查看: 572|回复: 5
[allegro16.6][4层] 蓝牙小板(nRF52832-QFAA-R+CE3153A420M+KX022-1020)pcb文件
发表于 2020-2-5 17:36 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
, |1 e" t& B! j
, P# G3 ?/ U# k/ ]3 F0 {
2 X* O" g7 M% L4 N: ^* B3 [/ f文件描述:
8 a8 L+ H8 K- O- D% X/ b+ \7 T7 B' O+ P1 ]& M# V
1. 作品用途:  蓝牙小板# D; J& K- e. w9 U5 S
2. 软件版本:allegro16.6
  R- ~1 F1 J1 E* @4 p' m( J/ [3. 层数:4层. _( [8 Y6 J* |+ P  ?. O  ]
4. 用到的主要芯片:nRF52832-QFAA-R+CE3153A420M+KX022-1020
( ~! P# Q; S" X5. pcb尺寸: 8937.01*6296.72 MIL* V" \$ q  k0 v0 e& C2 k
) B, Y# F) K! l7 b! y
作品截图如下:' P9 M8 e7 o4 S- [
8 H4 E" j: ^" d. Z! r: F
顶层截图:
6 J5 h/ r( ]% m6 C0 u# g ) x* L/ }+ \8 e0 F: z1 j
底层截图:
' A$ _3 Q: t$ H5 Y  \
  Q6 m. _5 ^* K6 N5 {! G3 h# S3 G0 c
全层截图:5 z& ]& p, O" b$ i3 ]- [
# ~' l" H1 G! h# Q+ F6 _. h& y) ~+ `- m: l
BOM:
& w. [  x3 r& p0 {. H
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
6P0_837P*0_0.8_6P0_83_6P*0.86P*0.8IC1CN1
ANT2ANTENNA_0_ANT2_NFC1NFC1IC1E2
ANT2ANTENNA_0_ANT2_NFC2NFC2IC1E3
AT18-AANTENNA_AT18-A_AT18-AAT18-AIC1E1
C0201CAP NP_C0201_12PF12pFIC3C2; C10; C15
C0201CAP NP_C0201_0.1UF0.1uFIC11C4; C8; C13; C14; C19; C23; C24; C25; C26; C34; C39
C0201CAP NP_C0201_20PF20PFIC2C5; C9
C0201CAP NP_C0201_100PF100pFIC2C11; C46
C0201CAP NP_C0201_NCNCIC4C12; C17; C40; C41
C0201CAP NP_C0201_0.8PF0.8pFIC1C16
C0201CAP NP_C0201_22PF22PFIC2C22; C30
C0201CAP NP_C0201_10PF10pFIC1C27
C0201CAP NP_C0201_0.01UF0.01uFIC1C28
C0402CAP NP_C0402_4.7UF4.7uFIC3C1; C20; C35
C0402CAP NP_C0402_4.7UF/10V4.7uF/10VIC1C3
C0402CAP NP_C0402_2.2UF/16V2.2uF/16VIC3C6; C7; C29
C0402CAP NP_C0402_0.1UF0.1uFIC1C32
C0402CAP NP_C0402_2.2UF/10V2.2uF/10VIC1C47
C0603CAP NP_C0603_22UF22uFIC1C18
C0603CAP NP_C0603_10UF10uFIC3C21; C37; C38
C0603CAP NP_C0603_4.7UF/16V4.7uF/16VIC2C31; C33
CAP0402CAP NP_CAP0402_4.7UF/10V4.7uF/10VIC1C44
CAP0402CAP NP_CAP0402_2.2UF/10V2.2uF/10VIC1C45
D0402DIODE BI-DIR TRIG_D0402_BTR04F1BTR04F15IC1D2
D0402DIODE BI-DIR TRIG_D0402_BTR04F0BTR04F05IC1D3
DFN1X1-4CE6232B33F_DFN1X1-4_CE6232B33FCE6232B33FIC1U4
DSBGA9TPS61254_2_DSBGA9_TPS61256YFFRTPS61256YFFRIC1U8
L0201INDUCTOR_L0201_3.9NH3.9nHIC1L3
L0201INDUCTOR_L0201_NCNCIC1L4
L0402INDUCTOR_L0402_120R@100MHZ120R@100MHZIC1FB1
L0402INDUCTOR_L0402_15NH15nHIC1L1
L0603INDUCTOR_L0603_10UH10uHIC1L2
L2016INDUCTOR_L2016_LQH2MCN100M52LQH2MCN100M52IC1L5
L2016INDUCTOR_L2016_LQM21PN1R0MC0LQM21PN1R0MC0IC1L6
LED0402LED56/TO_6_LED0402_GTG1005SURCGTG1005SURCIC1LED1
LGA12KX022-1020_LGA12_KX022-1020KX022-1020IC1U2
P2XD0_83T POINT S_P2XD0_83_VUSBVUSBIC1P1
P2XD0_83T POINT S_P2XD0_83_GNDGNDIC1P2
PAD_1T POINT S_PAD_1_VBAT-VBAT-IC1T1
PAD_1T POINT S_PAD_1_VBAT+VBAT+IC1T2
QFN48NRF52832_0_QFN48_NRF52832-QFAA-nRF52832-QFAA-RIC1U3
QG-6428TSWKG01QG-6428TSWKG01_QG-6428TSWKG01_QQG-6428TSWKG01IC1J1
R0201CAP NP_R0201_0.1UF0.1uFIC1C36
R0201RESISTOR_R0201_10K10KIC5R1; R4; R7; R12; R13
R0201RESISTOR_R0201_18.2K_1%18.2K_1%IC1R2
R0201RESISTOR_R0201_2K2KIC2R3; R18
R0201RESISTOR_R0201_1M_1%1M_1%IC3R5; R6; R9
R0201RESISTOR_R0201_680R680RIC1R8
R0201RESISTOR_R0201_196K_1%196K_1%IC1R10
R0201RESISTOR_R0201_470R470RIC1R14
R0201RESISTOR_R0201_1M 1%1M 1%IC1R16
R0201RESISTOR_R0201_160K 1%160K 1%IC1R17
R0201RESISTOR_R0201_560K560KIC1R19
R0201RESISTOR_R0201_100K100KIC1R20
R0201RESISTOR_R0201_33R33RIC1R21
R0201RESISTOR_R0201_10R10RIC1R23
R0402RESISTOR_R0402_1R1RIC1R22
R0603RESISTOR_R0603_25.5R25.5RIC1R15
SOD323DIODE_0_SOD323_1N58191N5819IC1D4
SOD523DIODE_2_SOD523_SD103AXSD103AXIC1D5
SOT23NPN BCE_0_SOT23_MMBT3904MMBT3904IC1Q1
SOT23-5XC6802A42XMR-G_SOT23-5_CE3153A4CE3153A420MIC1U1
SOT23-5TPS61046_1_SOT23-5_SGM6601SGM6601IC1U7
SOT23-6IQS211A_SOT23-6_IQS211AIQS211AIC1U6
TEST_1_0MMT POINT S_TEST_1_0MM_RXRXIC1T3
TEST_1_0MMT POINT S_TEST_1_0MM_TXTXIC1T4
TEST_1_0MMT POINT S_TEST_1_0MM_SWDIOSWDIOIC1T5
TEST_1_0MMT POINT S_TEST_1_0MM_SWDCLKSWDCLKIC1T6
TEST_1_0MMT POINT S_TEST_1_0MM_3V33V3IC1T7
TEST_1_0MMT POINT S_TEST_1_0MM_GNDGNDIC1T8
TEST_1_0MMT POINT S_TEST_1_0MM_9V9VIC1T12
TP_PT POINT S_TP_P_TOUCHKEYTouchKeyIC1P3
USON8LW25Q80BLEEK_0_USON8L_AT25SF081-AT25SF081-MAHD-TIC1U5
X2520CRYSTAL1-4/SM_0_X2520_32MHZ32MHzIC1X1
X3215CRYSTAL_X3215_32.768KHZ32.768KHzIC1X2
ZW0408TS4_4X4_4MOTOR AC_ZW0408TS4_4X4_4_FT4_4XFT4_4x4_4x8_6IC1M1
附件:) Y$ |3 x; d* Y. R
PCB文件如下:
2 E# i8 n4 ^6 A7 Y' x
游客,如果您要查看本帖隐藏内容请回复
1 [0 T7 i9 I* O, h1 t# V
7 E5 \3 E4 e$ m* A1 {3 S, }2 L
发表于 2021-11-16 16:17 | 只看该作者
感谢大神分享~: [: S) ]# D4 _6 v0 ^9 G
发表于 2021-11-16 17:27 | 只看该作者
瞧一瞧,谢谢分享
0 B8 w/ i' V. O" X% k- j
发表于 2023-6-15 14:25 | 只看该作者
蓝牙小板(nRF52832-QFAA-R+CE3153A420M+KX022-1020)pcb文件) M: [7 t3 |4 V
GMT+8, 2025-7-21 04:55 , Processed in 0.125000 second(s), 27 queries , Gzip On.
