作品名:[AD 10][4层]控制板(LPC1124FBD48+LPC1850FET180+SN65HVD3082EDR)PCB源文件" ^8 q( R9 n' `5 P" K% ?1 a8 F
/ ]" o) | ]2 V; l
文件描述
e3 S. F8 i& {$ K# B; G+ s* L- g& e
1. 作品用途:控制板6 m; e# o/ X; q6 V1 J: u
8 [8 k" _0 d3 W* G7 O
2. 软件版本:AD 10
6 m0 m+ N* j$ J7 @; j( a4 c3 _: V
3. 层数:4层板
# c1 C8 d0 |$ {9 [4 f! }. g7 s' S/ T/ W. P6 G$ ]7 b
4. 用到的主要芯片:LPC1124FBD48+LPC1850FET180+SN65HVD3082EDR" V& H9 X% N2 V: E) N2 W% [
' ]- C* J$ @9 D5 `2 a6 n
5. PCB尺寸:87mm*69mm, Z% b/ d% \, V. R1 y% X3 `0 a
" I) ]. i# l t+ A
7 U& ]: _' }! u7 ]7 z作品截图如下:# ]9 L$ F* ~1 `" T. u/ D6 b7 @% U
# x" Z# M$ }( }* r
顶层截图:
0 b1 ~5 @" D2 E, a. e9 s0 }
" S1 D [( D) f% h
. r j6 L" N, x; \# V底层截图:
! ]4 E4 `- p; c) E! ^
- ]' U2 D0 @1 T' [, M: ]) u1 @
% @) s3 S0 X4 O$ B4 `. ]全层截图:
9 w) J9 Y# H4 C6 {2 Z2 `6 V$ J+ S
8 e( i( g$ g- Y$ q$ w0 C1 [- Y) M8 D4 `8 f
叠层信息截图如下:& z5 V: X, G. u0 R- N$ l1 J
# D' P1 _0 Y8 W1 C5 D8 B
' A7 d/ T+ ]$ D, C6 f5 N
BOM:. C" u, N6 [% | i8 _0 r2 H
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | BUZZER | BZ1 | BUZZER(200MIL) | 1 | 0.1uF/16V-0603 | C1, C5, C16, C18, C20, C21, C27, C28, C29, C32, C33, C34, C35, C36, C37, C38, C39 | SMDCC-0603 | 17 | | C2, C3 | SMDCC-0603 | 2 | 0.1uF/50V-0603 | C4, C6, C7, C8, C12, C22, C25, C26 | SMDCC-0603 | 8 | | C9, C15 | SMDCC-1812 | 2 | | C10, C11 | SMDCC-0805 | 2 | | C13 | SMDCC-1210 | 1 | 47uF/50V | C14 | SMDEC-8MM(6.3MM)) | 1 | 100uF/10V | C17, C19 | SMDEC-6MM(220MIL) | 2 | 22pF | C23, C24, C30, C31 | SMDCC-0603 | 4 | | CN1 | SIP-3 | 1 | Header 5 | CON1, J1 | SIP-5 | 2 | | D1, D2, D3, D4 | SMDD-CCD | 4 | S1ML | D5, D6, D9 | SOD-123 | 3 | | D7, D8, D11, D12 | SMDD-4007 | 4 | SMCJ33CA | D10 | SMDD-CCE | 1 | Comment | Designator126 | LOGO-ESD | 1 | Comment | Designator127 | logo-pb | 1 | ISM010 | F1, F2, F3, F4 | SMDR-0805 | 4 | 1206/60V/0.25A | F5 | SMDR-1206 | 1 | SM020 | F6 | SMDL-1812 | 1 | | JA1, JAS1, JB1 | JS-1120R-4P | 3 | | JC1 | EH-4Aw | 1 | | JD1, JE1 | B2B-XH-AW | 2 | | JF1 | B7B-XH-AW | 1 | 100R | L1, L2, L3, L4, L7 | SMDR-0603 | 5 | | L5 | SMDL-NEW | 1 | 22uH/1A | L6 | SWPA4030 | 1 | 0603/红 | LED1, LED2 | SMDLED-0603 | 2 | KRC105S | Q1, Q4 | SOT-23 | 2 | BCX19 | Q2, Q3 | SOT-23 | 2 | 100K-0603 | R1, R8, R13, R20, R38, R73 | SMDR-0603 | 6 | 10K-0603 | R2, R10, R11, R14, R18, R22, R23, R24, R25, R28, R30, R34, R39, R42, R49, R51, R52, R54, R55, R56, R57, R58, R59, R60, R61, R62, R63, R67, R69, R71, R72, R76, R77, R78, R82 | SMDR-0603 | 35 | 47K-0603 | R3, R12 | SMDR-0603 | 2 | 15K-0603 | R4, R6, R7, R9, R15, R17 | SMDR-0603 | 6 | 1K-0603 | R5, R16, R19, R21, R26, R27, R29, R31, R32, R33, R35, R36, R37, R50, R53, R64, R65, R66, R68, R70, R74, R79, R80, R81 | SMDR-0603 | 24 | 4R7-2512 | R40 | SMDR-2512 | 1 | SMV1812H380NXB | R41 | SMDR-1812 | 1 | 124K-0603 | R43 | SMDR-0603 | 1 | 1.5K-1/10W-0603-1% | R44 | SMDR-0603 | 1 | 22R-0805 | R45, R47 | SMDR-0805 | 2 | | R46 | SMDR-0603 | 1 | 23.7K-0603 | R48 | SMDR-0603 | 1 | 12K-1/10W-0603-1% | R75 | SMDR-0603 | 1 | 330R-0603 | R83, R84 | SMDR-0603 | 2 | TQ2-5V | REL1 | TQ2-5V | 1 | RA-4*10K-1/16W-0603-5% | RP1 | RN(0603) | 1 | CHS-08TB | SW1 | sw-0817CKE-A | 1 | KSD-02H | SW2 | SW(SMD-4) | 1 | TESTPOINT | T1, T2, T3, T6, T8, T10, T11, T12, T13, T14, T17, T18, T19, T21, T22, T23, T24, T25, T26, T27, T28, T29, T30, T31, T32, T33, T34, T35, T36, T37, T38, T39, T40, T41, T42, T43, T44, T45, T46, T47, T48, T49, T50, T51, T52, T73, T74, T77, T78, T79, T80, T81, T82, T83, T85, T86, T88, T89, T90, T91, T92, T93, T94, T95, T96, T97, T98, T99, T100, T101, T102, T103, T104, T105, T106, T107, T108, T109, T110, T111, T112, T113, T114, T115, T116, T117, T118, T119, T120, T121, T122, T123, T124, T125, T126, T127, T128, T129, T130, T131, T132 | TEST | 101 | | T4, T5, T7, T9, T15, T16, T20, T55, T56, T57, T58 | TEST | 11 | ? | T53, T54, T59, T60, T61, T62, T63, T64, T65, T66, T67, T68, T69, T70, T71, T72, T75, T76 | TEST | 18 | MAX489EESD+ | U1, U3 | SO-14 | 2 | 74HC32D | U2 | SO-14 | 1 | SN65HVD3082EDR | U4 | SO-8 | 1 | | U5, U6 | SOT23-6P | 2 | LP38690DT-3.3(TO-252) | U7 | TO-252 | 1 | LPC1124FBD48 | U8 | LQFP48 | 1 | LPC1850FET180 | U9 | BGA180*14 | 1 | MX25L1635 | U10 | sop-8 | 1 | CAT706SVI | U11 | So-8 | 1 | USB | USB1 | USB_Micro_5p_SMT | 1 | 12.000MHz | X1, Y1 | HCX-5SB | 2 |
- A* z' e! O1 v8 ^- Z/ d附件:4 j9 {0 n& P# r' X' S
* a8 E( l; _7 T. b# ~3 E
PCB源文件如下:3 M8 L: @$ s& N( ]2 t* I4 z
5 L1 i7 T' I* U7 V# ~2 \
& x. C0 V. Z( L- ?- h* }
$ i+ K/ h4 m3 E8 x
