Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
806-0101 | SMA-CON-R_806-0101_DOSIN-806-00 | DOSIN-806-0011 | IC | 2 | J2; J34 |
ACFF-1024 | ACFF-1024_ACFF-1024_ACFF-1024-T | ACFF-1024-TR1 | IC | 2 | U9; U34 |
ANTS3L | CONN_UFL_0_ANTS3L_U.FL-R-SMT-1 | U.FL-R-SMT-1 | IC | 2 | J1; J36 |
C0402 | CAP NP_C0402_220PF | 220PF | IC | 2 | C37; C403 |
C0402 | CAP NP_C0402_100NF | 100NF | IC | 16 | C41; C45; C79; C84; C85; C86; C104; C107; C374; C389; C396; C397; C398; C399; C402; C404 |
C0402 | CAP NP_C0402_100PF | 100PF | IC | 10 | C42; C43; C44; C46; C47; C378; C379; C380; C393; C394 |
C0402 | CAP NP_C0402_1UF | 1UF | IC | 1 | C376 |
C0603 | CAP NP_C0603_10UF | 10UF | IC | 6 | C39; C40; C81; C390; C391; C395 |
C0603 | CAP NP_C0603_22UF | 22UF | IC | 2 | C77; C78 |
C0603 | CAP NP_C0603_1UF | 1UF | IC | 1 | C377 |
C0805 | CAP NP_C0805_47UF | 47UF | IC | 6 | C38; C105; C106; C392; C400; C401 |
C1206 | CAP NP_C1206_22UF | 22UF | IC | 2 | C373; C375 |
CON_2X8_1R27 | HD3_2_CON_2X8_1R27_HD3 | HD3 | IC | 1 | J3 |
HEADER3_H_R | CONN_HDR_0_HEADER3_H_R_IO_WB250 | WB250SD-03-G-RD03 | IO | 6 | J4; J5; J6; J7; J8; J9 |
HSL1008 | PINDUCTOR_0_HSL1008__4.7UH | 4.7uH | IC | 1 | L2 |
L0805 | FB_L0805_220OHM | 220ohm | IC | 5 | FB7; FB8; FB9; FB10; FB11 |
LED0805 | LED_LED0805__GREEN | Green | IC | 1 | D1 |
MGA-QFN16 | MGA-22003_MGA-QFN16_MGA-22003-B | MGA-22003-BCKG | IC | 2 | U3; U36 |
R0402 | RES_R0402_158K | 158K | IC | 2 | R9; R283 |
R0402 | RES_R0402_1M | 1M | IC | 2 | R10; R282 |
R0402 | RES_R0402_4K7 | 4K7 | IC | 1 | R51 |
R0402 | RES_R0402_40K2 | 40K2 | IC | 2 | R271; R272 |
R0402 | RES_R0402_100K | 100K | IC | 1 | R273 |
R0402 | RES_R0402_0R | 0R | IC | 1 | R274 |
R0402 | RES_R0402_10K7 | 10K7 | IC | 1 | R275 |
R0402 | RES_R0402_10K | 10K | IC | 8 | R276; R277; R278; R279; R280; R281; R289; R290 |
SOD123 | DIODE_1_SOD123__1N5819HW-7-F | 1N5819HW-7-F | IC | 1 | D2 |
SOT23-6 | MP1471AGJ_SOT23-6_MP1471AGJ | MP1471AGJ | IC | 1 | U29 |
SOT-89-5 | RP115H331D-FE_SOT-89-5_RP115H33 | RP115H331D-FE | IC | 2 | U30; U33 |
附件:
