查看: 598|回复: 8
[allegro16.6][2层] AM335X底板(LS335X+MP1530DM+LAN8710A)原理图和pcb文件
发表于 2020-1-21 15:11 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
4 J) G1 O0 N% t, V5 y$ S4 t) w[allegro16.6][2层] AM335X底板(LS335X+MP1530DM+LAN8710A)原理图和pcb文件. [- `- G( P6 F# T/ P
! @  v5 ?. Q% r: ]4 |$ N
文件描述:( z( J+ j) q% |1 N$ @3 g
& J9 |. \: F% D, r% a5 R( B1 t1. 作品用途: AM335X底板1 K" ^. z* X  v; O% J* G" F8 c
2. 软件版本:allegro16.6
  Y  r4 m( m# U2 I3. 层数:2层5 d" `# e. @: ~) _- i7 A# V
4. 用到的主要芯片:LS335X+MP1530DM+LAN8710A3 o7 q( q# H. m) D1 [1 ]
5. pcb尺寸: 140*168 MM0 C. x3 h6 I! h, m7 ^; X. V2 j
3 z( C6 I& x8 I. ?: [) v+ }' J作品截图如下:1 c* p, n% e% g
* l) y5 N$ j6 l" ?/ @+ f) @1 K顶层截图:0 K! A! Q/ B% X  C
8 O: m5 A6 z$ @, k& q0 E8 A
底层截图:% a2 ~) @8 U0 u# h
( Q6 J" T. b9 W3 O. Z* K1 C: I
5 {2 {( P1 p7 Z% o5 O4 L9 G全层截图:
; g6 o" P: \. R 4 {: _3 l( q9 y7 @
1 I5 h; ?  j1 K( I) o( e( BBOM:
! V9 i$ `& t( E# N' E- C7 f- Z! N2 O' I7 _
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
0603LL-FB_0603L_PBY160808T-121Y-N/B0PBY160808T-121Y-N/B0603IC4FBA1; FBA2; FBA3; FBA4
1206CL-CAP NP_1206C_4.7UF/CC1206/1004.7uF/CC1206/100VIC2C94; C98
1206CL-CAP NP_1206C_100UF/CC1206/16V100uF/CC1206/16VIC2C101; C102
A2001WVB_NP_4PL-CON-1X4_1_A2001WVB_NP_4P_A200A2001WVB_NP_4PIC3JL1; JT1; JT2
A2001WVB_NP_5PCON5_A2001WVB_NP_5P_CON5CON5IC1J1
BAT_CR1220_AL-BT_BAT_CR1220_A_CR1220CR1220IC1BK1
BC0805L-FB_BC0805_PBY201209T-121Y-NPBY201209T-121Y-NIC8BC1; BC3; BC4; BC5; BC6; BL1; BL2; BL3
BC0805L-FB_BC0805_DNU/BC0805DNU/BC0805IC1BC2
BUZZER_9P50_AL-BUZER-A_BUZZER_9P50_A_BZ/AX-1BZ/AX-1003-LFIC1BZK1
C0603CAP NP_C0603_0.1UF0.1uFIC3C25; C43; C44
C0603CAP NP_C0603_330PF330pFIC1C26
C0603CAP NP_C0603_0.1UF/50V0.1uF/50vIC2C27; C95
C0603CAP NP_C0603_0.01UF/CC0603/50V0.01uF/CC0603/50VIC2C28; C41
C0603CAP NP_C0603_330PF 50V330pF 50vIC1C30
C0603CAP NP_C0603_0.1UF/CC0603/50V0.1uF/CC0603/50VIC1C33
C0603CAP NP_C0603_0.1UF 50V0.1uF 50vIC2C35; C36
C0603L-CAP NP_C0603_0.01UF/CC0603/500.01uF/CC0603/50VIC2C49; C50
C0603L-CAP NP_C0603_0.1UF/C0603/50V0.1uF/C0603/50VIC4C54; C114; C117; C142
C0603L-CAP NP_C0603_1UF/C0603/25V1uF/C0603/25VIC5C76; C77; C78; C97; C143
C0603L-CAP NP_C0603_220NF/C0603/50V220nF/C0603/50VIC1C99
C0603L-CAP NP_C0603_DNU/C0603/25VDNU/C0603/25VIC1C116
C0805CAP NP_C0805_10UF10uFIC2C29; C39
C0805CAP NP_C0805_10UF 25V10uF 25vIC1C40
C0805CAP NP_C0805_10UF 25V10uF 25vIC1C42
C0805L-CAP NP_C0805_10UF/C0805/10V10uF/C0805/10VIC5C55; C56; C141; C144; C145
C0805L-CAP NP_C0805_10UF/C0805/50V10uF/C0805/50VIC3C72; C104; C105
C0805L-CAP NP_C0805_10UF/C0805/25V10uF/C0805/25VIC1C73
C1206CAP NP_C1206_103/1KV103/1KVIC1C135
CC0402L-CAP NP_CC0402_30PF/CC0402/50V30pF/CC0402/50VDISCRETE29C58; C59; C60; C61; C62; C63; C64; C65; C66; C67; C68; C69; C70; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C89; C90; C91; C92; C93; C113
CC0603L-CAP NP_CC0603_0.1UF/CC0603/500.1uF/CC0603/50VIC25C1; C2; C3; C21; C34; C37; C38; C46; C52; C100; C103; C107; C108; C109; C110; C112; C115; C125; C126; C127; C128; C133; C137; C139; C140
CC0603L-CAP NP_CC0603_0.01UF/CC0603/50.01uF/CC0603/50VIC8C7; C8; C11; C15; C106; C111; C121; C124
CC0603CAP_0402_100PF_COG_50V_CC0603_115pF,DNIIC4C9; C10; C149; C153
CC0603CAP_30PF_COG_50V_5%_0402_CC060327pF,50VIC2C12; C13
CC0603L-CAP NP_CC0603_2.2UF/CC0603/102.2uF/CC0603/10VIC1C22
CC0603C0603_CC0603_100N100nIC1C32
CC0603L-CAP NP_CC0603_47PF/CC0603/50V47pF/CC0603/50VIC1C47
CC0603L-CAP NP_CC0603_4700PF/CC0603/54700pF/CC0603/50VIC1C51
CC0603CAP_0.1UF_X5R_6.3V_20% 0201 _CC0.1uf,6.3VIC3C146; C147; C148
CC0603CAP_0402_0.1UF_X5R_10V_CC0603_00.022uF,10VIC1C150
CC0603CAP_1.0UF_X5R_10V_10%_0402_CC061uF,10VIC1C151
CC0603470PF/5%/50V/C0G/0603_0_CC0603_470pF,6.3VIC1C152
CC0805CE1206_CC0805_10U10uIC1C31
CC0805L-CAP NP_CC0805_0.1UF/CC0805/100.1uF/CC0805/100VIC2C53; C75
CC0805CAP_10UF_Y5V_10V_10%_0805_CC08010uF,10VIC1C154
CC1206L-CAP NP_CC1206_10UF/CC1206/25V10uF/CC1206/25VIC8C4; C5; C6; C45; C48; C57; C71; C74
CC1206L-CAP NP_CC1206_4.7UF/CC1206/254.7uF/CC1206/25VIC1C96
CY_3215_AL-CRYSTAL_CY_3215_A_32768HZ/X3232768Hz/X3215/NPIC1YK1
CY_3225_4PL-CRYSTAL-4_CY_3225_4P_25MHZ/X325MHz/X3225/NPIC1Y1
DCN1X6-2_0BCON6_DCN1X6-2_0B_CON6CON6IC1J11
DO_SMCL-DIODE-SCHOTTKY_DO_SMC_B560CB560CIC2D10; D15
DO_SMCL-DIODE-TVS_DO_SMC_1SMC24AT3G1SMC24AT3GIC1D16
DO_SOD_123L-DIODE-SCHOTTKY_DO_SOD_123_MBRMBR230LSFT1GIC1D13
DO_SOD_323L-DIODE-SCHOTTKY_DO_SOD_323_NSRNSR1020MW2T1GIC3D1; D2; D3
DO_SOD_323L-DIODE-ZENER_DO_SOD_323_MM3Z5VMM3Z5V6T1GIC2D14; D21
FS1206L-PPTC_FS1206_FSMD150-1206R/FS1FSMD150-1206R/FS1206IC1FL1
FS1812L-FUSE_FS1812_FSMD300R/F1812FSMD300R/F1812IC1FA1
FS1812L-FUSE_FS1812_DNU/F1812DNU/F1812IC1FA2
F_XT_8P_AL-FX-T_F_XT_8P_A_F0505XT-1WR2/NF0505XT-1WR2/NCIC1U11
HOLE284CIR126L-MT-A_HOLE284CIR126_MTMTIC4MA1; MA2; MA3; MA4
HSOIC_8P_EPL-TPS54360_HSOIC_8P_EP_TPS54560TPS54560DDIC1U7
L4X4INDUCTOR_0_L4X4_10UH/L4X410uH/L4X4IC1L1
L-FPC0_5-50B-S1L-70LCD-50PIN_2_L-FPC0_5-50B-S170LCD-50PIN-FPCIC1J8
L-FPC1_0-4A-S1L-FPC-4P-S1_L-FPC1_0-4A-S1_FPC-FPC-4P-S1/TTW410514/90mm-LeftOutIC1JA3
L-L-SCDS5DL-INDUCTOR_L-L-SCDS5D_2.2UH/SCD2.2uH/SCDS5D28-2R2IC1L2
L-SC70-5L-SN74LVC1G08_L-SC70-5_SN74LVC1SN74LVC1G08DCK/SC70-5IC1U18
L-SC70-5L-SN74AHC1G32_L-SC70-5_SN74AHC1SN74AHC1G32DCK/SC70-5IC1U19
L-SOT23-5L-TPS736XX_L-SOT23-5_TPS73601DBTPS73601DBV/SOT23-5IC1U8
L-SOT23-6L-TPS61165_L-SOT23-6_TPS61165DBTPS61165DBVIC1U12
LED0603LED_0_LED0603_IC_GGIC1D6
LED0603LED_0_LED0603_IC_YYIC1D7
LED-100_3LED_0_LED-100_3_IC_REDREDIC3D18; D19; D20
L_ACM2012L-FILTERS-CM-A_L_ACM2012_ACM201ACM2012-121-2P-T002IC2LC1; LL1
L_SCDS5DL-INDUCTOR_L_SCDS5D_2.2UH/SCDS52.2uH/SCDS5DIC1LA1
L_SLF12L-INDUCTOR_L_SLF12_5.6UH/SLF1275.6uH/SLF1275T-5R6T-NIC1LA2
MARK_1P00_AT-MARK_MARK_1P00_A_MARKMarkIC4M1; M2; M3; M4
QDIP_176P_2P00_B_MTL-LS335X_QDIP_176P_2P00_B_MT_LSLS335XIC1U1
QFN32_5X5MM_EP3P3MMLAN8710 QFN32_1_QFN32_5X5MM_EP3LAN8710AIC1U28
R0603100-1/10W-1%-0603_4_R0603_100,1100,1%DISCRETE5R14; R23; R27; R239; R243
R0603RES_100_1/10W_5%_0402_R0603_100100,1%DISCRETE5R18; R21; R28; R235; R250
R0603RES_470_1/10W_5%_0402_R0603_470470,5%IC2R19; R22
R0603RES_10K_1/16W_1%_0402_R0603_10K10K,1%IC2R24; R34
R0603RES_10K_1/16W_1%_0402_R0603_0,10,1%IC1R26
R0603RES_1M_1/16W_1%_0402_R0603_1M,11M,1%,DNIIC1R30
R0603RES_10K_1/16W_1%_0402_R0603_10,10,1%IC1R32
R0603RES_12.1K_1/16W_1%_0402_R0603_112.1K,1%IC1R33
R0603RESISTOR_0_R0603_56K 1%56K 1%IC1R84
R0603RESISTOR_0_R0603_10K 1%10K 1%IC2R85; R87
R0603RESISTOR_0_R0603_6.8K 1%6.8K 1%IC1R86
R0603RESISTOR_0_R0603_57K 1%57K 1%IC1R88
R0603RESISTOR_0_R0603_100K 1%100K 1%IC2R89; R97
R0603RESISTOR_0_R0603_140K 1%140K 1%IC1R92
R0603RESISTOR_0_R0603_10K 1%10K 1%IC1R93
R0603L-RESISTOR_R0603_52.3K/R0603/1%52.3K/R0603/1%IC1R101
R0603L-RESISTOR_R0603_30.1K/R0603/1%30.1K/R0603/1%IC1R102
R0603L-RESISTOR_R0603_10K/R0603/1%10K/R0603/1%DISCRETE6R103; R159; R166; R167; R212; R213
R0603RESISTOR_0_R0603_10K/R0603/1%10K/R0603/1%IC5R118; R208; R209; R215; R216
R0603L-RESISTOR_R0603_51K/R0603/1%51K/R0603/1%IC1R120
R0603L-RESISTOR_R0603_2R21/R0603/1%2R21/R0603/1%IC2R121; R125
R0603RESISTOR_0_R0603_16K/R0603/1%16K/R0603/1%IC1R122
R0603L-RESISTOR_R0603_DNU/R0603/1%DNU/R0603/1%DISCRETE4R124; R163; R164; R211
R0603L-RESISTOR_R0603_0R/NC0R/NCIC3R155; R160; R168
R0603L-RESISTOR_R0603_1K/R0603/1%1K/R0603/1%DISCRETE2R156; R210
R0603L-RESISTOR_R0603_0R/1%0R/1%IC1R161
R0603L-RESISTOR_R0603_0R/R0603/1%0R/R0603/1%IC3R169; R170; R171
R0603R_R0603_75R%175R%1IC2R193; R194
R0603RESISTOR_0_R0603_NC/R0603/1%NC/R0603/1%IC4R207; R214; R217; R218
R0603RES_4.75K_1/16W_1%_0402_R0603_110K,1%IC4R236; R237; R241; R251
R0603RES_4.7K_0402_R0603_49.9,1%49.9,1%IC4R240; R242; R245; R249
R0603RES_1.5K_1/16W_5%_0402_R0603_1.1.5K,1%IC1R244
R0603RES_4.75K_1/16W_1%_0402_R0603_21.5K,1%IC3R246; R247; R248
RC0603L-RESISTOR_RC0603_10K/RC0603/1%10K/RC0603/1%DISCRETE35R1; R3; R6; R10; R17; R25; R38; R104; R106; R119; R127; R130; R133; R134; R140; R146; R152; R154; R157; R219; R220; R221; R222; R223; R224; R225; R226; R227; R228; R229; R230; R231; R232; R233; R234
RC0603L-RESISTOR_RC0603_100K/RC0603/1100K/RC0603/1%DISCRETE24R2; R4; R5; R9; R11; R13; R16; R49; R53; R54; R55; R56; R57; R58; R59; R60; R61; R62; R65; R66; R69; R70; R71; R115
RC0603L-RESISTOR_RC0603_1K/RC0603/1%1K/RC0603/1%DISCRETE6R7; R81; R83; R135; R136; R137
RC0603L-RESISTOR_RC0603_0R/RC0603/1%0R/RC0603/1%IC14R8; R110; R117; R131; R141; R142; R143; R148; R149; R150; R153; R162; R165; R176
RC0603L-RESISTOR_RC0603_DNU/RC0603/1%DNU/RC0603/1%DISCRETE19R20; R50; R51; R52; R63; R64; R67; R68; R72; R73; R74; R75; R76; R77; R78; R79; R80; R147; R151
RC0603R0603_RC0603_0R0RIC1R90
RC0603L-RESISTOR_RC0603_0R0RIC16R91; R95; R98; R99; R105; R108; R123; R128; R184; R185; R189; R190; R195; R196; R202; R203
RC0603R0603_RC0603_120R(NC)120R(NC)IC1R94
RC0603R0603_RC0603_10K10kIC1R96
RC0603L-RESISTOR_RC0603_16.9K/RC0603/16.9K/RC0603/1%IC1R100
RC0603L-RESISTOR_RC0603_510R/RC0603/1510R/RC0603/1%IC4R109; R132; R138; R139
RC0603L-RESISTOR_RC0603_45.3K/RC0603/45.3K/RC0603/1%IC1R111
RC0603L-RESISTOR_RC0603_10.0K/RC0603/10.0K/RC0603/1%IC2R116; R205
RC0603L-RESISTOR_RC0603_120R/RC0603/1120R/RC0603/1%IC1R126
RC0603L-RESISTOR_RC0603_4.7K/RC0603/14.7K/RC0603/1%IC3R144; R145; R158
RC0603L-RESISTOR_RC0603_10K/RC0603/_110K/RC0603/1%/NCIC4R186; R191; R197; R204
RC0603L-RESISTOR_RC0603_53.6K/RC0603/53.6K/RC0603/1%IC1R206
RC0603L-RESISTOR_RC0603_0R/NC0R/NCIC1R252
RC0805L-RESISTOR_RC0805_5.1K/RC0805/15.1K/RC0805/1%IC1R12
RC0805L-RESISTOR_RC0805_243K/RC0805/1243K/RC0805/1%IC1R107
RC0805L-RESISTOR_RC0805_0/RC0805/1%0/RC0805/1%IC2R112; R129
RC0805L-RESISTOR_RC0805_442K/RC0805/1442K/RC0805/1%IC1R113
RC0805L-RESISTOR_RC0805_90.9K/RC0805/90.9K/RC0805/1%IC1R114
RP4_0402L-RP4_RP4_0402_0R/RP4-0402/1%0R/RP4-0402/1%DISCRETE8RPG1; RPG2; RPG3; RPG4; RPG5; RPG6; RPG7; RPG8
SC70_5P_AL-SN74AHC1G00_SC70_5P_A_SN74AHCSN74AHC1G00DCKIC1U14
SC70_5P_AL-SN74LVC1G07_SC70_5P_A_SN74LVCSN74LVC1G07DCKIC2U16; U17
SDCON-CMICROSD_CONN_2_SDCON-C_ALPS SCHALPS SCHA4B0100IC1J5
SG16116SG16116_SG16116_SG16116SG16116IC1U29
SIP12-8012 HEADER_SIP12-80_12 HEADER12 HEADERIC1J7
SIP-3P-2_54CON3_SIP-3P-2_54_DEBUGDEBUGIC1J10
SIP-8P-2_54CON8_SIP-8P-2_54_CON8CON8IC2J2; J3
SOD123DIODE_0_SOD123_IN5819IN5819IC1D11
SOD-123L-DIODE-SCHOTTKY_2_SOD-123_MBR2MBR230LSFT1G/SOD-123IC1D17
SOIC_8P_NL-MAX485E_SOIC_8P_N_MAX13487MAX13487IC1U10
SOIC_8P_N_SWL-ADUM1201_SOIC_8P_N_SW_ADUM120ADuM1201B/NCIC4U23; U24; U25; U27
SOIC_16P_N_AL-MAX202E_SOIC_16P_N_A_MAX3232EMAX3232ESEIC1U6
SOP-8DSN65HVD234_SOP-8D_SN65HVD234DRSN65HVD234DRIC1U4
SOT23_6P_ESDL-TPD4E001DBV_SOT23_6P_ESD_TPD4TPD4E001DBVIC4U2; U13; U21; U22
SOT-23DIODE_DUAL_0_SOT-23_BAT54SBAT54SIC3D8; D9; D12
SOT_23_ANPN_SOT_23_A_SS8050SS8050IC1Q1
SOT_23_AL-DIODE-SOT23-DP_SOT_23_A_NUP21NUP2105LIC2Q2; Q5
SOT_23_AL-DIODE-SOT23-DP_SOT_23_A_SM36TSM36T1GIC2Q3; Q4
SOT_23_AL-MOSFET-P_SOT_23_A_IRLML5203IRLML5203IC2QK1; QK2
SW_6X3SW PUSHBUTTON_SW_6X3_USER1USER1IC1SW1
SW_6X3SW PUSHBUTTON_SW_6X3_USER2USER2IC1SW2
SW_6X3SW PUSHBUTTON_SW_6X3_PWR_ONPWR_ONIC1SW3
SW_6X3SW PUSHBUTTON_SW_6X3_RSTRSTIC1SW4
SW_SOP_4PL-DIP-2-SOC_SW_SOP_4P_SW-2-SOCSW-2-SOCIC1SG1
TSSOP16MP1530_5_TSSOP16_MP1530DMMP1530DMIC1U5
UMAX_8P_AL-DS1339_UMAX_8P_A_DS1339U-33DS1339U-33IC1U15
USB_A_180DCON6_USB_A_180D_CON6CON6IC1J9
USB_SUSB_MICROAB_8_USB_S_47589-000147589-0001IC1J4
WSON_6P_PL-LM2832-6WSON_WSON_6P_P_LM2832LM2832XSDIC1U9
附件:
' K+ l9 s1 |3 p, m原理图和PCB文件如下:6 B; l8 D, u+ I/ c
游客,如果您要查看本帖隐藏内容请回复
  e! M9 z/ g' X, S, Y
) C6 H  p" F' U% H7 X9 d
    2021-5-27 15:09
    发表于 2021-5-27 14:40 | 只看该作者
    刚好用到,学习学习,谢谢楼主# K8 ?/ F( h/ z) C$ L$ l1 U# r  t. F
    发表于 2021-6-14 19:18 | 只看该作者
    这个资料不错。, Y4 Q; v& L/ s7 b" L2 v2 I, A
    发表于 2023-4-14 18:27 | 只看该作者
    看看老方案
    8 O; [  }% G: c' s/ j$ m
    2025-7-18 15:02
  • 签到天数: 557 天
    [LV.9]以坛为家II
    发表于 2023-4-17 15:30 | 只看该作者
    这个资料不错
    郁闷
    2019-11-20 15:02
    发表于 2023-4-26 09:38 | 只看该作者
    这个需要学习一下啊啊
    5 Z: L/ T0 ~4 f  H
    GMT+8, 2025-7-20 23:39 , Processed in 0.140625 second(s), 27 queries , Gzip On.
