查看: 2209|回复: 18
[allegro16.6][8层] S32R雷达微控制器(S32R274+KSZ9031RNXUA+TJA1051T/3)原理图...
发表于 2020-2-10 13:03 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
3 n# {' J: T, I, f  [
[allegro16.6][8层] S32R雷达微控制器(S32R274+KSZ9031RNXUA+TJA1051T/3)原理图和pcb文件  y" }' n' e' I0 K9 Y8 ^' V
" n& T0 z" z: r# a, p
文件描述:+ h  F: U2 Z  A/ f- d$ W3 Y0 V
( a" E" C: _: {7 U
1. 作品用途: S32R雷达微控制器
; P8 s* T8 q2 l2. 软件版本:allegro16.6$ T" V  Z$ z5 L- h1 e. N" ^! p
3. 层数:8层6 D! A0 w. K  C! N9 V
4. 用到的主要芯片:S32R274+KSZ9031RNXUA+TJA1051T/3
0 \) `. D$ L0 X2 G5 R0 B8 x5. pcb尺寸: 5000*4500 MIL
7 ~/ E- ~: }& n$ F8 j/ \3 m: u3 x# b1 D8 n0 Z
作品截图如下:% C1 n7 o- w2 ]' M
/ y1 d8 g( e% p: j顶层截图:
" ^0 p; x# E8 R+ W  D   _1 p& Y& T' K
底层截图:5 s. k0 K2 p# c* m7 t
! O/ H) ]! o1 _$ D1 l! ^" }1 `1 U4 y" c5 j/ e3 o) M) l7 u: ?
全层截图:
; B' B) P9 D0 I- E. [ + e* q3 f6 I0 P6 S. p- \5 p
( I9 m( g  c% U
叠层阻抗信息如下:
3 y2 C. {% S7 c8 _: `
, |! ~6 D1 x4 `4 kBOM:
( @+ O% \+ h; e5 q
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
1206LDLED_1206LD_IC_0.75MM_370-75084_LED REDIC1D9
C035ST POINT R_C035S_IC_0.1 MM_280-7TEST POINTIC26TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP32; TP33; TP34
CC0306_24CAP_NP_CC0306_24_DISCRETE_0.61M0.01uFDISCRETE2C219; C220
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_21000pFDISCRETE9C7; C95; C102; C135; C143; C145; C197; C206; C208
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M0.1uFDISCRETE67C8; C9; C10; C11; C35; C36; C37; C38; C39; C40; C41; C42; C43; C44; C45; C46; C54; C57; C58; C59; C60; C61; C62; C63; C64; C66; C67; C68; C70; C71; C72; C73; C74; C75; C76; C78; C79; C81; C84; C85; C86; C87; C88; C89; C90; C91; C93; C97; C98; C100; C107; C109; C110; C111; C112; C114; C117; C119; C122; C154; C155; C167; C172; C179; C186; C187; C188
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_50.1uFDISCRETE11C23; C129; C130; C134; C210; C214; C221; C224; C225; C226; C227
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_31000pFDISCRETE7C53; C115; C116; C120; C123; C180; C228
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_10.01uFDISCRETE2C94; C101
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_40.01uFDISCRETE2C125; C127
CC0402_25CAP_NP_CC0402_25_DISCRETE_.55MM15PFDISCRETE2C132; C133
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.63522PFDISCRETE2C157; C158
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_60.22uFDISCRETE8C159; C160; C161; C162; C163; C164; C165; C166
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.557.0PFDISCRETE2C182; C183
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_110PFDISCRETE2C184; C185
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_71000pFDISCRETE4C212; C213; C222; C223
CC0603CAP_NP_CC0603_DISCRETE_0.9MM_151uFDISCRETE3C2; C103; C108
CC0603CAP_NP_CC0603_DISCRETE_0.9MM__21uFDISCRETE26C21; C22; C27; C33; C137; C138; C139; C140; C142; C147; C148; C149; C150; C151; C153; C191; C192; C193; C194; C196; C200; C201; C202; C203; C204; C205
CC0603CAP_NP_CC0603_DISCRETE_0.87MM_14.7pFDISCRETE1C28
CC0603CAP_NP_CC0603_DISCRETE_1.016M_110uFDISCRETE3C47; C48; C189
CC0603CAP_NP_CC0603_DISCRETE_1.016MM_10uFDISCRETE6C55; C141; C152; C174; C195; C199
CC0603CAP_NP_CC0603_DISCRETE_0.9MM__11uFDISCRETE17C56; C65; C69; C80; C82; C83; C92; C96; C99; C106; C113; C118; C121; C124; C126; C168; C178
CC0603CAP_NP_CC0603_DISCRETE_1MM_150-0.47UFDISCRETE1C77
CC0603CAP_NP_CC0603_DISCRETE_0.90 MM_0.01uFDISCRETE6C136; C144; C146; C198; C207; C209
CC0805CAP_NP_CC0805_DISCRETE_1.45MM_24.7uFDISCRETE4C49; C50; C51; C52
CC0805CAP_NP_CC0805_DISCRETE_1.45MM_14.7uFDISCRETE1C131
CC1206CAP_NP_CC1206_DISCRETE_1.27MM_11.0UFDISCRETE2C25; C26
CC1210CAP_NP_CC1210_DISCRETE_2.7 MM_147uFDISCRETE1C24
CC3216CAP_POL_CC3216_DISCRETE_1.8MM_11.0UFDISCRETE2C6; C105
CC3528-21CAP_POL_CC3528-21_DISCRETE_2.110uFDISCRETE17C1; C3; C4; C5; C12; C13; C14; C15; C16; C17; C18; C19; C20; C30; C32; C34; C104
CC3528-21CAP_POL_CC3528-21_DISCRETE_2._122UFDISCRETE2C29; C31
CON4_TB_5MM282836-4_CON4_TB_5MM_IO_10MM_21CON_4_TBIO1J1
CON5_USB_RA_SMTUSB_MINI_AB_RECEPTACLE_CON5_USBCONN USB MINI-BIO1J12
CON10_SKT_0P8_SMCONN_HDR_6X2_CON10_SKT_0P8_SM_IERF8-005-05.0-L-DV-L-TRIO1J17
CON_2X17F_0P8_SMCON_2X17_F_CON_2X17F_0P8_SM_IO_CON 2x17IO1J23
CON_2X120_QSH_0P5_SMTQTH-120-02-L-D-A_CON_2X120_QSH_CON 2X120 SKTIO2J28; J29
CON_60_QTH_0P5_SMQTH-030-02-L-D-A_CON_60_QTH_0P5QTH-030-01-L-D-A-K-TRIO1J15
CON_RJ45_2X5_THV890-1AX1-A1_14P_CON_RJ45_2X5_TV890-1AX1-A1IO1J14
DFN10_0P5_3X3ISL8010X_DFN_10P_DFN10_0P5_3X3_ISL80103IRAJZIC1U1
FUSE_3P2X1P6FUSE_FUSE_3P2X1P6_IC_0.84MM_5100.5AIC1F1
HDR2X4CONN_HDR_4X2_HDR2X4_IO_8.6MM_21HDR_2X4IO1J16
HDR102_TMMJUMPER_2_2MM_HDR102_TMM_IO_5.2MHDR 1X2IO16J8; J9; J30; J32; J33; J34; J35; J36; J39; J40; J43; J44; J45; J46; J47; J48
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3IO6J6; J10; J18; J21; J37; J42
HDR202_TSM_SMCONN_HDR_2X2_HDR202_TSM_SM_IO_9HDR_2X2IO7J2; J3; J4; J5; J7; J11; J31
HDR206CONN_HDR_6X2_HDR206_IO_8.382 MMHDR_2X6IO1J13
HDR_2X7_045TCONN_HDR_7X2_HDR_2X7_045T_IO_9.CON_2X7IO1J24
IND2_8043INDUCTOR_FERRITE_A_IND2_8043_DI2.2uHDISCRETE1L1
IND2_XAL40INDUCTOR_IND2_XAL40_DISCRETE_3.4.7uHDISCRETE1L2
IND_0805BEAD_IND_0805_DISCRETE_1.05MM_1330OHMDISCRETE1L4
IND_1608BEAD_IND_1608_DISCRETE_0.95MM_1600 OhmDISCRETE5L3; L5; L6; L7; L8
LED_0603LED_LED_0603_IC_0.8MM_370-75076LED_YELLOWIC1D2
LED_0603LED_LED_0603_IC_0.75MM_370-7578BLUEIC4D5; D6; D7; D8
QFN18_0P5_3X4LT8614_QFN18_QFN18_0P5_3X4_IC_0LT8614IC1U2
QFN32_MC1320XFT232RQ_QFN32_MC1320X_IC_1.05MMFT232RQIC1U7
RC0201RES_RC0201_DISCRETE_0.30 MM_4700DISCRETE2M1; M2
RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_24KDISCRETE1R1
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_22.87KDISCRETE1R6
RC0402_25RES_RC0402_25_DISCRETE_0.4 MM_4100kDISCRETE1R14
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__310KDISCRETE8R22; R23; R24; R25; R26; R29; R32; R33
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__24.7KDISCRETE4R30; R31; R35; R168
RC0402_25RES_RC0402_25_DISCRETE_0.4 MM_112.1KDISCRETE1R36
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_11.1KDISCRETE2R149; R150
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_474.7KDISCRETE2R152; R159
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110KDISCRETE1R166
RC0603RES_RC0603_DISCRETE_0.6MM_470-70DISCRETE19R9; R13; R17; R18; R48; R49; R50; R51; R52; R53; R54; R55; R56; R57; R58; R59; R61; R155; R156
RC0603RES_RC0603_DISCRETE_0.55MM_470-1.37MDISCRETE1R10
RC0603RES_RC0603_DISCRETE_0.55 MM_47041.2KDISCRETE1R11
RC0603RES_RC0603_DISCRETE_0.55MM_47_1412.0KDISCRETE1R12
RC0603RES_RC0603_DISCRETE_0.55MM_47_268DISCRETE2R27; R28
RC0603RES_RC0603_DISCRETE_0.55 MM_4_140.2KDISCRETE1R37
RC0603RES_RC0603_DISCRETE_0.55 MM_4_2300DISCRETE2R38; R39
RC0603RES_RC0603_DISCRETE_0.6 MM_470-15KDISCRETE1R44
RC0603RES_RC0603_DISCRETE_0.6MM_470-3560DISCRETE2R65; R167
RC0603RES_RC0603_DISCRETE_0.6MM_470_11KDISCRETE2R148; R151
RC0805RES_RC0805_DISCRETE_0.7 MM_470-100KDISCRETE1R5
RC0805RES_RC0805_DISCRETE_0.6MM_470-7510DISCRETE1R7
RC0805RES_RC0805_DISCRETE_0.7 MM_47_1100KDISCRETE1R8
RC0805RES_RC0805_DISCRETE_0.46MM_470-0.05DISCRETE3R16; R19; R21
RC0805RES_RC0805_DISCRETE_0.6MM_470-3560DISCRETE1R90
RC1206RES_RC1206_DISCRETE_0.71MM_470-120DISCRETE2R146; R164
SKT_BGA257_0P8_30X30_THS32R274_257P_SKT_BGA257_0P8_30XSKT BGA 257 TH + S32R274IC1U11
SO8_1P27_4X5TJA1051T_SO_8P_SO8_1P27_4X5_IC_TJA1051T/3IC2U14; U16
SOT23NPN_SOT23_IC_1.12 MM_480-75173_MMBT3904LT1GIC1Q2
SOT89_123AP1117_SOT89_123_IC_1.60MM_315-AP1117Y33G-13IC2U3; U4
SW2_SPST_3P5X6P0_5P0SW2P_SW2_SPST_3P5X6P0_5P0_IC_5.EVQ-PE105KIC1SW2
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_210TEST POINT BLACKIO5TP1; TP2; TP3; TP28; TP29
TO_277ADIODE_SCH_227A_TO_277A_IC_1.2MMSS8P3LIC1D1
TSOP_6MOSFET_P_S1_D4_TSOP_6_IC_1.10MMSI3443BDVIC1Q1
TSOT23_8_0P65_2X1LTC2905_TSOT23-8_TSOT23_8_0P65_LTC2905IC1U18
VQFN20_0P65_5P15X5P15TPS7A7100RGW_VQFN20_0P65_5P15X5TPS7A7100IC1U5
WQFN48_0P5_7X7_EP5P05KSZ9031RNXUA_48P_EP_WQFN48_0P5_KSZ9031RNXUAIC1U17
XTAL2_3P3X2P6XTAL_CS10_XTAL2_3P3X2P6_IC_0.9540MHZIC1Y3
XTAL_4_7P2X5P2XTAL_13Y_XTAL_4_7P2X5P2_IC_1.3M25MHZIC1Y1
附件:1 P' l% Y0 e) Z, c" v
原理图和PCB文件如下:, @4 G1 o! E2 }: O
游客,如果您要查看本帖隐藏内容请回复
& g5 A! S% E$ h
- Y" s% e; _$ I0 j
推荐
发表于 2021-4-9 15:53 | 只看该作者
谢谢
! h- E: P- o3 U/ S
    擦汗
    2021-11-5 15:46
  • 签到天数: 14 天
    [LV.3]偶尔看看II
    推荐
    发表于 2021-7-5 16:32 | 只看该作者
    楼主大大,积分不够,能不能分享到邮箱,jiangleiqizai@163.com,谢谢
    擦汗
    2021-11-5 15:46
  • 签到天数: 14 天
    [LV.3]偶尔看看II
    推荐
    发表于 2021-7-8 16:23 | 只看该作者
    继续签到
    发表于 2020-4-4 00:43 | 只看该作者
    发表于 2021-6-15 13:48 | 只看该作者
    资料不错,下下来学习
    擦汗
    2021-11-5 15:46
  • 签到天数: 14 天
    [LV.3]偶尔看看II
    发表于 2021-7-5 15:31 | 只看该作者
    2024-8-26 15:16
    发表于 2021-7-6 10:48 | 只看该作者
    比较高大上,下载看看' |" A* _5 k- F
    2025-7-18 15:02
  • 签到天数: 557 天
    [LV.9]以坛为家II
    发表于 2021-7-6 16:02 | 只看该作者
    资料不错,下下来学习
    发表于 2021-7-8 20:40 | 只看该作者
    qqqqqqqqqqqqqq2 v2 M& t$ ~" b( ]  L
    2025-7-19 15:03
  • 签到天数: 757 天
    [LV.10]以坛为家III
    发表于 2021-7-9 17:13 | 只看该作者
    dddddddddddddddddd4 P5 S9 {6 T* R: O7 K3 {
    擦汗
    2021-11-5 15:46
  • 签到天数: 14 天
    [LV.3]偶尔看看II
    13#
    发表于 2021-7-11 11:44 | 只看该作者
    威望值不够啊
    14#
    发表于 2021-7-28 13:56 | 只看该作者
    KANKANXUEXIYIXIAQ
    郁闷
    2022-5-30 15:40
  • 签到天数: 17 天
    [LV.4]偶尔看看III
    15#
    发表于 2021-8-27 15:25 | 只看该作者
    谢谢 thanks
    3 `2 n- H$ u+ n% j8 ^. `
    GMT+8, 2025-7-20 02:54 , Processed in 0.156250 second(s), 29 queries , Gzip On.
