Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
0402_MLP | DIODE_TVS_BIDIR_0402_MLP_IC_0.4 | 0402ESDA-MLP | IC | 3 | U2; U3; U6 |
BATT_21X20MM | BATTERY_SKT_3V_BATT_21X20MM_IC_ | 3003 | IC | 1 | BT500 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55M | 1000pF | DISCRETE | 3 | C1; C2; C9 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_4 | 0.7pF | DISCRETE | 1 | C4 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_1 | 0.1uF | DISCRETE | 26 | C6; C11; C17; C18; C20; C21; C22; C24; C26; C31; C44; C57; C58; C59; C60; C61; C62; C63; C64; C65; C68; C69; C70; C74; C76; C79 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.6_1 | 10PF | DISCRETE | 2 | C8; C71 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.55 | 3.0PF | DISCRETE | 7 | C14; C77; C83; C84; C85; C86; C87 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_3 | 220PF | DISCRETE | 2 | C32; C33 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.65M | 4.7uF | DISCRETE | 1 | C41 |
CC0402_25 | CAP_NP_CC0402_25_DISCRETE_0.5_5 | 1uF | DISCRETE | 1 | C80 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_1MM_1 | 10uF | DISCRETE | 9 | C3; C19; C25; C27; C28; C30; C43; C66; C75 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9MM | 1uF | DISCRETE | 4 | C23; C29; C67; C78 |
CC0603_OV | CAP_NP_CC0603_OV_DISCRETE_0.9 M | 2.2uF | DISCRETE | 2 | C48; C56 |
CON5_SMA_7SQ_SM | CONN_COAX_1P_F_CON5_SMA_7SQ_SM_ | SLE-100010072-F01 | IO | 1 | J5 |
CON_1X8_SKT_2P54_TH | CONN_HDR_8X1_CON_1X8_SKT_2P54_T | SKT_1X8 | IO | 2 | J1; J3 |
CON_MICROAB_10F_25_SM_RA | MICRO_USB_CONN_10PIN_CON_MICROA | USB_MICRO_AB | IO | 1 | J6 |
CON_SKT1X6_TH | CONN_HDR_6X1_CON_SKT1X6_TH_IO_8 | SKT_1X6 | IO | 1 | J4 |
CON_SKT1X10_TH | CONN_HDR_10X1_CON_SKT1X10_TH_IO | SKT_1X10 | IO | 1 | J2 |
DFN8_1P27_6X5MM_3P6X4P2 | AT45DB021E_9P_DFN8_1P27_6X5MM_3 | AT45DB041E | IC | 1 | U4 |
ELECTRODE_SQ_3MM | ELECTRODE_ELECTRODE_SQ_3MM_IC_0 | 3x3mm | IC | 2 | SW2; SW5 |
F_ANTENNA_DIG528-2 | F_ANTENNA_F_ANTENNA_DIG528-2_IC | F_Antenna | IC | 1 | ANT1 |
HDR103 | CONN_HDR_3X1_HDR103_IO_8.38 MM_ | HDR_1X3 | IO | 2 | J18; J24 |
HDR203_M20 | CON_HDR_3X2_HDR203_M20_IO_8.9MM | HDR 2X3 | IO | 1 | J36 |
HDR_1X2_2P54MM | CONN_HDR_2X1_HDR_1X2_2P54MM_IO_ | HDR_1X2 | IO | 7 | J8; J19; J20; J21; J23; J34; J35 |
HDR_2X5_6X3_1P27MM_TH | CONN_HDR_5X2_HDR_2X5_6X3_1P27MM | HDR 2X5 | IO | 2 | J9; J11 |
IND_0402 | BEAD_IND_0402_DISCRETE_0.45MM_1 | 5.6nH | DISCRETE | 1 | L1 |
IND_0402 | INDUCTOR_IND_0402_DISCRETE_0.6M | 0.1uH | DISCRETE | 2 | L5; L6 |
IND_0603 | IND_FERRITE_IND_0603_DISCRETE_0 | 330 OHM@100MHZ | DISCRETE | 2 | L2; L4 |
IND_VLS4012E | IND_FERRITE_IND_VLS4012E_DISCRE | 10uH | DISCRETE | 1 | L3 |
LED4_3P4X3MM_SMT | CLV1A_LED_4P_LED4_3P4X3MM_SMT_I | CLV1A-FKB-CJ1M1F1BB7R4S3 | IC | 1 | LED4 |
LED_2P_0805 | LED_LED_2P_0805_IC_1.1MM_370-76 | RED | IC | 1 | LED3 |
LED_0603 | LED_LED_0603_IC_0.7MM_370-76693 | YEL-GRN | IC | 2 | D2; LED2 |
LED_0603 | LED_LED_0603_IC_0.7 MM_370-7669 | RED | IC | 1 | LED1 |
MAPLGA48_7X7_0P5MM | KW41Z512_64P_MAPLGA48_7X7_0P5MM | MKW41Z512VHT4 | IC | 1 | U1 |
PMDU_SOD123 | DIODE_SCHTKY_PMDU_SOD123_IC_0.9 | RB160M-30 | IC | 8 | D3; D4; D5; D6; D7; D8; D9; D10 |
QFN5X3_0P5_3X3 | FXOS8700CQ_QFN_16P_QFN5X3_0P5_3 | FXOS8700CQ | IC | 1 | U9 |
QFN8_1P6X1P6MM | 74LVC2T45GM_8P_QFN8_1P6X1P6MM_I | 74LVC2T45GM,125 | IC | 1 | U8 |
QFN32_S142EP | PK20DX128V_QFN_32P_QFN32_S142EP | MK20DX128VFM5 | IC | 1 | U7 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_4 | 100 | DISCRETE | 3 | R1; R2; R6 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_3 | 4.99K | DISCRETE | 2 | R8; R9 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 MM_ | 10K | DISCRETE | 17 | R11; R13; R15; R20; R23; R33; R34; R38; R47; R60; R63; R65; R93; R652; R653; R654; R675 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.45 MM_ | 0 | DISCRETE | 21 | R18; R22; R29; R30; R31; R35; R37; R39; R42; R61; R66; R74; R77; R79; R80; R82; R83; R84; R86; R89; R97 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_4 | 4.7K | DISCRETE | 5 | R19; R46; R59; R64; R91 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM_47 | 33 | DISCRETE | 2 | R21; R25 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.41MM_1 | 1K | DISCRETE | 3 | R27; R28; R41 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_1 | 15K | DISCRETE | 1 | R44 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_1 | 1.5K | DISCRETE | 1 | R55 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4MM__1 | 27K | DISCRETE | 1 | R56 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.4 MM_2 | 2.2K | DISCRETE | 2 | R62; R67 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_4 | 102K | DISCRETE | 1 | R85 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_2 | 270 | DISCRETE | 2 | R670; R671 |
RC0402_25 | RES_RC0402_25_DISCRETE_0.40 M_3 | 430 | DISCRETE | 1 | R672 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM_47 | 220 | DISCRETE | 3 | R10; R57; R81 |
RC0603_OV | RES_RC0603_OV_DISCRETE_0.6MM__1 | 0 | DISCRETE | 4 | R45; R54; R87; R88 |
RC0603_OV | THERMISTOR_RC0603_OV_DISCRETE_0 | 10K | DISCRETE | 1 | RT2 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.6MM_47 | 18.2 | DISCRETE | 1 | R52 |
SH0402 | RES_SHORT-2_SH0402_DISCRETE_0.1 | 0 | DISCRETE | 15 | SH3; SH4; SH7; SH8; SH9; SH10; SH11; SH12; SH13; SH14; SH15; SH25; SH28; SH29; SH30 |
SH0603 | RES_SHORT-2_SH0603_DISCRETE_0.1 | 0 | DISCRETE | 3 | SH500; SH501; SH503 |
SOT23-6_A | MIC2005-0.8YM6_SOT23-6_A_IC_1.4 | MIC2005-0.8YM6 | IC | 1 | U10 |
SOT23_A | NMOS_2N7002BKW_3P_SOT23_A_IC_1. | BSH111BK | IC | 4 | Q1; Q5; Q6; Q7 |
SOT223 | LD1117AS18_SOT223_IC_1.8MM_312- | NCP1117ST33T3G | IC | 1 | U17 |
SW2_TACT_4X3_SM | SW2P_SW2_TACT_4X3_SM_IC_2 MM_51 | KAN0444-0201E1 | IC | 4 | SW1; SW3; SW4; SW6 |
TPAD_030 | TESTLOOP_TPAD_030_IO_0.1MM_211- | TPAD_030 | IO | 35 | TP2; TP6; TP7; TP8; TP14; TP17; TP18; TP19; TP20; TP21; TP22; TP24; TP25; TP26; TP27; TP28; TP29; TP30; TP31; TP32; TP33; TP34; TP41; TP42; TP45; TP47; TP48; TP50; TP51; TP52; TP53; TP54; TP55; TP56; TP58 |
TPAD_040 | TESTLOOP_TPAD_040_IO_0.1MM_211- | TPAD_040 | IO | 18 | TP3; TP4; TP9; TP10; TP11; TP12; TP15; TP16; TP23; TP35; TP36; TP37; TP39; TP40; TP43; TP44; TP46; TP57 |
TPAD_040 | TESTLOOP_TPAD_040_0.1MM_211-766 | TPAD_040 | IC | 1 | TP38 |
TP_TH_063 | TESTLOOP_TP_TH_063_IO_8.13MM_21 | TESTLOOP_BLACK | IO | 1 | TP1 |
UDFN6_1P45X1_0P5MM | NLX2G14_6P_UDFN6_1P45X1_0P5MM_I | NLX2G14 | IC | 1 | U11 |
UDFN6_1X1P5MM | 74LVCH1T45_6P_UDFN6_1X1P5MM_IC_ | 74LVCH1T45 | IC | 3 | U5; U15; U16 |
XQFN8_1P45X1P25MM | NTSX2102GU8H_8P_XQFN8_1P45X1P25 | NTSX2102GU8H | IC | 1 | U500 |
XTAL2-3P2X1P5-SM | CRYSTAL_XTAL2-3P2X1P5-SM_IC_0.9 | 32.768KHZ | IC | 1 | Y2 |
XTAL3_3P35X1P45_SM | XTAL_CS_XTAL3_3P35X1P45_SM_IC_0 | 8.00MHZ | IC | 1 | X1 |
XTAL4_2P1X1P7MM_SM | XTAL_13Y_XTAL4_2P1X1P7MM_SM_IC_ | 32MHZ | IC | 1 | Y1 |
附件:
