查看: 278|回复: 0
[allegro16.6][4层]网络电视盒(WM8435+VT6103X_LQFP+SiI9022A QFN)原理图和pcb文件
发表于 2020-1-21 16:17 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
文件描述:
1. 作品用途:网络电视盒
2. 软件版本:allegro16.6
3. 层数:4层
4. 用到的主要芯片:WM8435+VT6103X_LQFP+SiI9022A QFN
5. PCB尺寸:7362*3897 mil
作品截图如下:
顶层截图:
底层截图:
全层截图:
叠层阻抗信息:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BATHOLDER-KB6810AP2LBATHOLDER-KB6810AP2LKB6810AP2L/XDISCRETE1BAT1
BEAD0603BEAD0603BLM18PG600SN1DDISCRETE13FB1; FB2; FB3; FB4; FB5; FB6; FB7; FB8; FB9; FB10; FB11; FB12; FB13
BEAD0603BEAD0603CB-82CJ02103DISCRETE3L4; L5; L6
CAP0402CAP04020.1uF/XDISCRETE1C173
CAP0603CAP06030.1uFDISCRETE78C3; C7; C19; C25; C30; C32; C34; C36; C37; C40; C43; C44; C45; C46; C47; C50; C51; C52; C54; C55; C56; C61; C62; C65; C66; C67; C70; C71; C72; C73; C74; C75; C76; C77; C78; C79; C81; C82; C84; C86; C87; C89; C90; C91; C92; C103; C109; C110; C111; C112; C113; C114; C116; C117; C118; C119; C127; C128; C129; C130; C131; C134; C136; C140; C141; C142; C143; C144; C146; C147; C148; C149; C150; C151; C152; C153; C154; C156
CAP0603CAP06030.01uFDISCRETE4C4; C16; C26; C31
CAP0603CAP06030.1uF/XDISCRETE1C5
CAP0603CAP06031uFDISCRETE19C8; C9; C11; C12; C42; C49; C58; C59; C83; C85; C88; C93; C94; C95; C99; C104; C105; C138; C139
CAP0603CAP06030.022uFDISCRETE1C13
CAP0603CAP060347pFDISCRETE1C20
CAP0603CAP06031500pFDISCRETE1C21
CAP0603CAP060333pFDISCRETE1C23
CAP0603CAP060322pFDISCRETE3C28; C57; C126
CAP0603CAP060320pFDISCRETE2C33; C35
CAP0603CAP060312pF/XDISCRETE2C38; C39
CAP0603CAP06031000pFDISCRETE4C63; C64; C106; C107
CAP0603CAP06032.2uFDISCRETE1C98
CAP0603CAP06030.015uFDISCRETE2C100; C101
CAP0603CAP0603100pFDISCRETE1C102
CAP0603CAP06035pFDISCRETE3C120; C122; C124
CAP0603CAP06033.3pFDISCRETE3C121; C123; C125
CAP0805CAP080510uFDISCRETE13C1; C2; C15; C17; C18; C24; C29; C53; C108; C137; C145; C155; C179
CAP0805CAP08054.7uFDISCRETE15C10; C14; C22; C27; C41; C48; C60; C68; C69; C80; C96; C97; C115; C132; C135
CHOKE-CDRH3D16-4R7YCHOKE-CDRH3D16-4R7YCDRH3D16-4R7YIO2L9; L11
CHOKE-SDR-54CHOKE-SDR-54SDR-54-3R3MIC1L1
CON-C022034CON-C022034HDMI-0002IO1J7
DIP_CONN_2RJ12R-05070-XX2-PLDIP_CONN_2RJ12R-05070-XX2-PL2RJ12R-05070-XX2IO1J6
DIP_CONN_2RJ13R-050XX-XX31-PLDIP_CONN_2RJ13R-050XX-XX31-PL2RJ13R-050XX-XX31IO1J8
DIP_JW-RJ45-001-PLDIP_JW-RJ45-001-PLJW-RJ45-001IO1J9
DIP_XTAL-32K768_CYLINDRICALDIP_XTAL-32K768_CYLINDRICAL32.768KHz/XDISCRETE1X4
DIP_XTAL_ELLIPTICDIP_XTAL_ELLIPTIC27MHZDISCRETE1X1
DLW21SDLW21SDLW21SN900SQ2/XIC1L7
DLW21SDLW21SDLW21SN900SQ2IC1L8
EC5X7-80EC5X7-80100uFDISCRETE5CE1; CE2; CE3; CE4; CE5
FBGA84-MT47H128M16HG-37EAFBGA84-MT47H128M16HG-37EAHY5PS121621CFP-Y5IC2U7; U8
FM-9038LM-5CNFM-9038LM-5CNFM-9038LM-5CNDISCRETE1IR1
FPC1P0-SMT11-5WX-1A-PLFPC1P0-SMT11-5WX-1A-PLFPC1-SMT11-5WX-1AIO1J3
FUSE1206FUSE1206SMD1206P050TFDISCRETE3F2; F3; F4
LED-KTL-44EGW-1LED-KTL-44EGW-1LED-KTL-44EGW-1DISCRETE1D7
LFBGA625-31P5LFBGA625-31P5WM8435IC1U6
LQFP48-19P7LQFP48-19P7VT6103X_LQFPIC1U16
OPTIC-DLT1111A-PLOPTIC-DLT1111A-PLDLT1111AIO1U13
P25X35BAAP25X35BAAMH5_3IO2MH4; MH5
P25X35BACP25X35BACMH5_3IO3MH1; MH2; MH3
P25X35BAEAP25X35BAEAMH5_3IO1MH6
QFN72-19P7-THQFN72-19P7-THSiI9022A QFNIC1U21
RES0402RES0402MLVS0402E10DISCRETE15ESD1; ESD2; ESD3; ESD4; ESD5; ESD6; ESD7; ESD8; ESD9; ESD10; ESD11; ESD12; ESD13; ESD14; ESD15
RES0603RES060310K/XDISCRETE10R3; R5; R11; R16; R19; R57; R69; R77; R81; R139
RES0603RES06030/XDISCRETE11R4; R101; R107; R110; R111; R128; R133; R145; R146; R159; R160
RES0603RES06031K/XDISCRETE4R6; R14; R18; R32
RES0603RES0603100K/XDISCRETE2R7; R113
RES0603RES06031KDISCRETE7R8; R9; R13; R21; R26; R29; R93
RES0603RES06034.7K/XDISCRETE11R10; R73; R115; R116; R117; R118; R120; R121; R122; R123; R124
RES0603RES060310KDISCRETE16R15; R20; R23; R37; R38; R55; R56; R58; R59; R61; R62; R63; R67; R68; R76; R109
RES0603RES0603100DISCRETE3R17; R78; R79
RES0603RES060321K_1%DISCRETE1R22
RES0603RES060324K_1%DISCRETE1R24
RES0603RES0603680K_1%DISCRETE1R25
RES0603RES0603150K_1%DISCRETE1R27
RES0603RES0603200K_1%DISCRETE1R28
RES0603RES0603100K_1%DISCRETE2R30; R156
RES0603RES06030DISCRETE18R31; R33; R34; R35; R65; R66; R99; R125; R130; R131; R134; R135; R136; R137; R138; R140; R150; R161
RES0603RES06034.7KDISCRETE7R36; R64; R75; R80; R82; R83; R92
RES0603RES0603120_1%DISCRETE1R39
RES0603RES0603301_1%DISCRETE1R40
RES0603RES06033.16K_1%DISCRETE2R41; R43
RES0603RES060322DISCRETE12R42; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53; R54
RES0603RES06035.62K_1%DISCRETE1R60
RES0603RES0603110DISCRETE2R70; R71
RES0603RES060380.6_1%DISCRETE1R74
RES0603RES060375DISCRETE7R86; R87; R88; R96; R97; R102; R104
RES0603RES06031.5KDISCRETE1R90
RES0603RES060333DISCRETE4R91; R98; R112; R114
RES0603RES06031MDISCRETE3R94; R95; R119
RES0603RES060349.9_1%DISCRETE4R100; R103; R105; R106
RES0603RES06036.2K_1%DISCRETE1R108
RES0603RES06032.2KDISCRETE5R126; R127; R162; R163; R164
RES0603RES0603330DISCRETE2R129; R132
RES0603RES060347KDISCRETE2R151; R158
RES0603RES060349.9K_1%DISCRETE1R157
RES0603RES06034.3KDISCRETE1R165
RES0603RES060310DISCRETE1R166
RES1206RES12060DISCRETE2R1; R2
RN-8P4R-19P7X50RN-8P4R-19P7X5010KDISCRETE2RN1; RN2
SMD_101-00402XX-PLSMD_101-00402XX-PL101-00402XXIO1J10
SMD_APW7145KAITRL_SOP8-PLSMD_APW7145KAITRL_SOP8-PLAPW7145KAITRLIC1U3
SMD_AT25FS040N-SH27_W600-PLSMD_AT25FS040N-SH27_W600-PLEN25F40-75GCPIC1U10
SMD_CONN_1226-08-02-PLSMD_CONN_1226-08-02-PL1226-08-02IC1J2
SMD_DC003-PLSMD_DC003-PLDC-003IO1J1
SMD_DOIDE_BZT52C-SOD123-PLSMD_DOIDE_BZT52C-SOD123-PLBZT52C5V1/XIC1D1
SMD_RT8008PB_SOT23-5-PLSMD_RT8008PB_SOT23-5-PLPAM2301CAABADJIC2U4; U5
SMD_TP_1SMD_TP_1PLLTPIO21P8V; 3P3V
SMD_TP_1MMSMD_TP_1MMTestPoint_1mmIO151P5V; 27M1; 32K1; DCIN_T1; RES2; RES3; RES4; RES5; SPICLK1; SPIMISO1; SPIMOSI1; SPISS1; VIN_T1; VSUS15; VSUS33
SMD_TS-A87-PLSMD_TS-A87-PLTS-A87/XIO1SW2
SMD_USBAS-T04-PLSMD_USBAS-T04-PLUSBAS-T04IO2J4; J5
SMD_WM8524_TSSOP16-PLSMD_WM8524_TSSOP16-PLWM8524GEDTIC1U12
SOD-523SOD-523RB520S-30DISCRETE1D3
SOIC8-50X204SOIC8-50X204APM9435KC-TRL/XIC1Q1
SOIC8-50X288SOIC8-50X288AT25DF041A-SH/XIC1U11
SOT23-5SOT23-5RT9193-33PBDISCRETE1U2
SOT23-5SOT23-5APL5315-BI-TRLDISCRETE1U22
SOT23-6SOT23-6AZC199-04S.R7FDISCRETE2U24; U25
SOT23-132SOT23-132BAT54C/XDISCRETE1D2
SOT23-132SOT23-132BAV99DISCRETE3D4; D5; D6
SOT23-132SOT23-132LY6206A15MDISCRETE1U1
SOT23-GDSSOT23-GDS2N7002LT1/XDISCRETE4Q3; Q4; Q6; Q7
SOT23-GDSSOT23-GDSAPM2301CAC-TRLDISCRETE1Q8
SW-DTSA-62N-S-VSW-DTSA-62N-S-VDTSA-63N-VIO1SW1
TSOP48-19P7X768TSOP48-19P7X768HY27UT088G2M-TPCBIC1U9
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
3 y  f3 L! c! L- m3 L- M
GMT+8, 2025-7-23 11:07 , Processed in 0.156250 second(s), 29 queries , Gzip On.
