Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
2-SMD | CRYSTAL_SMT_32_768KHZ_2-SMD_32. | 32.768KHz, CITIZEN | IC | 1 | Y6 |
402 | CAP NP_0402_1UF | 1uF | IC | 80 | C6; C18; C19; C47; C50; C56; C80; C140; C158; C168; C169; C170; C178; C187; C191; C193; C194; C195; C196; C197; C198; C199; C200; C201; C234; C237; C238; C240; C241; C242; C243; C244; C245; C246; C248; C249; C250; C251; C252; C253; C254; C255; C256; C257; C258; C259; C260; C261; C262; C264; C265; C287; C288; C289; C291; C292; C293; C294; C295; C296; C314; C315; C316; C317; C318; C319; C320; C321; C322; C342; C351; C352; C356; C357; C370; C373; C400; C401; C402; C1044 |
402 | CAP NP_0402_2700PF | 2700pF | IC | 8 | C7; C13; C34; C35; C117; C137; C266; C268 |
402 | CAP NP_0402_0.1UF | 0.1uF | IC | 114 | C8; C14; C15; C23; C24; C33; C46; C48; C57; C59; C60; C62; C73; C76; C77; C78; C83; C84; C85; C94; C96; C97; C98; C99; C101; C102; C114; C116; C133; C134; C136; C172; C173; C176; C177; C179; C184; C190; C192; C207; C209; C210; C211; C214; C215; C216; C217; C220; C221; C224; C225; C227; C229; C230; C233; C267; C269; C270; C273; C274; C277; C278; C299; C300; C301; C302; C304; C305; C308; C309; C311; C312; C313; C324; C325; C326; C327; C328; C329; C330; C331; C332; C333; C334; C335; C339; C340; C353; C354; C355; C358; C359; C364; C366; C367; C368; C369; C371; C374; C375; C382; C385; C387; C392; C393; C399; C404; C410; C411; C414; C415; C423; C424; C1043 |
402 | CAP_0.1UF_X5R_6.3V_20% 0201 _04 | 0.1uf | IC | 42 | C9; C27; C28; C29; C30; C31; C36; C37; C38; C39; C40; C42; C43; C44; C45; C52; C53; C54; C55; C103; C105; C124; C127; C128; C129; C130; C131; C145; C146; C147; C150; C153; C154; C164; C167; C188; C189; C235; C236; C285; C286; C420 |
402 | CAP NP_0402_2.2UF | 2.2uF | IC | 13 | C16; C25; C135; C171; C203; C204; C206; C213; C218; C219; C223; C226; C228 |
402 | CAP_0.1UF_X5R_6.3V_20% 0201 __2 | 1uF | IC | 3 | C17; C125; C163 |
402 | CAP NP_0402_100PF | 100pF | IC | 5 | C49; C51; C61; C63; C64 |
402 | CAP NP_0402_18PF | 18pF | IC | 2 | C72; C74 |
402 | CAP NP_0402_20PF | 20pF | IC | 2 | C75; C86 |
402 | CAP NP_0402_470PF | 470pF | IC | 3 | C89; C93; C95 |
402 | CAP NP_0402_0.01UF | 0.01uF | IC | 4 | C100; C281; C282; C283 |
402 | CAP_2.2UF_X5R_6.3V_10%_0402_040 | 2.2uF | IC | 4 | C104; C106; C421; C422 |
402 | CAP_0.1UF_X7R_16V_10% 0402 _040 | 47pF | IC | 2 | C107; C108 |
402 | CAP_0.1UF_X5R_6.3V_20% 0201 __1 | 0.01uf | IC | 16 | C118; C119; C126; C132; C138; C139; C144; C149; C152; C155; C162; C166; C180; C181; C182; C183 |
402 | CAP_0402_47PF_COG_50V_0402_47NF | 47nF | IC | 4 | C120; C121; C141; C143 |
402 | CAP_0.1UF_X7R_16V_10% 0402 _0_1 | 0.1uf | IC | 8 | C122; C123; C142; C159; C407; C408; C412; C413 |
402 | CAP_0.1UF_X5R_6.3V_20% 0201 __3 | 100pF | IC | 4 | C148; C151; C161; C165 |
402 | CAP NP_0402_12PF | 12pF | IC | 2 | C156; C157 |
402 | CAP NP_0402_820PF | 820pF | IC | 3 | C185; C202; C212 |
402 | CAP NP_0402_200PF | 200pF | IC | 3 | C205; C208; C222 |
402 | CAP NP_0402_47PF | 47pF | IC | 2 | C239; C290 |
402 | CAP NP_0402_0.22UF | 0.22uF | IC | 4 | C247; C263; C378; C403 |
402 | CAP_470PF_X7R_25V_10%_0402_0402 | 1000pF | IC | 1 | C388 |
402 | CAP_470PF_X7R_25V_10%_0402_04_1 | 470pF | IC | 1 | C419 |
402 | RESISTOR_0402_56.2 | 56.2 | IC | 31 | R1; R2; R3; R4; R5; R6; R7; R8; R9; R15; R16; R17; R18; R19; R21; R22; R23; R24; R35; R36; R39; R40; R43; R66; R67; R84; R86; R332; R333; R334; R340 |
402 | RESISTOR_0402_10K | 10K | IC | 104 | R10; R11; R25; R31; R32; R46; R50; R51; R61; R62; R70; R75; R92; R106; R108; R118; R119; R122; R143; R144; R164; R165; R171; R178; R182; R188; R198; R213; R214; R215; R216; R223; R224; R229; R231; R239; R240; R242; R243; R244; R245; R246; R247; R248; R256; R260; R274; R278; R279; R280; R281; R287; R295; R297; R299; R301; R302; R303; R314; R315; R316; R321; R322; R323; R324; R327; R328; R339; R345; R347; R348; R349; R350; R372; R374; R375; R377; R386; R387; R388; R393; R411; R415; R416; R417; R420; R422; R430; R431; R432; R433; R444; R445; R446; R449; R451; R452; R453; R454; R455; R456; R457; R476; R629 |
402 | RESISTOR_0402_51K | 51K | IC | 1 | R12 |
402 | RES_4.75K_1/16W_1%_0402_0402_4. | 4.7K | IC | 3 | R13; R14; R465 |
402 | RESISTOR_0402_39.2 | 39.2 | IC | 6 | R20; R33; R34; R37; R38; R55 |
402 | RESISTOR_0402_49.9 | 49.9 | IC | 12 | R26; R74; R97; R112; R116; R117; R145; R146; R364; R365; R391; R392 |
402 | RESISTOR_0402_20K | 20K | IC | 1 | R28 |
402 | RESISTOR_0402_510 | 510 | IC | 2 | R29; R48 |
402 | RESISTOR_0402_1K | 1K | IC | 61 | R30; R44; R45; R49; R52; R63; R71; R76; R77; R89; R90; R101; R107; R114; R115; R130; R131; R132; R133; R135; R172; R181; R183; R193; R209; R228; R236; R261; R262; R267; R270; R271; R272; R310; R311; R317; R320; R337; R368; R369; R394; R395; R396; R397; R398; R399; R403; R410; R447; R450; R473; R474; R475; R618; R619; R620; R623; R624; R625; R627; R628 |
402 | RESISTOR_0402_0 | 0 | IC | 28 | R41; R42; R58; R64; R65; R73; R79; R82; R85; R105; R166; R273; R276; R282; R305; R306; R370; R379; R381; R400; R419; R424; R440; R441; R458; R459; R460; R621 |
402 | RESISTOR_0402_18.2 | 18.2 | IC | 2 | R47; R360 |
402 | RESISTOR_0402_3.16K | 3.16K | IC | 2 | R53; R54 |
402 | RESISTOR_0402_220 | 220 | IC | 4 | R59; R60; R237; R238 |
402 | RESISTOR_0402_100 | 100 | IC | 13 | R72; R111; R194; R283; R288; R296; R300; R307; R308; R309; R331; R401; R448 |
402 | RESISTOR_0402_2K | 2K | IC | 4 | R88; R134; R336; R404 |
402 | RESISTOR_0402_33 | 33 | IC | 20 | R140; R142; R284; R285; R286; R289; R290; R291; R292; R293; R294; R298; R312; R313; R355; R358; R413; R414; R438; R439 |
402 | RESISTOR_0402_249 | 249 | IC | 1 | R141 |
402 | RESISTOR_0402_24.9 | 24.9 | IC | 5 | R167; R168; R169; R425; R426 |
402 | RESISTOR_0402_330 | 330 | IC | 4 | R173; R174; R195; R210 |
402 | RESISTOR_0402_0R56 | 0R56 | IC | 6 | R175; R185; R186; R196; R197; R212 |
402 | RESISTOR_0402_22 | 22 | IC | 14 | R179; R180; R189; R190; R191; R192; R329; R330; R338; R346; R351; R352; R353; R354 |
402 | RES_470_1/10W_5%_0402_0402_470 | 470 | IC | 1 | R184 |
402 | RESISTOR_0402_49.9K | 49.9K | IC | 5 | R199; R202; R203; R206; R207 |
402 | RESISTOR_0402_499 | 499 | IC | 5 | R200; R201; R204; R205; R208 |
402 | RES_33_1/16W_5%_0402_0402_0 | 0 | IC | 4 | R225; R373; R376; R463 |
402 | RESISTOR_0402_39K | 39K | IC | 1 | R234 |
402 | RESISTOR_0402_68K | 68K | IC | 1 | R235 |
402 | RES_33_1/16W_5%_0402_0402_5.1K | 5.1K | IC | 2 | R249; R257 |
402 | RESISTOR_0402_300 | 300 | IC | 5 | R250; R251; R252; R253; R263 |
402 | RESISTOR_0402_2.2K | 2.2K | IC | 3 | R254; R255; R626 |
402 | RES_33_1/16W_5%_0402_0402_100 | 100 | IC | 2 | R258; R259 |
402 | RESISTOR_0402_50 | 50 | IC | 2 | R264; R265 |
402 | RES_4.75K_1/16W_1%_0402_0402_20 | 20K | IC | 1 | R266 |
402 | RESISTOR_0402_5.6K | 5.6K | IC | 2 | R268; R269 |
402 | RESISTOR_0402_35.7 | 35.7 | IC | 2 | R275; R361 |
402 | RESISTOR_0402_191 | 191 | IC | 1 | R277 |
402 | RESISTOR_0402_750 | 750 | IC | 1 | R304 |
402 | RESISTOR_0402_12K | 12K | IC | 7 | R341; R344; R371; R378; R380; R382; R383 |
402 | RESISTOR_0402_54.9 | 54.9 | IC | 2 | R356; R363 |
402 | RESISTOR_0402_27.4 | 27.4 | IC | 2 | R357; R362 |
402 | RESISTOR_0402_2.43K | 2.43K | IC | 1 | R359 |
402 | RESISTOR_0402_60.4 | 60.4 | IC | 3 | R367; R389; R390 |
402 | RESISTOR_0402_10R | 10R | IC | 4 | R406; R407; R408; R409 |
402 | RESISTOR_0402_4.7K | 4.7K | IC | 3 | R412; R436; R437 |
402 | RESISTOR_0402_1.5K | 1.5K | IC | 1 | R421 |
402 | RESISTOR_0402_100K | 100K | IC | 2 | R427; R428 |
402 | RESISTOR_0402_2.37K | 2.37K | IC | 1 | R435 |
402 | RES_470_1/10W_5%_0402_0402_10R | 10R | IC | 1 | R442 |
402 | RES_470_1/10W_5%_0402_0402_374 | 374 | IC | 1 | R443 |
402 | RES_4.75K_1/16W_1%_0402_0402_0 | 0 | IC | 1 | R466 |
402 | RES_4.75K_1/16W_1%_0402_0402_10 | 10K | IC | 1 | R467 |
402 | RES_4.75K_1/16W_1%_0402_0402_1K | 1K | IC | 1 | R468 |
402 | RES_33_1/16W_5%_0402_0402_27 | 27 | IC | 2 | R469; R470 |
402 | RES_470_1/10W_5%_0402_0402_470K | 470K | IC | 1 | R471 |
402 | RES_470_1/10W_5%_0402_0402_280K | 280K | IC | 1 | R472 |
0402-S | RESISTOR_0402-S_0 | 0 | IC | 80 | R56; R57; R68; R69; R78; R80; R81; R83; R87; R91; R93; R94; R95; R96; R98; R99; R100; R102; R103; R104; R109; R110; R113; R120; R121; R123; R124; R125; R126; R127; R128; R129; R136; R137; R138; R139; R147; R148; R149; R150; R151; R152; R154; R155; R156; R157; R158; R159; R160; R161; R162; R163; R170; R177; R217; R218; R219; R220; R221; R222; R230; R232; R233; R318; R319; R325; R326; R335; R342; R343; R366; R384; R385; R402; R418; R423; R429; R434; R461; R622 |
0402-S | RES_33_1/16W_5%_0402_0402-S_0 | 0 | IC | 2 | R226; R227 |
603 | CAP 0603 0_0.1UF/25V_0603_0.1UF | 0.1uF | IC | 1 | C3 |
603 | CAP NP_0603_4.7UF | 4.7uF | IC | 14 | C10; C20; C26; C109; C160; C376; C377; C379; C381; C386; C389; C397; C398; C409 |
603 | KE32_3_1.15A_0603_0467002_NR_2A | 0467002_NR_2A_LF | IC | 1 | F1 |
603 | BEAD_0603_BEAD | BEAD | IC | 11 | FB1; FB2; FB3; FB4; FB5; FB8; FB9; FB10; FB11; FB12; FB13 |
603 | RESISTOR_0603_10M | 10M | IC | 1 | R27 |
805 | CAP NP_0805_10UF | 10uF | IC | 41 | C1; C2; C22; C32; C41; C65; C66; C67; C68; C69; C70; C79; C81; C82; C88; C90; C115; C271; C272; C275; C276; C279; C280; C284; C297; C298; C303; C306; C307; C310; C323; C336; C337; C347; C348; C349; C361; C365; C380; C390; C391 |
805 | CAP NP_0805_22UF | 22uF | IC | 11 | C71; C87; C91; C92; C186; C231; C232; C360; C362; C405; C406 |
805 | L_SMALL_0805_MLB_201209-0030P-N | MLB_201209-0030P-N1 | IC | 1 | L1 |
805 | RESISTOR_0805_0 | 0 | IC | 3 | R153; R405; R462 |
805 | RESISTOR_0805_0.01R | 0.01R | IC | 4 | R176; R187; R211; R241 |
805 | RES_470_1/10W_5%_0402_0805_0 | 0 | IC | 1 | R464 |
805 | THERMISTOR_0805_PTC,0ZCE0010FF2 | PTC,0ZCE0010FF2G | IC | 1 | RT1 |
1206 | NANO-SMF_1206_0.75A (1206L075WR | 0.75A (1206L075WRT) | IC | 1 | F2 |
1206P | CAP POL_1206P_1UF, TANTALUM | 1uF, TANTALUM | IC | 1 | C58 |
1210 | INDUCTOR_1210_4.7UH | 4.7uH | IC | 1 | L21 |
1411_THT | CAP POL_1411_THT_47UF | 47uF | IC | 8 | C174; C175; C338; C341; C343; C344; C345; C346 |
1808 | CAP NP_0_1808_8200PF | 8200pF | IC | 5 | C4; C21; C110; C111; C113 |
1808 | CAP NP_0_1808_150PF | 150pF | IC | 2 | C5; C112 |
3528 | CAPACITOR POL_4_3528_100UF | 100uF | IC | 2 | C11; C12 |
6605814-6 | CONNECTORRJ45_GIGABIT_6605814-6 | RJ-45 Gigabit | IC | 1 | J12 |
BATT3_190X610 | BATTERY_2_BATT3_190X610_BATT HO | BATT HOLDER, BS-1225-PC | IC | 1 | BH1 |
BGA6_C2_P5MM | TPS22922_0_BGA6_C2_P5MM_TPS2292 | TPS22922 | IC | 1 | U29 |
BGA169_N13_P8 | DA6011_1_BGA169_N13_P8_DA6011 | DA6011 | IC | 1 | U13 |
BGA676_22X22_8MM_MPI_ISO_BKPLT | INTEL_ATOM_PROCESSOR_E6XX_2_BGA | INTEL_ATOM_Processor_E6XX | IC | 1 | U5 |
BGA_376P | PCH EG20T_BGA_376P_(S1+S2+S3+S4 | PCH EG20T | IC | 1 | U6 |
CHOKE_QTC24CG | PLW3216S_0_CHOKE_QTC24CG_EXC24C | EXC24CG900U | IC | 4 | L2; L3; L4; L5 |
COIL5MMSMD_6SQ | INDUCTOR_COIL5MMSMD_6SQ_1.5UH | 1.5uH | IC | 2 | L15; L16 |
CON2X50SMD_P8MMLS-1 | CONN SOCKET 50X2/SM_1_CON2X50SM | CONN PLUG 50x2/SM | IC | 1 | J8 |
CONN60_ITP_XDP_VR | CONN PCB 30X2_CONN60_ITP_XDP_VR | CONN_ITP_XDP | IC | 1 | J7 |
CUI-SJ1-3515-SMT | CONN_STEREO_BLUE_CUI-SJ1-3515-S | SJ1-3515-SMT-TR-BE | IC | 1 | P2 |
CUI-SJ1-3515-SMT | CONN_STEREO_GREEN_CUI-SJ1-3515- | SJ1-3515-SMT-TR-GR | IC | 1 | P3 |
DBV-5 | TPS71718_DBV-5_TPS79318 | TPS79318 | IC | 1 | U35 |
DCK5 | SN74LVC1G06DCK_1_DCK5_SN74LVC1G | SN74LVC1G06 | IC | 1 | U12 |
DDR2_FBGA60PIN | MT47H256M8_DDR2_FBGA60PIN_MT47H | MT47H256M8 | IC | 4 | U1; U4; U26; U27 |
ECX-53 | CRYSTAL_SMT_14_3MHZ_ECX-53_ECS- | ECS-143-20-30-TR | IC | 1 | Y2 |
ECX-53 | CRYSTAL_SMT_25_0MHZ_ECX-53_ECS- | ECS-250-20-30-TR | IC | 1 | Y4 |
F603-41X39 | PGB0010603MR_F603-41X39_PGB0010 | PGB0010603MR | IC | 4 | D2; D3; D4; D5 |
HC-46X | CRYSTAL_THT_14_3MHZ_HC-46X_ECS- | ECS-143-20-46X | IC | 1 | Y1 |
HC-46X | CRYSTAL_THT_25_0MHZ_HC-46X_ECS- | ECS-250-20-46X-TR | IC | 1 | Y3 |
HDR2X4 | HEADER 4X2_1_HDR2X4_HEADER 4X2 | HEADER 4x2 | IC | 1 | J11 |
HDR2X5 | HEADER 5X2_0_HDR2X5_HEADER 5X2 | HEADER 5X2 | IC | 1 | J9 |
IND2P9SMD_4SQ | INDUCTOR_IND2P9SMD_4SQ_4.7UH | 4.7uH | IC | 1 | L12 |
IND2P75SMD_2P6X2P8 | INDUCTOR_IND2P75SMD_2P6X2P8_1UH | 1uH | IC | 1 | L19 |
IND3P4SMD_5SQ | INDUCTOR_IND3P4SMD_5SQ_1.8UH | 1.8uH | IC | 1 | L20 |
IND3P6SMD_4P9SQ | INDUCTOR_IND3P6SMD_4P9SQ_1.5UH | 1.5uH | IC | 3 | L13; L14; L17 |
IND603-24X32 | FER_MMZ1608R301A_IND603-24X32_F | FERRITE, MMZ1608R301A | IC | 7 | L6; L7; L8; L9; L10; L11; L18 |
LED_LTST-S270GKT_RA | LED_LTST-S270GKT_0_LED_LTST-S27 | LTST-S270GKT | DISCRETE | 4 | D11; D12; D13; D15 |
LED_LTST-S270GKT_RA | LED_LTST-S270KRKT_2_LED_LTST-S2 | LTST-S270KRKT | DISCRETE | 1 | D14 |
MTGH200C125D_PL | MHOLE_MTGH200C125D_PL_MHOLE | MHOLE | IC | 4 | MTG1; MTG2; MTG3; MTG4 |
PWRPAK_SO-8 | SI7540DP_16_PWRPAK_SO-8_SI7540D | SI7540DP | IC | 3 | U31; U32; U33 |
QFN48S6X6P4 | AR8031-AL1A_QFN48_QFN48S6X6P4_A | AR8031_AL1A | IC | 1 | U9 |
QFP48S7X7P5LS7P87 | SIL1162_0_QFP48S7X7P5LS7P87_SII | SII1362 | IC | 1 | U2 |
QFP48S7X7P5LS7P87 | IC_TLV320AIC3104_0_QFP48S7X7P5L | ALC262 | IC | 1 | U3 |
RAPC712 | CONN_PWRJACK_RAPC712_RAPC712_RA | RAPC712 | IC | 1 | J15 |
RD205SMD_THT_250D | CAP POL_220UF_RD205SMD_THT_250D | 220uF | IC | 8 | C350; C372; C384; C394; C395; C396; C417; C418 |
SATA_RA | SATA_HEADER_RA_SATA_RA_04708040 | 470804005 | IC | 1 | J3 |
SC70-5 | 74LVC1G08_0_SC70-5_74LVC1G07DCK | 74LVC1G07DCK | IC | 2 | U7; U8 |
SD-MICRO-SCHA5B0300 | MICROSD_CONN_8_SD-MICRO-SCHA5B0 | SCHA5B0200 | IC | 1 | P1 |
SIP2 | JUMPER_SIP2_JUMPER | JUMPER | IC | 3 | J2; J5; J13 |
SIP3 | HEADER 3_1_SIP3_HEADER 3 | HEADER 3 | IC | 1 | J10 |
SIP4 | HEADER_4_SIP4_HEADER_4 | HEADER_4 | IC | 1 | J4 |
SM-7351-IND-0805 | FER_180_200_0805_SM-7351-IND-08 | 150OHM800mA | IC | 2 | FB6; FB7 |
SMC | DIODE_SMCJ36CA_SMC_SMCJ5.0CA | SMCJ5.0CA | IC | 1 | D7 |
SMC | DIODE_SMCJ36CA_SMC_MBRS410LT3G | MBRS410LT3G | IC | 1 | D8 |
SMD_HDMIA_RA | CONN_HDMI_TYPEA_SMD_HDMIA_RA_HD | HDMIConnA | IC | 1 | J1 |
SMINI6-F3-B | RN1907_SMINI6-F3-B_DMC56404 | DMC56404 | IC | 3 | Q1; Q2; Q8 |
SO8-25X75 | PWR_TLV70233DBV_0_SO8-25X75_TL5 | TL5209 | IC | 1 | U34 |
SO16-25X75 | TPS2054BD_SO16-25X75_TPS2054BD | TPS2054BD | IC | 1 | U10 |
SOD123_146LS | 1/4M8.2Z10_SOD123_146LS_MMSZ522 | MMSZ5226B-7-F | IC | 1 | D6 |
SOD-123 | DIODE_7_SOD-123_SCS0520P | SCS0520P | IC | 1 | D1 |
SOIC8_260-1 | W25Q64_SOIC8_260-1_W25Q32CV | W25Q32CV | IC | 1 | U11 |
SOT23-5 | SN74LVC1G06DCK_1_SOT23-5_SN74LV | SN74LVC1G14DBVR | IC | 2 | U15; U16 |
SOT23-5 | TPS73633DBVT_1_SOT23-5_TPS73633 | TPS73633DBVR | IC | 1 | U17 |
SOT23-5 | 74LVC1G08_SOT23-5_74LVC1G08DBVR | 74LVC1G08DBVR | IC | 3 | U18; U19; U30 |
SOT23A | BAT54C/SOT_3_SOT23A_BAT54C, SOT | BAT54C, SOT23 | IC | 1 | D9 |
SOT23_GSD | MOSFET_NCHAN_BSS138_SOT23_GSD_B | BSS138 | IC | 5 | Q3; Q4; Q5; Q6; Q7 |
SOT23_GSD | MOSFET_PCHAN_DMG1013T_SOT23_GSD | DMG1013T | IC | 1 | Q9 |
SSOP8_0256P_146 | LM95245_SSOP8_0256P_146_LM95245 | LM95245CIMM | IC | 1 | U28 |
SSOP16_025P_186 | FT232RL_1_SSOP16_025P_186_FT230 | FT230XS | IC | 1 | U22 |
SW3SMD_D320000G_RA | 3-POS SW_3_SW3SMD_D320000G_RA_T | TL3320AF100Q | IC | 6 | S1; S2; S3; S4; S5; S6 |
TP40-SMT | TEST_PAD_1_TP40-SMT_TEST_PAD_1 | TEST_PAD_1 | IC | 24 | TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25 |
TP135X185R_SMD | TEST_PAD_0_TP135X185R_SMD_TEST_ | TEST_PAD_1 | IC | 4 | GH1; GH2; GH3; GH4 |
TSSOP14 | TXS0104EPW_TSSOP14_TXS0104EPW | TXS0104EPW | IC | 2 | U14; U36 |
TSSOP14 | GTL2005_TSSOP14_GTL2005PW | GTL2005PW | IC | 1 | U37 |
UMD3 | DIODE_DUAL_UMD3_RB717F | RB717F | IC | 1 | D10 |
USB5MINI_4SHIELDED_SMD | MINI-USB-AB-SOCKET_USB5MINI_4SH | mini USB-B | IC | 1 | P4 |
USB5_FCI-10103594 | CONN_MICROUSBAB_USB5_FCI-101035 | USB_MicroB | IC | 1 | J14 |
USB_STACKED2 | CONN_54819-0578_0_USB_STACKED2_ | USB-A Conn. | IO | 1 | P5 |
U_5_DRL | TPD2E001DRL_U_5_DRL_TPD2E001 | TPD2E001 | IC | 1 | U25 |
U_6_DRY | PROT_TPD4S012_U_6_DRY_TPD4S012 | TPD4S012 | IC | 3 | U20; U21; U23 |
U_10_RSE | TPD6E001RSE_U_10_RSE_TPD6E001 | TPD6E001 | IC | 1 | U24 |
XTAL_CFS-145 | CRYSTAL_THT_32_768KHZ_XTAL_CFS- | 32.768KHz, CITIZEN | IC | 1 | Y5 |
附件:
