查看: 290|回复: 1
[allegro16.6][6层] OMAP-L138参考板(OMAP-L138+LAN8710A-EZK+TVP5147M1PFP)pcb...
发表于 2020-2-5 19:34 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
9 p' i! |7 i$ H6 v
[allegro16.6][6层] OMAP-L138参考板(OMAP-L138+LAN8710A-EZK+TVP5147M1PFP)pcb文件
& X/ B( s+ O; d
+ ]6 O# K1 L5 b0 J文件描述:
' G  }% k7 ^" U' ^" p0 ?+ m0 d) R4 I% K* x; d8 |, p
1. 作品用途: OMAP-L138参考板
0 r% i* T# O, H- I/ F; v1 G' ^; g9 ~2. 软件版本:allegro16.6
2 Y  v! F& R# @( N# J1 _3. 层数:6层1 Y' g7 f8 h8 a. p: }
4. 用到的主要芯片:OMAP-L138+LAN8710A-EZK+TVP5147M1PFP
4 g0 V4 W3 j' x0 h: G5. pcb尺寸: 8937.01*6296.72 MIL
2 R- m( f/ N, t/ j3 r5 g' t  |6 T# k- t( q6 z+ h, P
作品截图如下:
) u; P+ y; B$ L* I5 _( ^
0 K% e0 N. Z( Y" j  y顶层截图:2 p9 K" _9 I. S, g9 e: ^
/ Z/ t9 C* _1 \( t* Y
底层截图:+ \/ K3 z) o  A
; o3 v& n2 V) y, ^& [( v. C- y, V% s; j
( t; F( I- S9 _3 U. ~9 ]全层截图:1 n1 u& o0 ^" N5 D% e
2 ^/ A8 {8 O' T" ~5 U* Y
. e0 R& y# K& v% Q7 q' p: A叠层阻抗信息如下:! z3 D+ y- g8 D& \
( f: J4 i" z+ R) F. E! _( L
BOM:
1 }: j/ D1 O' v/ J2 _1 k& ^
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BATTERYBATTERY_0_BATTERY_BATTERY HLBATTERY HlIC1BH1
BGA361OMAP-L138_0_BGA361_OMAP-L138OMAP-L138IC1U6
BGA-63K9F1208R0C_8_BGA-63_MT29F1G08ABMT29F1G08ABCHC:CIC1U17
BGA-DDR2MT47H64M16HR _1_BGA-DDR2_MT47H6MT47H64M16HR-3 ITIC1U16
C0402CAPACITOR NON-POL_C0402_0.1UF/50.1uF/50V X7RIC116C3; C19; C20; C21; C22; C23; C24; C25; C28; C29; C30; C32; C33; C35; C36; C37; C38; C39; C40; C41; C42; C43; C44; C45; C47; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C62; C63; C65; C66; C67; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C85; C88; C95; C96; C97; C98; C100; C101; C102; C103; C104; C105; C107; C108; C117; C118; C119; C121; C125; C127; C129; C132; C134; C136; C137; C139; C140; C143; C144; C145; C146; C147; C148; C149; C150; C151; C152; C153; C154; C155; C156; C157; C158; C159; C160; C161; C162; C163; C165; C166; C167; C168; C169; C170; C173; C175; C181; C182; C184; C185; C186; C187; C188; C189; C192
C0402CAP NP_C0402_0.1UF/50V X7R0.1uF/50V X7RDISCRETE5C4; C91; C92; C93; C94
C0402CAPACITOR NON-POL_C0402_0.22UF/0.22uF/50V X7RIC2C26; C27
C0402CAPACITOR_C0402_0.1UF/50V X7R0.1uF/50V X7RIC5C69; C70; C138; C202; C203
C0402CAPACITOR NON-POL_C0402_33PF/5033pF/50V NPOIC3C106; C111; C114
C0402CAPACITOR NON-POL_C0402_100PF/5100pF/50V NPOIC3C109; C112; C115
C0402CAPACITOR NON-POL_C0402_270PF/5270pF/50V NPOIC3C110; C113; C116
C0402CAPACITOR NON-POL_C0402_0.01UF/0.01uF/50V X7RIC8C120; C122; C126; C128; C130; C133; C135; C141
C0402CAP NP_1_C0402_0.1UF/50V X7R0.1uF/50V X7RIC1C179
C0603CAP POL_C0603_1UF/16V/X7R1uF/16V/X7RIC2C7; C180
C0603CAPACITOR NON-POL_C0603_10PF/_110pF/50V X7RIC1C48
C0603CAPACITOR NON-POL_C0603_18PF/5018pF/50V NPOIC2C83; C84
C0603CAPACITOR NON-POL_C0603_33PF/5033pF/50V/COGIC4C86; C87; C199; C200
C0603CAPACITOR NON-POL_C0603_27PF/5027pF/50V X7RIC4C89; C90; C171; C172
C0603CAPACITOR NON-POL_C0603_1UF/16V1uF/16V/X7RIC3C99; C142; C191
C0603CAPACITOR NON-POL_C0603_330PF/1330pF/100V X7RIC1C164
C0603CAP NP_C0603_220PF/50V X7R220pF/50V X7RIC2C174; C176
C0603CAPACITOR NON-POL_C0603_10PF/5010pF/50V COGIC4C193; C194; C195; C196
C0603CAPACITOR_C0603_0.022UF/50V X7R0.022uF/50V X7RIC1C197
C0603CAPACITOR_C0603_0.1UF/50V X7R0.1uF/50V X7RIC1C205
C0805CAP POL_C0805_10UF/16V X5R10uF/16V X5RIC14C1; C2; C5; C6; C8; C9; C10; C11; C12; C13; C14; C183; C190; C201
C0805CAP POL_C0805_2.2UF/16V X7R2.2uF/16V X7RIC3C15; C16; C17
C0805CAP POL_C0805_1UF/16V/X7R1uF/16V/X7RIC1C18
C0805CAPACITOR NON-POL_C0805_10UF/1610uF/16V X5RIC11C31; C34; C46; C49; C50; C64; C68; C81; C123; C124; C131
C1206CAPACITOR NON-POL_C1206_4.7UF/24.7uF/25V X5RIC1C82
C1206C_C1206_1000PF/2KV X7R1000pF/2KV X7RIC2C198; C204
CAPT6032NFUSE_CAPT6032N_1500MA1500mAIC1F1
CC1206PR_CC1206P_1.0OHM 2W1.0ohm 2WIC1R2
CON2X100P-14CON14AP_0_CON2X100P-14_72454-0172454-014LFIC1J6
CSM-7CRYSTAL_4_CSM-7_CS10-24.000MABJCS10-24.000MABJ-UTIC1Y3
CSM-7CRYSTAL_5_CSM-7_CS10-14.31818MACS10-14.31818MABJ-UTIC1Y4
CSM-7CRYSTALL_0_CSM-7_CS10 25.000MABCS10 25.000MABJ-UTIC1Y6
DB9-HFDSUB9-MALE_DB9-HF_190-009-163R0190-009-163R001IC1J3
DBVNC7WZ16P6X_1_DBV_SN74LVC2G34DBVSN74LVC2G34DBVRIC1U9
DBVSN74LVC1G11_DBV_SN74LVC1G11DBVRSN74LVC1G11DBVRIC1U10
DCUSN74LVC2T45DCUT_DCU_SN74AVCH2T4SN74AVCH2T45DCURIC1U11
DCUSN74LVC2T45DCUT_DCU_SN74LVC2T45SN74LVC2T45DCURIC1U13
DCUTXS0102DCUR_DCU_TXS0102DCURTXS0102DCURIC1U15
DIP8SW DIP-4_0_DIP8_MGDH04MGDH04IC1SW1
F0805INDUCTOR_F0805_MMZ2012S121AMMZ2012S121AIC27FB1; FB2; FB3; FB4; FB5; FB6; FB7; FB8; FB9; FB10; FB11; FB12; FB13; FB14; FB15; FB16; FB17; FB18; FB19; FB20; FB21; FB22; FB23; FB24; FB25; FB26; FB27
FSXCRYSTAL_6_FSX_FSX327LFFSX327LFIC1Y2
HDR50X2CONN PCB 50X2-S_HDR50X2_GRPB502GRPB502VWQP-RCIC1J13
L0805INDUCTOR_L0805_1UH/80MA1uH/80mAIC3L4; L5; L6
LED0805LED_LED0805_LED-GLED-GIC6LED1; LED2; LED3; LED4; LED5; LED6
LQFP48THS8135PHP_8_LQFP48_THS8135PFPTHS8135PFPIC1U12
MINIUSB-5PFMINI-USB-AB-SOCKET_2_MINIUSB-5PSD-56579-015IC1J2
MSOP8TPS2087_0_MSOP8_TPS2068DGNRTPS2068DGNRIC1U3
OSC_7X5OSC4/SM_0_OSC_7X5_CB3LV-3I-24M5CB3LV-3I-24M5760IC1Y5
OSC_SATAECS-250-20-33-A-E-L-TR_2_OSC_SAECS-250-20-33-A-E-L-TRIC1Y1
PE_RES_0402_3P_OPTIONJUMPER_0_PE_RES_0402_3P_OPTION_1K/1% 1/10WIC1R22
POWERJACKKLDX-0202-AC_1_POWERJACK_PJ-002PJ-002AIC1J1
PQFP80TVP5146M2_1_PQFP80_TVP5147M1PFPTVP5147M1PFPIC1U20
PULSE_H2019S558-5999-46_2_PULSE_H2019_HX11HX1188NLIC1TFR1
QFN32TPS650250_3_QFN32_TPS650250RHBRTPS650250RHBRIC1U5
QFN32CDCM61001RHBT_0_QFN32_CDCM61001CDCM61001RHBTIC1U8
QFN32LAN8700_SMALL_0_QFN32_LAN8710A-LAN8710A-EZKIC1U22
QFN48TLV320AIC3106_5_QFN48_TVL320AICTVL320AIC3106RGZIC1U21
R0402R_R0402_220E/5% 1/10W220E/5% 1/10WIC1R1
R0402R_R0402_3.4K/1% 1/10W3.4K/1% 1/10WIC2R3; R120
R0402R_R0402_1K/1% 1/10W1K/1% 1/10WIC9R4; R28; R33; R34; R43; R44; R128; R129; R153
R0402RESISTOR_R0402_0E/5% 1/10W0E/5% 1/10WIC19R5; R6; R58; R104; R105; R106; R107; R108; R109; R110; R111; R112; R113; R114; R115; R118; R119; R125; R126
R0402R_R0402_10K/1% 1/10W10K/1% 1/10WIC30R7; R8; R54; R59; R60; R63; R64; R65; R66; R67; R69; R70; R71; R73; R77; R78; R79; R80; R81; R82; R83; R84; R85; R86; R87; R88; R89; R92; R99; R100
R0402R_R0402_4.7K/5% 1/10W4.7K/5% 1/10WIC43R9; R10; R13; R16; R17; R19; R20; R23; R29; R30; R31; R32; R35; R36; R37; R39; R45; R46; R47; R48; R49; R50; R51; R57; R101; R102; R103; R116; R117; R130; R136; R143; R145; R146; R147; R149; R151; R154; R155; R167; R175; R191; R192
R0402R_R0402_1E/5%/1/10W1E/5%/1/10WIC1R11
R0402R_R0402_100K/1% 1/10W100K/1% 1/10WIC3R12; R14; R148
R0402R_R0402_330E/1% 1/10W330E/1% 1/10WIC1R15
R0402R_R0402_5.6K/1% 1/10W5.6K/1% 1/10WIC1R18
R0402R_R0402_1.4K/1% 1/10W1.4K/1% 1/10WIC1R21
R0402R_R0402_200K/1% 1/10W200K/1% 1/10WIC1R24
R0402R_R0402_160K/1% 1/10W160K/1% 1/10WIC1R25
R0402R_R0402_300K/1% 1/10W300K/1% 1/10WIC1R26
R0402R_R0402_60K/1% 1/10W60K/1% 1/10WIC1R27
R0402R_R0402_1.18K/1% 1/10W1.18K/1% 1/10WIC1R38
R0402R_R0402_680E/5% 1/10W680E/5% 1/10WIC2R40; R41
R0402RESISTOR_R0402_100E/1% 1/10W100E/1% 1/10WIC1R52
R0402R_R0402_100E/1% 1/10W100E/1% 1/10WIC18R53; R68; R72; R76; R93; R94; R95; R96; R177; R178; R179; R180; R181; R182; R183; R184; R187; R188
R0402RESISTOR_R0402_10K/1% 1/10W10K/1% 1/10WIC1R55
R0402R_R0402_0E/5% 1/10W0E/5% 1/10WIC6R56; R61; R62; R150; R173; R190
R0402R_R0402_330E/5% 1/10W330E/5% 1/10WIC2R90; R91
R0402RESISTOR_R0402_33E/5% 1/10W33E/5% 1/10WIC3R97; R98; R168
R0402R_R0402_75E/5% 1/10W75E/5% 1/10WIC3R121; R122; R127
R0402RESISTOR_R0402_2.2K/1% 1/10W2.2K/1% 1/10WIC2R123; R124
R0402RESISTOR_R0402_22E/1% 1/10W22E/1% 1/10WDISCRETE9R131; R132; R133; R134; R135; R139; R140; R141; R142
R0402RESISTOR_R0402_10E/1% 1/10W10E/1% 1/10WDISCRETE2R137; R138
R0402RESISTOR_R0402_4.7K/5% 1/10W4.7K/5% 1/10WIC1R144
R0402R_R0402_20K/1% 1/10W20K/1% 1/10WIC4R152; R160; R161; R165
R0402R_R0402_5.6K/5% 1/10W5.6K/5% 1/10WIC4R156; R157; R158; R159
R0402R_R0402_2K/1% 1/10W2K/1% 1/10WIC4R162; R163; R164; R166
R0402R_R0402_49.9E/1% 1/10W49.9E/1% 1/10WIC4R169; R170; R171; R172
R0402R_R0402_1.5K/1% 1/10W1.5K/1% 1/10WIC2R174; R176
R0402RESISTOR_R0402_75E/5% 1/10W75E/5% 1/10WIC2R185; R186
R0402RESISTOR_R0402_12.1K/1% 1/10W12.1K/1% 1/10WIC1R189
R0402R_R0402_10E/1% 1/10W10E/1% 1/10WIC1R193
R0402R_R0402_1M/5% 1/10W1M/5% 1/10WIC1R194
R0402RESISTOR_R0402_220E/5% 1/10W220E/5% 1/10WIC2R195; R202
R0402RESISTOR_R0402_49.9E/1% 1/10W49.9E/1% 1/10WIC6R196; R197; R198; R199; R200; R201
R0603R_R0603_50E/0.5% 1/8W50E/0.5% 1/8WIC1R42
R0603R_R0603_2.2K/5% 1/8W2.2K/5% 1/8WIC2R74; R75
RCACONNECTOR COAX-J_1_RCA_RCJ-014RCJ-014IC1J9
RJ45-59_LEDRJHSE-5384_0_RJ45-59_LED_2-40652-406549-4IC1J12
RN0804RESISTOR DIP 4_RN0804_4.7K/5% 14.7K/5% 1/10WIC11RP1; RP2; RP3; RP4; RP5; RP6; RP7; RP8; RP9; RP10; RP11
SATA8 HEADER_0_SATA_SD-67491-002SD-67491-002IC1J7
SDMMC4_1.0_CONN_SD_MHC-W21-601MHC-W21-601IC1J4
SIP100P2NB2S_0_SIP100P2N_JUMPER 2PJUMPER 2PIC1JP1
SMD_SWSPST W/ESD_2_SMD_SW_GSE10.00F13GSE10.00F130QPIC1S1
SOIC8TPS3705_0_SOIC8_TPS3705-33DRTPS3705-33DRIC1U1
SOIC-D16TPS2087B_SOIC-D16_TPS2087DTPS2087DIC1U2
SOP-DGG48OCT_DS_BUSTRASCEIVER_0_SOP-DGG4SN74AVC16T245DGGRIC2U14; U19
SOT23-5NC7SZ14P5X_2_SOT23-5_SN74AHC1G0SN74AHC1G04DBVRIC1U4
SOT23-5SN74LVC1G125_SOT23-5_SN74LVC1G1SN74LVC1G125DBVRIC1U18
SOT23_3DIODE ZENER_1_SOT23_3_BZX84B5V1BZX84B5V1LT1GIC1D1
SOT23_3DIODE_DUAL_RS_AJK_1_SOT23_3_BAVBAV99LT1IC1DN1
SOT23_3DIODE_DUAL_RS_AJK_2_SOT23_3_BAVBAV99LT1IC1DN2
SOT23_32N1613_1_SOT23_3_MMBT3904LT1GMMBT3904LT1GIC6Q1; Q2; Q3; Q4; Q5; Q6
SP53INDUCTOR IRON_SP53_3.3UH/2.6A3.3uH/2.6AIC1L2
SPC1608INDUCTOR IRON_SPC1608_2.2UH/1.72.2uH/1.7AIC2L1; L3
SSOP16TRS3221ECDBR_1_SSOP16_TRS3221ECTRS3221ECPWRIC1U7
STX3500KYCON ST-3500_3_STX3500_STX-350STX-3500-4NTRIC1J10
STX3500KYCON ST-3500_4_STX3500_STX-350STX-3500-4NTRIC1J11
TC7343CAPACITOR POL_0_TC7343_10UF/6.310uF/6.3V POLIC2C177; C178
TPTEST POINT_TP_TEST POINTTEST POINTIC19TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19
USB-A1-1734084-1_2_USB-A_156-1000000156-1000000901IC1J5
VGA-DB15CONN ASY CENT S/S 14_1_VGA-DB15070213FRIC1J8
附件:$ {" U; v& j  K! V
PCB文件如下:6 H, H& |  `" H( H- B8 M* X* n8 }
游客,如果您要查看本帖隐藏内容请回复
5 C  ]# N* O8 z* H( A
) L. `( h, i$ Q
发表于 2020-3-30 00:34 | 只看该作者
GMT+8, 2025-7-28 01:33 , Processed in 0.156250 second(s), 29 queries , Gzip On.
