Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
806-0101 | SMA-CON-R_806-0101_DOSIN-806-00 | DOSIN-806-0011 | IC | 1 | J2 |
2450BL15B050 | 2450BL15B050E_2450BL15B050_HHM1 | HHM1526 | IC | 1 | T2 |
ACFF-1024 | ACFF-1024_ACFF-1024_ACFF-1024 | ACFF-1024 | IC | 1 | U3 |
ANTS3L | CONN_UFL_0_ANTS3L_U.FL-R-SMT-1 | U.FL-R-SMT-1 | IC | 1 | J1 |
C0402 | CAP NP_C0402_2.7NF | 2.7nF | IC | 1 | C2 |
C0402 | CAP NP_C0402_100NF | 100NF | IC | 16 | C5; C15; C16; C27; C39; C43; C48; C51; C52; C54; C55; C56; C60; C62; C63; C105 |
C0402 | CAP NP_C0402_1UF | 1UF | IC | 24 | C6; C8; C9; C11; C17; C24; C35; C37; C38; C42; C45; C47; C49; C50; C53; C59; C104; C108; C110; C111; C112; C113; C114; C115 |
C0402 | CAP NP_C0402_10NF | 10NF | IC | 3 | C7; C10; C18 |
C0402 | CAP NP_C0402_2.2UF | 2.2UF | IC | 2 | C12; C14 |
C0402 | CAP NP_1_C0402_1NF | 1NF | IC | 1 | C23 |
C0402 | CAP NP_1_C0402_22PF | 22PF | IC | 6 | C25; C29; C31; C36; C116; C117 |
C0402 | CAP NP_C0402_10PF | 10PF | IC | 1 | C26 |
C0402 | CAP NP_1_C0402_4.7PF | 4.7PF | IC | 1 | C28 |
C0402 | CAP NP_1_C0402_0.7PF | 0.7PF | IC | 1 | C30 |
C0402 | CAP NP_1_C0402_1.5PF | 1.5PF | IC | 1 | C32 |
C0402 | CAP NP_0_C0402_4.7PF | 4.7PF | IC | 1 | C33 |
C0402 | CAP NP_1_C0402_1.8PF | 1.8PF | IC | 1 | C34 |
C0402 | CAP NP_C0402_470PF | 470PF | IC | 1 | C102 |
C0603 | CAP NP_C0603_3.9NF | 3.9nF | IC | 1 | C1 |
C0603 | CAP NP_C0603_82NF | 82NF | IC | 1 | C3 |
C0603 | CAP NP_C0603_68NF | 68NF | IC | 1 | C4 |
C0603 | CAP NP_C0603_22PF | 22PF | IC | 1 | C13 |
C0603 | CAP NP_C0603_10UF | 10UF | IC | 3 | C64; C103; C109 |
C0805 | CAP NP_C0805_47UF | 47UF | IC | 3 | C40; C61; C118 |
D26X68 | TP_P0_0.8_D0_D26X68_HOLE | HOLE | IC | 4 | H5; H6; H7; H8 |
DFN_2020-8 | PR505K_DFN_2020-8_PR505K001C | PR505K001C | IC | 1 | U10 |
DSPV08LHGET | SW_DIP_0_DSPV08LHGET__DSPV08LHG | DSPV08LHGET | IC | 1 | SW1 |
HOLE_1R4X2R8 | TP_P0_0.8_D0_HOLE_1R4X2R8_HOLE | HOLE | IC | 4 | H1; H2; H3; H4 |
HSL1008 | PINDUCTOR_0_HSL1008__2.2UH | 2.2uH | IC | 1 | L10 |
JUMPER_3P-254MM | HD3_JUMPER_3P-254MM_HD3 | HD3 | IC | 1 | J27 |
JUMPER_6P-2MM | HD6_JUMPER_6P-2MM_HD6 | HD6 | IC | 1 | J4 |
L0402 | FB_L0402_600OHM | 600ohm | IC | 2 | FB1; FB4 |
L0402 | IND_L0402_100NH | 100nH | IC | 2 | L5; L6 |
L0402 | IND_L0402_2.0NH | 2.0nH | IC | 1 | L7 |
L0402 | IND_L0402_4.7NH | 4.7nH | IC | 1 | L8 |
L0402 | IND_L0402_2.2NH | 2.2nH | IC | 1 | L9 |
L0805 | FB_L0805_220OHM | 220ohm | IC | 2 | FB3; FB5 |
L0805 | INDUCTOR_L0805_10UH | 10uH | IC | 1 | L1 |
L0805 | IND_L0805_22NH | 22nH | IC | 1 | L2 |
LED0805 | LED_LED0805__GREEN | Green | IC | 1 | D1 |
LEDX1_2R54 | LED_LEDX1_2R54__GREEN | Green | IC | 2 | D2; D3 |
LQFP32_7X7MM | ST32F030_LQFP32_7X7MM_STM32F030 | STM32F030K8T6 | IC | 1 | U9 |
LTC542_QFN20 | LT1575_0_LTC542_QFN20_LTC5542IU | LTC5542IUH | IC | 1 | U4 |
LTC6948_QFN28 | LTC6948IUFD-QFN28UFD-4X5_0_LTC6 | LTC6948IUFD-2 | IC | 1 | U1 |
MGA_64606 | MGA-64606_MGA_64606_MGA-64606 | MGA-64606 | IC | 1 | U2 |
R0402 | RES_R0402_0R | 0R | IC | 10 | R3; R5; R9; R11; R14; R16; R18; R24; R28; R52 |
R0402 | RES_R0402_15R | 15R | IC | 1 | R4 |
R0402 | RES_R0402_51R1 | 51R1 | IC | 1 | R7 |
R0402 | RES_R0402_470R | 470R | IC | 2 | R8; R41 |
R0402 | RES_R0402_200K | 200K | IC | 1 | R10 |
R0402 | RES_R0402_6K8 | 6K8 | IC | 1 | R13 |
R0402 | RES_R0402_2K | 2K | IC | 1 | R15 |
R0402 | RES_R0402_10R | 10R | IC | 1 | R17 |
R0402 | RES_R0402_1K | 1K | IC | 1 | R19 |
R0402 | RES_R0402_10K | 10K | IC | 19 | R22; R23; R25; R26; R27; R29; R30; R31; R32; R33; R34; R37; R42; R43; R45; R46; R47; R48; R50 |
R0402 | RES_R0402_100K | 100K | IC | 1 | R38 |
R0402 | RES_R0402_33R | 33R | IC | 1 | R44 |
R0402 | RES_R0402_53K6 | 53K6 | IC | 1 | R49 |
R0603 | RES_R0603_61R9 | 61R9 | IC | 2 | R1; R2 |
R0603 | RES_R0603_10R | 10R | IC | 1 | R6 |
SOT23-5 | RP111X_SOT23-5_RP111N331D-TR-FE | RP111N331D-TR-FE | IC | 3 | U5; U6; U8 |
TC4-1W | CTX100-1P_16_TC4-1W_TC4-1W-7ALN | TC4-1W-7ALN+ | IC | 1 | T1 |
TC800-3225 | TCXO_TC800-3225_7Q-40.000MBS-T | 7Q-40.000MBS-T | IC | 1 | Y1 |
TP30 | TESTLOOP_TP30__TP30 | tp30 | IC | 2 | TP1; TP2 |
UBAF-2203B | USB_A_1_UBAF-2203B_UBAF-2203B | UBAF-2203B | IC | 1 | J28 |
USBMICRO5_6A | USB_MICRO_0_USBMICRO5_6A__UBAF2 | UBAF2-006-SMT | IC | 1 | J25 |
附件:
