作品名:[AD 15][4层] 具有AI智能分析的网络摄像机(HI3516CV500_DDR+SY8088+MP6507)原理图、PCB源文件7 o+ U+ h! k9 u" Y3 x
0 Z. A$ n* b- j, d* e8 h6 [) D
文件描述
+ `! k# K6 \8 m7 F: t1. 作品用途:网络摄像机7 | O4 [. O" u
2. 软件版本:AD 154 n) y0 `* V' z- w3 _
3. 层数:4层板* R, D/ y+ @9 S3 c8 E
4. 用到的主要芯片:HI3516CV500_DDR+SY8088+MP6507& ~! o+ Q. N/ t- r5 _, _2 p1 J
5. PCB尺寸:145mm*134mm
9 ]( R O) y5 x$ C
6 z7 u( D/ p5 r( H- A4 l作品截图如下:
^5 w5 D' J6 f; q5 B, C顶层截图:
! U' Q9 _1 {; _- a
6 k( A+ M: g- T' c底层截图:( G- Z1 V' G$ W( G) l% ~
$ z; x! }, Y [全层截图:/ E0 c' [/ s: @$ Z% ?$ r( Q
5 T6 _ P3 X p- U! ?
叠层信息截图如下:
' w5 J) _& V( M" U5 R$ t4 W
- E0 b) |8 S7 QBOM:/ ^" d! M2 ^) s1 ~
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 5.6PF | C1 | SC0402 | 1 | 47PF | C2, C24 | SC0402 | 2 | 2.2uF | C3, C7, C9, C12, C29, C37, C96, C119, C122, C125, C139, C141 | SC0402-BGA | 12 | 22uF/NC* | C4 | SC1210B | 1 | 100NF | C5, C25, C26, C30, C31, C40, C43, C49, C50, C52, C53, C54, C57, C58, C66, C67, C68, C69, C98, C108, C109, C114, C164, C167, C202, C203, C229, C230, C283, C332, C423 | SC0402 | 31 | 100NF* | C6, C150 | SC0603 | 2 | 10uF | C8, C10, C13 | SC0805 | 3 | 10uF | C11, C35, C193, C408, C415 | SC0603 | 5 | 100NF/NC* | C14 | SC0805 | 1 | 1UF | C15, C189 | SC0402 | 2 | 100NF/NC* | C16, C38, C48, C61, C70, C92, C97, C162, C282 | SC0402 | 9 | 1UF | C17, C18 | SC0603 | 2 | 330N | C19, C20 | HSC0402-TA | 2 | 4.7uF | C21, C51, C93, C103, C105 | SC0402-BGA | 5 | 22NF | C22 | SC0402 | 1 | 15PF | C23, C136, C206, C207 | SC0402 | 4 | 2.2uF | C27, C28, C32, C33, C76, C77, C138 | SC0402-PD | 7 | 100NF | C34 | SC0805 | 1 | 4.7uF | C36, C41, C82, C83, C89, C116, C117, C118, C120, C134, C140, C157, C163 | SC0402-PD | 13 | 220nF | C47, C100, C104, C110, C111 | SC0402-BGA | 5 | 100NF | C55, C60, C62, C63, C64, C65, C90, C99, C102, C106, C126 | SC0402-BGA | 11 | 100NF | C74, C75, C84, C85, C86, C142, C149, C151, C252 | SC0603 | 9 | 10NF | C78, C79, C121 | SC0402 | 3 | 2.2uF* | C81 | SC0402-PD | 1 | 680PF | C87, C88 | SC0402 | 2 | 18PF | C128, C204 | SC0402 | 2 | 22UF | C129, C135, C181, C182, C183 | SC1210B | 5 | 1NF | C130, C131, C132, C281 | SC0402 | 4 | 1NF | C133 | SC1206 | 1 | 27PF | C144, C145 | SC0402 | 2 | 100UF | C146, C224 | SC1210 | 2 | 100UF/NC* | C147 | SC1210 | 1 | 220nF | C153, C156 | SC0402 | 2 | 220nF/NC* | C154, C155 | SC0402 | 2 | 100pF | C159, C160 | HSC0402-HDTA | 2 | 4.7uF/NC* | C165, C166 | SC0402-PD | 2 | 220PF | C173, C174 | SC0402 | 2 | 22PF | C185, C186 | SC0402 | 2 | 22UF | C192, C194, C196, C198, C199, C200, C201, C334, C460 | SC1206 | 9 | 22uF/NC* | C195, C197, C454 | SC1206 | 3 | 10UF/NC* | C225 | SC0603 | 1 | 220UF | C320 | SCAPC2-280-327 | 1 | D2-3_D | D1, D2 | SOT23 | 2 | LED | D3, D9, D22 | SD0805-LED | 3 | 0* | D4 | HSOD882 | 1 | DZ3 | D5, D6, D7, D8 | HSOD882 | 4 | DZ3 | D10 | SD1714D | 1 | DZ_L | D11, D12, D15, D16 | HSOD882 | 4 | | D13, D14 | SOD323-N | 2 | DZ3 | D21 | SD1710A | 1 | Comment | Designator55 | SC0402-BGA | 1 | FUSE2_1 | F1 | SF6127 | 1 | WBC1X4-M2 | J1, J21, J23, J24 | SHEAD-4P-49 | 4 | | J2, J3, J14, J16, J18, J25 | HEAD0101-T-B | 6 | SED60 | J4, J5 | DF17_7MH-60DP_P05 | 2 | IDC20_A | J6 | IDC20-DTM1-A | 1 | USB-4S4 | J7 | USB4-200-1907 | 1 | MMC8S4 | J8 | HSDC10-1614B | 1 | MIPI_60_CON_F | J9 | SED60-16F-A | 1 | DB9-2_A | J10 | DB9-2RM | 1 | MIC6M1_B | J11, J12 | VAF6-1406E | 2 | PWC3_A | J13 | PWC0103-M-N | 1 | MJ8-SL | J17 | MJ8-SRLFY | 1 | 3.9UH | L1, L3 | SPL0404L | 2 | 4.7UH | L2 | SL0805 | 1 | 2.2UH | L4, L6, L7 | HSL1008 | 3 | 470nH | L10 | HSL1008 | 1 | LB | LB1, LB2, LB3, LB4, LB9, LB10, LB11, LB16, LB17, LB19, LB20 | SL0402 | 11 | LB | LB5, LB7 | SL0603 | 2 | LB | LB8 | SL0805 | 1 | HOLE-8STARS | M1, M2, M3, M4, M5, M6, M7, M8, M9 | MTH_C6MMD3P2MM | 9 | PMOS-GSD | Q1 | SOT23 | 1 | NPN-BEC | Q3, Q4, Q6, Q7 | SOT23 | 4 | 100 | R1, R130, R131 | SR0603 | 3 | 100/NC* | R2 | SR0603 | 1 | 12K | R3 | SR0402 | 1 | 510 | R4, R5, R225, R226, R227, R229, R232 | SR0603 | 7 | 47K | R6 | SR0402 | 1 | 0 | R7, R40, R41, R42, R43, R46, R47, R50, R52, R53, R57, R58, R59, R62, R65, R73, R105, R107, R118, R444, R445, R446, R461, R462, R463 | SR0402 | 25 | 47K/NC* | R8, R10, R11, R12, R15 | SR0402 | 5 | 100 | R9, R18, R23, R28, R44, R45, R48, R51 | SR0402 | 8 | 10K | R13, R60, R63, R71, R72, R75, R82, R159, R160, R161, R162, R163, R164, R165, R171, R172, R178, R183, R188, R189, R196, R206 | SR0402 | 22 | 1.1K | R14, R93, R94, R95 | SR0603 | 4 | 2 | R16, R218 | SR0603 | 2 | 1K | R17, R68, R69, R80, R174, R175, R176, R177, R199, R200, R201, R203, R204, R205, R207, R208, R252, R354, R355, R356 | SR0402 | 20 | 30K | R19, R77 | SR0402 | 2 | 0.005 | R20, R27 | SR2512C | 2 | 33 | R21, R22, R26, R29, R30, R33, R35, R233, R234, R235, R236, R237, R245, R246, R247 | HSC0402-HDTA | 15 | 9.53K | R24 | SR0603 | 1 | 0/NC* | R25, R54, R64, R104, R106 | SR0402 | 5 | 2.2K | R31 | SR0402 | 1 | 5.1K | R32, R34 | SR0603 | 2 | 1MEG | R36, R37 | SR0402 | 2 | 10 | R38, R230, R231, R240, R241 | SR0402 | 5 | 24.9K | R39 | SR0402 | 1 | 20K | R49, R153, R219 | SR0402 | 3 | 91K | R55, R56 | SR0402 | 2 | 10K/NC* | R61 | SR0402 | 1 | 0 | R66, R67, R166, R168 | SR0805 | 4 | 15K | R78, R128 | SR0402 | 2 | 24K | R79, R220 | SR0402 | 2 | 100K/NC* | R81 | SR0402 | 1 | 470K/NC* | R83, R84 | SR0402 | 2 | 2K | R85, R86, R250 | SR0402 | 3 | 1.5K | R96 | SR0402 | 1 | 75 | R97 | SR0603 | 1 | 24.3K | R98, R99 | SR0603 | 2 | 2.49K | R100 | SR0402 | 1 | 560 | R101, R102 | HSR0402-TA | 2 | 4.7K | R103, R108, R109, R110, R111, R116, R117, R186, R187, R242, R243, R276, R277, R278 | SR0402 | 14 | 4.7K/NC* | R112, R190, R191, R244 | SR0402 | 4 | 240 | R114, R263 | SR0402 | 2 | 0 | R121, R122, R289 | SR0603 | 3 | 5.6K | R123 | SR0402 | 1 | 100K | R124, R125, R211, R212, R215, R217, R291 | SR0402 | 7 | 75 | R144 | SR0402 | 1 | 2.7K | R145, R146 | SR0402 | 2 | 4.7K | R149 | SR0603 | 1 | 22 | R150 | SR0402 | 1 | 3.3K | R156 | SR0402 | 1 | 33.2K | R158 | SR0603 | 1 | 22K | R170 | SR0402 | 1 | 150K | R185 | SR0402 | 1 | 6.8K | R222, R223 | SR0402 | 2 | 0/NC* | R290 | SR0603 | 1 | 51K | R308 | SR0402 | 1 | 1K/NC* | R367 | SR0402 | 1 | MSW4 | S2, S3, S4 | SSW-PUSH | 3 | DSW4 | SW1 | SW4_6M6X5M4 | 1 | TRANSMITOR100 | T1 | STFM16-50-285 | 1 | TESTPOINT | TP1, TP2 | GND12 | 2 | HI3516CV500_DDR | U1 | BGA280-26-1818 | 1 | NC* | U2 | SOP16-50-300A | 1 | SY8088 | U3 | SOT23-5 | 1 | SY8120 | U4, U5 | SOT23-6 | 2 | RT9065 | U6 | SOT23-6B | 1 | LMC6482 | U7 | SOP8-50-150 | 1 | RTL8201F-VB-CG | U9 | QFN32C-050-0505LH | 1 | SGM8903 | U11 | SGM8903 | 1 | SY8089 | U12 | SOT23-5 | 1 | MAX3232E | U13 | SOP16-26-208-255 | 1 | NT5CC256M16CP | U14 | BGA96-32-1609G | 1 | HPA00615DRVR | U16 | MLF6-065-0202L | 1 | PWR1-2 | U18 | SBAT2-13A | 1 | MX25L25635 | U19 | WSON8-MX25L12835ZN | 1 | MP6507 | U20 | QFN16-050-0303LH | 1 | INA220 | U34, U40 | SOP10-20-124A | 2 | 24MHZ | X1 | HSX4-0302 | 1 | 32.768KHZ | X2 | HSX2-0302 | 1 | 25MEG | X3 | HSX4-0302 | 1 | 附件:
1 l5 _' [& y( Z+ e/ N: N1 \原理图和PCB源文件如下:5 ` l" t# X' x# P
. }* Y {% E) b- U m% q8 K' |+ ^+ j# |7 ?7 `
