Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
7X5MM | OSC4_SM_7X5MM_IC_1.9 MM_230-300 | 50MHz | IC | 1 | Y3 |
0805_CC | RES_0805_CC_DISCRETE_0.65MM_470 | 0.02 | DISCRETE | 8 | R1; R3; R4; R7; R230; R239; R242; R378 |
BGA289_0P8_14X14 | PCIMX287DJM4A_MAPBGA_289P_BGA28 | PCIMX287DJM4A | IC | 1 | U1 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.01UF | DISCRETE | 22 | C1; C5; C9; C18; C25; C28; C38; C43; C62; C64; C66; C160; C162; C166; C174; C180; C201; C202; C203; C204; C205; C206 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_2 | 0.1UF | DISCRETE | 91 | C2; C6; C10; C13; C14; C15; C16; C17; C19; C22; C23; C24; C26; C29; C30; C31; C32; C33; C34; C35; C36; C37; C39; C41; C42; C44; C45; C46; C47; C48; C49; C50; C51; C52; C53; C54; C55; C56; C65; C68; C70; C72; C74; C75; C76; C77; C80; C81; C82; C83; C84; C85; C88; C89; C104; C117; C118; C129; C130; C131; C132; C133; C134; C135; C136; C137; C138; C139; C140; C141; C142; C143; C144; C145; C146; C147; C153; C165; C168; C169; C171; C173; C175; C176; C177; C178; C179; C181; C182; C183; C207 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_4 | 0.01UF | DISCRETE | 11 | C95; C96; C97; C98; C107; C108; C109; C110; C123; C126; C128 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_3 | 0.1UF | DISCRETE | 15 | C99; C103; C105; C111; C113; C119; C122; C125; C148; C154; C196; C197; C198; C208; C209 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5MM | 0.22UF | DISCRETE | 4 | C61; C63; C69; C71 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.635 | 0.1UF | DISCRETE | 1 | C212 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.56M | 0.01UF | DISCRETE | 1 | C213 |
CC0603 | CAP_NP_CC0603_DISCRETE_0.95MM_1 | 1UF | DISCRETE | 13 | C3; C7; C11; C20; C27; C40; C78; C79; C86; C87; C92; C106; C120 |
CC0603 | CAP_NP_CC0603_DISCRETE_0.95MM_2 | 10PF | DISCRETE | 4 | C57; C58; C59; C60 |
CC0603 | CAP_NP_CC0603_DISCRETE_0.84 MM_ | 220PF | DISCRETE | 2 | C93; C94 |
CC0603 | CAP_NP_CC0603_DISCRETE_0.87MM_1 | 15PF | DISCRETE | 4 | C100; C101; C112; C115 |
CC0603 | CAP_NP_CC0603_DISCRETE_0.84MM_1 | 0.022UF | DISCRETE | 2 | C102; C116 |
CC0603 | CAP_NP_CC0603_DISCRETE_0.9MM_15 | 30PF | DISCRETE | 2 | C149; C155 |
CC0603 | CAP_NP_CC0603_DISCRETE_0.86MM_1 | 100PF | DISCRETE | 4 | C150; C151; C156; C157 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9_1 | 10uF | DISCRETE | 14 | C67; C73; C161; C163; C167; C170; C190; C191; C192; C193; C194; C195; C211; C216 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.95 | 10uF | DISCRETE | 1 | C114 |
CC0805 | CAP_NP_CC0805_DISCRETE_1.4MM_15 | 4.7UF | DISCRETE | 1 | C127 |
CC0805_NFM21P | EMIFILTER_NFM21P_CC0805_NFM21P_ | NFM21PC104R1E3D | DISCRETE | 1 | FL1 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.35M | 22UF | DISCRETE | 7 | C184; C185; C186; C187; C188; C189; C210 |
CC1210 | CAP_NP_CC1210_DISCRETE_2.7MM_15 | 10uF | DISCRETE | 1 | C159 |
CC1812 | CAP_NP_CC1812_DISCRETE_2.75MM_1 | 1000PF | DISCRETE | 2 | C152; C158 |
CC7343-43 | CAP_POL_CC7343-43_DISCRETE_4.3M | 220UF | DISCRETE | 2 | C90; C91 |
CC7343A | MOT_TCAP_CC7343A_DISCRETE_3.0MM | 120UF | DISCRETE | 2 | C121; C124 |
CDRH3D16 | INDUCTOR_CDRH3D16_DISCRETE_3MM_ | 15UH | DISCRETE | 1 | L1 |
CHOKE_CM_4PIN | ZJYS51R5-2P_CHOKE_CM_4PIN_5.08M | ZJYS51R5-2P | IC | 2 | U44; U46 |
CON4_RCA_RA_TH | CONN_RCA_4P_CON4_RCA_RA_TH_IO_1 | CON JACK RCA 4 | IO | 1 | J97 |
CON5_AUD_JACK_RA_TH_SJ-43515TS | SJ-43515TS_CON5_AUD_JACK_RA_TH_ | AUD_5 | IO | 2 | J79; J80 |
CON19_SDCARD_28X16_SM | CONN_SDC013_19P_CON19_SDCARD_28 | CONN CRD 19 | IO | 2 | U42; U43 |
CON_2X14_TH | CONN_HDR_14X2_CON_2X14_TH_IO_4. | CON 2x14 SKT | IO | 1 | J90 |
CON_52F_8S_25_SM | CONN_2X26_S8_B_CON_52F_8S_25_SM | CON SKT 52 | IO | 1 | J93 |
CON_120S_QSH_SM_05PITCH | QSH060_CON_120S_QSH_SM_05PITCH_ | QSH-060-01-L-D-A | IO | 2 | J63; J78 |
CON_DB9S_RA_318 | CONN_DB9F_MTGTABS_CON_DB9S_RA_3 | DB9 | IO | 1 | J83 |
CON_MIC38P_AMP_SM | MICTOR_38_2-767004_CON_MIC38P_A | HDR_2X19_F | IO | 1 | P4 |
CON_RJ45_2X1_MAG_LED | RJ45_MAG_2X1_LED_CON_RJ45_2X1_M | RJ45 13X2PORTS | IO | 1 | P1 |
DIODE2_50X30 | DIODE_TVS_BIDIR_DIODE2_50X30_IC | PGB101 | IC | 4 | TVS1; TVS2; TVS3; TVS4 |
DIP8_3_SKT | DIP8_3_DIP8_3_SKT_IO_5.33MM_210 | SKT_DIP8 | IO | 2 | J88; J89 |
DO_VMN2 | DIODE_DO_VMN2_IC_0.4MM_480-7793 | RB521CS-30 | IC | 1 | D18 |
DUALDB-9MM | DSD9M_DUALDB-9MM_IO_29.21 MM_21 | DDB9_M | IO | 2 | P2; P3 |
FBGA_84_0P8_8X12P5 | MT47H64M16_84P_FBGA_84_0P8_8X12 | EDE1116AEBG | IC | 1 | U2 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.586 MM | HDR_1X3 | IO | 3 | J86; J94; J95 |
HDR103_49MIL | CONN_HDR_3X1_HDR103_49MIL_IO_4. | CON_1X3 | IO | 1 | J85 |
HDR105 | CONN_HDR_5X1_HDR105_IO_5.41MM_2 | HDR 1X5 | IO | 2 | J92; J96 |
HDR110 | RCPT 1X10_HDR110_IO_4.2MM_210-7 | CONN SKT 10 | IO | 1 | J91 |
HDR210_TST | HDR-2X10-SHRD_HDR210_TST_IO_13. | CON_2X10 | IO | 1 | J87 |
IND_0603 | INDUCTOR_IND_0603_DISCRETE_0.95 | 470OHM | DISCRETE | 3 | L2; L7; L8 |
IND_0603 | BEAD_IND_0603_DISCRETE_0.95MM_1 | 30 OHM | DISCRETE | 2 | L11; L12 |
IND_0603A | FER_BEAD_IND_0603A_DISCRETE_0.9 | BLM18HE102SN1D | DISCRETE | 20 | FB1; FB2; FB3; FB4; FB5; FB6; FB7; FB8; FB9; FB10; FB11; FB12; FB13; FB14; FB15; FB16; FB17; FB18; FB19; FB20 |
IND_0805 | INDUCTOR_IND_0805_DISCRETE_1.05 | 75 OHM | DISCRETE | 1 | L3 |
IND_DLW5BS_2020 | DLW43_IND_DLW5BS_2020_DISCRETE_ | DLW5BTN142SQ2L | DISCRETE | 1 | L13 |
LED2_2P1X1P5 | LED_LED2_2P1X1P5_IC_1.4MM_370-7 | RED | IC | 1 | D15 |
LED1206_SMT | LED_LED1206_SMT_IC_1.2MM_370-76 | GREEN | IC | 3 | LED1; LED2; LED3 |
MICRO_USB_CONN_9PIN | MICRO_USB_CONN_9PIN_MICRO_USB_C | ZX62-AB-5P | IO | 1 | J82 |
PJ-202B | DC POWER JACK_PJ-202B_IO_11MM_2 | CON_1_PWR | IO | 1 | J84 |
QFN24_4X4MM_SLUG | LAN8720A-QFN24_QFN24_4X4MM_SLUG | LAN8720A | IC | 2 | U4; U5 |
QFN32 | SGTL5000_QFN32_IC_0.9MM_315-779 | SGTL5000 32QFN | IC | 1 | U3 |
QFN38_0P5_5X7MM | LTC2495_QFN38_0P5_5X7MM_IC_0.8M | LTC2495 | IC | 1 | U62 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7536 | 0 | DISCRETE | 2 | R12; R13 |
RC0402_25 | RES_RC0402_25_DISCRETE_470-7997 | 1M | DISCRETE | 1 | R354 |
RC0603 | RES_RC0603_DISCRETE_0.45 MM_470 | 0 | DISCRETE | 38 | R5; R6; R11; R18; R28; R30; R31; R60; R103; R104; R105; R112; R113; R115; R116; R117; R118; R119; R120; R128; R307; R312; R313; R314; R315; R316; R317; R318; R319; R325; R326; R327; R328; R329; R331; R332; R339; R340 |
RC0603 | RES_RC0603_DISCRETE_470-75410_1 | 10K | DISCRETE | 43 | R10; R59; R106; R108; R244; R246; R248; R250; R261; R262; R263; R264; R265; R274; R289; R290; R291; R292; R293; R294; R295; R297; R299; R300; R301; R302; R303; R304; R335; R336; R337; R338; R341; R343; R344; R345; R346; R347; R352; R357; R360; R361; R390 |
RC0603 | RES_RC0603_DISCRETE_0.41MM_470- | 4.7K | DISCRETE | 7 | R14; R15; R16; R17; R309; R310; R311 |
RC0603 | RES_RC0603_DISCRETE_470-75407_0 | 0 | DISCRETE | 78 | R26; R46; R47; R48; R49; R50; R51; R53; R54; R55; R56; R57; R58; R61; R62; R64; R65; R66; R67; R80; R81; R82; R83; R84; R85; R86; R87; R88; R89; R90; R91; R92; R94; R96; R99; R102; R107; R109; R114; R123; R129; R140; R141; R196; R197; R198; R199; R200; R202; R203; R204; R205; R207; R210; R211; R212; R213; R214; R215; R232; R240; R255; R256; R257; R258; R259; R260; R268; R276; R288; R362; R369; R377; R383; R384; R385; R388; R389 |
RC0603 | RES_RC0603_DISCRETE_470-75421_1 | 1.0K | DISCRETE | 6 | R27; R29; R348; R349; R350; R353 |
RC0603 | RES_RC0603_DISCRETE_470-75849_4 | 47K | DISCRETE | 58 | R32; R33; R34; R35; R36; R37; R38; R39; R40; R41; R42; R43; R44; R45; R52; R68; R69; R70; R71; R72; R73; R74; R75; R76; R77; R78; R79; R93; R98; R167; R172; R173; R174; R175; R186; R187; R189; R191; R192; R194; R208; R209; R272; R273; R296; R320; R321; R322; R356; R368; R370; R371; R372; R373; R374; R375; R376; R382 |
RC0603 | RES_RC0603_DISCRETE_470-75444_1 | 100K | DISCRETE | 12 | R95; R100; R142; R245; R247; R249; R251; R253; R271; R379; R391; R392 |
RC0603 | RES_RC0603_DISCRETE_470-30145_4 | 470K | DISCRETE | 2 | R97; R101 |
RC0603 | RES_RC0603_DISCRETE_470-75414_4 | 4.7K | DISCRETE | 2 | R110; R111 |
RC0603 | RES_RC0603_DISCRETE_0.55 MM_470 | 0 | DISCRETE | 30 | R121; R124; R133; R135; R138; R152; R158; R159; R164; R166; R168; R169; R171; R181; R188; R190; R193; R195; R216; R217; R218; R219; R222; R223; R224; R225; R226; R229; R333; R334 |
RC0603 | RES_RC0603_DISCRETE_0.4 MM_470- | 10.0K | DISCRETE | 1 | R122 |
RC0603 | RES_RC0603_0.55 MM_470-75849_47 | 47K | IC | 3 | R125; R126; R127 |
RC0603 | RES_RC0603_0.55 MM_470-75432_49 | 49.9 | IC | 8 | R130; R131; R132; R134; R160; R161; R162; R163 |
RC0603 | RES_RC0603_0.55MM_470-75410_10K | 10K | IC | 14 | R136; R137; R139; R150; R151; R153; R154; R155; R156; R165; R170; R182; R183; R184 |
RC0603 | RES_RC0603_DISCRETE_470-30298_2 | 270 | DISCRETE | 4 | R148; R149; R179; R330 |
RC0603 | RES_RC0603_DISCRETE_470-75516_1 | 12.1K | DISCRETE | 2 | R157; R185 |
RC0603 | RES_RC0603_0.55 MM_470-75407_0_ | 0 | IC | 2 | R180; R254 |
RC0603 | RES_RC0603_DISCRETE_0.55MM_470- | 62 | DISCRETE | 4 | R220; R221; R227; R228 |
RC0603 | RES_RC0603_DISCRETE_470-76048_2 | 22.6K | DISCRETE | 1 | R231 |
RC0603 | RES_RC0603_DISCRETE_470-78050_1 | 15.4K | DISCRETE | 1 | R233 |
RC0603 | RES_RC0603_DISCRETE_470-75399_2 | 2.2K | DISCRETE | 4 | R235; R281; R323; R324 |
RC0603 | RES_RC0603_DISCRETE_470-75422_1 | 10.0K | DISCRETE | 6 | R236; R237; R243; R275; R285; R298 |
RC0603 | RES_RC0603_DISCRETE_470-78014_3 | 3.9K | DISCRETE | 2 | R241; R283 |
RC0603 | RES_RC0603_DISCRETE_470-75996_4 | 470 | DISCRETE | 2 | R266; R267 |
RC0603 | RES_RC0603_DISCRETE_470-75412_1 | 1K | DISCRETE | 2 | R269; R270 |
RC0603 | RES_RC0603_DISCRETE_470-77975_9 | 910 | DISCRETE | 1 | R277 |
RC0603 | RES_RC0603_DISCRETE_470-77980_1 | 1.1K | DISCRETE | 1 | R278 |
RC0603 | RES_RC0603_DISCRETE_470-77987_1 | 1.3K | DISCRETE | 1 | R279 |
RC0603 | RES_RC0603_DISCRETE_470-77180_1 | 1.74K | DISCRETE | 1 | R280 |
RC0603 | RES_RC0603_DISCRETE_470-78009_3 | 3.0K | DISCRETE | 1 | R282 |
RC0603 | RES_RC0603_DISCRETE_470-30493_6 | 6.2K | DISCRETE | 1 | R284 |
RC0603 | RES_RC0603_DISCRETE_470-75450_2 | 20K | DISCRETE | 1 | R286 |
RC0603 | RES_RC0603_DISCRETE_470-79974_6 | 62K | DISCRETE | 1 | R287 |
RC0603 | RES_RC0603_DISCRETE_470-75846_1 | 1.0M | DISCRETE | 1 | R305 |
RC0603 | RES_RC0603_DISCRETE_470-75812_4 | 47.0K | DISCRETE | 1 | R306 |
RC0603 | RES_RC0603_DISCRETE_0.45MM_470- | 100 | DISCRETE | 1 | R308 |
RC0603 | RES_RC0603_DISCRETE_470-75995_1 | 1.5K | DISCRETE | 1 | R342 |
RC0603 | RES_RC0603_DISCRETE_470-75775_1 | 1 | DISCRETE | 1 | R351 |
RC0603 | RES_RC0603_DISCRETE_470-75553_1 | 10M | DISCRETE | 1 | R355 |
RC0603 | RES_RC0603_DISCRETE_470-30141_3 | 330K | DISCRETE | 1 | R358 |
RC0603 | RES_RC0603_DISCRETE_0.55 MM_4_1 | 47.0K | DISCRETE | 2 | R359; R380 |
RC0603 | RES_RC0603_DISCRETE_470-76077_0 | 0.1 | DISCRETE | 6 | R363; R364; R365; R366; R367; R393 |
RC0603 | RES_RC0603_DISCRETE_470-75783_2 | 200K | DISCRETE | 1 | R381 |
RC0603 | RES_RC0603_DISCRETE_470-77923_2 | 210 | DISCRETE | 1 | R386 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7542 | 100 | DISCRETE | 1 | R387 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7541 | 10K | DISCRETE | 3 | R757; R928; R929 |
RC0603_OV | RES_RC0603_OV_DISCRETE_470-7545 | 470K | DISCRETE | 1 | R1245 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7998 | 2.7K | DISCRETE | 1 | R1246 |
RC1210 | RES_RC1210__470-79982_1.8K_5% | 1.8k | IC | 1 | R63 |
S08_1P27_4X5 | TLE6251DS_8P_S08_1P27_4X5_IC_1. | TLE6251DS | IC | 2 | U13; U14 |
SC70-6 | NC7WZ16_SC70-6_IC_0.95MM_312-75 | NC7WZ16 | IC | 1 | U65 |
SC70_3 | MOSFET_N_SC70_3_IC_1.0MM_480-76 | NTS4001NT1G | IC | 1 | Q5 |
SC70_6LEAD | NC7WV17P6X_SC70_6LEAD_IC_1.1MM_ | NC7WV17 | IC | 2 | U51; U52 |
SO8-25X75-200 | W25X80V_SO8-25X75-200_IC_2.16MM | W25X80VSSIG | IC | 1 | U49 |
SO8_PAK | FDMS6681Z_SO8_PAK_IC_1.10MM_480 | FDMS6681Z | IC | 1 | Q15 |
SO8 | 128K_EEPROM_16KX8_SOIC_8P_SO8_I | 24LC128 | IC | 1 | U50 |
SOD123 | DIODE_ZENER21_SOD123_IC_1.35MM_ | MMSZ5231BT1G | IC | 1 | D13 |
SOD523 | DIODE_SOD523_IC_0.8MM_480-76892 | ZHCS350TA | IC | 1 | D2 |
SOD-123 | DIODE_SCHTKY_SOD-123_IC_1MM_480 | MBR120VLSFT1G | IC | 1 | D1 |
SOD-923 | DIODE_TVS_SOD-923_IC_0.40MM_480 | ESD9L5.0ST5G | IC | 1 | D16 |
SOT23 | DUALDIODE_CA_SOT23_SOT23_IC_1.1 | BAT54A-7-F | IC | 1 | D7 |
SOT23 | 2N7002_SOT23_IC_1.3MM_480-75159 | 2N7002 | IC | 3 | Q4; Q6; Q7 |
SOT23 | NPN_SOT23_IC_1.12 MM_480-75173_ | MMBT3904LT1G | IC | 3 | Q49; Q50; Q54 |
SOT23 | PNP_SOT23_IC_1.3MM_480-75192_MM | MMBT3906L | IC | 1 | Q52 |
SOT23-5 | RT9706_SOT23-5_IC_1.295MM_315-7 | RT9706 | IC | 2 | U6; U7 |
SOT23-6 | 74LVC2G17_SOT23-6_IC_1.45MM_312 | 74LVC2G17 | IC | 2 | U19; U20 |
SOT23_5S | LMV331IDBVR_SOT23_5S_IC_1.45MM_ | LMV331IDBVR | IC | 1 | U48 |
SOT23_A | DUALDIODE_CC_SOT23_SOT23_A_IC_1 | BAT54CLT1 | IC | 1 | D8 |
SOT223-6 | REG104GA_SOT223-6_IC_1.8MM_315- | REG104GA-A | IC | 3 | U15; U16; U17 |
SOT323_5 | DIODE_PROT_SOT323_5_IC_1MM_480- | RSA6.1ENTR | IC | 1 | D6 |
SOT353 | 1G126_SOT353_IC_1.1MM_312-79742 | M74VHC1GT126DF1G | IC | 2 | U64; U66 |
SOT363 | DUAL_NPN_SOT363_IC_1.1MM_480-76 | MBT3904DW1T1 | IC | 1 | Q47 |
SOT363 | MOSFET_P_6P_SOT363_IC_1.1MM_480 | NTJS4151P | IC | 1 | Q51 |
SOT363 | PNP_DUAL_SOT363_IC_1.1MM_480-77 | MBT3906DW1T1 | IC | 1 | Q53 |
SOT-23 | MOSFET_P_SOT-23_IC_1.12MM_480-7 | SI2305 | IC | 5 | Q1; Q2; Q3; Q14; Q16 |
SOT-23 | MOSFET_N_SOT-23_IC_1.12MM_480-7 | SI2312BDS | IC | 6 | Q8; Q9; Q10; Q11; Q12; Q13 |
SOT-23 | DIODE_NUP2105L_SOT-23_IC_1.11MM | NUP2105L | IC | 2 | U45; U47 |
SSOP8_DCU | PCA9306DCUR_SSOP8_DCU_IC_0.9MM_ | PCA9306DCUR | IC | 1 | U63 |
SW4_PB_ESW_SM_P177 | SW_PB_ESW_SW4_PB_ESW_SM_P177_IC | SPST PB | IC | 11 | S4; S5; S6; S8; S9; S10; S11; S12; S13; S14; S15 |
SW6_DPDT_11X6MM | SW_DPDT_3_SW6_DPDT_11X6MM_IC_9. | EG2209A | IC | 5 | S1; S3; S7; S16; S17 |
SW_16P_22P4X9P65 | SW_SPDT_16P_SW_16P_22P4X9P65_IC | 78HJ04GWT | IC | 1 | S2 |
TESTPOINT_39MIL | TEST PAD_TESTPOINT_39MIL_DISCRE | 1 mm | DISCRETE | 4 | TP3; TP4; TP5; TP6 |
TEST_PIN_TP107 | TESTLOOP_TEST_PIN_TP107_2.286MM | TESTLOOP | IC | 5 | TP11; TP12; TP13; TP14; TP15 |
TPAD_015 | TESTLOOP_TPAD_015_IC_0.1MM_211- | TPAD_015 | IC | 2 | TP1; TP2 |
TSOP48_SKT | NANDFLASHSOCKET_TSOP48_SKT_IC_5 | 980020-48-P2 | IC | 1 | U23 |
TSSOP20 | MAX3222_TSSOP20_IC_1.1MM_312-79 | MAX3222 | IC | 3 | U10; U11; U12 |
USB_A | USB_A_USB_A_IO_7.01MM_210-30008 | USB_TYPE_A | IO | 1 | J81 |
XFMR6_6P6X6P2 | XFMR_XFMR6_6P6X6P2_DISCRETE_4.8 | TTWB1010L | DISCRETE | 1 | T1 |
XTAL2_5X2_SM | XTAL_XTAL2_5X2_SM_IC_1.0MM_230- | 32.768KHZ | IC | 1 | Y1 |
XTAL_CS10_SM | XTAL_CS10_XTAL_CS10_SM_IC_1.4MM | 24.0000 MHZ | IC | 1 | Y2 |
