; RG47; RG48; RG49
R0402R0402100IC1RG20
R0402R040247KIC1RG22
R0402R04028.2KIC1RG23
R0402R04025.6KIC1RG25
R0402R0402200, 1%IC1RG30
R0402R040230IC1RG31
R0402R04026.19K,1%IC1RG33
R0402R040275IC1RG34
R0402R0402XX_300K,1%IC1RG42
R0402R0402300K,1%IC2RG43; RG46
R0402R040251K,1%IC1RG44
R0402R040230.1K,1%IC1RG45
R0402R04024.02K, 1%IC1RG54
R0805R080510IC1RG19
SCHUBERT-BGA361-13X13-P065SCHUBERT-BGA361-13X13-P065SoCIC1UG1
SENSOR-PS5510SENSOR-PS5510PS5510IC1UG13
SMDCON1X2_125MMSMDCON1X2_125MMSMDCON1X2_125_180IC2JG1; JG3
SMDCON1X3_125MMSMDCON1X3_125MMSMDCON1X3_125_180IC1JG4
SMDCON1X4_125MMSMDCON1X4_125MMSMDCON1X4_125_90IC1JG2
SMDCON1X6P1MM-CSI-1181-XXXXSMDCON1X6P1MM-CSI-1181-XXXXWAFER 1X6(CSI-1181-061R)IC1JG5
SMDL-ZLDF2012SMDL-ZLDF20122.2uH/0.74A/0.22OhmIC1LG3
SOT23-6PSOT23-6PSY8121BIC2UG2; UG5
SOT26-6PSOT26-6PAP1511AIC1UG8
SOT143SOT143PT7M7811IC1UG6
TPTPTPIC8TPG1; TPG2; TPG3; TPG4; TPG5; TPG6; TPG7; TPG8
USPQ-4B04-XC6233USPQ-4B04-XC6233iD9349-18FA4RIC2UG4; UG12
VP2019VP2019FMVP-208SIC1TG1
WSON8-8X6P127H075WSON8-8X6P127H075MX25L12835FM2I-10GIC1UG7
XTAL_X32XTAL_X3219.2MHzIC1YG1
附件:
. h8 \5 V8 N( `- G/ |1 YPCB文件如下:
& Z  d2 N; N( W# \$ y" N
游客,如果您要查看本帖隐藏内容请回复
$ Z, L; q/ \: x- L0 ^# G
/ I- \- @' E! E( @/ c( F4 [4 C
GMT+8, 2025-7-25 05:07 , Processed in 0.109375 second(s), 28 queries , Gzip On.
