Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
0201_SOLDER_BLOB_JUMPER_SHORT | RES_SHORT-2_0201_SOLDER_BLOB_JU | 0201 SHORT | DISCRETE | 1 | SH1 |
BGA96_0P8_8P15X14P15 | MT41J256M16RE_FBGA96_BGA96_0P8_ | MT41K256M16TW-107 | IC | 1 | U10 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_1 | 0.1UF | DISCRETE | 63 | C3; C4; C10; C13; C51; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C62; C63; C64; C67; C68; C75; C76; C114; C115; C116; C117; C119; C120; C122; C135; C137; C140; C141; C142; C143; C155; C156; C157; C158; C159; C161; C172; C173; C201; C203; C211; C213; C214; C216; C218; C220; C222; C224; C226; C227; C228; C229; C231; C235; C236; C237; C241; C242 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.35MM_1 | 1uF | DISCRETE | 12 | C11; C82; C85; C212; C215; C217; C219; C221; C223; C225; C232; C238 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_2 | 0.1UF | DISCRETE | 11 | C24; C26; C30; C32; C45; C46; C49; C144; C146; C148; C150 |
CC0201 | CAP_NP_CC0201_DISCRETE_0.33MM_3 | 3300PF | DISCRETE | 4 | C80; C90; C209; C210 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 1.0UF | DISCRETE | 11 | C2; C7; C36; C37; C43; C47; C48; C147; C149; C151; C152 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 2.2uF | DISCRETE | 7 | C8; C92; C93; C94; C95; C101; C160 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | DISCRETE | 1 | C14 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_3 | 33pF | DISCRETE | 1 | C20 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_3 | 820pF | DISCRETE | 1 | C21 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_4 | 560PF | DISCRETE | 1 | C22 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_2 | 4.7uF | DISCRETE | 9 | C23; C25; C31; C38; C44; C81; C89; C205; C207 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_4 | 0.47uF | DISCRETE | 1 | C35 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_5 | 0.22UF | DISCRETE | 1 | C42 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.7MM | 10uF | DISCRETE | 2 | C79; C84 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.74 | 0.01UF | DISCRETE | 17 | C102; C103; C104; C105; C108; C109; C110; C111; C123; C124; C125; C126; C129; C130; C131; C132; C174 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6MM | 1.0UF | DISCRETE | 2 | C106; C127 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.65M | 4.7UF | DISCRETE | 1 | C162 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_2 | 2.2uF | DISCRETE | 2 | C163; C208 |
CC0603_NFM18PC | NFM18PC225B1A3_CC0603_NFM18PC_D | NFM18PC225B1A3 | DISCRETE | 5 | FL3; FL4; FL5; FL6; FL7 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1MM_2 | 22uF | DISCRETE | 7 | C28; C29; C33; C98; C168; C169; C170 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9 M | 4.7uF | DISCRETE | 3 | C71; C73; C154 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1MM_1 | 22uF | DISCRETE | 3 | C96; C97; C100 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.95M | 10UF | DISCRETE | 4 | C107; C113; C128; C134 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.45M | 47UF | DISCRETE | 4 | C83; C88; C204; C206 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.9MM | 100uF | DISCRETE | 2 | C12; C16 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.52M | 1000pF | DISCRETE | 2 | C112; C133 |
CON2_2P54_RA_TH_5P33X8P43MM | CONN_HDR_2X1_CON2_2P54_RA_TH_5P | HDR 1X2 | IO | 1 | J12 |
CON3_JACK_3P5MM_SM | CONN_AUDIOJACK_3P_CON3_JACK_3P5 | AUDIO 3 | IO | 2 | J8; J13 |
CON5_USBMICROAB_0P65_SM_RA | ZX62RD-AB-5P8_USB_MICROAB_CON5_ | CON SKT 5 SMT | IO | 1 | J11 |
CON10_MICROUSB_AB_0P65MM_SM_A | USB_MICRO_AB_10P_CON10_MICROUSB | USB3_MICRO_AB | IO | 1 | J5 |
CON_RJ45_12F_40_TH_RA | RJ45_LED_GY_CON_RJ45_12F_40_TH_ | 3520N811001-14LF | IO | 2 | J6; J7 |
DFN_8_0P5_2X2 | ICS524_DFN_8_0P5_2X2_IC_0.55 MM | 524S | IC | 1 | U30 |
DQFN14_3X2P5MM | 74LV08_QFN_14P_DQFN14_3X2P5MM_I | 74ALVC08BQ,115 | IC | 1 | U19 |
DQFN14_3X2P5MM | NTB0104BQ_DQFN14_3X2P5MM_IC_1MM | NTB0104BQ | IC | 1 | U670 |
HDR206_ESQ_SKT | CONN_HDR_6X2_HDR206_ESQ_SKT_IO_ | CON_2X6 | IO | 1 | J4 |
HDR208_ESQ_SKT | CONN_HDR_8X2_HDR208_ESQ_SKT_IO_ | CON_2X8 | IO | 2 | J1; J3 |
HDR210_ESQ_SKT | CONN_HDR_10X2_HDR210_ESQ_SKT_IO | CON_2X10 | IO | 1 | J2 |
HDR_5X2_FTSH_TH | CONN_HDR_5X2_HDR_5X2_FTSH_TH_IO | HDR 2X5 | IO | 2 | J9; J10 |
IND2_2P2X2P7_SM | INDUCTOR_IND2_2P2X2P7_SM_DISCRE | 1.0uH | DISCRETE | 1 | L5 |
IND_0603 | BEAD_FERRITE_IND_0603_DISCRETE_ | 120OHM | DISCRETE | 1 | L3 |
IND_0806_SM | INDUCTOR_IND_0806_SM_DISCRETE_1 | 2.2UH | DISCRETE | 2 | L11; L12 |
IND_2016A | INDUCTOR_IND_2016A_DISCRETE_1MM | 1.5uH | DISCRETE | 3 | L6; L7; L8 |
LED_0603 | LED_LED_0603_IC_0.7 MM_370-3001 | LED_GRN_DL | IC | 2 | D1; D2 |
LED_0603 | LED_LED_0603_IC_0.9MM_370-75079 | RED | IC | 1 | D3 |
LGA211_0P5_9P6SQ_NSP | LS1012A_LGA_211P_LGA211_0P5_9P6 | LS1012A | IC | 1 | U14 |
OSC4_2P5X2P0_SM | CLKGEN-SM_OSC4_2P5X2P0_SM_IC_1M | 24MHZ | IC | 1 | Y12 |
OSC4_2P6X2P1_SM | OSC4_KC2520_OSC4_2P6X2P1_SM_IC_ | 25MHz | IC | 1 | Y13 |
QFN8_1P6X1P6MM | 74LVC2T45GM_8P_QFN8_1P6X1P6MM_I | 74LVC2T45GM,125 | IC | 4 | U24; U25; U26; U28 |
QFN24_4X4MM_SLUG | MC34713_QFN24_4X4MM_SLUG_IC_1MM | MC34713EP | IC | 1 | U7 |
QFN32 | SGTL5000_32_QFN32_0.9MM_315-779 | SGTL5000 32QFN | IC | 1 | U18 |
QFN32_S142EP | PK20DX128V_QFN_32P_QFN32_S142EP | MK20DX128VFM5 | IC | 1 | U5 |
QFN48_0P5_7X7_EP4P14X4P22 | MC34VR5100A1EP_48P_EP_QFN48_0P5 | MC34VR5100A1EP | IC | 1 | U8 |
QFN_48_0P4_6X6MM | RTL8211_48P_QFN_48_0P4_6X6MM_IC | RTL8211FS | IC | 2 | U16; U17 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 10.0K | DISCRETE | 10 | R1; R8; R13; R25; R45; R46; R47; R116; R118; R747 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_2 | 330 | DISCRETE | 1 | R2 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_12 | 10.0K | DISCRETE | 1 | R4 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__4 | 33 | DISCRETE | 3 | R5; R7; R117 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__7 | 4.7K | DISCRETE | 22 | R6; R27; R41; R42; R70; R71; R73; R74; R75; R84; R85; R86; R87; R88; R125; R730; R731; R740; R744; R745; R750; R752 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_15 | 4.7K | DISCRETE | 1 | R9 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 MM_ | 8.25K | DISCRETE | 1 | R11 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__5 | 10.0K | DISCRETE | 1 | R12 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__8 | 20K | DISCRETE | 2 | R14; R18 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_2 | 5.36K | DISCRETE | 2 | R15; R19 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__9 | 2.0K | DISCRETE | 1 | R17 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_3 | 12.4K | DISCRETE | 1 | R20 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 68K | DISCRETE | 3 | R21; R22; R100 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_10 | 0 | DISCRETE | 3 | R24; R749; R754 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_4 | 240 | DISCRETE | 2 | R26; R28 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_4 | 200 | DISCRETE | 2 | R30; R62 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_11 | 698 | DISCRETE | 1 | R32 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45MM_4 | 3.74K | DISCRETE | 4 | R43; R44; R108; R109 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_3 | 1K | DISCRETE | 1 | R55 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_13 | 0.33 OHM | DISCRETE | 4 | R60; R61; R64; R66 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_5 | 5.1 | DISCRETE | 2 | R63; R65 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_14 | 510 | DISCRETE | 4 | R72; R77; R89; R91 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_7 | 2.49K | DISCRETE | 2 | R76; R90 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__2 | 0 | DISCRETE | 3 | R97; R104; R751 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_4 | 330 | DISCRETE | 1 | R102 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_1 | 1K | DISCRETE | 5 | R103; R119; R121; R122; R748 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__3 | 10.0K | DISCRETE | 3 | R110; R112; R114 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_1 | 10K | DISCRETE | 2 | R113; R753 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__6 | 33 | DISCRETE | 7 | R123; R124; R543; R544; R545; R742; R743 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_6 | 330K | DISCRETE | 1 | R741 |
RC0402_HD | RES_RC0402_HD_DISCRETE_0.40 MM_ | 30.9K | DISCRETE | 1 | R23 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.55 MM_ | 26.7K | DISCRETE | 1 | R58 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6 MM_4 | 75 | DISCRETE | 8 | R78; R79; R80; R81; R92; R93; R94; R95 |
SOD882 | DIODE_BIDIR_SOD882_IC_0.5 MM_48 | PESD5V0F1BL | IC | 6 | D4; D5; D6; D7; D8; D9 |
SOD-882 | DIODE_SCHTKY_SOD-882_IC_0.5MM_4 | PMEG2005AEL | IC | 1 | D10 |
SOT416 | TRAN_NPN_RES_SOT416_IC_0.95MM_4 | PDTC115T | IC | 2 | Q1; Q2 |
SOT891_6P_0P35_1P05X1P05 | 74AUP1G125GN_6P_SOT891_6P_0P35_ | 74AUP1G125GF | IC | 4 | U1; U3; U4; U6 |
SW_ELTSA6_TH | ELTSA-63K-H_SW_ELTSA6_TH_IC_7.2 | SPST PB | IC | 1 | SW1 |
TDFN_8_0P65_3X3 | MAX8586_TDFN_8_0P65_3X3_IC_0.80 | MAX8586 | IC | 1 | U13 |
TPAD_040 | TESTLOOP_TPAD_040_0.1MM_211-766 | TPAD_040 | IC | 3 | TP174; TP175; TP176 |
TSSOP16 | SC16IS740IPW_TSSOP16_IC_1.1 MM_ | SC16IS740IPW | IC | 1 | U27 |
UDFN6_1X1P5MM | PRTR5V0U2F_6P_UDFN6_1X1P5MM_IC_ | PRTR5V0U2F | IC | 2 | U2; U9 |
WSON8_1P27_8X6MM_EP138X162 | S25FS512SAGNFI011_WSON8_WSON8_1 | S25FS512SAGNFI011 | IC | 1 | U11 |
XFMR24_1_7P35X15P35MM | XFMR_ETH-4CH_24P_XFMR24_1_7P35X | GSC-2401T-R | IC | 2 | T1; T2 |
XQFN8_1P45X1P25MM | NTSX2102GU8H_8P_XQFN8_1P45X1P25 | NTSX2102GU8H | IC | 1 | U22 |
XSON10_0P5_1P1X2P6MM | DIODE_ESD_4CH_10P_XSON10_0P5_1P | PUSB3FR4 | IC | 1 | U15 |
XTLOSC4_5X3MM_SM | CRYSTAL_JXS63_XTLOSC4_5X3MM_SM_ | 8MHZ | IC | 1 | Y1 |
附件:
