作品名:[AD 10][2层]美国Genesis早期的 FLI30602 方案液晶电视PCB和原理图
: }- r* o; N9 ~ a. _& ~
) K0 Q( H) G/ {+ v1 O文件描述
% U- ?7 N! i9 b: ^7 O+ w1. 作品用途:液晶电视
* Y3 T3 T- d; C+ d2. 软件版本:AD 10
6 a; b- V4 Z' {0 G1 G: `0 C( p3. 层数:2层板
& s2 @* W* N' H* _+ v4. 用到的主要芯片:FLI30602 ' s; A8 z5 P1 l i8 T: V
5. PCB尺寸:112.4mm*90.4mm H6 ^5 n$ |; Q0 F M/ k1 t
$ T2 w& O1 `, o- i
作品截图如下:
9 `( b, \) k; X$ t# V1 F7 [& k顶层截图:
5 v9 O/ j: t9 m/ [( n
+ n) E9 J* S2 R" C/ ~$ }8 F
+ @* E- x; O) J" f) N, |底层截图:
0 u0 a" r6 Y, G% f/ d! f" b; N* P
6 L) Y! o# r8 D- b
, m, J/ m/ U- i d& {! n
全层截图:' ?, b4 J7 F7 y* d& L* N/ J4 \
6 a& d1 C# i1 ]& i& N
( M( m! m3 N4 W5 q5 m5 y
叠层信息截图如下:) U4 T" R. Y3 Y6 y: Q a
5 |% ~5 b7 \" P b& y. ~( m7 n
5 | y! A* q8 J/ @
BOM:
; J) B. O% m( U3 XComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 104 | C1, C3, C15, C28, C33, C36, C37, C66, C67, C68, C70, C71, C72, C80, C82, C84, C85, C86, C88, C89, C95, C96, C97, C98, C101, C102, C103, C104, C105, C109, C110, C112, C114, C115, C117, C118, C121, C126, C133, C134, C138, C141, C144, C145, C148, C149, C151 | C-0603 | 47 | 105 | C2, C4, C5, C7, C8, C9, C11, C22, C23, C25, C38, C39, C40, C47, C53 | C-0603 | 15 | 103 | C6, C10, C18, C19, C52, C135 | C-0603 | 6 | 474 | C12, C16, C29, C41, C43 | C-0603 | 5 | 47pF | C13, C17, C31, C42, C44, C45, C46 | C-0603 | 7 | 22uF/16V | C14, C34, C75, C76, C79, C81, C83, C90, C91, C93, C94, C100, C108, C111, C113, C116, C123, C130, C143, C146, C147, C150 | CE4MM | 22 | 220uF/16V | C48, C49, C50, C51 | CE6MM | 4 | 10uF/16V | C54 | CE4MM | 1 | 33pF | C131, C132 | C-0603 | 2 | 470uF/16V | C137, C139 | CE8MM | 2 | CVBS_SVIDEO | CN1 | CON6-2MM | 1 | IOPort | CN2 | CON6-2MM | 1 | AUDIO_IN | CN3 | CON6-2MM | 1 | YPBPR_IN | CN4 | CON6-2MM | 1 | TUNER | CN5 | CON8-2MM | 1 | PCINPU | CN6 | CON12-2MM | 1 | PWMOUT | CN7 | CON2-2MM | 1 | 87089-40 | CN8 | RCJP0.5-40TH | 1 | DC1R019WDH | CN13 | RCJP0.5-22TH | 1 | KEYPAD_IN | CN14 | CON10-2MM | 1 | IR_IN | CN15 | CON3-2MM | 1 | HEADER 4 | CN17, CN18, CN26 | CON4-2MM | 3 | 87089-40 | CN20 | CON40-2MMX2 | 1 | BACK-LIGHT | CN22 | CON6-2MM | 1 | BAT54 | D4 | SOT23 | 1 | BAV70 | D5 | SOT23 | 1 | PESD5V0S1BA | D7, D8, D20, D21, D22, D25, D26, D27, D32, D33, D34 | SOD323 | 11 | SS34 | D10 | DIO/MELF | 1 | 1N4148 | D13 | MINIMELF | 1 | 24V/5A | F1 | F1206 | 1 | 120R | FB1, FB2, FB3, FB4, FB5, FB6, FB7, FB8, FB9, FB10, FB11, FB12, FB13, FB14, FB15, FB16, FB17, FB18, FB19 | R-0603 | 19 | 4MM | HL1, HL2, HL3, HL4 | HOLE4-7 | 4 | JUMP | JP1 | HEADER3X2\100 | 1 | 22uH/3A | L1 | RCL14CA | 1 | MMBT3904L | Q3, Q6, Q7, Q8, Q9 | SOT23 | 5 | AO3401 | Q10 | DSOT-23 | 1 | 4.7K | R1, R3, R11, R77, R78, R79, R194, R200, R202 | R-0603 | 9 | 57.6R/1% | R2, R4, R7, R9 | R-0603 | 4 | 20R/1% | R5, R10, R13, R38, R43, R46, R61, R63, R64 | R-0603 | 9 | 2.2K | R6, R210 | R-0603 | 2 | 75R/1% | R8, R14, R17, R18, R40, R48, R57, R65, R66, R69 | R-0603 | 10 | 10K | R12, R59, R60, R96, R98, R99, R105, R107, R110, R116, R123, R125, R133, R139, R142, R158, R159, R160, R161, R168, R192, R195, R196, R197, R198, R199 | R-0603 | 26 | 0R | R15, R16, R49, R51, R53, R109, R115, R144, R163, R164, R167, R169, R170, R171, R172, R174, R181, R182 | R-0603 | 18 | 5.1K/1% | R24, R25, R28, R29, R54, R56, R67, R70, R72, R76 | R-0603 | 10 | 100R | R62, R68, R97, R100, R101, R102 | R-0603 | 6 | 47R/1% | R71, R73 | R-0603 | 2 | 510R/1% | R74, R75 | R-0603 | 2 | 27K | R95, R208 | R-0603 | 2 | 1K | R106, R120 | R-0603 | 2 | 100K | R108, R124, R127, R130, R135, R136, R140, R141, R143, R193 | R-0603 | 10 | 10K NC | R112, R137 | R-0603 | 2 | 56R/1% | R114 | R-0603 | 1 | 5.9K | R118, R206 | R-0603 | 2 | 820K | R119 | R-0603 | 1 | 2K | R121, R122 | R-0603 | 2 | 250R/1% | R131 | R-0603 | 1 | 100K NC | R132, R138 | R-0603 | 2 | 2.7K | R151, R152, R165, R166 | R-0603 | 4 | 7.5K(6.2k) | R178 | R-0603 | 1 | 17.4K(12k) | R179 | R-0603 | 1 | 0R NC | R180 | R-0603 | 1 | 47K | R203 | R-0603 | 1 | 1.3K | R204 | R-0603 | 1 | 6.8K | R205 | R-0603 | 1 | 15K | R207 | R-0603 | 1 | 330R | R209 | R-0603 | 1 | 0R x 8 | RN1, RN2, RN3, RN4, RN5, RN6, RN7 | R0603-4 | 7 | M24C02 | U1 | SOIC-8 | 1 | SN74LVC14APWR | U2 | SOP-14 | 1 | TDA7496 | U3 | DIP20 | 1 | Rclamp0514M | U6, U7 | MSOP-10 | 2 | 24AA02 | U8 | SOIC-8 | 1 | SST25VF080 | U9 | SOIC-8-200 | 1 | FLI30XXX | U10 | SQFP40P3060X3060 | 1 | 24LC32-SN | U12 | SOIC-8 | 1 | AP1510 | U13 | SOIC-8 | 1 | LT1084-3.3 | U14 | TO263-3 | 1 | AMC1117-1.8 | U15 | SOT-223 | 1 | 19.6608MHz | X1 | HC49 | 1 |
8 r$ h& ?4 d4 l1 B$ d附件:: F$ q: A1 d5 u1 c! M, y1 Q! i
原理图和PCB源文件如下:0 G% ]( J; ] c- G/ d0 m: q
) l1 l3 h2 Q% ^9 k, Q$ E$ @( O) ?7 @# l& V4 e
$ q5 M; p6 i2 C9 T |
