查看: 185|回复: 0
[allegro16.3][8层] Kinetis K40 100 MHz低功耗MCU塔式系统模块 8-1210(PK40DX256...
发表于 2020-1-20 17:28 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
" O( `8 L% A6 T. k7 e4 d+ ?- R- W* C' o[allegro16.3][8层] Kinetis K40 100 MHz低功耗mcu塔式系统模块 8-1210(PK40DX256VMD10+MC9S08JM60CLD+MMA8451Q)原理图和pcb文件
8 P7 H. t# }9 S8 Q! q7 c" E/ s1 ?
; h" c/ c( [. D. o$ F文件描述:8 Q: w1 I7 S- ~  t& n, v) r
& b5 d- y$ i& f- c  V1 Y6 ^
1. 作品用途:Kinetis K40 100 MHz低功耗MCU塔式系统模块 8-1210
* v8 H. l$ n5 b+ @9 ?2. 软件版本:allegro16.3
+ p! |) `/ P8 F/ v, ~, D3. 层数:8层
7 q9 n2 W2 z/ A( U7 s: v3 r/ }4. 用到的主要芯片:PK40DX256VMD10+MC9S08JM60CLD+MMA8451Q( j! @! j4 t7 ?/ |( P4 Z7 _
5. pcb尺寸: 3543*3174 MIL
" ]9 p! A; [" m' R
9 E0 u& u0 g: t' o作品截图如下:
- J9 D. p6 y6 c% o* ~
1 L+ e' G, p8 w5 x9 d) C顶层截图:
7 A" f! I) A/ I
9 I9 Z2 x+ m% s2 R# j: ?底层截图:. q3 J8 d, B7 J2 M
/ U& E+ e. i) j! i1 n- M
1 |. y: V# u6 |5 X3 G全层截图:& q. b# m$ m% j: k0 V" J7 J4 A
0 T& b+ v: T, a9 }7 I- W
) Y# c- q" L+ m3 _. M  u. x) ^叠层阻抗信息如下:; S1 G9 Q7 D- u
; }" Y" Y! F$ n$ k* BBOM:8 T; t+ K+ S/ A5 H# L
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UFDISCRETE32C2; C3; C4; C5; C7; C11; C15; C16; C17; C18; C19; C20; C23; C24; C25; C27; C29; C30; C31; C33; C35; C36; C37; C38; C39; C40; C41; C43; C44; C45; C48; C52
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PFDISCRETE4C6; C13; C26; C34
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM1000PFDISCRETE1C10
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.01UFDISCRETE2C28; C32
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.25M2.2UFDISCRETE1C47
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UFDISCRETE11C1; C8; C9; C12; C14; C42; C46; C49; C50; C51; C53
CC3528-21CAP_POL_CC3528-21_2.1MM_150-7854.7uFIC2C21; C22
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS TOWER SYSTEMIO1J8
CON5_MUSB_AB_0P8_RA_SMTUSB_MINI_B_SKT_CON5_MUSB_AB_0P8USB_MINI_B 5IO1J17
CONN-MMC_SD_OPTMMC_SD_CONN_2405_CONN-MMC_SD_OPMMC-SD ConnectorIO1J19
CON_FTSH_19M_50_SMCONN_HDR_19_CON_FTSH_19M_50_SM_HDR_19PIO1J16
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M_50CON_2X10IO1J5
CON_TFM_20M_50_SMCONN_SHRHDR_10X2_CON_TFM_20M__1CON_2X10IO2J6; J7
DIODE_3P2X2P2LED_DIODE_3P2X2P2_IC_1.1MM_480-QTLP610CIRIC1D6
HDR2X4_TSM_SMCONN_HDR_4X2_HDR2X4_TSM_SM_IO_9HDR_2x4IO1J4
HDR102CONN_HDR_2X1_HDR102_IO_8.71 MM_HDR 1X2 THIO6J2; J11; J12; J13; J14; J15
HDR103CONN_HDR_3X1_HDR103_IO_8.65MM_2HDR TH 1X3IO4J1; J3; J9; J10
HDR203_TSM_SMCONN_HDR_3X2_HDR203_TSM_SM_IO_9HDR_2X3IO1J18
IND_0603IND_IND_0603_0.8MM_180-75495_10100 OHM@100MHZIC5L1; L4; L5; L6; L7
IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHMDISCRETE2L2; L3
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_2LED_OR + ELECTRODEIC1D8
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_3LED_YEL + ELECTRODEIC1D9
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_ILED_GRN + ELECTRODEIC1D10
LED2_ELECTRODELED2_ELECTRODE_LED2_ELECTRODE_1LED2_ELECTRODEIC1D11
LED_0603LED_LED_0603_IC_1.0MM_370-76472YEL/GRNIC2D1; D4
LED_0603LED_LED_0603_IC_0.8MM_370-75076LED_YELLOWIC1D2
LED_0603LED_LED_0603_IC_0.8MM_370-75080ORANGEIC1D3
MAPBGA144_1_13X13PK40DX256VMD10_BGA144_MAPBGA144PK40DX256VMD10IC1U3
POT3_3352TPOT_POT3_3352T_DISCRETE_470-8015KDISCRETE1R65
QFN5X3_0P5_3X3MMA8451Q_16P_A_QFN5X3_0P5_3X3_IMMA8451QIC1U2
QTLP610TRAN_PHOTO_QTLP610_IC_1.1MM_480QTLP610CPDIC1Q3
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0KDISCRETE26R9; R12; R14; R17; R21; R22; R23; R24; R26; R28; R29; R31; R33; R34; R35; R36; R37; R38; R53; R66; R67; R71; R88; R89; R99; R101
RC0402_25RES_RC0402_25_DISCRETE__470-7601.0KDISCRETE1R13
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0KDISCRETE6R15; R79; R87; R90; R96; R102
RC0402_25RES_RC0402_25_DISCRETE_470-7646330DISCRETE1R16
RC0402_25RES_RC0402_25_DISCRETE_470-3078270DISCRETE1R18
RC0402_25RES_RC0402_25_DISCRETE_470-757933DISCRETE5R20; R30; R32; R91; R92
RC0402_25RES_RC0402_25_DISCRETE_470-75360DISCRETE2R25; R27
RC0402_25RES_RC0402_25_DISCRETE_470-30851.54KDISCRETE1R86
RC0402_25RES_RC0402_25_DISCRETE_470-764810MDISCRETE1R97
RC0402_25RES_RC0402_25_DISCRETE_470-30914.99KDISCRETE1R104
RC0402_25RES_RC0402_25_DISCRETE_470-78352.2KDISCRETE1R124
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400DISCRETE60R1; R2; R3; R4; R5; R6; R7; R8; R39; R40; R41; R42; R43; R44; R45; R46; R47; R48; R49; R50; R51; R52; R54; R55; R56; R57; R58; R59; R60; R61; R62; R63; R64; R76; R77; R84; R93; R95; R98; R100; R103; R105; R106; R107; R108; R109; R110; R111; R112; R113; R114; R115; R116; R117; R118; R119; R120; R121; R122; R123
RC0603_OVRES_RC0603_OV_DISCRETE_470-75434.70KDISCRETE4R10; R11; R19; R78
RC0603_OVRES_RC0603_OV_DISCRETE_470-75841.0MDISCRETE2R72; R82
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440DISCRETE11R68; R69; R70; R73; R74; R75; R80; R81; R83; R85; R94
SKT_BAT_780X1210BATTERY_SKT_3V_SKT_BAT_780X1210BK-883IC1BT1
SMB_2P7X1P4DIODE_SCHTKY_SMB_2P7X1P4_IC_0.7MSS1P3LIC1D5
SO6_A1T45_SO6_A_IC_1.1MM_312-75172_SSN74LVC1T45IC4U4; U5; U8; U13
SO8MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YMIC1U6
SOT23NPN_SOT23_IC_1.12 MM_480-75173_MMBT3904LT1GIC1Q1
SOT223LT1129CST-3.3_SOT223_IC_1.8MM_3MIC2920A-3.3WSIC1U10
SOT223MIC37139-1.8BS-1_SOT223_IC_1.8MMIC5239-1.8IC1U11
SOT-23BAT721B_SOT-23_IC_1.3MM_480-779BAT54CIC1D7
SOT-23TRAN_NPN_RES_SOT-23_IC_1.3MM_48PDTC115TIC1Q2
SOT_143SPB0503_SOT_143_IC_1.22MM_480-7SP0503BIC1U7
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switchIC3SW1; SW2; SW3
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8 MM_21TEST POINT WHITEIO12TP1; TP2; TP4; TP5; TP6; TP7; TP9; TP10; TP11; TP12; TP13; TP14
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_210TEST POINT BLACKIO3TP3; TP8; TP15
TQFP44MC9S08JM60CFGE_TQFP44_IC_1.60 MMC9S08JM60CLDIC1U12
TSSOP14SN74LVC126A_TSSOP14_TSSOP14_IC_SN74LVC126APWG4IC1U9
TSSOP2074LVC573A_TSSOP20_IC_1.2MM_312-74LVC573AIC1U1
XTAL3_3P35X1P45_SMXTAL_CS_XTAL3_3P35X1P45_SM_IC_08.00MHZIC1X1
XTL2_ECS_CSM7_SMXTAL_XTL2_ECS_CSM7_SM_IC_4.3MM_4MHzIC1Y2
XTL2_ECS_SMXTAL_XTL2_ECS_SM_IC_2.25MM_230-32.768KHzIC1Y1
附件:
$ b$ g/ g  J* E( |3 e+ k$ t原理图和PCB文件如下:
2 W  {5 |3 ?7 i+ D, w  O+ p8 P
游客,如果您要查看本帖隐藏内容请回复
; T. s& n0 F: h) v
* s2 z1 E$ H- F
GMT+8, 2025-7-23 14:39 , Processed in 0.125000 second(s), 28 queries , Gzip On.
