查看: 186|回复: 0
[allegro16.6][8层] RK3066 方案做的 netcast(RK3066+AP6XXX+2片DDR)原理图和pcb...
发表于 2020-2-7 13:56 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
/ D9 u) w  G, q, J[allegro16.6][8层] RK3066 方案做的 netcast(RK3066+AP6XXX+2片DDR)原理图和pcb文件
" \4 A( M, h, {; M6 V* y0 O3 ]5 s" y0 t
文件描述:' ~! y8 Z1 y' U: ^
& W) a( e1 ^2 n/ |
1. 作品用途: RK3066 方案做的 netcast
" L' d' A3 g0 ]2. 软件版本:allegro16.6
1 p2 G! L+ M3 z, w3. 层数:8层
; x  ~- s% ]1 G1 c4. 用到的主要芯片:RK3066+AP6XXX+2片DDR
' z7 ?3 {% O9 j6 V; Y5 T5. pcb尺寸: 异形  s- Q7 q8 I$ t. {4 T6 v
' o' B' x. T  g6 {; K$ U- S# \) Z作品截图如下:
" n# N2 p9 O8 ^% c8 H6 |3 O1 a& n% B* q. s5 m$ B
顶层截图:# S: d9 @, Q2 C* g: J
1 G3 ?1 F  Y0 y  K; T# K$ V, [
底层截图:2 f% F; s; b4 M2 K) s
1 a; B1 Z& M: A5 V
& W6 _2 p) T6 O! `) U) z! W0 K8 l( k全层截图:
7 w# J" T0 {) z9 d5 r ' w$ n4 y" C! \9 R
5 i. `( B. `& P2 u7 c1 z: ~BOM:* ]( k4 h1 b. y# K8 Y* _6 i; C
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BGA96EDJ4216EFBG FBGA 96P_2_BGA96_DDDR-MT41K256M16HA-125MIC2U4; U51
BGA453-19X19RK3066_10_BGA453-19X19_RK3066RK3066IC1U1
C0402CAP NP_C0402_104104IC82C1; C67; C68; C69; C70; C78; C80; C81; C85; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C99; C100; C101; C102; C103; C104; C105; C106; C107; C113; C114; C115; C116; C117; C121; C122; C123; C124; C125; C126; C127; C128; C129; C130; C131; C136; C137; C138; C139; C140; C141; C142; C143; C148; C149; C150; C151; C152; C153; C156; C157; C158; C159; C160; C161; C162; C163; C164; C165; C166; C169; C231; C233; C252; C299; C366; C367; C368; C369; C372; C374; C375; C376
C0402CAPNP_DUP1_1_C0402_10P10pIC1C3
C0402CAPNP_DUP1_1_C0402_NCNCIC2C5; C7
C0402C0201NC/104IC1C8
C0402CAPNP_DUP1_1_C0402_NC/105NC/105IC1C18
C0402CAP NP_4_C0402_104104IC1C41
C0402CAP NP_2_C0402_225225IC10C47; C52; C172; C175; C176; C177; C178; C181; C186; C188
C0402CAP NP_C0402_102102IC9C58; C96; C108; C109; C110; C111; C134; C147; C167
C0402CAP NP_C0402_8P8PIC2C74; C75
C0402CAP NP_C0402_105105IC8C79; C83; C84; C98; C135; C146; C234; C371
C0402CAPNP_DUP1_1_C0402_12P12pIC2C120; C171
C0402CAP NP_2_C0402_105105IC3C170; C180; C184
C0402CAP NP_4_C0402_NCNCIC1C182
C0402C_C0402_223223IC1C192
C0402CAP NP_4_C0402_100PF100pFIC1C194
C0402CAP NP_C0402_NC/102NC/102IC1C197
C0402CAP NP_C0402_12P12PIC2C198; C199
C0402CAP NP_2_C0402_104104IC1C245
C0402CAP NP_C0402_NC/100NFNC/100nfIC1C253
C0603CAPNP_DUP1_1_C0603_475475IC4C15; C16; C370; C373
C0603CAP NP_2_C0603_475475IC4C51; C183; C185; C190
C0603CAP NP_C0603_475475IC1C232
C0805CAP NP_2_C0805_106106IC3C37; C187; C189
C0805CAP NP_4_C0805_106106IC3C39; C179; C193
C0805CAP NP_C0805_106106IC8C65; C97; C133; C145; C173; C195; C230; C364
C0805CAP NP_C0805_226226IC6C82; C132; C144; C154; C155; C168
C0805CAP NP_4_C0805_226226IC3C174; C191; C264
CM4-0848DS8008_4_CM4-0848_HDMI2012F2SF-HDMI2012F2SF-900T04IC4U47; U49; U52; U53
CRY_D3225CRYSTAL-4_1_CRY_D3225_24M-10PPM24M-10ppmIC1Y2
CRY_D3225CRYSTAL-4_2_CRY_D3225_26MHZ-10P26MHz-10ppm-16pfIC1Y4
CRY_MC146CRYSTAL_2_CRY_MC146_32.768K32.768KIC1Y3
E0402NTVS_E0402N_AZ5725-01FAZ5725-01FIC5ED6; ED7; ED8; ED9; ED41
E0402NTVS_E0402N_NC/AZ5725-01FNC/AZ5725-01FIC1ED30
E0402NDIODE BI-DIR TRIG_E0402N_AZ5725AZ5725-01FIC2ED31; ED46
E0402NTVS_E0402N_AZ5425-01FAZ5425-01FIC2ED42; ED43
FBGA169-0_5-1216KLMCG8GE2A_FBGA169-0_5-1216_KLMKLMCG8GE2AIC1U16
HDMI_A_G_OKHDMI_A_HDMI_A_G_OK_HDMI_AHDMI_AIC1J3
IND_3X3INDUCTOR_1_IND_3X3_3.3UH/1A3.3uH/1AIC3L7; L8; L11
IND_4X4INDUCTOR_1_IND_4X4_2.2UH/2A2.2uH/2AIC1L9
IND_4X4INDUCTOR_1_IND_4X4_3.3UH/2A3.3uH/2AIC1L10
L0603INDUCTOR_L0603_BLM18PG181SN1BLM18PG181SN1IC2L38; L43
LED_R6GHCL4_2_LED_R6GHC_12-22/R6GHC-A30/12-22/R6GHC-A30/2CIC1U58
MICRO-USB-5P-E2USB MIN_4_MICRO-USB-5P-E2_MICROMICRO-USB-5P-E2IC1J1
MTG060_RD120XP-01-HX_MTG060_RD120_HOLEHOLEIC2XP1; XP2
R0402RESISTOR_R0402_22R22RIC8R1; R2; R3; R4; R5; R6; R58; R227
R0402RESISTOR_1_R0402_0R0RIC2R11; R42
R0402RESISTOR_R0402_NC/100KNC/100KIC1R12
R0402R_0_R0402_NC/1KNC/1KIC1R14
R0402RESISTOR_R0402_NC/0RNC/0RIC1R16
R0402RESISTOR_R0402_NC/4K7NC/4K7IC2R17; R18
R0402RESISTOR_R0402_150K150KIC1R25
R0402RESISTOR_R0402_82K82KIC1R26
R0402RESISTOR_R0402_22K22KIC1R27
R0402RESISTOR_1_R0402_20K%120K%1IC1R41
R0402RESISTOR_R0402_43R2,1%43R2,1%IC2R48; R50
R0402RESISTOR_1_R0402_100R100RIC1R49
R0402RESISTOR_R0402_10K10KIC18R51; R52; R54; R57; R79; R192; R211; R228; R229; R230; R231; R232; R233; R234; R235; R236; R239; R240
R0402RESISTOR_1_R0402_4.99K%14.99K%1IC1R53
R0402RESISTOR_0_R0402_1K1KIC1R55
R0402RESISTOR_R0402_1M1MIC1R59
R0402R_R0402_22K22KIC1R60
R0402R_R0402_14K7%114K7%1IC1R61
R0402RESISTOR_R0402_240,1%240,1%IC3R66; R77; R224
R0402RESISTOR_R0402_100R100RIC1R67
R0402RESISTOR_R0402_1K%11K%1IC4R68; R69; R70; R71
R0402RESISTOR_0_R0402_100K%1100K%1IC1R72
R0402RESISTOR_R0402_1K1KIC4R85; R148; R238; R244
R0402RESISTOR_R0402_4.7K4.7KIC7R90; R91; R152; R237; R241; R242; R243
R0402RESISTOR_R0402_470R,1%470R,1%IC1R157
R0402RESISTOR_0_R0402_NC/100RNC/100RIC1R166
R0402R_R0402_6K2%16K2%1IC1R167
R0402R_R0402_120K%1120K%1IC1R169
R0402R_R0402_196K%1196K%1IC1R170
R0402R_R0402_7K5%17K5%1IC1R171
R0402R_0_R0402_NC/0RNC/0RIC9R216; R221; R225; R226; R247; R248; R249; R250; R251
R0402R_0_R0402_0R0RIC2R218; R219
R0402R_0_R0402_100R100RIC1R220
R0402R_0_R0402_NC/560KNC/560KIC1R222
R0402R_0_R0402_NC/470RNC/470RIC1R223
R0402RESISTOR_R0402_33K33KIC1R245
R0402RESISTOR_R0402_NCNCIC1R246
R0402RES_R0402_200_2200_2IC4R253; R254; R255; R256
RF86J_AMC_JACK_1_RF86_PIN00625-TRPIN00625-TRIC2J2; J4
SLP2510P8DS8008_1_SLP2510P8_DS8008_1DS8008_1IC2U46; U48
SOD-323DIODE_SOD-323_1N58191N5819IC1D1
SOD-323DIODE ZENER13_0_SOD-323_3.3V3.3VIC1D9
SOP8-0_65-2_83_0PCA9406_SOP8-0_65-2_83_0_PCA940PCA9406DCTTIC1U55
SOT23-6DS8008_2_SOT23-6_SY8009BSY8009BIC1U15
SOT23_6LM1086_2_SOT23_6_NC/NL27WZU04NC/NL27WZU04IC1U50
SOT-23MOSFET N_SOT-23_BS138BS138IC2Q16; Q17
SOT-23-5PT5108_SOT-23-5_SGM2028-3.3SGM2028-3.3IC1U56
SSW4P-3_84_4-BRASW4P_2_SSW4P-3_84_4-BRA_RECOVERRECOVERIC1SW9
TPC60TEST_0_TPC60_NC/5VNC/5VIC1T25
TPC60TEST_0_TPC60_NC/HOST_DMNC/HOST_DMIC1T32
TPC60TEST_0_TPC60_NC/HOST_DPNC/HOST_DPIC1T33
TPC60TEST_0_TPC60_NC/GNDNC/GNDIC1T34
T_0_7TEST_0_T_0_7_TESTTESTIC12T17; T18; T19; T22; T26; T27; T28; T30; T31; T43; T100; T101
T_0_7TEST_1_T_0_7_TESTTESTIC1T29
VQFN48LP28300_9_VQFN48_TPS659102TPS659102IC1U12
WIFI_AP6493_12X12MMAP6493_1_WIFI_AP6493_12X12MM_APAP6XXXIC1U8
附件:
$ v) l: [; ]2 Z  C. t8 t$ b4 D; j原理图和PCB文件如下:
/ |* w5 Q, L, f- s+ \
游客,如果您要查看本帖隐藏内容请回复
8 A! H* V, u4 _3 e. i" y4 q8 }' x
* G2 s6 q/ y4 x+ O& ~, U* Q
GMT+8, 2025-7-23 22:22 , Processed in 0.125000 second(s), 28 queries , Gzip On.
