BPW34S | BPW_34_S_BPW34S_4MM_480-77972_Q | Q65110A1209 | IC | 1 | D1 |
CASE_A | CAP_POL_CASE_A_1.8MM_150-30020_ | 10UF | DISCRETE | 2 | C1; C52 |
CASE_A | CAP_POL_CASE_A_1.8MM_150-75413_ | 4.7UF | DISCRETE | 1 | C54 |
CC0603 | CAP_NP_CC0603_0.95MM_150-75142_ | 0.1UF | DISCRETE | 1 | C56 |
CC0603_OV | CAP_NP_CC0603_OV_0.95MM_150-751 | 0.1UF | DISCRETE | 24 | C4; C10; C13; C14; C15; C16; C19; C21; C25; C26; C27; C29; C32; C34; C36; C39; C41; C45; C46; C47; C48; C49; C50; C51 |
CC0603_OV | CAP_NP_CC0603_OV_0.9 MM_150-750 | 0.1UF | DISCRETE | 1 | C5 |
CC0603_OV | CAP_NP_CC0603_OV_0.90MM_150-751 | 18PF | DISCRETE | 4 | C7; C8; C30; C31 |
CC0603_OV | CAP_NP_CC0603_OV_0.9 MM_150-773 | 12.0PF | DISCRETE | 2 | C9; C11 |
CC0603_OV | CAP_NP_CC0603_OV_0.95MM_150-750 | 0.01UF | DISCRETE | 1 | C17 |
CC0603_OV | CAP_NP_CC0603_OV_1MM_150-30233_ | 0.47UF | DISCRETE | 1 | C18 |
CC0603_OV | CAP_NP_CC0603_OV_0.87 MM_150-78 | 1000PF | DISCRETE | 2 | C28; C40 |
CC0603_OV | CAP_NP_CC0603_OV_0.9MM_150-7735 | 3300PF | DISCRETE | 3 | C42; C43; C44 |
CC0603_OV | CAP_NP_CC0603_OV_0.86MM_150-758 | 47PF | DISCRETE | 2 | C53; C57 |
CC0603_OV | CAP_NP_CC0603_OV_0.86MM_150-750 | 180PF | DISCRETE | 1 | C55 |
CC1206_OV | CAP_NP_CC1206_OV_0.9MM_150-7754 | 8200PF | DISCRETE | 1 | C2 |
CC3216 | CAP_POL_CC3216_1.8MM_150-75055_ | 10UF | DISCRETE | 6 | C3; C12; C22; C23; C24; C33 |
CC3528-21 | CAP_POL_CC3528-21_2.1MM_150-785 | 47UF | DISCRETE | 2 | C37; C38 |
CCE40X54 | CAP_POL_CCE40X54_5.5MM_150-3032 | 4.7UF | DISCRETE | 1 | C20 |
CCE63X55 | CAP_POL_CCE63X55_5.7MM_150-7683 | 100UF | DISCRETE | 1 | C35 |
CN2X82_FINGER_ASS | CONN_PCI_XPRESS_X16_328P_CN2X82 | PCI EXPRESS X 16 | IO | 1 | J28 |
CON3_JACK_5X15_SM | MJ1-3510-SMT_CON3_JACK_5X15_SM_ | MJ1-3510-SMT | IC | 1 | J3 |
CON5_MUSB_AB_0P8_RA_SMT | USB_MINI_B_SKT_CON5_MUSB_AB_0P8 | USB_MINI_B 5 | IC | 1 | J17 |
DIODE_3P2X2P2_SMD | LED_1A2C_DIODE_3P2X2P2_SMD_1.10 | IR12-21C/TR8 | IC | 1 | D2 |
HC49SDLF | XTAL_HC49SDLF_4.2MM_230-77716_1 | 16MHZ | DISCRETE | 1 | Y2 |
HC49SDLF | XTAL_HC49SDLF_4.2MM_230-77700_4 | 4MHz | DISCRETE | 1 | Y3 |
HDR102 | CONN_HDR_1X2_HDR102_8.6MM_210-7 | HDR 1X2 TH | IC | 11 | J1; J2; J4; J6; J7; J8; J9; J11; J12; J20; J24 |
HDR103 | CONN_HDR_3X1_HDR103_8.6MM_210-7 | HDR TH 1X3 | IC | 6 | J5; J10; J15; J16; J26; J27 |
HDR203_M20 | CONN_HDR_3X2_HDR203_M20_8.64MM_ | HDR 2X3 | IC | 4 | J13; J14; J19; J25 |
HDR205 | CONN_HDR_5X2_HDR205_8.6MM_210-3 | HDR 2X5 | IC | 1 | J21 |
IND_0603 | IND_IND_0603_0.8MM_180-75495_10 | 100MHZ | DISCRETE | 3 | L1; L2; L3 |
IND_1206A | BEAD_IND_1206A_1.3MM_180-75060_ | 26OHM | DISCRETE | 2 | L4; L5 |
JUMP2X7-6040 | HDR-2X7_JUMP2X7-6040_8.6MM_210- | HDR_2X7 | IC | 1 | J18 |
LED_0603_C1 | LED_LED_0603_C1_1.0MM_370-76473 | OR/RED | IC | 2 | D3; D11 |
LED_0603_C1 | LED_LED_0603_C1_1.0MM_370-76472 | YEL/GRN | IC | 2 | D6; D9 |
LED_0603_C1 | LED_LED_0603_C1_1.0MM_370-76471 | YEL | IC | 2 | D7; D12 |
LED_0603_C1 | LED_LED_0603_C1_1.0MM_370-76470 | AMB | IC | 2 | D8; D10 |
LGA14_0P80_3X5_SH | MMA7360L_LGA14_0P80_3X5_SH_1.05 | MMA7361L | IC | 1 | U6 |
MIC_WM-63PR | MIC_MIC_WM-63PR_1.4MM_510-75938 | MIC | IC | 1 | P500 |
PHTRANS_2P2X3P2 | PT12_PHTRANS_2P_PHTRANS_2P2X3P2 | PT12-21C/TR8 | IC | 1 | Q1 |
POT3_3352T | POT_POT3_3352T_470-80115_5K | 5K | IC | 1 | R52 |
POT3_3352W | POT_POT3_3352W_470-79999_10K | 10K | IC | 1 | R35 |
RC0402_25 | RES_RC0402_25_470-75557_10K | 10K | DISCRETE | 2 | R45; R48 |
RC0603_OV | RES_RC0603_OV_470-75846_1.0M | 1.0M | DISCRETE | 4 | R2; R11; R14; R43 |
RC0603_OV | RES_RC0603_OV_0.55 MM_470-75421 | 1.0K | DISCRETE | 2 | R4; R13 |
RC0603_OV | RES_RC0603_OV_470-75421_1.0K | 1.0K | DISCRETE | 1 | R8 |
RC0603_OV | RES_RC0603_OV_470-75399_2.2K | 2.2K | DISCRETE | 2 | R9; R18 |
RC0603_OV | RES_RC0603_OV_470-75420_100 | 100 | DISCRETE | 1 | R10 |
RC0603_OV | RES_RC0603_OV_0.55MM_470-75400_ | 22K | DISCRETE | 1 | R12 |
RC0603_OV | RES_RC0603_OV_0.55 MM_470-75389 | 33 | DISCRETE | 1 | R15 |
RC0603_OV | RES_RC0603_OV_470-75451_330 | 330 | DISCRETE | 6 | R16; R34; R37; R38; R39; R40 |
RC0603_OV | RES_RC0603_OV_470-75414_4.7K | 4.7K | DISCRETE | 4 | R17; R27; R41; R42 |
RC0603_OV | RES_RC0603_OV_470-79994_47.0 | 47 | DISCRETE | 2 | R19; R24 |
RC0603_OV | RES_RC0603_OV__470-75412_1K | 1K | DISCRETE | 2 | R20; R28 |
RC0603_OV | RES_RC0603_OV_470-75410_10K | 10K | DISCRETE | 4 | R21; R23; R25; R26 |
RC0603_OV | RES_RC0603_OV_470-75412_1K | 1K | DISCRETE | 1 | R22 |
RC0603_OV | RES_RC0603_OV_470-79996_1.8K | 1.8K | DISCRETE | 1 | R29 |
RC0603_OV | RES_RC0603_OV_470-75553_10M | 10M | DISCRETE | 1 | R31 |
RC0603_OV | RES_RC0603_OV_470-75407_0 | 0 | DISCRETE | 4 | R36; R46; R47; R50 |
RC0603_OV | RES_RC0603_OV_470-78668_1.5K | 1.5K | DISCRETE | 2 | R44; R49 |
RC0603_OV | RES_RC0603_OV_470-78114_150.0K | 150.0K | DISCRETE | 1 | R51 |
RC0603_OV | RES_RC0603_OV_470-30141_330K | 330K | DISCRETE | 1 | R53 |
RC0805_OV | RES_RC0805_OV_470-75498_33 | 33 | DISCRETE | 4 | R32; R33; R54; R55 |
RNET_4_8 | RES_ISO4_SINGLE_RNET_4_8_470-80 | 10k | DISCRETE | 3 | RN1; RN2; RN3 |
SMB_2P7X1P4 | DIODE_SCHTKY_SMB_2P7X1P4_0.73MM | MSS1P2L | IC | 1 | D4 |
SO6_A | 1T45_SO6_A_1.1MM_312-75172_SN74 | SN74LVC1T45 | IC | 2 | U3; U9 |
SO8 | MIC2526_8P_SO8_1.73MM_312-75936 | MIC2026-1YM | IC | 1 | U2 |
SO8_UMAX | TS462CST_SO8_UMAX_1.1MM_315-788 | TS462 | IC | 1 | U8 |
SOT23 | PNP_SOT23_1.3MM_480-75192_MMBT3 | MMBT3906L | IC | 1 | Q2 |
SOT23 | NPN_SOT23_1.12 MM_480-75173_MMB | MMBT3904LT1G | IC | 2 | Q4; Q5 |
SOT223 | LM1117_SOT223_1.9 MM_315-78813_ | LD1117-3.3 | IC | 1 | U5 |
SOT-23 | DIODE_SCH_123_SOT-23_1.3MM_480- | BAT54C | IC | 1 | D5 |
SOT-23 | TRAN_NPN_RES_SOT-23_1.3MM_480-7 | PDTC115T | IC | 1 | Q3 |
SW4_6P5X7MM | SW_DIP-2_SW4_6P5X7MM_4.2MM_510- | SW_DIP-2/SM | IC | 1 | SW3 |
SW_SPST_TH | SW_PSHBT_SPST_2_SW_SPST_TH_7MM_ | LIGHT TOUCH PUSH BUTTON | IC | 3 | SW1; SW2; SW4 |
TESTPOINT_35MIL | TEST PAD_TESTPOINT_35MIL_0.1 MM | 35 MIL | IC | 3 | TP503; TP505; TP506 |
TP_TH_040 | TESTLOOP_TP_TH_040_5.1MM_210-79 | GROUND PIN/LOOP | IC | 8 | TP2; TP4; TP5; TP6; TP7; TP8; TP9; TP10 |
TQFP44 | MC9S08JM60CFGE_TQFP44_1.60 MM_3 | MC9S08JM60CLD | IC | 1 | U4 |
TQFP80_5MM | MC9S08JE128-LQFP80_TQFP80_5MM_1 | MC9S08JE128VLK | IC | 1 | U1 |
TSSOP16 | ICL3232_TSSOP16_1.1 MM_312-7954 | ICL3232 | IC | 1 | U7 |
XTL2_ECS_SM | XTAL_XTL2_ECS_SM_2.0MM_230-7770 | 32.768kHz | DISCRETE | 1 | Y1 |
附件:
