Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
BRIDGE_DFB20_TH | BRIDGE_RECTIFIER_BRIDGE_DFB20_T | DFB2060 | IC | 1 | D6 |
C402_520_154_35 | CAP_NP_C402_520_154_35_DISCRETE | 2200PF | DISCRETE | 2 | C19; C20 |
CAP_10P5_RAD | CAP_POL_CAP_10P5_RAD_DISCRETE_2 | 4.7uF | DISCRETE | 1 | C45 |
CAP_METPLY_15MM_18P2X6P9 | CAP_NP_CAP_METPLY_15MM_18P2X6P9 | 0.68uF | DISCRETE | 1 | C17 |
CAP_MET_PLY_18X6MM | CAP_NP_CAP_MET_PLY_18X6MM_DISCR | 0.15UF | DISCRETE | 1 | C46 |
CASE403D_02 | DIODE_CASE403D_02_IC_2.41MM_480 | MURA160T3G | IC | 3 | D17; D18; D23 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.27MM_1 | 2.2UF | DISCRETE | 2 | C6; C9 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4 M | 47PF | DISCRETE | 10 | C1; C4; C14; C15; C18; C58; C61; C65; C75; C77 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.35 | 0.1UF | DISCRETE | 23 | C2; C3; C8; C10; C11; C13; C21; C22; C25; C28; C31; C34; C35; C41; C42; C43; C47; C52; C68; C69; C70; C71; C82 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.3_1 | 0.1UF | DISCRETE | 7 | C5; C62; C66; C67; C72; C76; C79 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4_2 | 4.7UF | DISCRETE | 1 | C7 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 1.0uF | DISCRETE | 3 | C12; C27; C40 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_0.88M | 0.01UF | DISCRETE | 2 | C16; C81 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4MM | 1000PF | DISCRETE | 11 | C26; C30; C33; C36; C37; C38; C39; C44; C49; C50; C51 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4_1 | 10UF | DISCRETE | 3 | C48; C53; C73 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.473 | 0.01UF | DISCRETE | 3 | C78; C80; C84 |
CC1812 | CAP_NP_CC1812_DISCRETE_2 MM_150 | 0.1uF | DISCRETE | 2 | C59; C83 |
CCE8P3X8P3 | CAP_POL_CCE8P3X8P3_DISCRETE_10. | 100uF | DISCRETE | 1 | C57 |
CCE10_3X10_3 | CAP_POL_CCE10_3X10_3_DISCRETE_1 | 150uF | DISCRETE | 1 | C64 |
CCE50X54 | CAP_POL_CCE50X54_DISCRETE_5.4MM | 47UF | DISCRETE | 1 | C23 |
CCE50X54 | CAP_POL_CCE50X54_DISCRETE_5.5MM | 47UF | DISCRETE | 2 | C24; C32 |
CCE50X54 | CAP_POL_CCE50X54_DISCRETE_5.5 M | 10UF | DISCRETE | 5 | C54; C55; C56; C60; C74 |
CON3_TB_5P08_TH | CONN_HDR_3X1_CON3_TB_5P08_TH_IO | MC000049 | IO | 2 | J8; J13 |
CONN_2X32_THRUHOLE | CONN_PCIEXP_64P_CUST_CONN_2X32_ | CONN PCI EXP 64 | IO | 1 | J11 |
CON_2_TB_5P08_TH | CONN_HDR_2X1_CON_2_TB_5P08_TH_I | MC000048 | IO | 1 | J12 |
CON_5M_100_TH | CONN_HDR_5X1_CON_5M_100_TH_IO_1 | CON_1X5 | IO | 1 | J9 |
CON_USB_RA | USB_B_RCPT_CON_USB_RA_IO_11.50M | USB_TYPE_B | IO | 1 | J4 |
CR1653_1220_POL | CAP_POL_CR1653_1220_POL_DISCRET | 330uF | DISCRETE | 2 | C29; C63 |
D2PAK_B | MOSFET_N_D4_D2PAK_B_IC_4.82 MM_ | 600V 20.2A | IC | 1 | Q4 |
DIP_26P_39P5X23P5_SPMAA-C26_TH | FNB41560_26P_DIP_26P_39P5X23P5_ | FNB41560 | IC | 1 | U12 |
DO214AC_4P06 | DIODE_DO214AC_4P06_IC_2.64MM_48 | ES1J-LTP | IC | 2 | D8; D9 |
DPAK_MC33269 | MC33269_DPAK_DPAK_MC33269_IC_2. | MC33269DT-3.3G | IC | 1 | U5 |
HDR102 | CONN_HDR_2X1_HDR102_IO_8.6MM_21 | HDR 1X2 | IO | 1 | J5 |
HSMX-C170 | LED_HSMX-C170_IC_0.9 MM_370-300 | HSMG-C170 | IC | 2 | D1; D20 |
HSMX-C170 | LED_HSMX-C170_IC_0.8MM_370-7578 | HSMY-C170 | IC | 1 | D2 |
IND12X12 | INDUCTOR_IND12X12_DISCRETE_8.0M | 1000UH | DISCRETE | 1 | L4 |
IND_12P_45P5X42P4 | GA3199_12P_IND_12P_45P5X42P4_DI | 650uH | DISCRETE | 2 | L2; L3 |
IND_2012 | INDUCTOR_IND_2012_DISCRETE_0.85 | 1uH | DISCRETE | 1 | L1 |
JUMP1X4-6040 | CONN_HDR_4X1_JUMP1X4-6040_IO_8. | HDR_1X4 | IO | 3 | J1; J2; J3 |
LED0805 | LED_LED0805_IC_1.2MM_370-76452_ | BLUE | IC | 1 | D22 |
LED_2P_0805 | LED_LED_2P_0805_IC_0.9MM_370-76 | RED | IC | 1 | D19 |
PLATED_HOLE_3_5MM | MOUNT_HOLE_PLATED_HOLE_3_5MM_IC | MOUNTING HOLE | IC | 1 | BH1 |
QFN28_5X5MM_3P3_EP | CP2102_QFN28_5X5MM_3P3_EP_IC_1M | CP2102 | IC | 1 | U3 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7546 | 15.0K | DISCRETE | 4 | R1; R20; R117; R118 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.55MM_4 | 1.6K | DISCRETE | 19 | R2; R8; R12; R16; R26; R27; R29; R30; R34; R35; R66; R68; R72; R75; R97; R103; R109; R112; R122 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.6MM_47 | 220 | DISCRETE | 12 | R3; R7; R13; R17; R67; R69; R73; R76; R98; R104; R110; R113 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7557 | 470 | DISCRETE | 4 | R4; R5; R126; R137 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7842 | 82K | DISCRETE | 4 | R9; R10; R11; R119 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.6 MM_4 | 24 | DISCRETE | 4 | R14; R24; R64; R125 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-75_1 | 10.0K | DISCRETE | 3 | R15; R80; R121 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7590 | 4.7K | DISCRETE | 13 | R18; R22; R23; R25; R38; R42; R45; R47; R79; R86; R87; R115; R127 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-75_2 | 560K | DISCRETE | 1 | R21 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-75_3 | 1.0K | DISCRETE | 2 | R28; R52 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7881 | 120 | DISCRETE | 11 | R36; R39; R40; R43; R44; R46; R48; R84; R102; R124; R128 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7544 | 0 | DISCRETE | 2 | R37; R41 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7877 | 22.0K | DISCRETE | 2 | R49; R74 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.55MM_1 | 7.5K | DISCRETE | 9 | R65; R77; R82; R83; R85; R89; R93; R95; R114 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7634 | 2K | DISCRETE | 4 | R70; R71; R88; R123 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7595 | 16.5K | DISCRETE | 1 | R78 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7968 | 30K | DISCRETE | 1 | R81 |
RC1206_OV | RES_RC1206_OV_DISCRETE_470-8065 | 130K | DISCRETE | 18 | R31; R32; R33; R50; R53; R55; R56; R57; R58; R90; R91; R92; R99; R100; R101; R106; R107; R108 |
RC1206_OV | RES_RC1206_OV_DISCRETE_470-7868 | 3.01K | DISCRETE | 4 | R54; R96; R105; R111 |
RC1206_OV | RES_RC1206_OV_DISCRETE_470-3006 | 1.5K | DISCRETE | 3 | R59; R63; R116 |
RC2512_B | RES_RC2512_B_DISCRETE_470-80263 | 0.05 | DISCRETE | 6 | R6; R19; R51; R60; R61; R62 |
RELAY_4P_19P8X15P8 | G5LA-1A4-DC12_RELAY_4P_19P8X15P | G5LA-1A4 DC12 | IC | 1 | K1 |
S08_1P27_4X5 | MC33152D_S08_1P27_4X5_IC_1.75MM | MC33152 | IC | 1 | U9 |
SHORTBAR_1206 | SHORTBAR1206_SHORTBAR_1206_IC_0 | ShortingBar1206 | IC | 1 | BAR1 |
SIP3_2P54_12X8P6_TH | MC78XXCT_SIP3_2P54_12X8P6_TH_IC | R-78E5.0-0.5 | IC | 1 | U6 |
SMA | ZDIODE_SMA_IC_2.41MM_480-77778_ | 1SMA5936BT3G | IC | 1 | D16 |
SMC_CASE403 | DIODE_SMC_CASE403_IC_2.616MM_48 | ES3J | IC | 1 | D21 |
SMD-8B | LNK306G_SMD-8B_IC_3.98MM_312-79 | LNK306G | IC | 1 | U7 |
SO8_1P27_4X5 | MC33502D_SO8_1P27_4X5_IC_1.75MM | MC33502DG | IC | 3 | U2; U8; U11 |
SO8_1P27_4X5 | FAN3224_SO_8P_SO8_1P27_4X5_IC_1 | FAN3224 | IC | 1 | U14 |
SO16W | SI8622BD_16P_SO16W_IC_2.65MM_31 | SI8622BD-B-IS | IC | 1 | U1 |
SOD123 | ZDIODE_SOD123_IC_1.35MM_480-780 | MMSZ5248ET1 | IC | 2 | D7; D10 |
SOD123 | DIODE_SCHTKY_SOD123_IC_1.45MM_4 | MBR0520LT1G | IC | 5 | D14; D15; D26; D27; D28 |
SOD-123 | DIODE_SOD-123_IC_1.35MM_480-760 | MMSD4148T1G | IC | 3 | D11; D12; D13 |
SOT23-3 | DUALDIODE_CC_SOT23_SOT23-3_IC_1 | BAS70-05 | IC | 1 | D24 |
SOT23-3 | LM4041_SOT23-3_IC_1.12MM_315-78 | LM4041 | IC | 1 | D25 |
SOT-23 | MOSFET_EN_SOT-23_IC_1.11 MM_480 | BSS138LT1G | IC | 1 | Q3 |
SOT-23-5 | LMV7271MF_SOT-23-5_IC_1.22MM_31 | LMV7271MF | IC | 2 | U10; U13 |
TESTPOINT_060_039MIL | T POINT TH_TESTPOINT_060_039MIL | TEST_POINT | IC | 46 | TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP28; TP29; TP30; TP31; TP32; TP33; TP34; TP35; TP36; TP37; TP38; TP39; TP40; TP41; TP42; TP43; TP44; TP45; TP46 |
THERMISTOR_328_770X220_TH | THERMISTOR_THERMISTOR_328_770X2 | 16 OHM | DISCRETE | 1 | RT1 |
TO-220AB_NSP | MOSFET_N3_TO-220AB_NSP_IC_19.62 | SIHF22N60E-E3 | IC | 2 | Q1; Q2 |
TO-220AC_VERT | DIODE_TO-220AC_VERT_IC_19.07 MM | VS-15ETL06P | IC | 1 | D5 |
TO-220AC_VERT_2P | DIODE_SCHTKY_TO-220AC_VERT_2P_I | C3D10060A | IC | 2 | D3; D4 |
VARISTOR_7P5_17X5P6_TH | VARISTOR_VARISTOR_7P5_17X5P6_TH | V14E275P | DISCRETE | 1 | RV1 |
附件:
