Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
B-0805 | INDUCTOR_B-0805_0R | 0R | IC | 1 | L100 |
B-0805 | INDUCTOR_B-0805_470NH | 470nH | IC | 2 | L102; L103 |
BATT_3V_D14 | BATTERY_BATT_3V_D14_BATTERY | BATTERY | IC | 1 | BT100 |
BI-COLOUR | LED BI-COLOUR_1_BI-COLOUR_LED B | LED BI-COLOUR | IC | 1 | D102 |
BUTTON10X7_5 | SWNEW_BUTTON10X7_5_SWNEW | SWNEW | IC | 1 | U602 |
C-0402 | CAP NP_1_C-0402_NC/1UF | NC/1uF | IC | 1 | C102 |
C-0402 | CAP NP_C-0402_22PF | 22pF | IC | 2 | C103; C104 |
C-0402 | CAP NP_C-0402_100NF | 100nF | IC | 32 | C106; C109; C110; C111; C112; C113; C114; C115; C116; C117; C118; C119; C120; C121; C122; C123; C124; C125; C126; C127; C128; C129; C130; C131; C132; C133; C134; C135; C136; C137; C138; C139 |
C-0402 | CAP NP_C-0402_20PF | 20pF | IC | 2 | C107; C108 |
C-0402 | CAP NP_C-0402_0.1UF | 0.1uF | IC | 17 | C140; C141; C400; C406; C412; C413; C419; C500; C501; C502; C504; C505; C506; C606; C607; C609; C610 |
C-0402 | MOT_CAP_3_C-0402_30PF | 30pF | IC | 1 | C200 |
C-0402 | CAP NP_C-0402_510P | 510P | IC | 1 | C201 |
C-0402 | CAP NP_C-0402_30PF | 30pF | IC | 4 | C202; C405; C411; C418 |
C-0402 | CAP NP_C-0402_1UF | 1uF | IC | 14 | C203; C204; C401; C402; C403; C404; C407; C408; C409; C410; C414; C415; C416; C417 |
C-0402 | CAP NP_C-0402_220PF/50V | 220pF/50V | IC | 1 | C503 |
C-0402 | CAP_NP_0_C-0402_0.1UF | 0.1uF | IC | 2 | C602; C604 |
C-0402 | CAP NP_C-0402_3.3NF | 3.3nF | IC | 1 | C608 |
C-0805 | MOT_CAP_3_C-0805_10UF/10V | 10uF/10V | IC | 2 | C100; C101 |
C-0805 | CAP NP_C-0805_10UF | 10uF | IC | 1 | C105 |
C-0805 | CAP NP_C-0805_1UF/50V | 1uF/50V | IC | 1 | C600 |
C-0805 | CAP NP_C-0805_10UF/10V | 10uF/10V | IC | 3 | C601; C603; C611 |
C-0805 | CAP NP_C-0805_0.1UF/50V | 0.1uF/50V | IC | 1 | C605 |
CAPAE530X610N | CAP POL_CAPAE530X610N_10UF/25V | 10uF/25V | IC | 1 | CT600 |
CAPAE530X610N | CAP POL_CAPAE530X610N_100UF/10V | 100uF/10V | IC | 1 | CT601 |
CAPAE600X300N | INDUCTOR_1_CAPAE600X300N_10UH/2 | 10uH/2A | IC | 1 | L601 |
CRYS-H49S | CRYSTAL_CRYS-H49S_12M | 12M | IC | 1 | Y100 |
D-1206 | DIODE_2_D-1206_IN4148 | IN4148 | IC | 1 | D200 |
D-1206 | ZENER3_0_D-1206_13V/0.5W | 13V/0.5W | IC | 2 | D201; D600 |
DB15 | DB15_1_DB15_DB15M | DB15M | IC | 1 | MS600 |
DO-214AA | DIODE_2_DO-214AA_1N4001 | 1N4001 | IC | 1 | D601 |
DT-206 | CRYSTAL_0_DT-206_32.768KHZ | 32.768KHz | IC | 1 | Y101 |
HD_5R1_1X2P | FUSE_HD_5R1_1X2P_LP60-020 | LP60-020 | IC | 2 | F400; F401 |
HD_5R1_1X2P | FUSE_HD_5R1_1X2P_XE060 | XE060 | IC | 1 | F600 |
L-1210 | IND0-100UH/SMT_1_L-1210_22UH/1A | 22uH/1A | IC | 1 | L101 |
L-1210 | INDUCTOR_L-1210_22UH | 22uH | IC | 1 | L500 |
LCM_40 | 4_0_LCM_40_4_3LCM | 4_3LCM | IC | 1 | CON100 |
MINIUSB | USB_A/B_0_MINIUSB_USBOTG | USBOTG | IC | 1 | J100 |
QFP50P3000X3000X120-208N | LPC_5_QFP50P3000X3000X120-208N_ | LPC_1788 | IC | 1 | U100 |
R-0402 | JUMPER_2_R-0402_0R | 0R | IC | 3 | J601; J602; J604 |
R-0402 | MOT_RES_R-0402_82K | 82K | IC | 1 | R100 |
R-0402 | MOT_RES_R-0402_NC/4.7K | NC/4.7K | IC | 1 | R101 |
R-0402 | MOT_RES_R-0402_4.7K | 4.7K | IC | 2 | R103; R425 |
R-0402 | MOT_RES_R-0402_NC/6.8K | NC/6.8K | IC | 1 | R104 |
R-0402 | MOT_RES_R-0402_NC/1M | NC/1M | IC | 2 | R106; R110 |
R-0402 | R_R-0402_100K | 100K | IC | 3 | R107; R109; R622 |
R-0402 | R_R-0402_10 | 10 | IC | 1 | R108 |
R-0402 | R_R-0402_0R | 0R | IC | 1 | R111 |
R-0402 | R_R-0402_10K | 10K | IC | 21 | R112; R115; R203; R207; R208; R211; R227; R228; R231; R500; R509; R515; R521; R600; R601; R602; R603; R604; R606; R621; R631 |
R-0402 | R_R-0402_4.7K | 4.7K | IC | 5 | R113; R114; R204; R210; R230 |
R-0402 | MOT_RES_R-0402_0_-/+5% | 0 | IC | 6 | R116; R120; R121; R122; R123; R125 |
R-0402 | R_R-0402_100R | 100R | IC | 1 | R117 |
R-0402 | MOT_RES_R-0402_3K_-/+5% | 3K | IC | 4 | R118; R126; R127; R128 |
R-0402 | R_R-0402_22R | 22R | IC | 2 | R119; R124 |
R-0402 | R_0_R-0402_NC | NC | IC | 2 | R129; R130 |
R-0402 | MOT_RES_R-0402_NC/4.7K_-/+5% | NC/4.7K | IC | 1 | R131 |
R-0402 | R_R-0402_1.5K | 1.5K | IC | 2 | R132; R214 |
R-0402 | R_R-0402_15K | 15K | IC | 2 | R133; R134 |
R-0402 | R_0_R-0402_470R | 470R | IC | 2 | R135; R136 |
R-0402 | MOT_RES_0_R-0402_2K | 2K | IC | 2 | R201; R639 |
R-0402 | MOT_RES_0_R-0402_10K | 10K | IC | 23 | R202; R212; R221; R222; R223; R234; R235; R236; R237; R502; R503; R505; R506; R508; R511; R518; R519; R523; R525; R526; R527; R528; R534 |
R-0402 | R_R-0402_20K | 20K | IC | 1 | R206 |
R-0402 | R_R-0402_2K | 2K | IC | 2 | R213; R226 |
R-0402 | MOT_RES_0_R-0402_4.7K | 4.7K | IC | 9 | R215; R217; R220; R504; R507; R512; R520; R524; R644 |
R-0402 | MOT_RES_0_R-0402_51R | 51R | IC | 1 | R216 |
R-0402 | MOT_RES_0_R-0402_22K | 22K | IC | 1 | R218 |
R-0402 | R_R-0402_470R | 470R | IC | 1 | R225 |
R-0402 | R_R-0402_1K | 1K | IC | 1 | R229 |
R-0402 | MOT_RES_R-0402_NC/0R | NC/0R | IC | 2 | R238; R239 |
R-0402 | MOT_RES_R-0402_10K | 10K | IC | 3 | R240; R241; R243 |
R-0402 | MOT_RES_0_R-0402_20K | 20K | IC | 1 | R242 |
R-0402 | RESISTOR_1_R-0402_10K | 10K | IC | 1 | R244 |
R-0402 | RESISTOR_1_R-0402_4.7K | 4.7K | IC | 1 | R245 |
R-0402 | MOT_RES_0_R-0402_47K | 47k | IC | 17 | R300; R301; R302; R303; R304; R305; R306; R307; R308; R309; R310; R311; R312; R313; R531; R532; R533 |
R-0402 | MOT_RES_R-0402_2K | 2K | IC | 12 | R400; R401; R402; R403; R404; R405; R411; R412; R413; R415; R417; R424 |
R-0402 | MOT_RES_R-0402_20K | 20K | IC | 2 | R410; R450 |
R-0402 | MOT_RES_R-0402_47K | 47K | IC | 12 | R414; R416; R419; R422; R430; R432; R434; R436; R442; R444; R446; R448 |
R-0402 | R_R-0402_NC/10K | NC/10K | IC | 5 | R501; R510; R516; R522; R620 |
R-0402 | R_R-0402_2.7K | 2.7K | IC | 2 | R513; R514 |
R-0402 | R_R-0402_9.1K | 9.1K | IC | 1 | R517 |
R-0402 | R_R-0402_NC/0R | NC/0R | IC | 2 | R529; R530 |
R-0402 | MOT_RES_0_R-0402_24K | 24K | IC | 8 | R623; R624; R625; R626; R627; R628; R629; R630 |
R-0402 | R_R-0402_7.5K | 7.5K | IC | 1 | R632 |
R-0402 | MOT_RES_0_R-0402_100 | 100 | IC | 9 | R633; R634; R636; R638; R640; R642; R643; R646; R647 |
R-0402 | R_R-0402_47K | 47K | IC | 4 | R635; R637; R641; R648 |
R-0603 | MOT_RES_R-0603_1R8 | 1R8 | IC | 1 | R102 |
R-0603 | MOT_RES_R-0603_47 | 47 | IC | 12 | R418; R420; R421; R423; R431; R433; R435; R437; R443; R445; R447; R449 |
R-0805 | MOT_RES_R-0805_1R8 | 1R8 | IC | 1 | R105 |
R-0805 | MOT_RES_0_R-0805_NC/3.3K | NC/3.3K | IC | 1 | R200 |
R-0805 | MOT_RES_0_R-0805_NC/0R | NC/0R | IC | 3 | R205; R232; R233 |
R-0805 | MOT_RES_0_R-0805_0R | 0R | IC | 14 | R209; R605; R607; R608; R609; R611; R612; R613; R614; R615; R616; R617; R618; R619 |
R-0805 | MOT_RES_0_R-0805_1.5K | 1.5K | IC | 2 | R219; R610 |
R-0805 | R_R-0805_2.2K | 2.2K | IC | 1 | R224 |
R-0805 | RESISTOR_1_R-0805_2.2K | 2.2K | IC | 12 | R406; R407; R408; R409; R426; R427; R428; R429; R438; R439; R440; R441 |
R-0805 | MOT_RES_0_R-0805_NC/10K | NC/10K | IC | 1 | R645 |
SD_MMC_PUSH | SDCARDSOCKET_1_SD_MMC_PUSH_SDCA | SDCardSocket | IC | 1 | J605 |
SIP5_2R54 | CON4_1_SIP5_2R54_UT232_2_DB | UT232_2_Db | IC | 1 | J603 |
SIP9_2R454 | CON9_SIP9_2R454_CON9 | CON9 | IC | 1 | J600 |
SMA | DIODE PIN_1_SMA_SS32 | SS32 | IC | 1 | D100 |
SMA | DIODE PIN_1_SMA_1N4001 | 1N4001 | IC | 1 | D101 |
SMD_L_4X4 | IND0-100UH/SMT_1_SMD_L_4X4_4.7U | 4.7uH/1A | IC | 1 | L600 |
SO16 | DG408_SO16_DG408DYZ | DG408DYZ | IC | 5 | U400; U401; U402; U403; U404 |
SO16 | CD4052B/SO_0_SO16_CD4052B/SO | CD4052B/SO | IC | 1 | U506 |
SOIC127P600X140-8N | CX8505_SOIC127P600X140-8N_CX850 | CX8505 | IC | 1 | U601 |
SOIC-8 | LM393_1_SOIC-8_LM393 | LM393 | IC | 2 | U200; U201 |
SOIC-8 | TJA1050_1_SOIC-8_TJA1050 | TJA1050 | IC | 4 | U500; U501; U503; U504 |
SOIC-8 | AU5790_SOIC-8_AU5790 | AU5790 | IC | 1 | U502 |
SOP80P1180X140-54N | MT48LC16M16A2TG_3_SOP80P1180X14 | MT48LC16M16A2TG-256Mbit | IC | 2 | U103; U104 |
SOT26 | RT9293BGJ6_0_SOT26_RT9293BGJ6 | RT9293BGJ6 | IC | 1 | U101 |
SOT223 | NPN_2_SOT223_FZT853 | FZT853 | IC | 1 | Q600 |
SOT223 | CON5_1_SOT223_C1117-33 | C1117-33 | IC | 1 | U600 |
SOT-23 | DIODE_0_SOT-23_BAT54C | BAT54C | IC | 4 | D202; D203; D501; D602 |
SOT-23 | DIODE_0_SOT-23_NC/BAT54C | NC/BAT54C | IC | 1 | D500 |
SOT-23 | PNPR_SOT-23_PNPR | PNPR | IC | 14 | Q100; Q400; Q401; Q402; Q403; Q408; Q409; Q410; Q411; Q416; Q417; Q418; Q419; Q601 |
SOT-23 | NPN_1_SOT-23_2N2222 | 2N2222 | IC | 16 | Q200; Q202; Q204; Q206; Q404; Q405; Q406; Q407; Q412; Q413; Q414; Q415; Q420; Q421; Q422; Q423 |
SOT-23 | PNP BCE_0_SOT-23_2N2907 | 2N2907 | IC | 10 | Q201; Q208; Q209; Q211; Q212; Q500; Q502; Q504; Q506; Q508 |
SOT-23 | PNP BCE_0_SOT-23_MMBT3906 | MMBT3906 | IC | 1 | Q203 |
SOT-23 | NPN_1_SOT-23_MMBT3904 | MMBT3904 | IC | 2 | Q205; Q207 |
SOT-23 | NPNR_SOT-23_NPNR | NPNR | IC | 40 | Q210; Q213; Q214; Q300; Q301; Q302; Q303; Q304; Q305; Q306; Q307; Q308; Q309; Q310; Q311; Q312; Q313; Q314; Q315; Q316; Q317; Q318; Q319; Q320; Q321; Q322; Q323; Q324; Q325; Q424; Q501; Q503; Q505; Q507; Q509; Q510; Q511; Q512; Q603; Q604 |
SOT-23 | APM2301_SOT-23_APM2305 | APM2305 | IC | 1 | Q602 |
SOT-23 | CON3_1_SOT-23_NC/IMP809SEUR_T_2 | NC/IMP809SEUR_T_2.93V | IC | 1 | U105 |
TSSOP16A | ADS7843_0_TSSOP16A_ADS7843 | ADS7843 | IC | 1 | U102 |
附件:
