作品名:[AD 15][4层] 核心板(TMS320F2808+TMS320F28335)PCB源文件2 k1 i, H3 I' |/ V7 o
6 N+ i6 m: O2 o* M' F' c; ], I9 S文件描述
. a; V+ X K" a0 I. z7 ^2 b1. 作品用途:核心板
; N3 ~$ W& c8 [ E4 n C2. 软件版本:AD 15
# a! ?3 ?3 T7 T' u$ S& u3. 层数:4层板' j! E1 T7 w. P
4. 用到的主要芯片:TMS320F2808+TMS320F28335, H# B7 d& J. K" A+ g
5. PCB尺寸:120mm*60mm
t; x( o( A) T9 \
- D: {! t* U- v2 m* T1 e作品截图如下:
* ~* u' b9 O @6 r4 @顶层截图:
1 w, @' h$ L: r/ s3 v0 k+ B. P
# e: N8 w6 ]+ H) T: S
底层截图:6 w v" ^2 g3 i' s
* B" o# |1 n8 G9 \" d全层截图:( N! D9 w8 s8 s! s4 `" [1 I; e
' P& H* H0 ]3 F% X" U5 M- {& S
叠层信息截图如下:1 y: q% x7 @' o) v p, P
# v8 E, j9 O# Y; S4 y# CBOM:
; p- ^( i3 p2 s0 x% i( X& v5 JComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 1.8VD | +1.8V-E, +1.9V | TP | 2 | 2.048V | +2.048V, +2.048V-E | TP | 2 | 3.3VD | +3.3V, +3.3V-E | TP | 2 | +5V | +5V, +5V-E | TP | 2 | 0.1uF | C1E, C1T, C2E, C2T, C3E, C3T, C4E, C4T, C5E, C5T, C6E, C6T, C7E, C7T, C8E, C8T, C9T, C11E, C12E, C12T, C13E, C13T, C14E, C14T, C15T, C16E, C16T, C17E, C17T, C18E, C18T, C19E, C19T, C20E, C21E, C21T, C22E, C22T, C23E, C23T, C24E, C24T, C25E, C25T, C26E, C26T, C27E, C27T, C28E, C28T, C29T, C30T, C31T, C32T, C33T, C34T, C35T, C36T, C37T | 0805 | 59 | 4.7uF | C31E, C43T | 1210 | 2 | 20pf | C32E, C33E, C44T, C45T | 0805 | 4 | 100uF | C34E | 1812-2 | 1 | 10uF | C35E, C36E, C46T, C47T | 1210 | 4 | 2.2uf | C37E, C38E, C48T, C49T | 0805 | 4 | CAP | C39E, C40E, C41E, C42E, C43E, C44E, C45E, C46E, C47E, C48E, C49E, C50E, C50T, C51E, C51T, C52E, C52T, C53E, C53T, C54E, C54T, C55T, C56T, C57T, C58T, C59T, C60T, C61T, C62T, C63T, C64T, C65T | 0805 | 32 | Cap Pol1 | C42T | 1812-2 | 1 | XCLKOUT | CLKOUT, CLKOUT-E | TP | 2 | IN5819 | D1E, D1T | IN5819 | 2 | | D2E, D2T | LED | 2 | LED | D3E, D3T, D4T | LED | 3 | 33uf | E1E, E1T, E2E, E2T | 1210 | 4 | CON3 | J1E, J1T | SIP3-3 | 2 | CON3 | J2E, J2T, J3T | SIP3-2 | 3 | JTAG_14 | JP1E, JP1T | JTAG-14 | 2 | HEADER 12X2 | JP2E, JP3E, JP4E | DIP24-2 | 3 | HEADER26X2 | JP2T | DIP52-2 | 1 | HEADER 17X2 | JP3T | DIP34-2 | 1 | HEADER 24X2 | JP4T | DIP52-2 | 1 | 50uH/1A | L3E, L3T, L4E, L4T, L5E, L5T | 1210-2 | 6 | +5Vin | P1E, P1T | POWER | 2 | 4.7k | R1E, R1T, R2E, R2T | 0805 | 4 | 2.2K | R3E, R3T | 0805 | 2 | 250K | R4E, R4T | 0805 | 2 | 2K | R5E, R7T | 0805 | 2 | 30.1K | R5T | 0805 | 1 | 22K | R6E, R10T | 0805 | 2 | 18.2K | R6T | 0805 | 1 | 1K | R7E, R8T, R9T | 0805 | 3 | 47K | R8E, R9E, R10E, R11T, R12T, R13T, R14T | 0805 | 7 | SW-PB | S1E, S1T | RESET | 2 | TPS767D318 | U1E | TPS767D318 | 1 | TPS767D301 | U1T | TPS767D318 | 1 | TMS320F2808 | U2E | TMS320F2808 | 1 | TMS320F28335 | U2T | TMS320F28335 | 1 | max6021A | U3E, U3T | SOT-23 | 2 | NUP4201MR6T1 | U4E, U4T, U5E, U5T, U6E, U6T, U7E, U7T | TSOP-6 | 8 | 56RX4 | U8E, U8T, U9E, U9T, U10E, U10T, U11E, U11T | 56RX4 | 8 | 30MHz | Y1E, Y1T | CRYSTAL | 2 | 附件:
3 |0 j, L. n8 |; q PCB源文件如下:
/ X5 G- s& U- L [$ V S, V: v, J1 R, K9 Q! \
0 v& W$ v7 B' R$ u |
