查看: 221|回复: 1
[allegro16.6][6层] OMAP-L138参考板(OMAPL138ZWT+TVP5147M1PFP+DDR)原理图和pcb...
发表于 2020-2-5 19:41 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][6层] OMAP-L138参考板(OMAPL138ZWT+TVP5147M1PFP+DDR)原理图和pcb文件
+ u# H5 c% U7 v! \! K4 ?
- j+ c! B$ {" n4 f文件描述:9 H9 S9 B: K) |, {9 T- d7 h
" }, G$ O9 ^0 {, B& U7 ]7 p1. 作品用途: OMAP-L138参考板
" ]4 Y/ L& v% I) Y  W- c9 e% D, W! C0 K2. 软件版本:allegro16.6
! g, e$ Q; E6 ?3 n8 O3. 层数:6层8 H7 U) i2 |0 T
4. 用到的主要芯片:OMAPL138ZWT+TVP5147M1PFP+DDR: D2 D6 o. @. U6 U+ U7 I5 n2 [
5. pcb尺寸: 4807*3500 MIL/ m( M2 C2 R7 v3 g
7 R' q" x6 @6 g+ H5 o
作品截图如下:
: x  p  }* I1 \
9 d' {0 H2 p) r) o顶层截图:/ \# Y3 T! r" U5 z% q
0 v- r, ^- S  A1 N3 X底层截图:! e$ q- z; U) P4 v
0 |2 ^) N; t: H
2 d: }) @8 A' r7 M1 n1 V; f# o全层截图:
0 H( a- [# x  Z! s$ }1 C9 l8 U+ X4 P( S, Z4 L9 F$ q" v
- b8 B; y2 U8 j8 w/ j3 W: r, JBOM:
% Q3 }# W; Z) h1 b% |% ^
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
402CAPACITOR NON-POL_0402_0.22UF/50.22uF/50V X7RIC1C25
402CAPACITOR NON-POL_0402_0.1UF/500.1uF/50V X7RIC34C35; C36; C37; C38; C39; C40; C41; C42; C43; C44; C50; C51; C52; C53; C54; C55; C57; C58; C59; C61; C62; C64; C65; C67; C68; C70; C71; C72; C73; C74; C75; C77; C78; C79
402R_0402_10K/1% 1/10W10K/1% 1/10WIC1R59
603CAPACITOR NON-POL_0603_0.1UF/500.1uF/50V X7RIC62C3; C4; C20; C21; C23; C24; C27; C28; C29; C31; C32; C56; C60; C66; C76; C82; C119; C121; C125; C127; C129; C132; C134; C136; C138; C139; C146; C147; C148; C149; C150; C151; C152; C153; C154; C155; C156; C157; C158; C159; C160; C161; C162; C164; C165; C166; C167; C168; C169; C172; C176; C182; C185; C186; C187; C188; C189; C190; C193; C207; C222; C257
603CAPACITOR NON-POL_0603_1UF/16V1uF/16V X7RIC3C7; C18; C181
603CAPACITOR NON-POL_0603_2.2UF/162.2uF/16V X7RIC3C15; C16; C17
603CAPACITOR NON-POL_0603_0.22UF/50.22uF/50V X7RIC1C26
603CAPACITOR NON-POL_0603_0.01UF/50.01uF/50V X7RIC13C34; C46; C90; C91; C92; C93; C120; C122; C126; C128; C130; C133; C135
603CAPACITOR NON-POL_0603_10PF/50V10pF/50V NPOIC1C47
603CAPACITOR NON-POL_0603_22PF/50V22pF/50V NPOIC6C84; C85; C86; C142; C143; C219
603CAP NP_0603_1UF/16V X7R1uF/16V X7RIC1C144
603CAPACITOR NON-POL_0603_330PF/10330pF/100V X7RIC1C163
603CAPACITOR NON-POL_0603_0.47UF/50.47uF/50V X7RIC2C173; C175
603CAPACITOR NON-POL_0603_220PF/50220pF/50V NPOIC2C174; C177
603CAP NP_1_0603_0.1UF/50V X7R0.1uF/50V X7RIC1C180
603CAPACITOR_0603_0.1UF/50V X7R0.1uF/50V X7RIC2C200; C201
603CAPACITOR NON-POL_0603_33PF/50V33pF/50V NPOIC2C202; C203
603CAPACITOR NON-POL_0603_0.1UF0.1uFIC3C208; C209; C223
603CAPACITOR NON-POL_0603_103103IC4C211; C212; C213; C214
603CAP_0402_0.1UF_X5R_10V_0603_0.10.1uF/50V X7RIC1C215
603CAP NP_0603_104104IC3C221; C255; C256
603R_0603_10K, 5%10K, 5%IC1R30
805CAP POL_0805_10UF/16V X5R10uF/16V X5RIC17C1; C2; C5; C6; C8; C9; C10; C11; C12; C13; C14; C22; C178; C179; C184; C191; C199
805CAPACITOR NON-POL_0805_10UF/50V10uF/50V X7RIC1C19
805CAPACITOR NON-POL_0805_10UF/16V10uF/16V X5RIC10C30; C33; C45; C48; C49; C63; C69; C80; C170; C171
805INDUCTOR_0805_MMZ2012S121AMMZ2012S121AIC12FB1; FB2; FB3; FB4; FB5; FB9; FB10; FB11; FB14; FB15; FB16; FB18
BATTERYBATTERY_0_BATTERY_BATTERY HL, DBATTERY Hl, DNIIC1BH1
BGA84_R9_P8MT47H64M16HR _1_BGA84_R9_P8_K4TK4T1G164QF-BCF8IC1U17
BGA361_W19_P8_16X16OMAP-L138_0_BGA361_W19_P8_16X16OMAPL138ZWTIC1U7
C0805CAPACITOR NON-POL_C0805_10UF/1610uF/16V X5RIC3C123; C124; C131
CON2X100P-14_V6CON14AP_1_CON2X100P-14_V6_7245472454-014LFIC1J6
CON36UPSMD_P5MMCONN FLEX 36_0_CON36UPSMD_P5MM_52559-3652IC1J16
DBVSN74LVC1G11_DBV_SN74LVC1G11DBVRSN74LVC1G11DBVRIC1U11
DBV574LVC1G126DBV_0_DBV5_74LVC1G12674LVC1G126DBVIC1U27
DIP-10SW DIP-5/SM_DIP-10_SW DIP-5/SMSW DIP-5/SMIC1SW1
IDC10CON10A_IDC10_CON10ACON10AIC1J19
IDC40-2HEADER 20X2_IDC40-2_HEADER 20X2HEADER 20X2IC2J14; J15
IMP811SIMP811S_IMP811S_IMP811SIMP811SIC1U1
IND3P4SMD_5SQINDUCTOR IRON_IND3P4SMD_5SQ_2.22.2uH/1.7AIC2L1; L3
IND3P4SMD_5SQINDUCTOR IRON_IND3P4SMD_5SQ_3.33.3uH/2.6AIC1L2
K9F2G08K9F2G08_K9F2G08_K9F2G08K9F2G08IC1U18
LAN8710TPS650250_3_LAN8710_TPS650250RHTPS650250RHBRIC1U3
LAN8710FT232RQ_LAN8710_FT232RQFT232RQIC1U8
LAN8710CDCM61001RHBT_0_LAN8710_CDCM610CDCM61001RHBTIC1U9
LAN8710LAN8700_SMALL_0_LAN8710_LAN8710LAN8710A-EZKIC1U23
MICROSDMICROSD_MICROSD_MICROSDMICROSDIC1J4
MINIUSBMINI-USB-AB-SOCKET_2_MINIUSB_5656579-0576IC2J2; J3
POWERCONN_PWRJACK_RAPC712_POWER_POWEPower Jack RAPC712IC1J1
PQFP80_25VTVP5146M2_1_PQFP80_25V_TVP5147MTVP5147M1PFPIC1U21
R0603R_R0603_1E/5%/1/10W1E/5%/1/10WIC1R3
R0603R_R0603_576K/1% 1/10W576K/1% 1/10WIC1R6
R0603R_R0603_4.7K/5% 1/10W4.7K/5% 1/10WIC29R7; R10; R11; R15; R22; R23; R24; R25; R26; R34; R35; R36; R37; R38; R39; R40; R103; R104; R105; R106; R125; R141; R143; R145; R148; R163; R170; R188; R189
R0603R_R0603_499K/1% 1/10W499K/1% 1/10WIC1R8
R0603R_R0603_330E/1% 1/10W330E/1% 1/10WIC1R9
R0603R_R0603_5.6K/1% 1/10W5.6K/1% 1/10WIC1R12
R0603R_R0603_0E0EIC1R13
R0603R_R0603_1.4K/1% 1/10W1.4K/1% 1/10WIC1R14
R0603R_R0603_0, DNI0, DNIIC2R16; R31
R0603R_R0603_200K/1% 1/10W200K/1% 1/10WIC1R17
R0603R_R0603_160K/1% 1/10W160K/1% 1/10WIC1R18
R0603R_R0603_300K/1% 1/10W300K/1% 1/10WIC1R19
R0603R_R0603_60K/1% 1/10W60K/1% 1/10WIC1R20
R0603R_R0603_1K/1% 1/10W1K/1% 1/10WIC4R27; R28; R123; R124
R0603RESISTOR_R0603_0E/5% 1/10W0E/5% 1/10WIC2R29; R81
R0603R_R0603_49.9E/1% 1/10W49.9E/1% 1/10WIC5R33; R165; R166; R167; R168
R0603R_R0603_10K/1% 1/10W10K/1% 1/10WIC11R41; R52; R55; R57; R58; R65; R86; R89; R96; R97; R274
R0603RESISTOR_R0603_10K, DNI10K, DNIIC1R42
R0603R_R0603_10K/5% 1/10W10K/5% 1/10WIC3R49; R50; R329
R0603R_R0603_0E/5% 1/10W0E/5% 1/10WIC4R53; R187; R205; R208
R0603R_R0603_100E/1% 1/10W100E/1% 1/10WDISCRETE11R60; R172; R173; R174; R175; R177; R178; R179; R182; R183; R184
R0603R_R0603_4.7K4.7KIC9R61; R62; R63; R275; R276; R277; R278; R279; R280
R0603R_R0603_5.6K/1%5.6K/1%IC1R75
R0603R_R0603_1K/5% 1/10W1K/5% 1/10WIC4R82; R83; R84; R85
R0603R_R0603_330R330RIC2R87; R88
R0603RESISTOR_R0603_33E/5% 1/10W33E/5% 1/10WIC3R94; R95; R164
R0603R_R0603_4.7K/5%4.7K/5%IC2R137; R139
R0603R_R0603_100K/1% 1/10W100K/1% 1/10WIC1R142
R0603R_R0603_4.7K, DNI4.7K, DNIIC1R149
R0603R_R0603_2K/5% 1/10W2K/5% 1/10WIC2R150; R151
R0603R_R0603_20K/1% 1/10W20K/1% 1/10WIC2R156; R157
R0603R_R0603_2K/1% 1/10W2K/1% 1/10WIC2R158; R159
R0603R_R0603_1.5K/1% 1/10W1.5K/1% 1/10WIC2R169; R171
R0603R_R0603_10E/5% 1/10W10E/5% 1/10WIC1R185
R0603RESISTOR_R0603_12.1K/1% 1/10W12.1K/1% 1/10WIC1R186
R0603R_R0603_1M/5% 1/10W1M/5% 1/10WIC1R191
R0603R_R0603_10K10kIC5R204; R220; R221; R281; R287
R0603R_R0603_OR, DNIOR, DNIIC2R206; R209
R0603RESISTOR_R0603_330R330RIC2R210; R211
R0603RESISTOR_R0603_0, DNI0, DNIIC6R214; R215; R216; R217; R218; R219
R0603R_R0603_1K1KIC3R222; R223; R288
R0603RESISTOR_R0603_22E/1% 1/10W22E/1% 1/10WIC3R269; R271; R272
R0603R_R0603_75E/5% 1/10W75E/5% 1/10WIC1R273
R0603R_R0603_330E/5% 1/10W330E/5% 1/10WIC2R284; R285
R0603R_R0603_0R0RIC1R286
R0603RESISTOR_R0603_10K10kIC2R327; R328
RJ45-AUTOETHERNET CONNECTER_RJ45-AUTO_1313F-64GYD2PL2NLIC1CON19
SATA-7P8 HEADER_0_SATA-7P_SD-67491-002SD-67491-002IC1J7
SAUDIOPHONEJACK STEREO SW_SAUDIO_LINELINEINIC1J10
SAUDIOPHONEJACK STEREO SW_SAUDIO_MICMICIC1J11
SAUDIOPHONEJACK STEREO SW_SAUDIO_PHPHPHPHONEIC1J17
SMD4R4R_SMD4R_4R4RIC1R48
SMD4R4R_SMD4R_1K1KIC1R74
SMD4R4R_SMD4R_10K10KIC1R80
SMD4R4R_SMD4R_4.7K4.7KIC2R282; R283
SMDKEYSW MAG-SPST_SMDKEY_SW MAG-SPSTSW MAG-SPSTIC4RST; S1; S2; S3
SMDLCDCON32_SMDLCD_CON32CON32IC1J18
SMDLEDLED_5_SMDLED_LEDLEDIC1D3
SMDLEDLED_6_SMDLED_LEDLEDIC1D4
SMDLEDLED_7_SMDLED_LEDLEDIC1D5
SMDLEDLED_2_SMDLED_LEDLEDIC1D6
SMDLEDLED_3_SMDLED_LEDLEDIC1D7
SOP824CXX_SOP8_24CXX24CXXIC1U26
SOT23_3DIODE ZENER_1_SOT23_3_BZX84B5V1BZX84B5V1LT1GIC1D1
SOT23_32N1613_1_SOT23_3_MMBT3904LT1GMMBT3904LT1GIC4Q1; Q2; Q3; Q4
SST25VF016BSST25VF016B_SST25VF016B_SST25VFSST25VF016BIC1U25
SXTOSC4/SM_0_SXT_CB3LV-3I-24M5760CB3LV-3I-24M5760IC1Y5
SXT-0301CRYSTAL_SXT-0301_32768HZ32768HzIC1Y8
SXT-0305CRYSTAL25MHZABM3_SXT-0305_25MHZ25MHzIC2Y1; Y6
SXT-0305CRYSTAL_5_SXT-0305_ECS-143-20-5ECS-143-20-5P-TRIC1Y4
SXT-0305CRYSTAL_SXT-0305_24M24MIC1Y9
TLV3106TLV320AIC3106_5_TLV3106_TLV320ATLV320AIC3106IRGZIC1U22
TPTEST POINT_TP_TEST POINTTEST POINTIC111.2V; 1.8V; 1V3; 1V8; 3V3; 5V; GND; TP10; TP11; TP13; TP18
TPS2051TPS2051_TPS2051_TPS2051TPS2051IC1U29
TSC2046TSC2046IPW_TSC2046_TSC2046IPWTSC2046IPWIC1U31
TVBNC_TV_BNCBNCIC1J9
USB_A_SHCONN_54819-0578_2_USB_A_SH_IO_UUSB-A Conn. - 87520-xx1xxIO1J5
附件:
8 m' K* `7 V& d; o( r% F; K2 _原理图和PCB文件如下:
! w9 L' ~8 C# R
游客,如果您要查看本帖隐藏内容请回复
9 D  o, j7 }  g6 M
发表于 2020-3-30 00:30 | 只看该作者
GMT+8, 2025-7-28 01:48 , Processed in 0.125000 second(s), 29 queries , Gzip On.
