Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
1P8X3P5 | CRYSTAL_1P8X3P5_0.9 MM_230-3002 | 32.768KHZ | DISCRETE | 1 | Y2 |
7X5MM | O4-0_7X5MM_1.75 MM_230-75873_12 | 12MHz | IC | 1 | Y1 |
7X5MM | O4-0_7X5MM_1.9MM_230-76592_22.5 | 22.5792MHz | IC | 1 | Y4 |
0603LED_1A2C | LED_1A2C_0603LED_1A2C_1.1MM_370 | LED_GREEN | IC | 1 | D1 |
0603LED_1A2C | LED_1A2C_0603LED_1A2C_1.1MM_3_1 | LED_ORANGE | IC | 2 | D2; D4 |
0603LED_1A2C | LED_1A2C_0603LED_1A2C_0.75MM_37 | BLUE | IC | 1 | D3 |
BGA139_0P5_7X7MM | MC13892_AAPL_TO2_BGA139_0P5_7X7 | MC13892 | IC | 1 | U1 |
C035S | TEST PAD_C035S_0.005 MM_280-751 | TEST POINT | IO | 28 | TP1; TP2; TP3; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP28; TP30 |
CASE403D_02 | ZDIODE_CASE403D_02_2.41MM_480-7 | 1SMA5935B | IC | 1 | D7 |
CASE1206A-03 | NTHS2101P_8P_CASE1206A-03_1.10M | NTHS2101P | IC | 1 | Q3 |
CC0201 | CAP_NP_CC0201_0.33 MM_150-77852 | 0.22UF | DISCRETE | 30 | C34; C39; C40; C41; C47; C49; C52; C57; C102; C108; C112; C117; C120; C122; C125; C128; C130; C136; C138; C141; C147; C148; C152; C158; C169; C192; C193; C195; C196; C200 |
CC0201 | CAP_NP_CC0201_0.33MM_150-75429_ | 0.1UF | DISCRETE | 52 | C35; C36; C42; C46; C51; C55; C56; C58; C100; C105; C106; C107; C110; C118; C121; C123; C124; C131; C132; C134; C139; C140; C144; C145; C149; C150; C151; C153; C154; C163; C165; C166; C167; C170; C173; C174; C177; C178; C182; C183; C184; C185; C186; C187; C188; C191; C197; C198; C199; C203; C205; C207 |
CC0201 | CAP_NP_CC0201_0.33 MM_150-75465 | 0.01UF | DISCRETE | 26 | C37; C43; C44; C50; C54; C59; C111; C113; C114; C115; C126; C127; C129; C135; C156; C159; C160; C161; C162; C168; C172; C179; C181; C583; C584; C586 |
CC0402_25 | CAP_NP_CC0402_25_0.55MM_150-767 | 2.2UF | DISCRETE | 19 | C2; C4; C5; C11; C13; C23; C63; C71; C73; C74; C76; C80; C89; C90; C93; C95; C96; C97; C142 |
CC0402_25 | CAP_NP_CC0402_25_0.635MM_150-75 | 0.1UF | DISCRETE | 20 | C7; C20; C21; C24; C25; C29; C30; C31; C66; C72; C75; C78; C84; C92; C101; C137; C155; C189; C204; C206 |
CC0402_25 | CAP_NP_CC0402_25_0.59MM_150-766 | 18PF | DISCRETE | 4 | C15; C16; C61; C62 |
CC0402_25 | CAP_NP_CC0402_25_0.5MM_150-7518 | 0.01uF | DISCRETE | 1 | C17 |
CC0402_25 | CAP_NP_CC0402_25_0.73 MM_150-75 | 1.0UF | DISCRETE | 6 | C26; C27; C28; C69; C88; C180 |
CC0603 | CAP_NP_CC0603_1MM_150-30233_0.4 | 0.47UF | DISCRETE | 4 | C9; C12; C14; C18 |
CC0603_OV | CAP_NP_CC0603_OV_0.95MM_150-754 | 4.7UF | DISCRETE | 7 | C1; C32; C70; C81; C83; C85; C87 |
CC0603_OV | CAP_NP_CC0603_OV_1.0MM_150-7783 | 10UF | DISCRETE | 14 | C3; C6; C8; C10; C22; C65; C67; C68; C82; C86; C91; C94; C98; C99 |
CC0805 | CAP_NP_CC0805_1.27MM_150-30139_ | 10.0uF | DISCRETE | 15 | C19; C33; C38; C53; C60; C103; C104; C109; C119; C143; C146; C157; C190; C201; C202 |
CC0805_OV | CAP_NP_CC0805_OV_1.27MM_150-301 | 10.0uF | DISCRETE | 2 | C64; C77 |
CC0805_OV | CAP_NP_CC0805_OV_1.45MM_150-301 | 22UF | DISCRETE | 2 | C79; C116 |
CC1210 | CAP_NP_CC1210_2.42 MM_150-30186 | 47uF | DISCRETE | 1 | C164 |
CON_BBC_40P_0P4_SM | FX12B-40P_CON_BBC_40P_0P4_SM_1. | CONN PLUG 40 | IC | 1 | J1 |
CON_MIC38P_AMP_SM | MICTOR_38_767004_CON_MIC38P_AMP | HDR_2X19_F | IC | 1 | P1 |
CON_SEAM500_REV_NUMBERED | SEAM-10X50_CON_SEAM500_REV_NUMB | SEAM-10X50 | IO | 1 | J2 |
CSP6_0P5_1P6X1P1 | MOSFET_P_S5_D3_4_CSP6_0P5_1P6X1 | FDZ193P | IC | 2 | Q1; Q2 |
FID-040 | FID-040_FID-040_N/A_510-75177_F | FID | IC | 6 | FID1; FID2; FID3; FID4; FID5; FID6 |
IND0603_CC | BEAD_FERRITE_IND0603_CC_0.95MM_ | 120OHM | DISCRETE | 2 | L7; L15 |
IND_2P2X2 | IND_IND_2P2X2_1.4MM_180-76836_3 | 3.3UH | DISCRETE | 1 | L2 |
IND_2P2X2 | IND_IND_2P2X2_1.4MM_180-76837_1 | 1.5UH | DISCRETE | 1 | L4 |
IND_0402 | INDUCTOR_IND_0402_0.55MM_180-76 | 120OHM | DISCRETE | 7 | L8; L10; L13; L14; L16; L17; L18 |
IND_1608 | IND_IND_1608_0.75MM_180-75485_1 | 100OHM | DISCRETE | 1 | L9 |
IND_COILCRAFT_3X3MM | INDUCTOR_IND_COILCRAFT_3X3MM_1. | 2.2UH | DISCRETE | 2 | L11; L12 |
IND_COIL_3314 | INDUCTOR_IND_COIL_3314_1.40MM_1 | 2.2 UH | DISCRETE | 4 | L1; L3; L5; L6 |
MECHANICAL_PART_A | MARLEY_PCB_2_MECHANICAL_PART_A_ | Elvis_Socket | IC | 1 | XP1 |
MLF6_TAB | MIC5319YML_MLF6_TAB_0.9MM_315-7 | MIC5319 | IC | 1 | U9 |
MX51_13X13 | IMX51_TO2_BGA_0_MX51_13X13_IMX5 | iMX51_TO2_BGA_0p5 | IC | 1 | U7 |
QFN24_4X4MM_SLUG | MAX9701_25P_QFN24_4X4MM_SLUG_0. | MAX9701 | IC | 1 | U2 |
QFN32 | SGTL5000_QFN32_0.9MM_315-77907_ | SGTL5000 32QFN | IC | 1 | U4 |
RC0402_25 | RES_RC0402_25_470-75394_0 | 0 | DISCRETE | 141 | R3; R4; R5; R7; R8; R12; R14; R20; R21; R22; R24; R27; R29; R31; R33; R39; R40; R42; R43; R44; R45; R46; R47; R48; R49; R50; R51; R52; R57; R59; R61; R63; R65; R66; R67; R68; R70; R71; R72; R74; R75; R77; R79; R81; R83; R87; R88; R90; R91; R94; R97; R99; R100; R102; R104; R105; R109; R111; R112; R113; R114; R115; R116; R118; R119; R122; R124; R127; R130; R131; R132; R136; R137; R140; R141; R142; R143; R146; R147; R148; R149; R150; R152; R153; R154; R160; R161; R165; R170; R174; R176; R178; R179; R180; R182; R183; R184; R185; R186; R187; R188; R189; R190; R195; R196; R197; R198; R200; R204; R206; R207; R209; R210; R211; R212; R213; R214; R216; R227; R228; R230; R231; R232; R233; R234; R235; R236; R237; R238; R239; R240; R241; R252; R254; R255; R256; R257; R262; R263; R420; R1950 |
RC0402_25 | RES_RC0402_25_470-75418_4.7K | 4.7K | DISCRETE | 40 | R6; R34; R37; R38; R53; R54; R55; R56; R58; R60; R62; R64; R73; R78; R80; R82; R84; R85; R86; R89; R92; R93; R98; R101; R103; R106; R107; R108; R110; R135; R158; R215; R225; R242; R243; R244; R258; R259; R260; R261 |
RC0402_25 | RES_RC0402_25_470-76240_100K | 100K | DISCRETE | 4 | R17; R18; R25; R121 |
RC0402_25 | RES_RC0402_25_470-75790_33 | 33 | DISCRETE | 2 | R26; R253 |
RC0402_25 | RES_RC0402_25_470-75416_10.0K | 10.0K | DISCRETE | 28 | R32; R35; R36; R41; R120; R125; R138; R139; R155; R159; R166; R168; R169; R171; R172; R173; R175; R177; R191; R192; R193; R194; R205; R224; R245; R246; R247; R248 |
RC0402_25 | RES_RC0402_25_470-76037_1.0K | 1.0K | DISCRETE | 3 | R69; R76; R221 |
RC0402_25 | RES_RC0402_25_470-77002_1.21K | 1.21K | DISCRETE | 4 | R95; R151; R157; R229 |
RC0402_25 | RES_RC0402_25_470-30000_1M | 1M | DISCRETE | 4 | R129; R133; R162; R163 |
RC0402_25 | RES_RC0402_25_470-31087_178K | 178K | DISCRETE | 1 | R134 |
RC0402_25 | RES_RC0402_25_470-31125_383K | 383K | DISCRETE | 1 | R164 |
RC0402_25 | RES_RC0402_25_470-76255_200 | 200 | DISCRETE | 2 | R181; R226 |
RC0402_25 | RES_RC0402_25_470-30842_1.18K | 1.18K | DISCRETE | 1 | R201 |
RC0402_25 | RES_RC0402_25_470-31042_68K | 68K | DISCRETE | 9 | R202; R203; R208; R217; R218; R219; R220; R222; R223 |
RC0402_25 | RES_RC0402_25_470-30454_100 | 100 | DISCRETE | 1 | R264 |
RC0603 | RES_RC0603_470-30139_10M | 10M | DISCRETE | 1 | R96 |
RC0603 | RES_RC0603_470-75423_10 | 10 | DISCRETE | 1 | R156 |
RC0603 | RES_RC0603_470-75517_6.04K | 6.04K | DISCRETE | 1 | R199 |
RC0603 | RES_RC0603_470-75826_75.0 | 75 | DISCRETE | 3 | R249; R250; R251 |
RC0603_OV | RES_RC0603_OV_470-75407_0 | 0 | DISCRETE | 4 | R15; R16; R30; R117 |
RC0603_OV | RES_RC0603_OV_470-75399_2.2K | 2.2K | DISCRETE | 1 | R28 |
RC0603_OV | RES_RC0603_OV_470-76249_1.0M | 1.0M | DISCRETE | 2 | R123; R128 |
RC0805_OV | RES_RC0805_OV_470-79241_0.02 | 0.02 | DISCRETE | 7 | R10; R11; R13; R19; R23; R126; R167 |
RC0805_OV | RES_RC0805_OV_470-75442_0 | 0 | DISCRETE | 2 | R144; R145 |
RC1206_OV | RES_RC1206_OV_470-75924_0 | 0 | IC | 1 | D8 |
RC1210 | RES_RC1210_470-30131_0.1 | 0.1 | DISCRETE | 1 | R9 |
RCA_8_10 | NETW_B8_10P_RCA_8_10_470-75833_ | 10K | DISCRETE | 2 | RN1; RN2 |
RCA_8_10 | NETW_B8_10P_RCA_8_10__1K | 1K | IC | 1 | RN3 |
SC70-5_A | 1G125_SC70-5_A_1.1MM_312-30153_ | NC7SP125P5X | IC | 3 | U11; U13; U22 |
SC-70 | 1G17_SC-70_1.1MM_312-75956_NL17 | NL17SZ17 | IC | 2 | U3; U21 |
SO8-25X75-200 | SST25LF080A_SO8-25X75-200_1.75M | SST25VF016B | IC | 1 | U15 |
SOD123 | DIODE_SCHTKY_SOD123_1.0MM_480-7 | MBR120LSFT1G | IC | 3 | D5; D10; D11 |
SOD123 | DIODE_SCHTKY_SOD123_1.0 MM_480- | MBR140SFT | IC | 1 | D6 |
SOD123 | ZDIODE_SOD123_1.35MM_480-77119_ | MMSZ5222BT1G | IC | 1 | D9 |
SOT23-6 | 1T45_SOT23-6_1.45MM_312-75471_7 | 74LVC1T45 | IC | 1 | U16 |
SOT353 | NL17SZ14_SOT353_1.10 MM_312-300 | NL17SZ14DFT | IC | 3 | U5; U12; U255 |
SOT353 | 1G07_SOT353_1.1MM_312-75421_NL1 | NL17SZ07DFT2G | IC | 2 | U18; U20 |
SW_DIP8_4POS_SM | SW_DIP4_SW_DIP8_4POS_SM_2.32MM_ | SW DIP-4 | IC | 1 | SW1 |
SW_DIP16_8POS_SM | SW_DIP_8_SW_DIP16_8POS_SM_2.36M | SW DIP-8 | IC | 3 | SW2; SW3; SW4 |
TESTPOINT_138_059MIL | TEST_POINT_TESTPOINT_138_059MIL | TEST POINT | IO | 3 | TP4; TP29; TP31 |
TSOP48_18P5X12P4 | MT29F32G08Q_TSOP48_18P5X12P4_1. | MT29F32G08QAAWP | IC | 1 | U271 |
TSOP48_SKT | 980020-48-P2_TSOP48_SKT_5.33MM_ | 980020-48-P2 | IC | 1 | XU1 |
VFBGA60_8MM_10P1X11P6 | MT46H64M16LFCK_5_VFBGA60_8MM_10 | MT46H64M16LFCK-5 | IC | 4 | U261; U263; U264; U265 |
WCSP20_2P19X1P98MM | TPS63010_WCSP20_2P19X1P98MM_0.6 | TPS63010 | IC | 2 | U10; U14 |
WDFN3_2X2MM | PNP_WDFN3_2X2MM_0.8MM_480-77906 | NSS12100UW3 | IC | 6 | Q4; Q5; Q6; Q7; Q8; Q9 |
XTAL4_SX_3225 | XTAL_13Y_XTAL4_SX_3225_0.7MM_23 | 24MHz | IC | 1 | Y3 |
附件:
