作品名:[AD 10][2层] 开发板(AT91RM9200+DM9161E+LM4549)PCB源文件
2 N+ j7 P' V, \0 F2 U, n R$ j6 A& H/ w' {1 ]
文件描述 n. C% o+ }6 i) _: Z4 _# D
1. 作品用途:开发板 O9 w i6 @4 J: } u
2. 软件版本:AD 10# G3 K' p7 B9 ~4 p9 G
3. 层数:2层板2 S, {# w- [6 a7 y
4. 用到的主要芯片:AT91RM9200+DM9161E+LM4549
- u- y* \; N' N8 W5. PCB尺寸:165mm*116mm4 c% n2 q( [* i4 c* @/ A
2 Q9 c6 A; H1 Q; ?作品截图如下:
! [: z% z/ K3 m2 _顶层截图:: r3 ~1 J6 Z% S9 r/ V
" ?& p8 }" O o# f! G
底层截图:# l; f1 C( v( x4 |
$ K3 W; ~# B/ E: E
全层截图:
# o7 H/ o( w# N: M1 G: g
: V2 ~4 {% r' |
叠层信息截图如下:1 I3 I6 |+ h4 q/ k
. C8 s9 Z! {$ |. R' w# XBOM:+ W% ]0 U/ G4 x3 g1 D; g
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | | | VIA | 4 | 3.6V | BT1 | BATTERY | 1 | 103 | C1, C23, C25, C26, C27 | 0805 | 5 | 47PF | C2, C3, CU3, CU4 | 0805 | 4 | C104 | C4, C5, C6, C7, C8, C9, C10, C11, C12, C13, C14, C15, C16, C17, C18, C19, C20, C21, CE1, CE2, CE3, CE4, CEM1, CM1, CM2, CM3, CM4, CM5, CM6, CM7, CM8, CM9, CM10, CM11, CM12, CM13, CM14, CM15, CN1, CN3, CN4, CN5, CN6, CPLLB1, CPLLB2, CU2, RSC1, RSC2, RSC3, RSC4, UC1 | 0805 | 51 | cap | C22 | 0805 | 1 | 470UF | C24 | RB8 | 1 | C103 | C28 | 0805 | 1 | 1UF | C30, C31 | 0805 | 2 | 220PF | C32 | 0805 | 1 | 2.2UF | C33 | RB.2/.4 | 1 | 1UF | C34 | RB.2/.4 | 1 | 104 | C35 | RB.2/.4 | 1 | 104 | C36, C38, CAC1, CAC2, CAC971, CAC972, CAC973, CDISK1, CDISK2, CDISK3, CDISK4, CDISK5, CE5, CE6, CE7 | 0805 | 15 | 2200p | C37 | 0805 | 1 | 33PF | C39, C40 | 0805 | 2 | 100UF | CDISK7 | RB8 | 1 | 22uF | CN2 | RB8 | 1 | 0.01uF | CNET1 | RAD0.1 | 1 | 5600P | CRCA1 | 0805 | 1 | 680P | CRCA2 | 0805 | 1 | 4700P | CRCB1 | 0805 | 1 | 470P | CRCB2 | 0805 | 1 | 10P | CT1, CT2 | 0805 | 2 | 30P | CT3, CT4 | 0805 | 2 | 10uF | CU1 | rb8 | 1 | | D1 | 0805 | 1 | | D2 | LED | 1 | 1N4001 | D3 | LED | 1 | RUN | D4 | LED | 1 | STATUS | D5 | LED | 1 | TXLED | D6 | LED | 1 | LED | D7 | LED | 1 | diode | D8 | LED | 1 | FDX | DE1 | LED-SMT | 1 | 100BPS | DN1 | LED-SMT | 1 | LINK | DN2 | LED-SMT | 1 | IDE40 | J1 | HDR2X20 | 1 | JTAG | J2 | IDC20 | 1 | USBH | J3 | USB-HOST | 1 | | J4 | sip3 | 1 | | J5 | DB9FL | 1 | USBD | J6 | USB-B | 1 | DC-12V | J7 | POWER3 | 1 | con4 | J8 | POWER-4 | 1 | MIC | J9 | mic-a | 1 | DIS | J10 | IDC50 | 1 | con3 | J11, J12 | SIP3 | 2 | PHONEJACK STEREO SW | J13 | HEADPHONE | 1 | PHONEJACK S TEREO 3.5 | J14 | SIP3 | 1 | | JP1 | SIP2 | 1 | NET-TRAIN | LF | PPT | 1 | BEAD2 | LN1 | L3 | 1 | BEAD1 | LPLL1 | L3 | 1 | 18.432MHz | M1 | XTAL0 | 1 | 32.768KHz | M2 | XTAL1 | 1 | 32768KHz | M3 | XTAL1 | 1 | XTAL1 | M4 | XTAL3 | 1 | 24.576MHz | M5 | XTAL0 | 1 | 8050 | Q1 | SOT-23 | 1 | 470 | R1 | 0805 | 1 | 1K | R2, R3, R8, R22, R23, R24, R25, R29 | 0805 | 8 | 10K | R4, R5, R7, R15, R16, R17, R28, RE1, RE2, RE3, RE4, RE5, RNET1, RWAIT1 | 0805 | 14 | res2 | R6, R9, R10, R11, R12, R13 | 0805 | 6 | 0R | R14, R18, R19, R20 | 0805 | 4 | 47K | R21, R30, R31 | 0805 | 3 | 47 | R26 | 0805 | 1 | 2.2K | R27 | 0805 | 1 | 1M | R32 | 0805 | 1 | R47K | RBMS1, USBR3 | 0805 | 2 | 2K2 | RE6 | 0805 | 1 | 6K8 | RE7 | 0805 | 1 | 510R | RE8, RE9, RE10 | 0805 | 3 | NET-RJ45 | RJ1 | RJ45P | 1 | 50R | RN1, RN2, RN3, RN4 | 0805 | 4 | 75R | RN5, RN6, RN7, RN8 | 0805 | 4 | 10R | RPLLB1 | 0805 | 1 | 1K27 | RRCA1 | 0805 | 1 | 1K96 | RRCB1 | 0805 | 1 | R22 | RU1, RU2 | 0805 | 2 | R15K | RU3, RU4, USBR1 | 0805 | 3 | | S1, S2, S3 | SW-PB2 | 3 | AT91RM9200 | U1 | PQFP208 | 1 | | U2 | SOIC8 | 1 | 74LVC245 | U3, U4, U5, U6 | SSOP20 | 4 | HY57V281620 | U7, U8 | SOP54 | 2 | AM29LV640 | U9 | TSOP48 - duplicate | 1 | AT24C512 | U10 | SOIC8 | 1 | DM9161E | U11 | TQFP-48 | 1 | 74LVT08 | U12 | SSOP14 | 1 | SP117-3v3 | U13 | SOT-223 | 1 | SP117-1v8 | U14 | SOT-223 | 1 | LM4549 | U15 | TQFP-48 | 1 | | U16, U17, U19 | TA7805F | 3 | Power-3 | U18 | TA7805F | 1 | SP3232ECA | URS1 | SsOP16 | 1 | SP708S-SOIC | URST1 | SOIC8 | 1 | 33P | USBC1 | 0805 | 1 | 15P | USBC2, USBC3 | 0805 | 2 | R22K | USBR2 | 0805 | 1 | R1K5 | USBR4 | 0805 | 1 | 27R | USBR5, USBR6 | 0805 | 2 | 附件:4 `0 F2 I, F! Y9 j( B- R
PCB源文件如下:
0 O9 X/ }2 n" M* x8 J& i: G5 w9 A. F4 G8 ]- Y$ r' ?
7 X( L0 h/ K% v) |8 A3 ^
