查看: 474|回复: 5
[allegro16.6][12层]工业主板(XC6VLX240T+CDCE18005+LTC2285+MAX5875)原理图和pc...
发表于 2020-1-21 17:25 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][12层]工业主板(XC6VLX240T+CDCE18005+LTC2285+MAX5875)原理图和pcb文件
文件描述:
1. 作品用途:工业主板
2. 软件版本:allegro16.6
3. 层数:12层
4. 用到的主要芯片:XC6VLX240T+CDCE18005+LTC2285+MAX5875
5. PCB尺寸:6296*3937 mil
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
0603_A4RP_0603_A4_RPRPIC7RP1; RP2; RP3; RP4; RP5; RP6; RP7
0805_A4CP_0805_A4_CPCPIC9CP1; CP2; CP3; CP4; CP5; CP6; CP7; CP8; CP9
282825-44 HEADER_282825-4_4 HEADER4 HEADERIC1J1
D0805_LCCL-CRS10/SM_D0805_L_CCL-CRS10/CCL-CRS10/SMIC5D1; D2; D3; D4; D5
D0805_LDIODE PIN_D0805_L_DIODE PINDIODE PINIC4D_JTAG_ADD1; D_JTAG_ADD2; D_JTAG_ADD3; D_JTAG_ADD4
D7343_LCAP POL_D7343_L_330U330uIC4C73; C74; C75; C76
D7343_LCAP POL_D7343_L_100U100uIC8C183; C273; C277; C284; C287; C299; C300; C320
FF784XC6VLX240T_FFG784_FF784_(S1+S2+XC6VLX240T_FFG784IC1FPGA1
FT64_LXCF128XFT_FT64_L_XCF128XFTXCF128XFTIC1U18
JTAG_LXILINX JTAG_JTAG_L_XILINX JTAGXilinx JTAGIC1XJ2
MF72-5D7_LPTC_MF72-5D7_L_PTCPTCIC1U30
MF72-25D13_LPTC_MF72-25D13_L_PTCPTCIC2U33; U35
MINISMDC125F_LICL_MINISMDC125F_L_ICLICLIC1U31
MM50-200B2-1EDDR2_SODIMM_MM50-200B2-1E_DDR2DDR2 SODIMMIC1DDR1
OSC4S_LOSCILLATOR_OSC4S_L_OSCILLATOROscillatorIC2OSC1; OSC2
PTH03010_LPTH03010_PTH03010_L_PTH03010PTH03010IC1U44
PTH05050W_LPTH05050W_PTH05050W_L_PTH05050WPTH05050WIC1U32
PTH05050W_LPTH05050W_PTH05050W_L_PTH03050WPTH03050WIC1U38
PXI_P1_LPXI_P1_PXI_P1_L_(S1+S2+S3+S4+S5PXI_P1IC1PXI3
PXI_XP3_LPXI_XP3_PXI_XP3_L_(S1+S2+S3+S4+PXI_XP3IC1PXI2
PXI_XP4_LPXI_XP4_PXI_XP4_L_(S1+S2+S3+S4+PXI_XP4IC1PXI1
QFN48_LARGE_LCDCE18005_QFN48_LARGE_L_CDCE180CDCE18005IC1CDCE2
QFN64_LARGE_LLTC2285_QFN64_LARGE_L_LTC2285LTC2285IC1LTC2285_1
QFN68_LARGE_LMAX5875_QFN68_LARGE_L_MAX5875MAX5875IC2MAX1; MAX2
R0402_LC_R0402_L_0.1U0.1uIC61C37; C38; C43; C47; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C68; C69; C71; C79; C80; C81; C82; C83; C84; C85; C89; C96; C97; C98; C99; C104; C105; C106; C107; C110; C113; C116; C119; C122; C129; C130; C131; C137; C140; C143; C146; C195; C196; C197; C210; C211; C212; C223; C224; C225; C404; C405; C406; C408; C409; C410; C411
R0603_LC_R0603_L_1N1nIC5C1; C30; C33; C151; C158
R0603_LC_R0603_L_0.1U0.1uDISCRETE149C2; C3; C4; C5; C6; C7; C8; C9; C10; C11; C12; C13; C14; C15; C16; C17; C18; C19; C20; C21; C22; C23; C24; C25; C26; C29; C31; C32; C34; C35; C39; C40; C41; C42; C123; C124; C125; C126; C128; C147; C163; C164; C165; C166; C167; C168; C169; C170; C171; C172; C173; C174; C175; C176; C177; C178; C179; C180; C181; C182; C228; C233; C237; C240; C243; C244; C245; C246; C247; C248; C250; C252; C253; C254; C255; C256; C257; C258; C259; C260; C262; C264; C265; C266; C267; C268; C269; C270; C271; C272; C281; C304; C305; C308; C309; C339; C340; C341; C348; C349; C350; C354; C355; C356; C360; C361; C362; C367; C368; C369; C373; C374; C375; C384; C385; C386; C387; C388; C389; C390; C391; C392; C393; C394; C395; C396; C397; C398; C399; C418; C419; C420; C_ADD1; C_PXIE1; C_PXIE2; C_PXIE3; C_PXIE4; C_PXIE5; C_PXIE6; C_PXIE7; C_PXIE8; C_PXIE9; C_PXIE10; C_PXIE11; C_PXIE12; C_PXIE13; C_PXIE14; C_PXIE15; C_PXIE16
R0603_LC_R0603_L_20P20pIC6C148; C149; C150; C155; C156; C157
R0603_LC_R0603_L_60P60pIC6C152; C153; C154; C159; C160; C161
R0603_LC_R0603_L_1U1uIC7C162; C231; C234; C235; C238; C249; C261
R0603_LC_R0603_L_0.01U0.01uIC1C198
R0603_LC_R0603_L_5.0P5.0pIC2C226; C227
R0603_LC_R0603_L_2.2U2.2uIC4C229; C232; C236; C242
R0603_LC_R0603_L_12P12pIC2C230; C239
R0603_LC_R0603_L_10N10nIC2C283; C293
R0603_LC_R0603_L_10U10uIC31C288; C289; C290; C291; C294; C295; C296; C297; C315; C316; C317; C318; C322; C323; C324; C325; C326; C327; C328; C329; C330; C331; C332; C333; C334; C335; C336; C337; C338; C402; C403
R0603_LC_R0603_L_10P10pIC4C_JTAG_ADD1; C_JTAG_ADD2; C_JTAG_ADD3; C_JTAG_ADD4
R0603_LL_R0603_L_100MHZ100MHzIC13L8; L10; L12; L13; L14; L15; L16; L17; L18; L19; L20; L21; L22
R0603_LR_R0603_L_INFINFIC3LED_ADD1; LED_ADD2; LED_ADD3
R0603_LR_R0603_L_10K10kIC20R1; R2; R3; R4; R5; R6; R7; R18; R19; R20; R22; R23; R24; R25; R27; R28; R29; R30; R44; R48
R0603_LR_R0603_L_20K20kIC1R8
R0603_LR_R0603_L_00IC44R9; R21; R34; R43; R55; R59; R63; R67; R71; R75; R95; R106; R107; R108; R110; R111; R112; R126; R148; R151; R173; R177; R178; R221; R222; R229; R230; R231; R232; R233; R234; R235; R236; R237; R238; R239; R249; R250; R251; R252; R253; R254; R272; R278
R0603_LR_R0603_L_1010IC5R10; R14; R15; R17; R90
R0603_LR_R0603_L_5050IC14R11; R12; R13; R36; R42; R58; R66; R74; R139; R164; R243; R244; R258; R259
R0603_LR_R0603_L_100100IC10R16; R37; R50; R79; R84; R85; R86; R91; R92; R190
R0603_LR_R0603_L_1K1kIC52R26; R62; R70; R78; R80; R81; R82; R83; R87; R88; R89; R93; R94; R96; R97; R98; R113; R114; R115; R116; R118; R120; R121; R122; R123; R124; R125; R133; R140; R158; R165; R176; R179; R180; R181; R184; R185; R219; R266; R267; R268; R270; R271; R273; R274; R275; R_ADD2; R_LED_ADD1; R_LED_ADD2; R_LED_ADD3; R_POWER_ADD1; R_POWER_ADD2
R0603_LR_R0603_L_2.7K2.7kIC4R31; R32; R45; R46
R0603_LR_R0603_L_300300IC4R33; R39; R47; R52
R0603_LR_R0603_L_2525IC16R35; R38; R49; R51; R223; R224; R225; R226; R245; R246; R247; R248; R260; R261; R262; R263
R0603_LR_R0603_L_7.8K7.8kIC4R40; R41; R53; R54
R0603_LR_R0603_L_500500IC6R56; R61; R64; R69; R72; R77
R0603_LR_R0603_L_225225IC6R57; R60; R65; R68; R73; R76
R0603_LR_R0603_L_4.7K4.7KIC7R99; R100; R101; R102; R103; R104; R105
R0603_LR_R0603_L_330330IC7R109; R132; R135; R138; R157; R160; R163
R0603_LR_R0603_L_2K2KIC10R117; R149; R174; R220; R228; R240; R242; R255; R257; R_ADD3
R0603_LR_R0603_L_510510IC24R127; R128; R129; R130; R131; R134; R136; R137; R141; R142; R143; R147; R152; R153; R154; R155; R156; R159; R161; R162; R166; R167; R168; R172
R0603_LR_R0603_L_5K5kIC4R144; R146; R169; R171
R0603_LR_R0603_L_3K3kIC5R150; R175; R227; R241; R256
R0603_LR_R0603_L_150150IC4R186; R187; R188; R189
R0603_LR_R0603_L_4.75K4.75kIC2R217; R218
R0603_LR_R0603_L_6.18K6.18kIC2R264; R265
R0603_LR_R0603_L_2.22K2.22kIC1R269
R0603_LR_R0603_L_17.5K17.5kIC2R276; R277
R0805_LC_R0805_L_10U10uIC73C36; C44; C48; C49; C50; C51; C78; C93; C94; C95; C101; C102; C103; C109; C112; C115; C118; C127; C136; C142; C145; C184; C199; C274; C275; C276; C278; C279; C280; C282; C285; C286; C292; C298; C301; C302; C303; C306; C307; C310; C311; C312; C313; C314; C319; C321; C342; C343; C344; C345; C346; C347; C351; C352; C353; C357; C358; C359; C363; C364; C365; C366; C370; C371; C372; C400; C401; C412; C413; C414; C415; C416; C417
R1210_LL_R1210_L_10UH10uHIC2L1; L2
R1210_LL_R1210_L_100MHZ100MHzIC7L3; L4; L5; L6; L7; L9; L11
RGEF600_LICL_RGEF600_L_ICLICLIC2U34; U36
SIP_3P_100RVAR_DIP_SIP_3P_100_1K1kIC2R145; R170
SMA_LSMA_SMA_L_SMASMAIC7SMA1; SMA2; SMA3; SMA4; SMA5; SMA6; SMA7
SO8_LSN65ELT22_SO8_L_SN65ELT22SN65ELT22IC1U11
SO8_LAD8056_SO8_L_AD8056AD8056IC7U13; U14; U15; U24; U25; U27; U28
SO8_LAD8138_SO8_L_AD8138AD8138IC2U26; U29
SO8_PAD_LADP1706_SO8_PAD_L_ADP1706ADP1706IC2U39; U42
SOP08_LDSW4_SOP08_L_DSW4DSW4IC1U23
SOT23_5_LOPA209_SOT23_5_L_OPA209OPA209IC2U40; U43
SOT23_6_LSN74LVC1T45_SOT23_6_L_SN74LVC1TSN74LVC1T45IC4U6; U7; U8; U9
SOT23_LNDS336P_SOT23_L_NDS336PNDS336PIC2Q1; Q2
SOT23_LMA147_SOT23_L_MA147MA147IC2U10; U12
SOT223ALM1117_SOT223A_LM1117LM1117IC5U47; U48; U49; U50; U51
SW2_LSW2_PB_SW2_L_SW2_PBSW2_PBIC2SW1; SW3
S_PDSO_G10TPS51100DGQ_S_PDSO_G10_TPS51100TPS51100DGQIC2U37; U52
TANT_BCAP POL_TANT_B_47U47uIC8C77; C108; C376; C377; C378; C380; C382; C383
TANT_BCAP POL_TANT_B_100U100uIC2C92; C100
TO92TL431_TO92_TL431TL431IC2U41; U45
TO263_3_L7905_TO263_3_L_79057905IC1U46
TSSOP8_L74LVC3G07_TSSOP8_L_74LVC3G0774LVC3G07IC1U5
TSSOP16_LICS854104_TSSOP16_L_ICS854104ICS854104IC1U17
TSSOP20_LICS874001_TSSOP20_L_ICS874001ICS874001IC1U16
TSSOP48_LSN74LVCH16T245_TSSOP48_L_SN74LVSN74LVCH16T245IC4U1; U2; U3; U4
TSSOP48_LSN74LVCH16T245_TSSOP48_L_SN74AVSN74AVCH16T245IC4U19; U20; U21; U22
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
& v, P2 F/ X$ {& n5 x( s2 t
发表于 2023-1-7 17:19 | 只看该作者
谢谢分享,不错哈
发表于 2023-1-7 17:25 | 只看该作者
没有原理图啊
    2025-8-18 15:03
  • 签到天数: 98 天
    [LV.6]常住居民II
    发表于 2023-1-9 10:14 | 只看该作者
    看看,相互学习!. ~8 u$ C- o# W$ }/ o7 J% E0 s
    GMT+8, 2025-8-19 17:09 , Processed in 0.156250 second(s), 27 queries , Gzip On.
