查看: 1084|回复: 13
[allegro16.6][6层] RK3288-MID参考板(MCU_RK3288+K3PE0E000E+RC5T619-1017(RK328...
发表于 2020-2-7 14:38 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
- W& d" O6 F8 i' {$ o[allegro16.6][6层] RK3288-MID参考板(mcu_RK3288+K3PE0E000E+RC5T619-1017(RK3288))原理图和pcb文件
5 a/ }" I4 N5 ]) ?2 `/ Z7 m
4 `" V2 x  Z' K: D* C0 V0 }文件描述:
  c) b, z/ B& |% u' A1 c# C8 \
. s6 ^9 A' x3 {; T- K" l+ i* d/ x, \1. 作品用途: RK3288-MID参考板
- A) y. W  `* L1 w7 l2. 软件版本:allegro16.6
* {1 R  x: r( ^$ p1 @1 a3 O3. 层数:6层
8 ^, b9 E. B3 t+ X$ P1 F4. 用到的主要芯片:MCU_RK3288+K3PE0E000E+RC5T619-1017(RK3288). ~2 k5 c  s" C0 J# o+ v
5. pcb尺寸:6591.1405*2506.7 MIL
$ a8 R; S8 F) q" A- [6 t, b
. L$ x- N6 @7 K3 M$ H作品截图如下:
7 E8 ?4 G' t8 j/ j- T3 V6 p& }6 y; a  N8 `' y! P
顶层截图:, O6 Z+ j$ P7 r3 f+ ?/ w
" y: Q6 ~! v% V1 m底层截图:4 ^9 V9 a1 p/ I7 K  f5 A4 S  h6 C- r
5 x2 J8 i- E. {
* D3 u( F3 k8 B全层截图:# V5 j+ G. X  F+ n4 m$ J
6 j0 f+ t  e7 v0 j$ w' |" _9 T: S 1 t, x0 ]# v% k4 o5 {* S" x' m; o
+ h- \; z# r; H& Q
BOM:
& H2 I$ g. {; v3 P: ^! g
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
0_9MM_SHIELDSHIELD_0_9MM_SHIELD_SHIELDSHIELDIC16S1; S2; S3; S4; S5; S6; S7; S8; S9; S10; S11; S12; S13; S14; S15; S16
78171-0002MIC_78171-0002_MICMICIC1MIC1
78171-0004HEADER 4_78171-0004_78171-000478171-0004IC1J6
505004-0810HEADER 6X2_505004-0810_505004-0505004-0810IC1J1
AA07P032VA1NA070SN02_0.0_AA07P032VA1N_AA07-AA07-P032VA1IC1J7
ALC5616_QFN32ALC5616_ALC5616_QFN32_ALC5616ALC5616IC1U15
ANT-JACKA-1CON_IPEX_0_ANT-JACKA-1_CON_IPEXCON_IPEXIC2ANT1; ANT2
AP6XXXAMPAK_SIPAP6476IC1U24
AXT524124LCM0200CE1A0_0_AXT524124_OV2659OV2659IC1U22
BAG14-2X2AK8975C_0_BAG14-2X2_AK8963CAK8963CIC1U12
BGA636_1MCU_RK3288_3_BGA636_1_MCU_RK328MCU_RK3288IC1U8
BL509-04G31CON4_0_BL509-04G31_BL509-04G31BL509-04G31IC1J3
BL509-08G31CON8_4.5MM_BL509-08G31_CON8_0.5Con8_0.5mmIC1CON1
C0201CAP NP_0_C0201_0.1UF0.1uFIC2C135; C148
C0201CAP NP_0_C0201_1NF1nFIC1C150
C0201CAP NP_C0201_10NF10nFIC1C187
C0201CAP NP_4_C0201_0.1UF0.1uFIC1C211
C0201CAP NP_C0201_1UF1uFIC1C228
C0201CAP NP_C0201_0.1UF0.1uFIC1C231
C0402CAP NP_2_C0402_0.1UF0.1uFIC4C24; C27; C53; C57
C0402CAP NP_C0402_0.1UF0.1uFIC81C33; C40; C61; C70; C71; C72; C77; C78; C79; C80; C87; C88; C89; C90; C92; C96; C99; C100; C101; C103; C104; C153; C154; C155; C156; C159; C161; C162; C163; C164; C166; C167; C168; C169; C170; C171; C172; C173; C174; C175; C176; C177; C180; C181; C183; C184; C188; C191; C192; C194; C201; C202; C215; C216; C219; C220; C221; C225; C226; C232; C233; C234; C235; C236; C241; C242; C243; C244; C245; C246; C247; C253; C254; C257; C261; C264; C266; C268; C269; C271; C285
C0402CAP NP_2_C0402_1UF1uFIC11C34; C36; C37; C39; C42; C43; C44; C47; C48; C50; C52
C0402CAP NP_C0402_1UF1uFIC11C35; C65; C66; C67; C76; C86; C94; C160; C185; C190; C238
C0402CAP NP_4_C0402_12PF12pFIC2C49; C51
C0402CAP NP_C0402_22PF22pFIC1C63
C0402CAP NP_C0402_1NF1nFIC8C73; C81; C91; C158; C223; C224; C229; C230
C0402CAP NP_C0402_10NF10nFIC1C95
C0402CAP NP_C0402_8PF8pFIC3C97; C98; C251
C0402CAP NP_0_C0402_1UF1uFIC2C129; C206
C0402CAP NP_0_C0402_0.1UF0.1uFIC8C130; C133; C134; C144; C145; C146; C147; C149
C0402CAP NP_4_C0402_1UF1uFIC1C136
C0402CAP NP_4_C0402_0.1UF0.1uFIC7C138; C139; C141; C142; C143; C209; C213
C0402CAP NP_0_C0402_NCNCIC1C151
C0402CAP NP_C0402_0.22UF0.22uFIC1C182
C0402CAP NP_C0402_10PF10PFIC2C186; C290
C0402SMALL CAP_C0402_0.1UF0.1uFIC3C196; C198; C199
C0402CAP NP_C0402_100PF100pFIC3C214; C217; C218
C0402CAP NP_C0402_NCNCIC4C240; C255; C289; C291
C0402CAP NP_3_C0402_0.1UF0.1uFDISCRETE3C258; C259; C260
C0402CAPNP_DUP1_1_C0402_NCNCIC2C273; C275
C0402CAPNP_DUP1_1_C0402_10PF10pFIC1C274
C0402CAP NP_C0402_33PF33pFIC6C276; C277; C278; C279; C280; C281
C0402CAPNP_DUP1_1_C0402_1UF1uFIC2C282; C294
C0402CAPNP_DUP1_1_C0402_2.2UF2.2uFIC1C283
C0402CAPNP_DUP1_1_C0402_8PF8pFIC2C287; C288
C0603CAP NP_4_C0603_10UF10uFIC6C1; C6; C128; C140; C212; C265
C0603CAP NP_2_C0603_4.7UF4.7uFIC12C5; C8; C9; C12; C13; C17; C18; C19; C29; C30; C45; C46
C0603CAP NP_2_C0603_10UF10uFIC10C10; C11; C14; C15; C20; C21; C22; C25; C28; C41
C0603CAP NP_1_C0603_10UF10uFIC2C32; C267
C0603SMALL CAP_C0603_4.7UF4.7uFIC4C54; C55; C56; C208
C0603CAP NP_C0603_10UF10uFIC15C62; C68; C69; C74; C83; C93; C165; C189; C193; C210; C222; C227; C239; C256; C284
C0603CAP NP_C0603_4.7UF4.7uFIC5C102; C178; C179; C203; C270
C0603CAP NP_0_C0603_10UF10uFIC1C132
C0603CAP NP_4_C0603_4.7UF4.7uFIC1C137
C0603SMALL CAP_C0603_2.2UF2.2uFIC5C195; C197; C200; C204; C205
C0603CAP NP_0_C0603_4.7UF4.7uFIC1C207
C0603CAP NP_C0603_NC/4.7UFNC/4.7uFIC1C237
C0603C0603_C0603_10UF10uFIC1C263
C0603CAPNP_DUP1_1_C0603_4.7UF4.7uFIC2C272; C286
C0805CAP NP_4_C0805_22UF22uFIC5C2; C3; C4; C7; C131
C0805CAP NP_2_C0805_22UF22uFIC5C16; C23; C26; C31; C38
C0805CAP NP_C0805_22UF22uFIC6C64; C75; C82; C84; C85; C157
C0805CAP NP_0_C0805_22UF22uFIC1C127
C1206CAP NP_C1206_2.2UF/50V2.2uF/50VIC1C262
CRY-D3225CRYSTAL OSC_CRY-D3225_1XTW260001XTW26000CGAIC1U25
CRY-D3225CRYSTAL-4_1_CRY-D3225_24M-30PPM24M-30ppmIC1Y2
CRY-D3225CRYSTAL-4_0_CRY-D3225_37.4MHZ-137.4MHz-10ppmIC1Y3
CRY-MC146CRYSTAL_CRY-MC146_32.768K32.768KIC1Y1
CSP9LM4990_0_CSP9_AW8110CSRAW8110CSRIC2U16; U17
CSP0608-805T619_2_CSP0608-80_RC5T619-1017RC5T619-1017(RK3288)IC1U2
DFN3X3-10MP3202-QFN8_1_DFN3X3-10_SY7203SY7203IC1U23
DO214ACDIODE_DO214AC_PMEG3030EPPMEG3030EPIC1D1
E0201TVS_E0201_TESA15R0V09B1XTESA15R0V09B1XIC18ED1; ED4; ED5; ED6; ED7; ED8; ED9; ED10; ED11; ED12; ED13; ED14; ED15; ED16; ED17; ED18; ED23; ED24
E0201DIODE BI-DIR TRIG_E0201_TESA15RTESA15R0V09B1XIC4ED19; ED20; ED21; ED22
E0201TVS_E0201_ED?ED?IC1TESA15R0V09B1X1
E0402NTVS_E0402N_TEPB0R2V12B1XTEPB0R2V12B1XIC2ED2; ED3
FBGA220-14X14K3PE0E000E_1_FBGA220-14X14_K3PEK3PE0E000EIC1U9
INAND_169INAND_INAND_169_INANDINANDIC1U19
IND-3X3INDUCTORS OF FERRITE_IND-3X3_1U1uH/1.5AIC5L3; L4; L5; L6; L7
IND-3X3INDUCTOR_1_IND-3X3_4.7UH/2.5A4.7uH/2.5AIC1L9
IND-3X3INDUCTOR_IND-3X3_3.3UH/0.7A3.3uH/0.7AIC1L12
IND-4X4INDUCTORS OF FERRITE_IND-4X4_0.0.33uH/5AIC2L1; L2
IND-5X5INDUCTORS OF FERRITE_IND-5X5_1U1uH/3AIC1L8
IND-5X5INDUCTORS OF FERRITE_IND-5X5_1515uH/1.5AIC1L10
J301R05GA6ZL2PHONEJACK STEREO SW_0_J301R05GAPHONEJACKIC1J5
L0402INDUCTOR_L0402_600R100M600R100MIC4FB2; FB3; FB4; FB5
L0603INDUCTOR_L0603_0R0RIC1FB6
L0603INDUCTOR_L0603_BLM18PG181SN1BLM18PG181SN1IC1L11
L0603DL_CHOKE CM14_L0603D_NCNCIC1FB1
LGA16MMA8452Q_0_LGA16_LSM303D/LIS3DHLSM303D/LIS3DH/MMA8452QIC1U11
LSM330LSM330_LSM330_LSM330TRLSM330TRIC1U14
MICRO_USB_DIPMINI USB_0_MICRO_USB_DIP_USBUSBIC1J2
R0402RESISTOR_1_R0402_100R100RIC6R1; R2; R3; R4; R8; R102
R0402RESISTOR_1_R0402_5.1K5.1KIC2R5; R7
R0402RESISTOR_1_R0402_0R0RIC4R6; R10; R18; R25
R0402RESISTOR_1_R0402_20K%120K%1IC1R9
R0402RES 1B_R0402_200K%1200K%1IC1R12
R0402RESISTOR_R0402_100K100KIC3R13; R75; R176
R0402RES 1B_R0402_120K%1120K%1IC1R14
R0402RESISTOR_1_R0402_NCNCIC4R15; R19; R40; R42
R0402RESISTOR_1_R0402_10K10KIC6R16; R20; R21; R22; R28; R87
R0402RESISTOR_1_R0402_1K51K5IC2R23; R24
R0402RES 1B_R0402_100K100KIC2R26; R136
R0402RESISTOR_0_R0402_330K330KIC1R27
R0402RESISTOR_0_R0402_43K43KIC1R29
R0402RESISTOR_1_R0402_47K47KIC1R30
R0402RESISTOR_R0402_10K10KIC16R31; R32; R35; R65; R95; R96; R115; R116; R117; R118; R119; R120; R121; R122; R123; R131
R0402RESISTOR_0_R0402_0R0RIC2R33; R34
R0402RESISTOR_R0402_1K1KIC1R36
R0402RESISTOR_R0402_15K15KIC1R37
R0402RESISTOR_1_R0402_1M1MIC1R38
R0402RESISTOR_1_R0402_22R22RIC1R39
R0402RESISTOR_0_R0402_10K10KIC2R41; R52
R0402RESISTOR_0_R0402_NCNCIC2R50; R68
R0402RESISTOR_0_R0402_240R%1240R%1IC1R53
R0402RESISTOR_0_R0402_10K%110K%1IC2R54; R56
R0402RESISTOR_0_R0402_120K120KIC2R58; R59
R0402RESISTOR_1_R0402_200R200RIC2R60; R61
R0402RESISTOR_R0402_22R22RIC3R62; R104; R105
R0402RESISTOR_R0402_47K47KIC1R63
R0402RESISTOR_R0402_1.2M1.2MIC1R64
R0402RESISTOR_R0402_10K%110K%1IC1R66
R0402RESISTOR_R0402_NC/0RNC/0RIC8R69; R148; R149; R150; R151; R152; R153; R177
R0402RESISTOR_R0402_0R0RIC12R70; R103; R126; R154; R155; R156; R157; R158; R159; R160; R175; R178
R0402RESISTOR_R0402_0R/NC0R/NCIC2R71; R72
R0402RESISTOR_0_R0402_1K51K5IC2R73; R74
R0402RES 1B_R0402_10K10KIC1R76
R0402RESISTOR_0_R0402_1K1KIC1R78
R0402RESISTOR_0_R0402_200K200KIC1R79
R0402RESISTOR_1_R0402_33R33RIC7R80; R81; R82; R83; R84; R85; R86
R0402R_R0402_0R0RIC1R88
R0402R_R0402_33R33RIC6R89; R90; R92; R94; R97; R98
R0402R_R0402_4.7K4.7KIC2R91; R93
R0402RESISTOR_1_R0402_100K100KIC4R99; R109; R134; R135
R0402RESISTOR_1_R0402_1K1KIC1R100
R0402RESISTOR_0_R0402_2K22K2IC2R101; R106
R0402RESISTOR_R0402_30K30KIC4R107; R108; R110; R111
R0402RESISTOR_R0402_4.7K4.7KIC3R112; R145; R146
R0402RESISTOR_R0402_NCNCIC3R113; R114; R125
R0402RESISTOR_R0402_33R33RIC7R124; R168; R169; R170; R171; R172; R173
R0402RESISTOR_0_R0402_33R33RIC2R129; R130
R0402RESISTOR_0_R0402_4.7K4.7KIC2R132; R133
R0402RES 1B_R0402_56K56KIC1R137
R0402RESISTOR_3_R0402_100K100KIC1R140
R0402RESISTOR_3_R0402_10K10KIC2R141; R147
R0402RES 1B_R0402_330K330KIC2R142; R143
R0402RESISTOR_3_R0402_22K22KIC1R144
R0402RESISTOR_R0402_NC/10KNC/10KIC5R161; R162; R163; R164; R165
R0402RESISTOR_4_R0402_10K10KIC2R166; R167
R0402R_0_R0402_100R100RIC1R174
R0603RESISTOR_0_R0603_6.8R6.8RIC1R77
R1206MOTOR SERVO_R1206_MOTOMOTOIC1M1
R1206RES 1B_R1206_2R2RIC2R138; R139
R1210RESISTOR_1_R1210_20MR20mRIC2R11; R17
SOD123DIODE_SOD123_1N58191N5819IC1D2
SOD128DIODE_SOD128_PMEG3030EPPMEG3030EPIC1D5
SOD323DIODE_SOD323_IN4148IN4148IC1D3
SOD323DIODE_SOD323_1N58191N5819IC1D4
SOT23MOSFET P_SOT23_WPM2341WPM2341IC2Q1; Q2
SOT23NPN4_SOT23_80508050IC1Q3
SOT2340852_1_SOT23_80508050IC1Q4
SOT23MOSFET N_SOT23_SI2306SI2306IC1Q5
SOT23MOSFET N_SOT23_2SK30182SK3018IC1Q6
SOT23FET N MOS_SOT23_WNM2016WNM2016IC1Q7
SOT23MOSFET N_0_SOT23_WPM2341WPM2341IC1Q8
SOT23NPN_0_SOT23_80508050IC1Q9
SOT23NPN_0_SOT23_HAL48HAL48IC1U13
SOT25LPW5206H_SOT25_SY6280AACSY6280AACIC1U7
SOT25DS8008_4_SOT25_PT5108E23E-18PT5108E23E-18IC1U10
SOT25DS8008_4_SOT25_NC/PT5108E23E-18NC/PT5108E23E-18IC1U20
SOT26PT5127_SOT26_PT5128E23F-EPT5128E23F-EIC1U4
SOT26G5121_1_SOT26_SY7152ABCSY7152ABCIC1U6
T-0_7TEST_0_T-0_7_TESTTESTIC38P1; P2; P3; T3; T4; T5; T6; T7; T8; T9; T10; T11; T12; T13; T18; T19; T20; T21; T22; T23; T24; T25; T26; T27; T28; T29; T30; T31; T32; T33; T34; T35; T36; T37; T38; T39; T40; T41
T-0_7TEST_1_T-0_7_TESTTESTIC4T14; T15; T16; T17
TF-CARDKLJ07002SD_SOCKET_0_TF-CARDKLJ07002_TF_TF_SD_SOCKETIC1J4
TSOP1-48NANDFLASH_0_TSOP1-48_NAND_FLASHNAND_FLASHIC1U18
WLCSP-20BB27_1_WLCSP-20_SYR828SYR828IC1U1
WLCSP-20BB27_1_WLCSP-20_SYR827SYR827IC1U3
附件:
7 h6 N. R3 ]- R* h原理图和PCB文件如下:
# w, m1 j6 v+ v" V" d
游客,如果您要查看本帖隐藏内容请回复
; x, j( B5 }$ B# Y# z5 ]% T. M0 ~
+ `: r$ w; c. R2 L- s& }+ u, ~; e
发表于 2020-6-3 10:36 | 只看该作者
666666666666666666666
    无聊
    2021-11-3 15:09
  • 签到天数: 6 天
    [LV.2]偶尔看看I
    发表于 2020-10-26 20:48 | 只看该作者
    66666666666666666666666666666666666666666
    0 }( G4 S9 n9 D, C2 o1 f+ k' Y
    发表于 2020-11-10 17:17 | 只看该作者
    感谢楼主分享0 S  o3 U7 u- r1 O# d  q1 b
    楼主还是那个楼主
    ; C( `1 Q8 _; `" S" @- ~& Z' }$ P
    发表于 2020-12-10 08:46 | 只看该作者
    板子布局不错
    发表于 2020-12-14 09:22 | 只看该作者
    这个值得参考
    发表于 2020-12-14 11:12 | 只看该作者
    111111111111111111111111111111
    2024-8-26 15:16
    发表于 2020-12-14 15:02 | 只看该作者
    还不错,感谢分享! V, `$ M0 \  u8 F. V
    2023-9-8 15:14
    发表于 2022-8-12 14:44 | 只看该作者
    学习学习,谢谢
    # s2 u" W  k5 `' `4 T
    发表于 2022-8-12 16:15 | 只看该作者
    2025-7-18 15:02
  • 签到天数: 557 天
    [LV.9]以坛为家II
    13#
    发表于 2023-1-5 10:39 | 只看该作者
    下载看看学习
    GMT+8, 2025-7-19 13:26 , Processed in 0.156250 second(s), 27 queries , Gzip On.
