Bill of Material Report (Condensed) | | | | | |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
BEAD0603 | BEAD0603 | MCB1608S221FB | DISCRETE | 5 | FB5; FB6; FB7; FB8; FB9 |
BEAD0805 | BEAD0805 | MHC2012S221QB | DISCRETE | 2 | FB1; FB2 |
BEAD0805 | BEAD0805 | MCB2012S221HB | DISCRETE | 7 | FB3; FB4; FB10; FB11; FB12; FB13; FB14 |
CAP0603 | CAP0603 | 1000pF | DISCRETE | 17 | C1; C2; C3; C7; C28; C38; C48; C49; C76; C77; C80; C104; C105; C106; C107; C108; C110 |
CAP0603 | CAP0603 | 1uF | DISCRETE | 15 | C4; C5; C21; C22; C43; C62; C63; C64; C79; C96; C98; C119; C120; C125; C133 |
CAP0603 | CAP0603 | 0.1uF | DISCRETE | 46 | C6; C8; C10; C11; C27; C29; C37; C40; C41; C42; C44; C46; C52; C53; C56; C57; C58; C60; C65; C66; C67; C68; C69; C71; C73; C83; C84; C85; C90; C92; C94; C97; C102; C109; C111; C112; C113; C114; C115; C118; C122; C124; C126; C129; C130; C132 |
CAP0603 | CAP0603 | 0.01uF | DISCRETE | 1 | C20 |
CAP0603 | CAP0603 | 20pF/X | DISCRETE | 1 | C30 |
CAP0603 | CAP0603 | 2200pF | DISCRETE | 1 | C31 |
CAP0603 | CAP0603 | 10pF | DISCRETE | 3 | C34; C47; C54 |
CAP0603 | CAP0603 | 10pF/X | DISCRETE | 1 | C75 |
CAP0603 | CAP0603 | 47pF/X | DISCRETE | 1 | C127 |
CAP0603 | CAP0603 | 1uF/X | DISCRETE | 1 | C131 |
CAP0805 | CAP0805 | 4.7uF | DISCRETE | 16 | C12; C17; C55; C59; C61; C78; C81; C82; C86; C89; C91; C93; C95; C99; C100; C101 |
CAP0805 | CAP0805 | 2.2uF | DISCRETE | 5 | C16; C87; C88; C116; C117 |
CAP0805 | CAP0805 | 10uF | DISCRETE | 16 | C23; C24; C25; C26; C32; C33; C35; C36; C39; C45; C50; C51; C72; C74; C103; C121 |
CAP1206 | CAP1206 | 10uF/16V | DISCRETE | 8 | C9; C13; C14; C15; C18; C19; C123; C128 |
CAP1210 | CAP1210 | 0.01uF/X | DISCRETE | 1 | C70 |
CAP3528 | CAP3528 | 47uF | DISCRETE | 2 | CE1; CE2 |
CHOKE-CDRH3D16-4R7Y | CHOKE-CDRH3D16-4R7Y | STD03015100M | IO | 2 | L4; L5 |
CHOKE-CDRH3D28-PL | CHOKE-CDRH3D28-PL | SFE3015-3R3M-R-S-LF | DISCRETE | 1 | L3 |
CHOKE-IHLP-2525CZ-01 | CHOKE-IHLP-2525CZ-01 | 6.8uH | IC | 2 | L1; L2 |
CON-85201-2805 | CON-85201-2805 | 85201-2805 | IO | 1 | J13 |
CON-A2502_PL | CON-A2502_PL | CON-A2502 | IO | 1 | J2 |
CON-FFC-6210-30 | CON-FFC-6210-30 | 6212-30 | IO | 2 | J7; J16 |
CON-FPC-A951250-1 | CON-FPC-A951250-1 | 9631S-50Y913 | IO | 1 | J18 |
CON-_USB-A-SOCKET_A1D41F | CON-_USB-A-SOCKET_A1D41F | SUA-110E | DISCRETE | 2 | J3; J4 |
CONN_1223-06-02-PL | CONN_1223-06-02-PL | 1223-06-02 | IO | 1 | J14 |
DIP_JACK_PJ-328-M-PL | DIP_JACK_PJ-328-M-PL | PJ-328 | IO | 1 | J9 |
H1183 | H1183 | S16013LF | IC | 1 | T1 |
HEADER1X4-100 | HEADER1X4-100 | 2211S-04G/X | IO | 1 | J12 |
JACK_PJK-114-M-PL | JACK_PJK-114-M-PL | PJK-114 | IO | 1 | J8 |
LED-LT8A23-51-UR96-T5 | LED-LT8A23-51-UR96-T5 | LED LAMP RED | DISCRETE | 1 | LED1 |
LED-LT8A23-51-UR96-T5 | LED-LT8A23-51-UR96-T5 | LED LAMP GREEN | DISCRETE | 3 | LED2; LED3; LED4 |
LQFP48-19P7 | LQFP48-19P7 | VT6113_LQFP | IC | 1 | U8 |
MIC-WM-64PC | MIC-WM-64PC | O422-40C1-PCD-00-L/X | DISCRETE | 1 | MIC1 |
PAD_1X2_2_2P-PL | PAD_1X2_2_2P-PL | 1x2-2.0/X | DISCRETE | 2 | J10; J11 |
PIN_A-PL | PIN_A-PL | PIN/X | DISCRETE | 4 | B1; B2; B3; B4 |
QFN48-19P7-TH | QFN48-19P7-TH | VT1603A | IC | 1 | U10 |
RES0402 | RES0402 | MLVS0402E10 | DISCRETE | 8 | ESD1; ESD2; ESD3; ESD6; ESD9; ESD10; ESD11; ESD12 |
RES0402 | RES0402 | MLVS0402E10/X | DISCRETE | 4 | ESD4; ESD5; ESD7; ESD8 |
RES0603 | RES0603 | 10K | DISCRETE | 18 | R1; R5; R6; R7; R9; R12; R18; R21; R23; R29; R37; R55; R58; R62; R63; R64; R65; R135 |
RES0603 | RES0603 | 100 | DISCRETE | 6 | R2; R3; R76; R77; R78; R79 |
RES0603 | RES0603 | 100K | DISCRETE | 23 | R4; R10; R13; R14; R16; R24; R25; R28; R35; R36; R39; R40; R41; R42; R49; R51; R52; R80; R81; R90; R97; R101; R118 |
RES0603 | RES0603 | 1K | DISCRETE | 6 | R8; R85; R86; R103; R113; R114 |
RES0603 | RES0603 | 100K/X | DISCRETE | 1 | R11 |
RES0603 | RES0603 | 30K_1% | DISCRETE | 1 | R15 |
RES0603 | RES0603 | 240K_1% | DISCRETE | 2 | R17; R117 |
RES0603 | RES0603 | 510 | DISCRETE | 4 | R22; R108; R111; R112 |
RES0603 | RES0603 | 3K | DISCRETE | 1 | R26 |
RES0603 | RES0603 | 2M | DISCRETE | 1 | R27 |
RES0603 | RES0603 | 52.3K_1% | DISCRETE | 1 | R30 |
RES0603 | RES0603 | 5.1M | DISCRETE | 1 | R31 |
RES0603 | RES0603 | 10K_1% | DISCRETE | 2 | R32; R126 |
RES0603 | RES0603 | 453K_1% | DISCRETE | 1 | R34 |
RES0603 | RES0603 | 100K_1% | DISCRETE | 1 | R38 |
RES0603 | RES0603 | 4.7K | DISCRETE | 9 | R43; R100; R120; R121; R122; R123; R127; R131; R132 |
RES0603 | RES0603 | 33 | DISCRETE | 3 | R44; R53; R54 |
RES0603 | RES0603 | 0/X | DISCRETE | 11 | R45; R48; R56; R61; R83; R87; R88; R92; R94; R104; R134 |
RES0603 | RES0603 | 0 | DISCRETE | 11 | R46; R50; R57; R68; R82; R84; R89; R91; R93; R95; R99 |
RES0603 | RES0603 | 1M | DISCRETE | 2 | R47; R69 |
RES0603 | RES0603 | 6.2K_1% | DISCRETE | 1 | R59 |
RES0603 | RES0603 | 10K/X | DISCRETE | 4 | R60; R109; R110; R128 |
RES0603 | RES0603 | 49.9_1% | DISCRETE | 4 | R66; R67; R70; R71 |
RES0603 | RES0603 | 75 | DISCRETE | 4 | R72; R73; R74; R75 |
RES0603 | RES0603 | 226K_1% | DISCRETE | 1 | R96 |
RES0603 | RES0603 | 120K_1% | DISCRETE | 1 | R98 |
RES0603 | RES0603 | 7.5K/X | DISCRETE | 1 | R102 |
RES0603 | RES0603 | 7.5K | DISCRETE | 2 | R105; R106 |
RES0603 | RES0603 | 15K | DISCRETE | 1 | R107 |
RES0603 | RES0603 | 2.4 | DISCRETE | 2 | R115; R116 |
RES0603 | RES0603 | 5.9K_1% | DISCRETE | 1 | R119 |
RES0603 | RES0603 | 4.7K/X | DISCRETE | 3 | R124; R130; R133 |
RES0603 | RES0603 | 15K/X | DISCRETE | 1 | R125 |
RES0603 | RES0603 | 6.19K_1% | DISCRETE | 1 | R129 |
RES1206 | RES1206 | 0/X | DISCRETE | 1 | R33 |
RES1210 | RES1210 | 0.15_1% | DISCRETE | 2 | R19; R20 |
RN-8P4R-31P5X062 | RN-8P4R-31P5X062 | 100 | DISCRETE | 4 | RN1; RN2; RN3; RN4 |
SC-82 | SC-82 | S-80860CNNB-B9LT2G | IC | 1 | U2 |
SMD_CONN_52207-0467-PL | SMD_CONN_52207-0467-PL | 52207-0467 | IO | 2 | J15; J17 |
SMD_EUP3472ADIR1_SOP8-PL | SMD_EUP3472ADIR1_SOP8-PL | EUP3472ADIR1 | IC | 1 | U6 |
SMD_PJK107-M-PL | SMD_PJK107-M-PL | PJK-107 | DISCRETE | 1 | J1 |
SMD_RJ45_SMT8P8C_M_PL | SMD_RJ45_SMT8P8C_M_PL | SMT8P8C | IO | 1 | J6 |
SMD_RT8008PB_SOT23-5-PL | SMD_RT8008PB_SOT23-5-PL | AAP2408VIR1 | IC | 1 | U7 |
SMD_TP_1 | SMD_TP_1 | PLLTP | IO | 7 | 3P3VSUS; 5V; 5VIN; EN5VIN; ENVCC; VBAT; VCC33 |
SMD_TP_1MM | SMD_TP_1MM | TestPoint_1mm | IO | 4 | 3P3VA; RSMRST-; VIN; VPACK+ |
SMD_TS-A87-PL | SMD_TS-A87-PL | KFC-A05-03 | IO | 4 | SW1; SW2; SW3; SW4 |
SMD_VR_100K-PL | SMD_VR_100K-PL | 10K/X | DISCRETE | 1 | RV1 |
SMD_WM8650_IOB_120P-PL | SMD_WM8650_IOB_120P-PL | WM8650_CoreBoard | IC | 1 | U1 |
SOD123 | SOD123 | RB161M-20 | DISCRETE | 2 | D6; D9 |
SOD123 | SOD123 | MMSZ5246B-TP | DISCRETE | 1 | D7 |
SOD123 | SOD123 | MMSZ5235B | DISCRETE | 1 | D8 |
SOD-106 | SOD-106 | RB051L-40 | DISCRETE | 2 | D1; D2 |
SOD-106 | SOD-106 | RB051L-40/X | DISCRETE | 1 | D3 |
SOIC8-50X204 | SOIC8-50X204 | GS9435 | IC | 2 | Q1; Q10 |
SOIC8-50X204 | SOIC8-50X204 | GS4953 | IC | 1 | Q6 |
SOIC8-50X204 | SOIC8-50X204 | EUP8207-84ADIR1 | IC | 1 | U4 |
SOT23-5 | SOT23-5 | S-80829CNMC-B8OT2G/X | DISCRETE | 1 | U3 |
SOT23-5 | SOT23-5 | EUP2571 | DISCRETE | 1 | U13 |
SOT23-6 | SOT23-6 | EUP2584 | DISCRETE | 1 | U12 |
SOT23-132 | SOT23-132 | BAT54S | DISCRETE | 2 | D4; D5 |
SOT23-132 | SOT23-132 | AP6209-33GB | DISCRETE | 1 | U5 |
SOT23-132 | SOT23-132 | AP1722B-33GC | DISCRETE | 1 | U9 |
SOT23-BCE | SOT23-BCE | MMBT3906 | DISCRETE | 1 | Q16 |
SOT23-GDS | SOT23-GDS | SPN7002S23RG | DISCRETE | 8 | Q2; Q3; Q4; Q7; Q8; Q11; Q12; Q15 |
SOT23-GDS | SOT23-GDS | GN2305 | DISCRETE | 4 | Q5; Q9; Q13; Q14 |
SSOP48-25X378 | SSOP48-25X378 | HT82B40R | IC | 1 | U11 |
ZWSDC0506-PL | ZWSDC0506-PL | ZWSDC0506 | IO | 1 | SD1 |
