查看: 297|回复: 0
[allegro16.6][6层] S32K118EVB S32K118评估板(S32K116+UJA1169TK/F+USB)原理图...
发表于 2020-2-10 12:35 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][6层] S32K118EVB S32K118评估板(S32K116+UJA1169TK/F+USB)原理图和pcb文件
: C% E5 O. O. P* h
7 ^. |* r- w. b$ ^文件描述:/ ], V, a5 o) T/ U* J( L
. L8 F: b1 [* A2 V
1. 作品用途:S32K118EVB S32K118评估板
6 ]4 c- o' ?1 r# H2. 软件版本:allegro16.6% K+ S' i5 Q6 O" [( x7 |
3. 层数:6层
( a& t) z* {* N. ?* o4. 用到的主要芯片:S32K116+UJA1169TK/F+MK20DX128VFM5) D# g7 j* x1 t. H
5. pcb尺寸:4550*2300 MIL$ L+ a% o5 [+ ]% E( `
# @8 y% v8 l0 R! {  |1 A# I% c
作品截图如下:
, ]% ~* e. Z8 Q, Z$ K6 h$ A/ k/ {5 N5 k% y. ~
顶层截图:
& ]; X: T; Y4 \0 J7 J * K3 {& Q, K' O
底层截图:& ~) g( D; k5 c3 N6 N
8 L$ \  M2 T& @8 g  Q( q全层截图:
6 T! D7 B0 e2 S; K. x: q
8 X" W# }! T+ t" `& M% v3 }; `$ U- A0 y5 O+ `: v& F# R: W
叠层阻抗信息如下:) o2 g( ]) \7 C6 H2 g  y" F, w
' H6 Y. z1 f6 i4 iBOM:3 x0 N! N4 ?! [- K  y, W4 H
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.65M4.7uFDISCRETE4C2; C3; C8; C18
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UFDISCRETE8C4; C5; C7; C10; C19; C25; C26; C549
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6MM1.0UFDISCRETE1C6
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.7MM10uFDISCRETE1C11
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_10.1UFDISCRETE2C16; C28
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.9 M0.1uFDISCRETE13C22; C47; C544; C545; C546; C547; C548; C550; C552; C555; C556; C557; C558
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.56M0.01UFDISCRETE1C59
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_112PFDISCRETE2C126; C127
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uFDISCRETE6C131; C140; C141; C540; C543; C553
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.25M2.2UFDISCRETE1C9
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_110uFDISCRETE1C12
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.965220PFDISCRETE1C17
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.0MM4700 PFDISCRETE2C40; C551
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM10pFDISCRETE2C533; C535
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.27M10.0uFDISCRETE5C21; C24; C27; C536; C554
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4MM10UFDISCRETE4C143; C144; C539; C542
CCE6P8X6P8CAP_POL_CCE6P8X6P8_DISCRETE_6.147uFDISCRETE1C128
CON3_PWR_JACK_TH_PJ051ADC_POWER_JACK_SHD_CON3_PWR_JACKCON PWR 3IO1J16
CON_2RH_10_50CONN_HDR_5X2_CON_2RH_10_50_IO_3HDR 2X5IO2J12; J14
CON_HDR_4M_100_TH_RACONN_HDR_4X1_CON_HDR_4M_100_TH_HDR 1X4 RAIO2J11; J13
CON_MICROAB_10F_25_SM_RAMICRO_USB_CONN_10PIN_CON_MICROAUSB_MICRO_ABIO1J7
CON_SKT1X10_THCONN_HDR_10X1_CON_SKT1X10_TH_IOSKT_1X10IO1J2
DSN0603-2DIODE_BIDIR_DSN0603-2_IC_0.32MMPESD5V0R1BSFIC3D17; D18; D19
ELECTRODE_SQ_15MMELECTRODE_ELECTRODE_SQ_15MM_IC_ElectrodeIC2SW7; SW8
HDR102CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR 1X2IO2J15; J108
HDR103_ACONN_HDR_3X1_HDR103_A_IO_8.74MMHDR 1X3IO3J10; J104; J107
IND_0402INDUCTOR_FERRITE_IND_0402_DISCR30 OHMDISCRETE1L512
IND_1608BEAD_IND_1608_DISCRETE_0.95MM_1330 OHMDISCRETE2L1; L2
LED6_5X6MMLED_TRI_COLOR_LED6_5X6MM_IC_2.6LED RED/GRN/BLIC1D11
LED_0603LED_LED_0603_IC_0.9MM_370-75079REDIC1D1
LED_0603LED_LED_0603_IC_0.67MM_370-7656LED GREENIC1D2
LED_0603LED_LED_0603_IC_0.85MM_370-7654GREENIC1D3
LFPAK5_1P27_5X4PMOS_5P_LFPAK5_1P27_5X4_IC_1.2PHPT61003PYIC1Q1
LQFP64S32K118_LQFP_0_LQFP64_IC_1.6MM_S32K118IC1U36
POT3_3352TPOT_POT3_3352T_DISCRETE_4.32 MM5KDISCRETE1R13
QFN8_1P6X1P6MM74LVC2T45GM_8P_QFN8_1P6X1P6MM_I74LVC2T45GM,125IC1U2
QFN32_S142EPPK20DX128V_QFN_32P_QFN32_S142EPMK20DX128VFM5IC1U8
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7KDISCRETE9R1; R15; R30; R52; R57; R562; R571; R572; R576
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0KDISCRETE14R3; R16; R31; R39; R42; R51; R530; R538; R607; R608; R609; R712; R713; R730
RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_180KDISCRETE1R4
RC0402_25RES_RC0402_25_DISCRETE_0.45 M_10DISCRETE3R18; R24; R701
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__333DISCRETE2R21; R25
RC0402_25RES_RC0402_25_DISCRETE_0.45 MM_0DISCRETE89R32; R35; R47; R49; R84; R88; R119; R120; R169; R577; R578; R579; R580; R581; R582; R583; R584; R585; R586; R587; R588; R589; R590; R591; R592; R632; R635; R636; R637; R638; R639; R640; R641; R642; R643; R644; R645; R649; R650; R651; R652; R653; R654; R655; R656; R657; R658; R659; R660; R662; R663; R666; R667; R668; R669; R671; R673; R675; R676; R677; R678; R679; R680; R685; R686; R687; R688; R696; R697; R737; R738; R740; R743; R744; R745; R746; R747; R748; R749; R754; R755; R756; R757; R758; R760; R764; R767; R768; R770
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__410.0KDISCRETE2R44; R74
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__510.0KDISCRETE1R60
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__210.0KDISCRETE2R62; R77
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_115KDISCRETE1R68
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__61.0KDISCRETE1R69
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710KDISCRETE9R121; R573; R574; R575; R598; R601; R603; R604; R623
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_433KDISCRETE4R599; R600; R602; R605
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_2100KDISCRETE1R731
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_318KDISCRETE1R732
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__74.7KDISCRETE1R733
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_4560 OHMDISCRETE1R2
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__1220DISCRETE1R12
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_2680DISCRETE4R56; R95; R96; R97
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__21.0MDISCRETE1R91
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470DISCRETE19R117; R172; R300; R527; R533; R534; R593; R624; R625; R626; R627; R628; R674; R693; R694; R695; R752; R759; R771
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_14.7KDISCRETE2R525; R528
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 M_11KDISCRETE3R595; R596; R597
RC0805_OVRES_RC0805_OV_DISCRETE_0.65MM_42KDISCRETE2R80; R171
RC0805_OVRES_RC0805_OV_DISCRETE_0.65MM_12.2DISCRETE1R535
RC0805_OVRES_RC0805_OV_DISCRETE_0.65 MM_10kDISCRETE1R537
RC1206_OVRES_RC1206_OV_DISCRETE_0.6MM_4760.4DISCRETE2R92; R98
SC_75NPN_SC_75_IC_0.9 MM_480-75477_MMMBT3904TT1GIC4Q6; Q7; Q8; Q9
SKT2X8_TH_SSQCONN_HDR_8X2_SKT2X8_TH_SSQ_IO_8SSQ-108-23-T-DIO3J1; J3; J4
SO8_1P27_4X5TJA1027T_0_SO8_1P27_4X5_IC_1.75TJA1027T/20IC1U21
SOD-128DIODE_SCHTKY_SOD-128_IC_1.1 MM_PMEG3050EPIC2D6; D9
SON20_0P5_3P6X5P6UJA1169TKF_3_SON20_0P5_3P6X5P6_UJA1169TK/FIC1U19
SOT23-6_AMIC2005-0.8YM6_SOT23-6_A_IC_1.4MIC2005-0.8YM6IC1U11
SOT23_5SSPX3819M5_FIX_0_SOT23_5S_IC_1.4SPX3819M5-L-3-3IC1U15
SOT891_6P_0P35_1P05X1P05NC7WP14_SOT891_6P_0P35_1P05X1P074LVC2G14GF,132IC1U9
SOT-563_6P_0P5_SMTBJT_DUAL_PNP_NPN_SOT-563_6P_0P5BC847BVNIC2Q10; Q11
SW4_SPST_4P8X3P6_2P5EDGE_MOUNT_PB_SW_2_SW4_SPST_4P8EVQ-P2402WIC4SW2; SW3; SW5; SW9
TESTPOINT_135_070MILTEST_POINT_4_TESTPOINT_135_070MTESTLOOPIC8TS1; TS2; TS3; TS4; TS5; TS6; TS7; TS8
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030IO59TP5; TP6; TP7; TP8; TP10; TP11; TP12; TP18; TP28; TP29; TP30; TP503; TP504; TP505; TP506; TP507; TP508; TP509; TP510; TP511; TP512; TP513; TP514; TP515; TP516; TP517; TP518; TP519; TP520; TP521; TP523; TP524; TP525; TP528; TP529; TP530; TP531; TP532; TP533; TP534; TP535; TP536; TP537; TP538; TP539; TP540; TP541; TP542; TP543; TP544; TP545; TPAD93; TPAD94; TPAD95; TPAD96; TPAD97; TPAD98; TPAD99; TPAD100
TP_TH_063TEST_POINT_3_TP_TH_063_IC_5.6MM5006IC2GND1; GND2
TP_TH_063TEST_POINT_0_TP_TH_063_IC_5.59MTEST_POINTIC4TP4; TP522; TP526; TP527
UDFN6_1X1P5MM74LVCH1T45_6P_UDFN6_1X1P5MM_IC_74LVCH1T45IC3U4; U7; U10
XQFN8_1P45X1P25MMNTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HIC1U1
XQFN8_1P45X1P25MMNTSX2102GU8H_0_XQFN8_1P45X1P25MNTSX2102GU8HIC4U26; U32; U33; U34
XTAL2_3P3X2P6XTAL_XTAL2_3P3X2P6_IC_0.95MM_2340MHzIC1Y3
XTAL3_3P35X1P45_SMXTAL_CS_XTAL3_3P35X1P45_SM_IC_08.00MHZIC1Y1
1 N7 ?& _1 M1 w. o+ G; Q9 S4 y: T
2 [5 C# N3 `' R" N) t  Z& n* d
附件:
- u3 m* w8 N9 w原理图和PCB文件如下:
4 }# ?0 J' s% F  X
游客,如果您要查看本帖隐藏内容请回复
) z( T: B. l7 R, U; T
GMT+8, 2025-7-25 05:15 , Processed in 0.140625 second(s), 29 queries , Gzip On.
