[allegro17.2][6层]网络摄像机(M3881C+PS5510+IP101GR)原理图和pcb文件 文件描述: 1. 作品用途:网络摄像机 2. 软件版本:allegro17.2 3. 层数:6层 4. 用到的主要芯片:M3881C+PS5510+IP101GR 5. PCB尺寸:1496*1496 mil 作品截图如下: 顶层截图: 底层截图: 全层截图: BOM: Bill of Material Report (Condensed) | | | | | | SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES | 名称 | 类型 | 属性 | 类别 | 数量 | 位号 | C157D79 | C157D79 | MOUNT_HOLE | IC | 2 | HG1; HG2 | C0201 | C0201 | 1uF,6.3V | IC | 26 | CG3; CG4; CG6; CG7; CG11; CG12; CG17; CG28; CG29; CG31; CG38; CG45; CG48; CG57; CG58; CG59; CG60; CG72; CG75; CG76; CG77; CG79; CG85; CG131; CG132; CG133 | C0201 | C0201 | 0.1uF,6.3V | IC | 54 | CG5; CG8; CG13; CG14; CG15; CG16; CG18; CG19; CG21; CG25; CG30; CG35; CG36; CG39; CG43; CG44; CG47; CG49; CG50; CG52; CG61; CG62; CG63; CG64; CG65; CG66; CG67; CG68; CG69; CG84; CG86; CG88; CG90; CG92; CG99; CG103; CG105; CG109; CG110; CG112; CG113; CG116; CG117; CG118; CG119; CG120; CG121; CG122; CG125; CG126; CG127; CG129; CG130; CG134 | C0201 | C0201 | 0.01uF,6.3V | IC | 4 | CG81; CG83; CG100; CG106 | C0402 | C0402 | 0.1uF,16V | IC | 4 | CG2; CG73; CG93; CG94 | C0402 | C0402 | 10uF,6.3V | IC | 21 | CG10; CG22; CG27; CG46; CG51; CG53; CG55; CG56; CG80; CG82; CG87; CG91; CG97; CG107; CG108; CG111; CG114; CG115; CG123; CG124; CG128 | C0402 | C0402 | 22pF,50V | IC | 3 | CG23; CG32; CG40 | C0402 | C0402 | 27pF,50V | IC | 2 | CG70; CG71 | C0402 | C0402 | 220pF,50V | IC | 1 | CG78 | C0402 | C0402 | XX_10pF,50V | IC | 1 | CG89 | C0402 | C0402 | 15pF,50V | IC | 2 | CG96; CG101 | C0603 | C0603 | 10uF,10V | IC | 7 | CG1; CG20; CG33; CG37; CG41; CG74; CG102 | C0603 | C0603 | 22uF,6.3V | IC | 8 | CG9; CG24; CG26; CG34; CG42; CG54; CG98; CG104 | C1206 | C1206 | 1000pF,2KV | IC | 1 | CG95 | DFN6-2X2P065 | DFN6-2X2P065 | XCA201A06BCR | IC | 1 | UG3 | L0402 | L0402 | FBM-11-100505-121T | IC | 3 | LG1; LG5; LG7 | L0402 | L0402 | SBY100505T-121Y-N | IC | 1 | LG6 | L-25201B | L-25201B | 2.2uH, 2A | IC | 2 | LG2; LG4 | Q-SOT23-6 | Q-SOT23-6 | TPS79301,200mA,ADJ | IC | 2 | UG10; UG11 | QFN32-4X4P04 | QFN32-4X4P04 | IP101GR | IC | 1 | UG9 | R0402 | R0402 | 2.7K | IC | 2 | RG1; RG7 | R0402 | R0402 | 10K | IC | 4 | RG2; RG40; RG50; RG53 | R0402 | R0402 | 75K,1% | IC | 1 | RG3 | R0402 | R0402 | 100K,1% | IC | 1 | RG4 | R0402 | R0402 | 10K, 1% | IC | 2 | RG5; RG6 | R0402 | R0402 | 105K,1% | IC | 1 | RG8 | R0402 | R0402 | 23.7K,1% | IC | 1 | RG9 | R0402 | R0402 | 4.7K | IC | 11 | RG10; RG17; RG18; RG32; RG35; RG36; RG37; RG38; RG39; RG51; RG52 | R0402 | R0402 | 240,1% | IC | 2 | RG11; RG12 | R0402 | R0402 | 1K,1% | IC | 2 | RG13; RG14 | R0402 | R0402 | XX_0 | IC | 3 | RG15; RG21; RG24 | R0402 | R0402 | 0 | IC | 9 | RG16; RG26; RG27; RG28; RG29; RG41; RG47; RG48; RG49 | R0402 | R0402 | 100 | IC | 1 | RG20 | R0402 | R0402 | 47K | IC | 1 | RG22 | R0402 | R0402 | 8.2K | IC | 1 | RG23 | R0402 | R0402 | 5.6K | IC | 1 | RG25 | R0402 | R0402 | 200, 1% | IC | 1 | RG30 | R0402 | R0402 | 30 | IC | 1 | RG31 | R0402 | R0402 | 6.19K,1% | IC | 1 | RG33 | R0402 | R0402 | 75 | IC | 1 | RG34 | R0402 | R0402 | XX_300K,1% | IC | 1 | RG42 | R0402 | R0402 | 300K,1% | IC | 2 | RG43; RG46 | R0402 | R0402 | 51K,1% | IC | 1 | RG44 | R0402 | R0402 | 30.1K,1% | IC | 1 | RG45 | R0402 | R0402 | 4.02K, 1% | IC | 1 | RG54 | R0805 | R0805 | 10 | IC | 1 | RG19 | SCHUBERT-BGA361-13X13-P065 | SCHUBERT-BGA361-13X13-P065 | SoC | IC | 1 | UG1 | SENSOR-PS5510 | SENSOR-PS5510 | PS5510 | IC | 1 | UG13 | SMDCON1X2_125MM | SMDCON1X2_125MM | SMDCON1X2_125_180 | IC | 2 | JG1; JG3 | SMDCON1X3_125MM | SMDCON1X3_125MM | SMDCON1X3_125_180 | IC | 1 | JG4 | SMDCON1X4_125MM | SMDCON1X4_125MM | SMDCON1X4_125_90 | IC | 1 | JG2 | SMDCON1X6P1MM-CSI-1181-XXXX | SMDCON1X6P1MM-CSI-1181-XXXX | WAFER 1X6(CSI-1181-061R) | IC | 1 | JG5 | SMDL-ZLDF2012 | SMDL-ZLDF2012 | 2.2uH/0.74A/0.22Ohm | IC | 1 | LG3 | SOT23-6P | SOT23-6P | SY8121B | IC | 2 | UG2; UG5 | SOT26-6P | SOT26-6P | AP1511A | IC | 1 | UG8 | SOT143 | SOT143 | PT7M7811 | IC | 1 | UG6 | TP | TP | TP | IC | 8 | TPG1; TPG2; TPG3; TPG4; TPG5; TPG6; TPG7; TPG8 | USPQ-4B04-XC6233 | USPQ-4B04-XC6233 | iD9349-18FA4R | IC | 2 | UG4; UG12 | VP2019 | VP2019 | FMVP-208S | IC | 1 | TG1 | WSON8-8X6P127H075 | WSON8-8X6P127H075 | MX25L12835FM2I-10G | IC | 1 | UG7 | XTAL_X32 | XTAL_X32 | 19.2MHz | IC | 1 | YG1 |
附件: 原理图和pcb文件 |
6 Y9 W, K$ Z. k0 ~ |
