查看: 233|回复: 0
[allegro16.6][4层] MKM34Z256CLL7参考板(MKM34Z256CLL7+AT24C32D+SPX3819M5-L)...
发表于 2020-2-4 12:17 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
. S# f6 r3 G2 A, k5 R/ n4 |% x" H
[allegro16.6][4层] MKM34Z256CLL7参考板(MKM34Z256CLL7+AT24C32D+SPX3819M5-L)pcb文件
  y) \2 ^% j2 g) h5 O# o1 l; M( c9 x
文件描述:; n" S# I# j) _
; N; A0 L, D; P, t; I' {6 w* @1. 作品用途: MKM34Z256CLL7参考板: h) S( v. [8 G3 |
2. 软件版本:allegro16.6
$ Y& G; G' s1 Y! p  J5 V2 `3. 层数:4层
6 t% x7 K6 w' {6 R, v8 D" `5 m4. 用到的主要芯片:MKM34Z256CLL7+AT24C32D+SPX3819M5-L4 M& t# c( A2 l8 g# b
5. pcb尺寸: 5177*3810 MIL
6 ~2 {$ q  v# N( s7 a, y) C+ e- j
) D/ ^- N4 K* [" U& {4 h作品截图如下:& y" ]: m7 Q; B/ O% u9 |; ?
* y* X) q8 _7 Q* v. L/ v
顶层截图:
0 A7 S1 w% |7 R7 T2 y & T; ^; B7 s. f1 F3 n0 `  F
底层截图:
- o! V. ~8 J6 P
3 L1 g& X1 L) Y% j$ f! _  q5 E- I4 d+ b; t3 P
全层截图:. z  X2 s* j0 B4 Y' G8 w7 v# A. H  k5 Z
# v' A8 B- x  @8 \/ b. x% @7 c
: {1 _9 W3 u- P叠层阻抗信息如下:: e  W4 D! W: Q: L1 r' |% a
) C! P. R# L( u. q! D
BOM:
. r2 ~7 M; L4 \
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
CAP_POL_7P5_18P5CAP_POL_CAP_POL_7P5_18P5_DISCRE4700 uFDISCRETE1C95
CASE403D_02DIODE_CASE403D_02_IC_2.41MM_480MRA4007T3GIC4D90; D91; D92; D94
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.1UFDISCRETE1C94
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9 M4.7uFDISCRETE1C96
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UFDISCRETE5C291; C382; C383; C384; C385
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.350.1UFDISCRETE17C1; C2; C3; C4; C5; C6; C7; C8; C9; C10; C11; C12; C13; C14; C281; C282; C371
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UFDISCRETE6C20; C21; C22; C23; C24; C25
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.35M1uFDISCRETE6C26; C27; C28; C29; C30; C31
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_0.7 M0.1uFDISCRETE1C92
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_322uFDISCRETE1C93
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_0.88M0.01UFDISCRETE9C201; C211; C221; C241; C242; C251; C252; C261; C262
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_0.8_10.047UFDISCRETE2C231; C232
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4MM1000pFDISCRETE3C271; C272; C273
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_12.2UFDISCRETE1C301
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4732200pFDISCRETE3C321; C361; C362
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_21.0UFDISCRETE1C381
CCE10_3X10_3CAP_POL_CCE10_3X10_3_DISCRETE_14.7uFDISCRETE2C90; C91
CON2X10F_SMT_SSWCONN_HDR_10X2_CON2X10F_SMT_SSW_CON_2X10IO1J311
CON_2X5_FTS_SMCONN_HDR_5X2_CON_2X5_FTS_SM_IO_HDR 2X5IO1J1
CON_2X6_SKT_100_SMCONN_HDR_6X2_CON_2X6_SKT_100_SMCON 2X6 SKTIO1J314
CR2032_LFBATTERY_CR2032_LF_IC_5.4 MM_801BATTERYIC1BT20
DFN_10_0P4_2X2_AMAG3112_DFN_10P_DFN_10_0P4_2X2_MAG3110IC1U381
DIODE2_2P9X1P9DIODE_DIODE2_2P9X1P9_IC_1.43MM_ES1JLIC1D95
HDR102_STAG_SMCONN_HDR_2X1_HDR102_STAG_SM_IO_HDR_1X2IO6J20; J21; J22; J316; J317; J318
HDR205_SMCONN_HDR_5X2_HDR205_SM_IO_9.65HDR_2X5IO1J301
HDR_2X8_2P54_SMHDR_2X8_M_HDR_2X8_2P54_SM_IO_10CON 2X8IO2J312; J363
IND_2012INDUCTOR_IND_2012_DISCRETE_0.851uHDISCRETE2L20; L21
IND_LPS6225IND_IND_LPS6225_DISCRETE_3.5 MM1500uHDISCRETE1L90
IND_RFB0807_THINDUCTOR_IND_RFB0807_TH_DISCRET470uHDISCRETE1L91
LCD_44P_96P5X37LCD_44P_LCD_44P_96P5X37_IC_3MM_LK-LCD-REV2IC1DS300
LED2_100_3_THLED_LED2_100_3_TH_IC_6.1 MM_370TSAL4400IC1D321
LED_2_3P85LED_LED_2_3P85_IC_5.9MM_370-765WP7104LSRDIC2D351; D352
LQFP100_0P5_14X14PKM34Z256CLL7_LQFP_100P_LQFP100MKM34Z256CLL7IC1U1
PHTRANS_4P19MMPT12_PHTRANS_2P_PHTRANS_4P19MM_OP506BIC1Q321
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_423.7KDISCRETE1R21
RC0603_OVRES_RC0603_OV_DISCRETE_470-78014.3KDISCRETE1R94
RC0603_OVRES_RC0603_OV_DISCRETE_470-78254.7MDISCRETE1R291
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_11.6MDISCRETE1R292
RC0805_OVRES_RC0805_OV_DISCRETE_470-30404.7KDISCRETE8R1; R3; R4; R5; R6; R7; R8; R34
RC0805_OVRES_RC0805_OV_DISCRETE_470-3004820DISCRETE1R2
RC0805_OVRES_RC0805_OV_DISCRETE_470-754745.3KDISCRETE1R20
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440DISCRETE7R30; R32; R36; R38; R40; R311; R313
RC0805_OVRES_RC0805_OV_DISCRETE_0.65MM_42.0KDISCRETE1R93
RC0805_OVRES_RC0805_OV_DISCRETE_470-75031.6KDISCRETE1R96
RC0805_OVRES_RC0805_OV_DISCRETE_470-774047DISCRETE3R207; R217; R227
RC0805_OVRES_RC0805_OV_DISCRETE_470-786922DISCRETE8R233; R234; R243; R244; R253; R254; R264; R265
RC0805_OVRES_RC0805_OV_DISCRETE_470-759010KDISCRETE8R271; R272; R273; R281; R282; R362; R364; R372
RC0805_OVRES_RC0805_OV_DISCRETE_470-7558390DISCRETE2R302; R307
RC0805_OVRES_RC0805_OV_DISCRETE_470-75461.0KDISCRETE2R304; R322
RC0805_OVRES_RC0805_OV_DISCRETE_470-75_14.7KDISCRETE1R305
RC0805_OVRES_RC0805_OV_DISCRETE_470-3035470DISCRETE1R306
RC0805_OVRES_RC0805_OV_DISCRETE_470-75_210.0KDISCRETE1R321
RC0805_OVRES_RC0805_OV_DISCRETE_470-7597680DISCRETE1R323
RC0805_OVRES_RC0805_OV_DISCRETE_470-7665390DISCRETE2R341; R342
RC0805_OVRES_RC0805_OV_DISCRETE_470-75491.0MDISCRETE2R361; R363
RC0805_OVRES_RC0805_OV_DISCRETE_470-75_3220KDISCRETE1R371
RC_MELF_0204RES_RC_MELF_0204_DISCRETE_470-8220KDISCRETE6R201; R202; R211; R212; R221; R222
RC_MELF_0204RES_RC_MELF_0204_DISCRETE_470_1100KDISCRETE6R203; R204; R213; R214; R223; R224
RC_MELF_0204RES_RC_MELF_0204_DISCRETE_470_21kDISCRETE3R206; R216; R226
RC_MELF_0204RES_RC_MELF_0204_DISCRETE_470_34.7DISCRETE8R231; R232; R241; R242; R251; R252; R261; R262
SO8_1P27_3P9X4P9LNK302DN_8P_SO8_1P27_3P9X4P9_ICLNK306DNIC1U90
SOD-123DIODE_SOD-123_IC_1.35MM_480-760MMSD4148T1GIC4D20; D301; D302; D303
SOP4_2P54_6P8X4P8SFH6106_4P_SOP4_2P54_6P8X4P8_ICSFH6106-4IC3U301; U302; U303
SOT23-5_ASPX3819M5_5P_SOT23-5_A_IC_1.45SPX3819M5-LIC1U20
SOT23_5SLMV321_SOT23_5S_IC_1.22MM_315-7LMV321IC1U281
SOT23_ADUALDIODE_CC_SOT23_SOT23_A_IC_1BAT54CLT1IC1D21
SOT23_ADUALDIODE_SERIES_SOT23_SOT23_A_BAV99LT1IC3D201; D211; D221
SW4_PB_ESW_SM_P177SW_PB_ESW_SW4_PB_ESW_SM_P177_ICTL3301AF160QGIC1SW371
TESTPOINT_70MILTEST PAD_TESTPOINT_70MIL_IC_0.170 MILIC19TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP201; TP211; TP221; TP231; TP232; TP241; TP242; TP251; TP252; TP261; TP262
VARISTOR_21P5X5P4MMVARISTOR_VARISTOR_21P5X5P4MM_DI20S0271DISCRETE3RV201; RV211; RV221
XTL2_ECS_SMXTAL_XTL2_ECS_SM_IC_8.84MM_230-32.768KHzIC1Y1
附件:( z; N& v8 K+ _+ B- {- X5 F" V
PCB文件如下:1 d) d3 O$ y- X1 `, e# r9 f
游客,如果您要查看本帖隐藏内容请回复
$ A3 b- {2 m# \
7 B6 U& o4 X2 ]' {4 S
GMT+8, 2025-7-23 22:14 , Processed in 0.125000 second(s), 28 queries , Gzip On.
