查看: 204|回复: 0
[allegro16.3][8层] PK60N512VMD100(飞思卡尔K60)参考板(PK60N512VMD100+MIC202...
发表于 2020-2-6 18:39 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.3][8层] PK60N512VMD100(飞思卡尔K60)参考板(PK60N512VMD100+MIC2026-1YM+MC9S08JM60CLD)原理图和pcb文件! D  ^, D( k. o; X6 d7 p; I" t! f
# e9 A* \8 B) k* X! q文件描述:
" r, J- b9 w$ e0 k6 Y
8 O8 j9 f4 t' a' }1. 作品用途:PK60N512VMD100(飞思卡尔K60)参考板; Q" ]. A, w5 d, [0 |( d
2. 软件版本:allegro16.36 f+ e) g! m5 m- |
3. 层数:8层
8 e4 }7 a# g' F( F' M8 E4. 用到的主要芯片:PK60N512VMD100+MIC2026-1YM+MC9S08JM60CLD- g0 V! ^$ O3 n
5. pcb尺寸: 3543*3175 MIL& _6 u! ~' _) S" s, z  S3 r# H
9 ^7 ^" V% [$ Z; N$ O: q$ M
作品截图如下:
2 P' f: g. k" T: M- j2 Q) p
8 J/ g7 A0 G5 m) j) U9 S8 F顶层截图:
! z( V& e. n  ^; g' E3 e( b
  {/ r4 a4 A3 q7 L4 _' z( p/ B底层截图:+ g! B) `% X- I" A; G" [
1 V* O- C& ~6 s+ n0 h5 s; z
( ]6 R- C7 \; e  \全层截图:
, e- F; s3 C: l1 H4 H
% Q$ c/ N# d# v+ S 0 W7 F$ [6 p2 `/ T- S
( }9 A) E, _" s0 l. u9 @7 ~% B4 O) r. f
BOM:. F3 c% w2 S7 c: w, R! S0 d8 W1 F
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M0.1uFDISCRETE1C20
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UFDISCRETE27C2; C3; C4; C5; C9; C13; C14; C15; C16; C17; C18; C23; C24; C26; C29; C30; C31; C32; C33; C34; C36; C37; C38; C40; C41; C42; C44
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.25M2.2UFDISCRETE1C7
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PFDISCRETE4C8; C10; C21; C28
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.01UFDISCRETE2C22; C25
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.871000PFDISCRETE1C43
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UFDISCRETE7C6; C11; C12; C19; C27; C35; C39
CC3528-21CAP_POL_CC3528-21_2.1MM_150-7854.7uFIC1C1
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS TOWER SYSTEMIO1J7
CON5_MUSB_AB_0P8_RA_SMTUSB_MINI_B_SKT_CON5_MUSB_AB_0P8USB_MINI_B 5IO1J13
CON_FTSH_20M_50_SMCONN_HDR_10X2_CON_FTSH_20M_50_SHDR_2X10IO1J11
CON_SDCARD_13F_SM_RA_511CONN_SDCARD_1X13_F_511_CON_SDCASD/MMC SKTIO1J15
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M_50CON_2X10IO1J3
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M__1CON_2X10IO2J4; J5
DFN_10_0P5_3X3AMMA7660FC_DFN_10_0P5_3X3A_IC_1MMMA7660FCIC1U5
DIODE_3P2X2P2LED_DIODE_3P2X2P2_IC_1.1MM_480-QTLP610CIRIC1D1
HDR102CONN_HDR_2X1_HDR102_IO_8.71 MM_HDR 1X2 THIO5J1; J2; J8; J10; J12
HDR103CONN_HDR_3X1_HDR103_IO_8.6MM_21HDR TH 1X3IO2J6; J9
HDR203_TSM_SMCONN_HDR_3X2_HDR203_TSM_SM_IO_9HDR_2X3IO1J14
IND_0603IND_IND_0603_0.8MM_180-75495_10100MHZIC5L1; L4; L6; L7; L8
IND_0603BEAD_FERRITE_IND_0603_DISCRETE_120OHMDISCRETE1L5
IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHMDISCRETE2L2; L3
LED2_ELECTRODE_ALED2_ELECTRODE_ABC_LED2_ELECT_2LED_OR + ELECTRODEIC1D7
LED2_ELECTRODE_ALED2_ELECTRODE_ABC_LED2_ELECT_3LED_YEL + ELECTRODEIC1D8
LED2_ELECTRODE_ALED2_ELECTRODE_ABC_LED2_ELECTROLED_GRN + ELECTRODEIC1D11
LED2_ELECTRODE_ALED2_ELECTRODE_ABC_LED2_ELECT_1LED2_ELECTRODEIC1D12
LED_0603LED_LED_0603_IC_0.8MM_370-75080ORANGEIC1D2
LED_0603LED_LED_0603_IC_0.8MM_370-75076LED_YELLOWIC1D3
LED_0603LED_LED_0603_IC_1.0MM_370-76472YEL/GRNIC2D4; D5
POT3_3352TPOT_POT3_3352T_DISCRETE_470-8015KDISCRETE1R52
QTLP610TRAN_PHOTO_QTLP610_IC_1.1MM_480QTLP610CPDIC1Q1
RC0402_25RES_RC0402_25_DISCRETE_470-757933DISCRETE5R12; R22; R23; R41; R42
RC0402_25RES_RC0402_25_DISCRETE_470-30851.54KDISCRETE1R13
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0KDISCRETE6R14; R16; R58; R64; R67; R77
RC0402_25RES_RC0402_25_DISCRETE_470-7646330DISCRETE1R15
RC0402_25RES_RC0402_25_DISCRETE__470-7601.0KDISCRETE1R17
RC0402_25RES_RC0402_25_DISCRETE_470-3078270DISCRETE1R18
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0KDISCRETE29R19; R20; R21; R24; R26; R28; R29; R30; R31; R32; R33; R34; R35; R36; R37; R53; R56; R69; R70; R71; R73; R74; R75; R76; R79; R80; R81; R82; R84
RC0402_25RES_RC0402_25_DISCRETE_470-78352.2KDISCRETE2R27; R83
RC0402_25RES_RC0402_25_DISCRETE_470-75360DISCRETE2R38; R39
RC0402_25RES_RC0402_25_DISCRETE_470-30914.99KDISCRETE1R40
RC0402_25RES_RC0402_25_DISCRETE_470-764810MDISCRETE1R78
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400DISCRETE27R1; R2; R3; R4; R5; R6; R7; R8; R9; R10; R11; R43; R44; R45; R46; R47; R48; R49; R50; R51; R57; R59; R63; R65; R66; R68; R72
RC0603_OVRES_RC0603_OV_DISCRETE_470-75434.70KDISCRETE2R54; R55
RC0603_OVRES_RC0603_OV_DISCRETE_470-75841.0MDISCRETE1R61
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440DISCRETE3R25; R60; R62
SKT_BAT_780X1210BATTERY_SKT_3V_SKT_BAT_780X1210BK-883IC1BT1
SKT_BGA144_1_18X18_CUSTOMNEWTON_144BGA_SKT_BGA144_1_18X1PK60N512VMD100 + 144 BGA SOCKETIC1U1
SMB_2P7X1P4DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7MSS1P3LIC1D10
SO8MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YMIC1U2
SOIC1474-125_14P_SOIC14_IC_1.75MM_31274HCT125IC1U6
SOT23NPN_SOT23_IC_1.12 MM_480-75173_MMBT3904LT1GIC1Q2
SOT223LT1129CST-3.3_SOT223_IC_1.8MM_3MIC2920A-3.3WSIC1U3
SOT-23BAT721B_SOT-23_IC_1.3MM_480-779BAT54CIC2D6; D9
SOT-23TRAN_NPN_RES_SOT-23_IC_1.3MM_48PDTC115TIC1Q3
SOT_143SPB0503_SOT_143_IC_1.22MM_480-7SP0503BIC1U7
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switchIC3SW1; SW2; SW3
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8 MM_21TEST POINT WHITEIC18T1; TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP16; TP18; TP19
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8MM_210TEST POINT BLACKIC2TP15; TP17
TQFP44MC9S08JM60CFGE_TQFP44_IC_1.60 MMC9S08JM60CLDIC1U8
TSSOP1474LVC125_TSSOP14_IC_1.2MM_312-774LVC125IC1U9
TSSOP-1474_04_TSSOP-14_IC_1.2MM_312-753SN74LVC04APWE4IC1U4
XTL2_ECS_CSM7_SMXTAL_XTL2_ECS_CSM7_SM_IC_4.3MM_4MHzIC1Y3
XTL2_ECS_SMXTAL_XTL2_ECS_SM_IC_2.25MM_230-32.768KHzIC1Y2
XTLOSC4_SMCLKGEN-SM_XTLOSC4_SM_IC_1.75MM_50MHZIC1Y1
附件:  ?9 g1 ]4 e$ f1 l
原理图和PCB文件如下:3 Z4 S; ^0 Y: q( F# W
游客,如果您要查看本帖隐藏内容请回复
: y, ^; g# F% p# r7 E, ~, \
GMT+8, 2025-7-23 22:23 , Processed in 0.125000 second(s), 29 queries , Gzip On.
