查看: 237|回复: 0
[allegro16.3][4层] 4通道信号调制发射器(CY7C68014A+RFMD2080+SL9002i)pcb文件
发表于 2020-2-6 16:11 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
0 q) M2 z$ e7 T! W
1 a1 D/ r0 |  c9 L! |- U! ~; t1 C% f. ]
文件描述:, D& r" L8 d( r
: @6 W* d) F  w8 L
1. 作品用途:4通道信号调制发射器$ B, \( V' z6 A; w
2. 软件版本:allegro16.37 R+ H1 {3 i: K& X. S' n
3. 层数:4层3 |4 T8 a. ]7 [; N# A$ q: P$ Q4 ]& V
4. 用到的主要芯片:CY7C68014A+RFMD2080+SL9002i8 ^* T% t; C; c  H& p
5. pcb尺寸: 6592*4190.63 MIL
% X* E2 q! i6 N# @# ?0 {2 S. C( E; t' P" l1 i. {
作品截图如下:
- U! a$ I: q  x3 h" c/ [4 N9 L+ N
顶层截图:2 {) G' J# \- _* z
$ H) w4 C& H  B# A
底层截图:
. s$ M+ r$ w" c& Y; R
* d  |* n8 ^* k2 @3 Y$ y, c7 _
- k9 D$ q5 W! ]& R全层截图:5 t! T9 q9 |( ]% A, M
0 ]5 F4 V% h& R. y6 ]: K5 I
- j- z# |7 S! o* ~; ~2 g2 uBOM:
* d; N. s- E: I- T( W
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BERG_1X4_2P54CON_4PIN_M_TH_1.96MM_BERG_1X4_24-PinIC1CN10
BGA_176_0P8MM_WOSOCSL9002I_0_BGA_176_0P8MM_WOSOC_SSL9002iIC4U8; U19; U30; U41
C0402_SCAP_NP_0.1UF_0402_C0402_S_0.1UF0.1uFIC213C1; C4; C5; C6; C8; C18; C19; C22; C23; C33; C34; C35; C36; C38; C40; C41; C42; C45; C46; C47; C50; C52; C53; C54; C55; C56; C57; C61; C62; C63; C64; C65; C66; C69; C71; C72; C73; C74; C75; C76; C78; C79; C80; C81; C82; C83; C84; C85; C86; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C98; C99; C100; C101; C124; C125; C128; C130; C131; C132; C133; C134; C135; C139; C140; C141; C142; C143; C144; C147; C149; C150; C151; C152; C153; C154; C156; C157; C158; C159; C160; C161; C162; C163; C164; C166; C167; C168; C169; C170; C171; C172; C173; C174; C175; C176; C177; C178; C179; C202; C203; C207; C208; C209; C210; C211; C212; C213; C217; C218; C219; C220; C221; C222; C225; C227; C228; C229; C230; C231; C232; C234; C235; C236; C237; C238; C239; C240; C241; C242; C244; C245; C246; C247; C248; C249; C250; C251; C252; C253; C254; C255; C280; C281; C285; C286; C287; C288; C289; C290; C291; C295; C296; C297; C298; C299; C300; C303; C304; C306; C307; C308; C309; C310; C312; C313; C314; C315; C316; C317; C318; C319; C320; C322; C323; C324; C325; C326; C327; C328; C329; C330; C331; C332; C333; C335; C359; C361; C368; C371; C372; C373; C374; C375; C376; C378; C382; C388; C390; C393; C395; C398; C408; C416
C0402_SCAP_NP_1UF_0603_C0402_S_0.1UF0.1uFIC1C11
C0402_SCAP_NP_10UF_0805_C0402_S_0.01UF0.01uFIC17C12; C13; C14; C15; C16; C17; C20; C21; C24; C25; C26; C27; C28; C29; C30; C31; C32
C0402_SCAP_NP_0.1UF_0402_C0402_S_8.2PF8.2pFIC6C43; C44; C117; C195; C273; C351
C0402_SCAP_NP_22PF_0_C0402_S_22PF22pFIC8C51; C59; C129; C137; C206; C215; C284; C293
C0402_SCAP_NP_0.1UF_0402_C0402_S_12PF12pFIC10C67; C68; C145; C146; C223; C224; C257; C301; C302; C377
C0402_SCAP_NP_0.1UF_0402_C0402_S_33PF33pFIC32C102; C103; C104; C105; C106; C107; C109; C111; C180; C181; C182; C183; C184; C185; C187; C189; C258; C259; C260; C261; C262; C263; C265; C267; C336; C337; C338; C339; C340; C341; C343; C345
C0402_SCAP_NP_0.1UF_0402_C0402_S_0.01U0.01uFIC27C108; C110; C112; C121; C123; C186; C188; C190; C199; C200; C264; C266; C268; C277; C278; C342; C344; C346; C355; C357; C358; C362; C363; C365; C366; C367; C370
C0402_SCAP_NP_0.1UF_0402_C0402_S_100PF100pFIC12C113; C114; C115; C191; C192; C193; C269; C270; C271; C347; C348; C349
C0402_SCAP_NP_0.1UF_0402_C0402_S_180PF180pFIC4C116; C194; C272; C350
C0402_SCAP_NP_0.1UF_0402_C0402_S_1NF1nFIC4C118; C196; C274; C352
C0402_SCAP_NP_0.1UF_0402_C0402_S_330PF330pFIC8C119; C120; C197; C198; C275; C276; C353; C354
C0402_SCAP_NP_0.1UF_0402_C0402_S_22PF22pFIC4C122; C201; C279; C356
C0402_SCAP_NP_0.1UF_0402_C0402_S_680PF680pFIC1C403
C0603CAP_NP_2.2UF_0603_C0603_2.2UF2.2uFIC12C48; C49; C58; C126; C127; C136; C204; C205; C214; C282; C283; C292
C0603CAP_NP_0.1UF_0402_C0603_1UF1uFIC10C60; C70; C138; C148; C216; C226; C294; C305; C391; C400
C0603CAP_NP_10UF_0805_C0603_10UF10uFIC8C77; C87; C155; C165; C233; C243; C311; C321
C0603CAP_NP_0.1UF_0402_C0603_10UF10uFIC2C410; C412
C0603CAP_NP_0.1UF_0402_C0603_0.1UF0.1uFIC1C413
C0603CAP_NP_0.1UF_0402_C0603_4.7UF4.7uFIC1C415
C0805CAP_NP_4.7NF_0402_C0805_4.7NF4.7nFIC1C10
C0805CAP_NP_0.1UF_0402_C0805_10UF10uFIC12C380; C404; C414; C417; C418; C419; C420; C421; C422; C423; C424; C425
C0805CAP_NP_0.1UF_0402_C0805_22UF22uFIC1C399
C1206CAP_NP_1UF_0603_C1206_1UF1uFIC3C2; C3; C9
C1206CAP_NP_10UF_0805_C1206_10UF10uFIC2C37; C39
C1206CAP_NP_0.1UF_0402_C1206_10UF10uFIC3C360; C364; C369
C1206CAP_NP_0.1UF_0402_C1206_22 UF22 uFIC1C405
C1206_PCAP POL_C1206_P_10UF10uFIC2C7; C256
C1206_PCAP_P_10UF_3216_C1206_P_10UF10uFIC18C334; C379; C381; C383; C384; C385; C386; C387; C389; C392; C394; C396; C397; C401; C406; C407; C409; C411
CONN_PCI_EDGE_1MM_36PINPCIE-CARD-EDGE_0_CONN_PCI_EDGE_PCIE-CARD-EDGEIC1CON1
CON_COAX_RTMMCX_CON_0_CON_COAX_RT_RFRFIC1J1
CON_DCPJACK_PDCJ01-01CONN JACK PWR_CON_DCPJACK_PDCJ0CONN JACK PWRIC1CN12
CON_USB_B_F_5PCN-USB_4_CON_USB_B_F_5P_CN-USBCN-USBIC1CN1
CRY_FQ3225BCRYSTAL_SMD_25MHZ_EPSON_10_CRY_12MHzIC1Y15
DI_SMAZC2800E/SOT_0_DI_SMA_B2220A-13-B2220A-13-FIC2D35; D36
DO-219-ABDO-219ABSL03IC1D1
HVQFN56_0P5CY7C68014A-56LFXC_0_HVQFN56_0P5CY7C68014AIC4U6; U17; U28; U39
IND_XAL40INDUCTOR_100NH_SMD_COIL_IND_X_11.0uHIC2L9; L16
IND_XAL40INDUCTOR_100NH_SMD_COIL_IND_XAL2.2uHIC1L15
L0402INDUCTOR_L0402_1UH1uHIC4L10; L11; L13; L14
L0402_SFB_6_L0402_S_300MA300mAIC58FBS1; FBS2; FBS3; FBS5; FBS6; FBS8; FBS9; FBS10; FBS11; FBS12; FBS13; FBS14; FBS15; FBS16; FBS17; FBS18; FBS19; FBS20; FBS21; FBS22; FBS23; FBS24; FBS25; FBS26; FBS27; FBS28; FBS29; FBS30; FBS31; FBS32; FBS33; FBS34; FBS35; FBS36; FBS37; FBS38; FBS39; FBS40; FBS41; FBS42; FBS43; FBS44; FBS45; FBS46; FBS47; FBS48; FBS49; FBS50; FBS51; FBS52; FBS53; FBS54; FBS55; FBS56; FBS57; FBS58; FBS59; FBS60
L0603FB_7_L0603_750,400MA750,400mAIC12FBM1; FBM7; FBM13; FBM19; FBM25; FBM26; FBM27; FBM28; FBM32; FBM33; FBM34; FBM38
L0805FB_4_L0805_600,2A600,2AIC10FBL1; FBL2; FBL3; FBL4; FBL5; FBL6; FBL7; FBL8; FBL9; FBL10
L0805FB_8_L0805_600,2A600,2AIC4FBL26; FBL27; FBL28; FBL29
L0805INDUCTOR_100NH_SMD_COIL_L0805_4470nHIC2L1; L2
L1206FB_8_L1206_600,2.5A600,2.5AIC15FBB1; FBB2; FBB3; FBB4; FBB5; FBB6; FBB7; FBB8; FBB9; FBB10; FBB11; FBB12; FBB13; FBB14; FBB15
LED_0402LED_0_LED_0402_REDLEDRedLEDIC13D2; D21; D22; D23; D24; D26; D27; D28; D29; D30; D31; D32; D33
LED_0402LED_0_LED_0402_AMBERLEDAmberLEDIC14D3; D4; D5; D7; D8; D9; D11; D12; D13; D15; D16; D17; D19; D25
LED_0402LED_0_LED_0402_GREENLEDGreenLEDIC4D6; D10; D14; D18
OSC_887_CW662CTOSC_SMD_12_OSC_887_CW662CT_26MH26MHz, CW659CT-NDIC4Y5; Y8; Y11; Y14
OSC_SMD4CRYSTAL_SMD_25MHZ_EPSON_10_OS_124MHzIC1Y2
OSC_SMD4_XRCGBCRYSTAL_SMD_1_OSC_SMD4_XRCGB_2424MHzIC4Y3; Y6; Y9; Y12
OSC_SMD4CRYSTAL_SMD_25MHZ_EPSON_10_OSC_27MHzIC4Y4; Y7; Y10; Y13
PSON_6PTPS720105_PSON_6P_TPS720105DRVTPS720105DRVIC1U60
QFN32_0P5_5X5RFMD2080_QFN32_0P5_5X5_RFMD2080RFMD2080IC4U15; U26; U37; U48
QFN32_0P5_5X5RDA2032ZSR_QFN32_0P5_5X5_RDA203RDA2032ZSRIC1U51
QFN_16P_0P5MMTPS62140_0_QFN_16P_0P5MM_TPS621TPS62130AIC1U58
QFN_28L_0P5MMHX2VL_QFN_28L_0P5MM_CY7C65632CY7C65632IC1U1
QFN_68L_0P4MMUPD720201_QFN_68L_0P4MM_UPD7202UPD720201IC1U52
R0402_SR_10K_0_R0402_S_510K510KIC1R1
R0402_SR_10K_0_R0402_S_100K100KIC2R2; R10
R0402_SR_10K_0_R0402_S_10K10KIC118R3; R4; R6; R7; R8; R11; R13; R18; R19; R20; R21; R27; R28; R29; R30; R31; R32; R33; R34; R35; R37; R39; R40; R41; R42; R44; R46; R70; R83; R107; R108; R111; R112; R125; R126; R127; R128; R129; R130; R131; R132; R158; R169; R193; R196; R197; R198; R211; R212; R213; R214; R215; R216; R217; R218; R244; R255; R261; R262; R264; R271; R272; R274; R279; R282; R283; R284; R297; R298; R299; R300; R301; R302; R303; R304; R330; R341; R347; R350; R357; R358; R360; R365; R367; R369; R370; R384; R385; R392; R394; R397; R429; R430; R433; R434; R435; R438; R439; R440; R441; R442; R443; R444; R445; R446; R447; R448; R450; R451; R452; R453; R454; R455; R466; R467; R468; R469; R470
R0402_SR_100K_1_R0402_S_100K100KIC1R5
R0402_SR_9.1K_0402_R0402_S_1M1MIC1R9
R0402_SR_10K_0_R0402_S_649E649EIC1R12
R0402_SR_10K_0_R0402_S_680E680EIC1R14
R0402_SR_0.2K_0603_R0402_S_2.2K2.2KIC37R15; R52; R56; R60; R73; R77; R81; R100; R102; R133; R135; R140; R144; R148; R159; R163; R167; R226; R230; R234; R246; R249; R253; R312; R316; R320; R332; R335; R339; R387; R396; R418; R419; R426; R427; R437; R459
R0402_SR_0E_1_R0402_S_0E0EIC48R22; R54; R57; R61; R63; R78; R79; R92; R105; R142; R145; R149; R151; R164; R165; R174; R175; R178; R185; R186; R188; R191; R220; R222; R228; R231; R235; R237; R250; R251; R277; R307; R314; R317; R321; R323; R336; R337; R346; R363; R383; R386; R428; R431; R432; R436; R449; R472
R0402_SR_0E_1_R0402_S_680E680EIC1R23
R0402_SR_100K_1_R0402_S_10K10KIC1R24
R0402_SR_100K_1_R0402_S_47K47KIC1R25
R0402_SR_33E_0402_R0402_S_1.6K1.6KIC1R26
R0402_SR_22E_0402_R0402_S_22E22EIC102R36; R43; R45; R47; R48; R49; R50; R51; R53; R55; R58; R59; R62; R64; R65; R66; R67; R68; R69; R71; R72; R75; R80; R82; R93; R96; R103; R104; R106; R109; R134; R137; R138; R139; R141; R143; R146; R147; R150; R152; R153; R154; R155; R156; R157; R161; R166; R168; R179; R182; R189; R190; R192; R194; R219; R223; R224; R225; R227; R229; R232; R233; R236; R238; R239; R240; R241; R242; R243; R245; R252; R254; R265; R268; R275; R276; R278; R280; R306; R309; R310; R311; R313; R315; R318; R319; R322; R324; R325; R326; R327; R328; R329; R331; R338; R340; R351; R354; R361; R362; R364; R368
R0402_SR_33E_0402_R0402_S_1K1KIC24R38; R74; R136; R160; R221; R247; R308; R333; R398; R399; R401; R402; R404; R405; R407; R408; R412; R413; R415; R416; R420; R421; R423; R424
R0402_SR_68E_0_R0402_S_68E68EIC8R76; R84; R162; R170; R248; R256; R334; R342
R0402_SR_0E_1_R0402_S_287E287EIC16R85; R86; R94; R95; R171; R172; R180; R181; R257; R258; R266; R267; R343; R344; R352; R353
R0402_SR_33E_0402_R0402_S_221E221EIC16R87; R89; R97; R98; R173; R176; R183; R184; R259; R260; R269; R270; R345; R348; R355; R356
R0402_SR_33E_0402_R0402_S_10E10EIC10R91; R101; R177; R187; R263; R273; R349; R359; R462; R464
R0402_SR_33E_0402_R0402_S_2M2MIC5R110; R195; R281; R366; R471
R0402_SR_0E_1_R0402_S_1K1KIC5R113; R199; R285; R371; R473
R0402_SR_33E_0402_R0402_S_22E22EIC4R114; R200; R286; R372
R0402_SR_33E_0402_R0402_S_15K15KIC4R115; R201; R287; R373
R0402_SR_33E_0402_R0402_S_22K22KIC4R116; R202; R288; R374
R0402_SR_33E_0402_R0402_S_0E0EIC4R117; R203; R289; R375
R0402_SR_33E_0402_R0402_S_68E68EIC4R118; R206; R292; R378
R0402_SR_33E_0402_R0402_S_470E470EIC16R119; R121; R122; R123; R204; R205; R208; R209; R290; R291; R294; R295; R376; R377; R380; R381
R0402_SR_33E_0402_R0402_S_120E120EIC4R120; R207; R293; R379
R0402_SR_33E_0402_R0402_S_51K51KIC4R124; R210; R296; R382
R0402_SR_100E_0402_R0402_S_3.74K3.74KIC1R388
R0402_SR_33E_0402_R0402_S_8.25K8.25KIC1R389
R0402_SR_33E_0402_R0402_S_10K10KIC4R390; R461; R463; R465
R0402_SR_0.2K_0603_R0402_S_10K10KIC1R391
R0402_SR_10K_0_R0402_S_316K316KIC1R393
R0402_SR_100E_0402_R0402_S_665K665KIC1R395
R0402_SR_33E_0402_R0402_S_75E75EIC8R400; R403; R406; R409; R414; R417; R422; R425
R0402_SR_10K_0_R0402_S_0E0EIC1R410
R0402_SR_100E_0402_R0402_S_0E0EIC1R411
R0402_SR_0E_1_R0402_S_100K100KIC1R456
R0402_SR_0E_1_R0402_S_1M1MIC1R457
R0402_SR_33E_0402_R0402_S_45.3K45.3KIC1R460
R0805R_0E_1_R0805_0E0EIC4R16; R17; R90; R305
R0805R_0E_1_R0805_180K180KIC1R458
RF_FIL_SAANP3LP_COILCRAFT_2_RF_FIL_SAAN_P3P3LPIC1U56
S20_5PRFXF8553_0_S20_5P_RFXF8553RFXF8553IC4U16; U27; U38; U49
SC70_5PTPS71701DCKR_SC70_5P_TPS71701DCTPS71701DCKRIC2U31; U32
SM-46-8PINMACOOMMAPD-007246-ES4700_SM-46-MAPD-007246-ES4700IC1U50
SOIC_8L_UDFN_0P524C128N-108U-2.7AT24C128C-MAIC5U3; U7; U18; U29; U40
SOP_8L_150W_50PAT25640_0_SOP_8L_150W_50P_MX25LMX25L5121EMC-20GIC1U5
SOT-323BAV99W_0_SOT-323_BAV99WBAV99WIC1D20
SOT-533SN74AUP1G08_3_SOT-533_SN74AUP1GSN74AUP1G08IC1U2
SOT_223TLV1117-33CDCYR_0_SOT_223_TLV11TLV1117LV30DCYRIC1U33
TP_62_36TP_TH_0_TP_62_36_TP_THTP_THIC8AGND1; AGND2; AGND3; AGND4; DGND1; DGND2; DGND3; DGND4
TP_REC_STP_TH_0_TP_REC_S_TP_TH_0TP_TH_0IC4T1; T2; T3; T4
TP_SMDTP_TH_0_TP_SMD_TP_TH_0TP_TH_0IC10TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10
WSON_6PLP38691_0_WSON_6P_LP38691SDLP38691SDIC1U59
WSON_10L_0P5LMR10530Y_1_WSON_10L_0P5_LMR105LMR10530YSDIC2U53; U54
附件:
* w1 P2 u: B$ A/ ]; p; E$ YPCB文件如下:
8 F  l- i  X, M: g3 R) s% ]5 R
游客,如果您要查看本帖隐藏内容请回复
( {( ^+ B8 P, ?5 h- }( }1 V# K: p9 D& H1 y+ d% ]/ N! U
GMT+8, 2025-7-23 22:22 , Processed in 0.140625 second(s), 28 queries , Gzip On.
