Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
0402_CC | CAP_NP_0402_CC_DISCRETE_0.55MM_ | 0.1uF | DISCRETE | 96 | C902; C904; C1001; C1002; C1003; C1004; C1005; C1006; C1007; C1008; C1009; C1010; C1011; C1013; C1015; C1017; C1102; C1104; C1105; C1107; C1108; C1110; C1201; C1208; C1302; C1303; C1306; C1307; C1308; C1309; C1311; C1312; C1313; C1314; C1315; C1402; C1403; C1407; C1408; C1415; C1418; C1420; C1421; C1423; C1424; C1502; C1504; C1505; C1506; C1507; C1508; C1602; C1604; C1605; C1606; C1607; C1608; C1701; C1702; C1706; C1802; C1804; C1805; C1806; C1808; C1810; C1812; C1815; C1817; C1824; C1903; C1905; C2002; C2011; C2102; C2104; C2106; C2107; C2110; C2129; C2130; C2131; C2133; C2136; C2137; C2138; C2139; C2140; C2147; C2148; C2149; C2150; C2151; C2152; C2153; C2154 |
0402_CC | CAP_NP_0402_CC_DISCRETE_0.65MM_ | 4.7uF | DISCRETE | 17 | C1014; C1016; C1301; C1305; C1310; C1404; C1409; C1414; C1417; C1422; C1801; C1803; C1807; C1811; C1816; C1902; C2132 |
0402_CC | CAP_NP_0402_CC_DISCRETE_0.6MM_2 | 1.0UF | DISCRETE | 7 | C1202; C1203; C1207; C1209; C1705; C2003; C2134 |
0402_CC | CAP_NP_0402_CC_DISCRETE_0.55 _1 | 56PF | DISCRETE | 4 | C1204; C1206; C1210; C1212 |
0402_CC | CAP_NP_0402_CC_DISCRETE_0.55M_2 | 220PF | DISCRETE | 2 | C1410; C1413 |
0402_CC | CAP_NP_0402_CC_DISCRETE_0.55M_3 | 15PF | DISCRETE | 6 | C1416; C1419; C1425; C1426; C1427; C1428 |
0402_CC | CAP_NP_0402_CC_DISCRETE_0.55M_4 | 0.22UF | DISCRETE | 2 | C1704; C1904 |
0402_CC | CAP_NP_0402_CC_DISCRETE_0.55M_5 | 0.1uF | DISCRETE | 2 | C2001; C2006 |
0402_CC | CAP_NP_0402_CC_DISCRETE_0.74 MM | 0.01UF | DISCRETE | 1 | C2005 |
0402_CC | INDUCTOR_FERRITE_0402_CC_DISCRE | 120 Ohm | DISCRETE | 5 | L903; L904; L905; L1401; L1402 |
0402_CC | RES_0402_CC_DISCRETE_470-75394_ | 0 | DISCRETE | 88 | R903; R904; R905; R906; R912; R917; R919; R920; R921; R922; R923; R924; R925; R926; R927; R928; R929; R930; R931; R932; R933; R934; R935; R936; R937; R938; R939; R940; R941; R942; R943; R944; R945; R946; R1001; R1008; R1017; R1018; R1024; R1110; R1117; R1120; R1121; R1201; R1202; R1203; R1206; R1208; R1211; R1301; R1404; R1407; R1411; R1412; R1413; R1417; R1420; R1423; R1424; R1425; R1426; R1427; R1428; R1429; R1430; R1431; R1432; R1433; R1434; R1435; R1633; R1634; R1635; R1636; R1701; R1705; R1706; R1707; R1708; R1709; R1715; R1716; R1801; R1803; R1804; R1805; R1806; R1909 |
0402_CC | RES_0402_CC_DISCRETE_470-75597_ | 100K | DISCRETE | 8 | R913; R1102; R1105; R1119; R1303; R1305; R1402; R2003 |
0402_CC | RES_0402_CC_DISCRETE_470-75557_ | 10K | DISCRETE | 25 | R914; R1016; R1025; R1103; R1109; R1118; R1207; R1304; R1306; R1307; R1406; R1410; R1509; R1607; R1807; R1808; R1810; R1811; R1819; R1820; R1905; R1919; R2008; R2101; R2105 |
0402_CC | RES_0402_CC_DISCRETE_470-75626_ | 4.7K | DISCRETE | 7 | R1006; R1013; R1520; R1525; R1529; R1614; R1623 |
0402_CC | RES_0402_CC_DISCRETE_470-30905_ | 4.3K | DISCRETE | 1 | R1015 |
0402_CC | RES_0402_CC_DISCRETE_470-75636_ | 2.2K | DISCRETE | 2 | R1019; R1020 |
0402_CC | RES_0402_CC_DISCRETE_470-31028_ | 51.1K | DISCRETE | 1 | R1021 |
0402_CC | RES_0402_CC_DISCRETE_470-75555_ | 1K | DISCRETE | 31 | R1414; R1415; R1416; R1419; R1421; R1422; R1501; R1504; R1508; R1518; R1519; R1523; R1524; R1530; R1531; R1532; R1534; R1606; R1615; R1616; R1621; R1622; R1626; R1628; R1629; R1630; R1632; R1906; R1907; R2004; R2005 |
0402_CC | RES_0402_CC_DISCRETE_470-75607_ | 220 | DISCRETE | 4 | R1505; R1507; R1603; R1605 |
0402_CC | RES_0402_CC_DISCRETE_470-30927_ | 6.49K | DISCRETE | 2 | R1515; R1613 |
0402_CC | RES_0402_CC_DISCRETE_470-75609_ | 22K | DISCRETE | 1 | R1711 |
0402_CC | RES_0402_CC_DISCRETE_470-76089_ | 51 | DISCRETE | 1 | R1712 |
0402_CC | RES_0402_CC_DISCRETE_0.4 MM_470 | 10K | DISCRETE | 3 | R1713; R1714; R2002 |
0402_CC | RES_0402_CC_DISCRETE_470-76240_ | 100K | DISCRETE | 1 | R1809 |
0402_CC | RES_0402_CC_DISCRETE_470-31093_ | 200K | DISCRETE | 2 | R1812; R1816 |
0402_CC | RES_0402_CC_DISCRETE_470-31122_ | 360K | DISCRETE | 1 | R1813 |
0402_CC | RES_0402_CC_DISCRETE_470-75591_ | 100 | DISCRETE | 1 | R1915 |
0402_CC | RES_0402_CC_DISCRETE_0.40 MM_47 | 100K | DISCRETE | 1 | R2009 |
0402_CC | RES_0402_CC_DISCRETE_0.4MM_470- | 1M | DISCRETE | 10 | R2107; R2108; R2109; R2110; R2111; R2112; R2113; R2114; R2115; R2116 |
0603_CC | CAP_NP_0603_CC_DISCRETE_1.016MM | 10uF | DISCRETE | 14 | C901; C903; C1103; C1401; C1405; C1406; C1809; C1814; C1901; C2009; C2101; C2103; C2108; C2109 |
0603_CC | CAP_NP_0603_CC_DISCRETE_0.9MM_1 | 4.7uF | DISCRETE | 2 | C1109; C1112 |
0603_CC | CAP_NP_0603_CC_DISCRETE_1MM_150 | 22UF | DISCRETE | 7 | C1411; C1412; C1501; C1503; C1601; C1603; C2135 |
0603_CC | BEAD_0_0603_CC_DISCRETE_0.95MM_ | 120OHM | DISCRETE | 9 | L1102; L1104; L1403; L1801; L1901; L2002; L2003; L2101; L2102 |
0603_CC | RES_0603_CC_DISCRETE_470-80866_ | 0 | DISCRETE | 2 | R1026; R1405 |
0603_CC | RES_0603_CC_DISCRETE_0.55 MM_47 | 4.70K | DISCRETE | 1 | R1802 |
0603_CC | RES_0603_CC_DISCRETE_470-75402_ | 3.3K | DISCRETE | 2 | R2001; R2012 |
0603_CC | RES_0603_CC_DISCRETE_470-75399_ | 2.2K | DISCRETE | 1 | R2006 |
0805_CC | CAP_NP_0805_CC_DISCRETE_1.45 MM | 47uF | DISCRETE | 5 | C1106; C1703; C2004; C2127; C2128 |
0805_CC | CAP_NP_0805_CC_DISCRETE_1.4MM_1 | 1000pF | DISCRETE | 1 | C1111 |
0805_CC | RES_0805_CC_DISCRETE_470-75442_ | 0 | DISCRETE | 6 | R1122; R1123; R1124; R2013; R2014; R2106 |
0805_CC | RES_0805_CC_DISCRETE_470-78674_ | 62 | DISCRETE | 4 | R1204; R1205; R1209; R1210 |
CON1X2_1P25_SM | CON1X2_TAB_CON1X2_1P25_SM_IO_3. | WF1250201200 | IO | 2 | J1402; J1403 |
CON3_PWR_TH | PHONEJACK-3_CON3_PWR_TH_IO_11.2 | CON_1_PWR | IO | 1 | J2001 |
CON4_USB_A_FE_RA_TH | USB_A_CON4_USB_A_FE_RA_TH_IO_8. | USB_TYPE_A | IO | 1 | J1101 |
CON6_AUDJACK_RA_TH | CONN_AUDIOJACK_6P_CON6_AUDJACK_ | SPJ-31060AD | IO | 1 | J1401 |
CON9_SDCARD_28X29MM_SMT | SD_SOCKET_SMT_CON9_SDCARD_28X29 | SD01A-01202 | IO | 1 | P1701 |
CON14_FPC_0P5_RA_SMT_1 | CONN_HDR_7_CON14_FPC_0P5_RA_SMT | CON 1X14 | IO | 1 | J1802 |
CON50_FPC_0P5_RA_SMT_1 | CONN_1_CON50_FPC_0P5_RA_SMT_1_2 | FPC05050-08100 | IC | 1 | J901 |
CON_1X2_RJ45_1P27_TH_RA | RJ45_MAG_LED_24P_CON_1X2_RJ45_1 | CON_2XRJ45 | IO | 1 | J1501 |
CON_BBC_40P_0P4_SM_MIRROR | FX12B-40P_CON_BBC_40P_0P4_SM_MI | CONN PLUG 40 | IO | 1 | J1801 |
CON_FPC_20_0P5_RA_F050_1 | CON20_0_CON_FPC_20_0P5_RA_F050_ | FPC20 | IO | 1 | J1701 |
CON_RA_HDMI_19P_0P5_SM | ATOM010130010052_HDMI_19P_CON_R | CON HDMI 1X19 | IO | 1 | J1001 |
CON_USB_TYPE_B_SM | MICRO_USB_CONN_11PIN_CON_USB_TY | MICRO_USB_TYPEB | IO | 2 | J1102; J1901 |
CON_W2B_8M_1P25_SM_RA | CON_W2B_8P_CON_W2B_8M_1P25_SM_R | CON_8P | IO | 1 | J1201 |
DFN_10_0P4_2X2_B | MAG3112_DFN_10P_DFN_10_0P4_2X2_ | MAG3110 | IC | 1 | U1302 |
DIODE2_SOD523 | DIODE_TVS_BIDIR_DIODE2_SOD523_I | | IC | 7 | TVS1101; TVS1201; TVS1401; TVS1402; TVS1403; TVS1404; TVS2002 |
HDR_20M_100_TH | CONN_HDR_10X2_HDR_20M_100_TH_IO | BH25420B301 | IO | 1 | J1902 |
IND4_CHOKE_0805 | DLW43_IND4_CHOKE_0805_DISCRETE_ | 90OHM | DISCRETE | 3 | L1103; L1105; L1902 |
IND0603_CC | INDUCTOR_FERRITE_IND0603_CC_DIS | 470 Ohm | DISCRETE | 4 | L901; L902; L1501; L1601 |
LED_0606 | LED4_DUAL_OG_LED_0606_IC_0.7MM_ | LED ORANGE/GREEN | IC | 1 | D1903 |
LED_DUAL_3025MM_SM | LED_DUAL_SEP_RG_LED_DUAL_3025MM | LED_RED-GRN | IC | 1 | D2003 |
MH315-158T_6P | MOUNTING_HOLE_ATX_6P_MH315-158T | MOUNTING HOLE | IC | 2 | U2102; U2103 |
MIC_WM-63PR | MIC_POM_MIC_WM-63PR_IC_2.4MM_51 | EM6022P | IC | 1 | P1401 |
MLP6_2X2MM_SLUG | FDMA530PZ_MLP6_2X2MM_SLUG_IC_0. | FDMA530PZ | IC | 2 | Q2002; Q2003 |
PLATED_HOLE_120_220MIL | MOUNT_HOLE_PLATED_HOLE_120_220M | MOUNTING HOLE | IC | 4 | BH2101; BH2102; BH2103; BH2104 |
QFN5X3_0P5_3X3 | FXLS8471Q_16P_QFN5X3_0P5_3X3_IC | FXLS8471Q | IC | 1 | U1301 |
QFN28_5X5MM_3P3_EP | CP2102_QFN28_5X5MM_3P3_EP_IC_1M | CP2102 | IC | 1 | U1901 |
QFN32_0P5_EP3P3 | KSZ8081RNB_32P_QFN32_0P5_EP3P3_ | KSZ8081RNB | IC | 2 | U1501; U1601 |
QFN32_S142EP | WM8960_QFN_33P_QFN32_S142EP_IC_ | WM8960 | IC | 1 | U1401 |
SC_75 | PNP_SC_75_IC_0.9 MM_480-78465_M | MMBT3906TT1G | IC | 1 | Q2001 |
SO8 | MIC2526_8P_SO8_IC_1.73MM_312-75 | MIC2026-1YM | IC | 1 | U1101 |
SO8_1P27_4X5 | MC33901WEF-8P_SO8_1P27_4X5_IC_1 | MC34901WEF | IC | 2 | U1201; U1202 |
SODIMM_200_STD_0P6_SM_1 | SD200_0_SODIMM_200_STD_0P6_SM_1 | DDR2 SODIMM 200 | IO | 1 | J2101 |
SOD_523 | DIODE_SCHTKY_SOD_523_IC_0.7MM_4 | RB521S30T1G | IC | 9 | D901; D1102; D1701; D1702; D1801; D1802; D1905; D1906; D2002 |
SOD_523_1P4 | ZDIODE_SOD_523_1P4_IC_0.7MM_480 | MM5Z5V1ST1G | IC | 1 | D2001 |
SOT23-5_A | UM1750S-00_5P_SOT23-5_A_IC_1.25 | UM1750S-00 | IC | 2 | U1802; U1803 |
SOT23_S6 | SRV05-4_SOT23_S6_IC_1.45MM_480- | SRV05-4 | IC | 2 | U1102; U1203 |
SOT323_3 | 2SK3018_SOT323_3_IC_0.9MM_480-7 | 2SK3018 | IC | 7 | Q1102; Q1103; Q1702; Q1703; Q1801; Q1802; Q2004 |
SOT-23 | MOSFET_P_SOT-23_IC_1.12MM_480-7 | IRLML6401 | IC | 4 | Q901; Q1101; Q1701; Q2101 |
SOT-723 | DZ_DUAL_CK_C1C2A_SOT-723_IC_0.5 | ESD7C | IC | 1 | D1101 |
SSOP8 | SN74LVC2G126DCTR_SSOP8_IC_1.30 | SN74LVC2G126 | IC | 1 | U1902 |
SW4_PB_ESW_SM_P177 | SW_PB_ESW_SW4_PB_ESW_SM_P177_IC | SPST PB | IC | 2 | SW2101; SW2102 |
SW6_DPDT_11X6MM | SW_DPDT_3_SW6_DPDT_11X6MM_IC_9. | EG2209A | IC | 1 | SW2001 |
TESTPOINT_35MIL | T POINT R_TESTPOINT_35MIL_IC_0. | TP_35MIL | IC | 30 | TP1001; TP1501; TP1601; TP1802; TP1803; TP1901; TP1902; TP1903; TP1904; TP1905; TP1906; TP2001; TP2002; TP2003; TP2101; TP2102; TP2103; TP2104; TP2105; TP2106; TP2107; TP2108; TP2109; TP2110; TP2111; TP2112; TP2113; TP2114; TP2115; TP2116 |
TEST_LOOP | TESTLOOP_TEST_LOOP_IO_4.8 MM_21 | TEST POINT WHITE | IO | 1 | TP1713 |
TEST_PIN_TP107 | TESTLOOP_TEST_PIN_TP107_IO_2.28 | TESTLOOP | IO | 2 | TP2129; TP2130 |
TPAD_015 | TESTLOOP_TPAD_015_IO_0.1MM_211- | TPAD_015 | IO | 3 | TP1502; TP1503; TP1602 |
TPAD_020 | TESTLOOP_TPAD_020_IO_0.1MM_211- | TPAD_020 | IO | 13 | TP1301; TP1302; TP1303; TP1703; TP1705; TP2117; TP2118; TP2120; TP2121; TP2124; TP2126; TP2127; TP2128 |
TSSOP16 | 74LV595_TSSOP16_IC_1.1MM_312-79 | 74LV595PW | IC | 1 | U2101 |
