Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
8P4R-0402 | 8P4R-0402 | 8p4r-0402 | IC | 12 | RP1; RP2; RP3; RP4; RP5; RP6; RP9; RP12; RP13; RP14; RP15; RP16 |
AUDIO_JA6H67 | AUDIO_JA6H67 | | DISCRETE | 2 | AUD1; MIC1 |
BUZZER_5_D9_6 | BUZZER_5_D9_6 | | IC | 1 | BUZ1 |
BVY_27X25_1170P_01-04 | BVY_27X25_1170P_01-04 | bvy_27x25_1170p_01-04 | IC | 1 | U1 |
CAP8X9 | CAP8X9 | | DISCRETE | 2 | C202; C235 |
CON-PCIE-MINI-CARD-4MM-NUT | CON-PCIE-MINI-CARD-4MM-NUT | con-pcie-mini-card-4mm-nut | IC | 2 | MPCIE1; MSATA1 |
CRYSMD6D9X1D4_4P | CRYSMD6D9X1D4_4P | crysmd6d9x1d4_4p | IC | 1 | Y2 |
FAN3P | FAN3P | fan3p | IC | 1 | CPU_FAN1 |
FAN4P_50X50_CUPM | FAN4P_50X50_CUPM | fan4p_50x50_cupm | IC | 1 | U1_SET |
FBGA96-9X14 | FBGA96-9X14 | | IC | 8 | U13; U14; U15; U16; U31; U32; U33; U34 |
FPC2P-1_25MM | FPC2P-1_25MM | fpc2p-1_25mm | IC | 1 | J_RTC1 |
FUSE1812 | FUSE1812 | | DISCRETE | 5 | F3; F4; F6; F7; F8 |
HDMI_QJ11191-WFB3-4F | HDMI_QJ11191-WFB3-4F | | IO | 1 | HDMI1 |
HEADER_1X4_2MM | HEADER_1X4_2MM | | DISCRETE | 1 | X_SATA_PWR1 |
HOLE180_140 | HOLE180_140 | hole180_140 | IC | 1 | SATA_H1 |
IO-30P-1MM | IO-30P-1MM | io-30p-1mm | IC | 1 | LVDS1 |
IT8781F-QFP128 | IT8781F-QFP128 | | IC | 1 | U22 |
JH2X30-HD-2M | JH2X30-HD-2M | jh2x30-hd-2m | IC | 2 | COM1; MISC1 |
L0603 | L0603 | l0603 | DISCRETE | 3 | L1; L2; L3 |
LCC10_SLP10 | LCC10_SLP10 | lcc10_slp10 | IC | 6 | TVS3; TVS4; TVS5; TVS6; TVS9; TVS11 |
LQFP_48 | LQFP_48 | | IC | 1 | U6 |
MARK | MARK | mark | IC | 6 | FD1; FD2; FD3; FD4; FD5; FD6 |
PB6142RL-4-101 | PB6142RL-4-101 | | DISCRETE | 1 | PWR_SW1 |
PH2X3_79 | PH2X3_79 | | DISCRETE | 7 | AUD_SEL1; AUD_SEL2; COM3_PWR1; COM3_SEL; COM4_PWR1; COM4_SEL; LCDPWR_SEL1 |
PIN1X3_2D0 | PIN1X3_2D0 | | DISCRETE | 1 | PWRON_SEL1 |
POWERPAK3D0X3D0-SO8 | POWERPAK3D0X3D0-SO8 | powerpak3d0x3d0-so8 | IC | 19 | PQ1; PQ2; PQ3; PQ4; PQ5; PQ7; PQ8; PQ9; PQ10; PQ11; PQ12; PQ13; PQ14; PQ15; PQ16; PQ17; PQ18; PQ19; PQ20 |
PQFP14-3_6X3_6MM | PQFP14-3_6X3_6MM | pqfp14-3_6x3_6mm | IC | 2 | PU2; PU7 |
PTH3R0X5R0 | PTH3R0X5R0 | pth3r0x5r0 | IC | 4 | H1; H2; H3; H4 |
PTH_LEDX1 | PTH_LEDX1 | | DISCRETE | 1 | HDD_LED1 |
QFN24-TPS51125 | QFN24-TPS51125 | qfn24-tps51125 | IC | 1 | PU1 |
QFN40 | QFN40 | qfn40 | IC | 1 | PU9 |
QFN64-0_5-9X9X1MM | QFN64-0_5-9X9X1MM | | IC | 2 | U8; U18 |
QFN68_8X8P04 | QFN68_8X8P04 | qfn68_8x8p04 | IC | 1 | U26 |
R1206 | R1206 | x_1uh 100ma 400m | IC | 1 | R956 |
RJ45-1X1-LED | RJ45-1X1-LED | rj45-1x1-led | IC | 2 | LAN2; LAN3 |
SATA7P-M-HUANXUN_1 | SATA7P-M-HUANXUN_1 | sata7p-m-huanxun_1 | IC | 1 | SATA2 |
SHORT_PAD | SHORT_PAD | SHORT PAD | IC | 18 | SP1; SP3; SP4; SP5; SP6; SP7; SP10; SP11; SP12; SP13; SP14; SP15; SP16; SP17; SP18; SP19; SP20; SP21 |
SIM-SPPN08-X0-1X80_UPDATE | SIM-SPPN08-X0-1X80_UPDATE | sim-sppn08-x0-1x80_update | IC | 1 | SIM1 |
SMA | SMA | sma | IC | 2 | D9; D10 |
SMC0402 | SMC0402 | smc0402 | IC | 339 | C1; C2; C4; C5; C6; C7; C9; C10; C11; C14; C15; C16; C17; C18; C19; C20; C21; C22; C23; C24; C25; C26; C28; C29; C30; C39; C40; C41; C42; C43; C44; C45; C46; C47; C49; C50; C52; C53; C54; C56; C57; C58; C59; C60; C61; C62; C63; C64; C67; C73; C74; C75; C76; C77; C78; C79; C80; C81; C86; C88; C89; C90; C92; C94; C95; C96; C98; C104; C116; C117; C118; C119; C122; C123; C124; C125; C126; C127; C128; C132; C133; C134; C138; C139; C140; C141; C142; C143; C144; C145; C146; C147; C148; C149; C150; C151; C153; C154; C155; C156; C157; C158; C159; C161; C164; C165; C166; C167; C168; C169; C170; C171; C172; C174; C175; C176; C179; C180; C183; C186; C187; C188; C189; C196; C197; C199; C200; C204; C205; C206; C207; C208; C211; C212; C214; C215; C217; C218; C224; C225; C226; C228; C229; C232; C233; C234; C237; C238; C239; C240; C241; C244; C245; C249; C250; C251; C253; C254; C255; C256; C259; C261; C262; C263; C264; C265; C266; C269; C270; C271; C272; C273; C274; C275; C276; C277; C278; C279; C280; C281; C285; C286; C287; C288; C290; C292; C293; C296; C297; C298; C299; C300; C301; C302; C303; C304; C305; C306; C307; C308; C309; C310; C311; C312; C313; C314; C315; C316; C317; C318; C319; C320; C321; C322; C323; C324; C325; C326; C328; C329; C330; C331; C332; C333; C334; C335; C336; C337; C338; C340; C341; C342; C344; C345; C346; C347; C348; C349; C350; C351; C352; C357; C359; C360; C367; C370; C371; C372; C373; C374; C375; C376; C377; C378; C379; C380; C385; C388; C391; C392; C393; C410; C414; C421; C422; C423; C424; C425; C426; C427; C428; C429; C430; C431; C432; C433; C434; C435; C436; C437; C438; C439; C440; C441; C442; C443; C446; C449; C450; C451; C452; C453; C458; C459; C460; C464; C467; C468; C469; C470; C471; C492; C493; C494; C495; C496; C497; C498; C499; C500; C501; C502; C503; C504; C505; C506; C507; C508; C509; C510; C511; C806; C807; C808; C809; C815; C816; C817; C818; C819; C820; C821; C822; C823; C825; C826; C832; C837; C838 |
SMC0603 | SMC0603 | smc0603 | DISCRETE | 81 | C27; C31; C32; C33; C34; C35; C36; C37; C38; C48; C51; C65; C66; C68; C69; C70; C82; C83; C84; C85; C87; C91; C97; C99; C135; C160; C173; C185; C194; C198; C219; C227; C231; C236; C246; C252; C282; C283; C284; C339; C343; C353; C354; C355; C356; C361; C362; C363; C364; C365; C366; C368; C382; C383; C384; C394; C395; C396; C397; C398; C399; C400; C401; C402; C403; C404; C405; C406; C407; C408; C409; C411; C412; C413; C415; C416; C417; C418; C419; C420; C831 |
SMC0805 | SMC0805 | smc0805 | DISCRETE | 23 | C136; C137; C152; C177; C178; C190; C191; C192; C193; C203; C209; C213; C216; C221; C230; C242; C243; C257; C260; C358; C369; C381; C390 |
SMC1210 | SMC1210 | | DISCRETE | 2 | C386; C387 |
SMC7343 | SMC7343 | smc7343 | DISCRETE | 14 | C181; C182; C184; C195; C220; C223; C247; C248; C258; C267; C268; C327; C389; C836 |
SMF0603 | SMF0603 | smf0603 | DISCRETE | 13 | FB4; FB5; FB6; FB7; FB8; FB11; FB12; FB13; FB14; FB15; FB16; FB17; FB38 |
SMF0805 | SMF0805 | smf0805 | IC | 4 | FB24; FB37; FB39; FB44 |
SML0504_4P | SML0504_4P | | DISCRETE | 30 | L7; L8; L9; L10; L11; L12; L13; L14; L15; L16; L17; L18; L19; L20; L21; L22; L23; L24; L25; L26; L27; L28; L29; L30; L31; L32; L33; L34; L35; L36 |
SMPI_0603 | SMPI_0603 | smpi_0603 | IC | 7 | PL2; PL3; PL4; PL5; PL6; PL7; PL8 |
SMR0402 | SMR0402 | | IC | 557 | R1; R2; R3; R4; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R15; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R26; R27; R28; R29; R30; R31; R32; R33; R34; R35; R36; R37; R38; R39; R40; R41; R42; R43; R44; R45; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R56; R57; R58; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R72; R73; R74; R75; R76; R77; R78; R79; R80; R81; R82; R83; R84; R85; R86; R87; R88; R89; R90; R91; R92; R93; R94; R95; R96; R97; R98; R99; R100; R101; R102; R103; R104; R105; R106; R107; R108; R110; R111; R112; R113; R114; R115; R116; R117; R118; R119; R120; R121; R122; R123; R124; R125; R126; R127; R128; R129; R130; R131; R132; R133; R134; R135; R136; R137; R138; R139; R140; R141; R142; R143; R144; R145; R146; R147; R148; R149; R150; R151; R152; R153; R154; R155; R156; R157; R158; R159; R160; R161; R164; R167; R168; R169; R170; R171; R172; R173; R174; R175; R176; R177; R178; R179; R180; R181; R182; R183; R184; R185; R186; R187; R188; R189; R190; R191; R192; R193; R194; R195; R196; R197; R198; R199; R200; R201; R202; R203; R204; R205; R206; R207; R208; R209; R210; R211; R212; R213; R214; R215; R216; R217; R218; R219; R220; R221; R222; R223; R225; R226; R227; R228; R229; R230; R231; R232; R233; R234; R235; R236; R238; R239; R240; R241; R242; R243; R244; R245; R246; R247; R248; R249; R250; R251; R252; R253; R254; R255; R256; R257; R258; R259; R260; R261; R262; R263; R264; R265; R266; R267; R268; R269; R270; R271; R272; R273; R274; R275; R276; R277; R278; R279; R280; R281; R282; R283; R284; R285; R286; R287; R288; R289; R290; R291; R292; R293; R294; R295; R296; R297; R298; R299; R300; R301; R302; R303; R304; R305; R306; R307; R308; R309; R310; R311; R312; R313; R314; R315; R316; R317; R318; R319; R320; R321; R322; R323; R324; R325; R326; R327; R328; R329; R330; R331; R332; R333; R334; R335; R336; R337; R338; R339; R340; R341; R342; R343; R344; R345; R346; R347; R348; R349; R350; R351; R352; R353; R354; R355; R356; R357; R358; R359; R360; R361; R362; R363; R364; R365; R366; R367; R368; R369; R370; R371; R374; R375; R376; R377; R378; R380; R381; R382; R383; R384; R385; R386; R387; R388; R392; R394; R395; R396; R397; R398; R400; R401; R402; R403; R404; R405; R406; R407; R408; R409; R410; R411; R412; R413; R414; R415; R416; R417; R418; R419; R421; R422; R423; R424; R425; R426; R427; R428; R430; R432; R433; R434; R435; R436; R437; R438; R439; R440; R441; R442; R443; R444; R445; R446; R447; R448; R449; R450; R451; R452; R453; R454; R455; R456; R457; R458; R459; R460; R461; R462; R464; R465; R466; R467; R468; R469; R470; R471; R472; R473; R474; R475; R476; R477; R478; R479; R480; R481; R482; R483; R488; R489; R490; R491; R492; R493; R494; R526; R527; R531; R535; R545; R551; R552; R686; R746; R752; R753; R754; R755; R900; R957; R958; R959; R960; R961; R962; R963; R964; R965; R966; R967; R968; R969; R970; R971; R972; R973; R974; R975; R976; R977; R978; R979; R980; R981; R982; R983; R984; R985; R986; R987; R988; R989; R990; R991; R992; R993; R994; R995; R996; R1000; R1001; R1002; R1003; R1004; R1005; R1006; R1007; R1008; R1010; R1012; R1013; R1014; R1015; R1016; R1017; R1018; R1019; R1020; R1021; R1022; R1023; R1024; R1025; R1026; R1027; R1028; R1029; R1030; R1031; RT1; RT2 |
SMR0603 | SMR0603 | smr0603 | IC | 10 | R224; R237; R379; R399; R611; R612; R613; R693; RT3; RT4 |
SO8_PWP | SO8_PWP | so8_pwp | IC | 6 | PQ6; PQ21; PQ22; PQ23; PQ24; PQ25 |
SOCKET8-FLASH | SOCKET8-FLASH | socket8-flash | IC | 1 | U2 |
SOD123 | SOD123 | | DISCRETE | 10 | D1; D2; D3; D7; D8; PD1; PD2; PD3; PD7; PD8 |
SOD323 | SOD323 | | DISCRETE | 3 | D4; D5; D6 |
SOP8-1_27-5X6X1_75MM | SOP8-1_27-5X6X1_75MM | sop8-1_27-5x6x1_75mm | IC | 3 | U4; U21; U29 |
SOP8-1_27-DS9025 | SOP8-1_27-DS9025 | sop8-1_27-DS9025 | IC | 4 | PU6; PU8; PU10; PU11 |
SOP8-50-150 | SOP8-50-150 | sop8-50-150 | IC | 4 | U23; U24; U38; U43 |
SOP16_50_220 | SOP16_50_220 | sop16_50_220 | IC | 1 | U37 |
SOT23 | SOT23 | sot23 | IC | 27 | PU12; Q1; Q2; Q3; Q4; Q8; Q10; Q12; Q13; Q14; Q15; Q16; Q18; Q19; Q22; Q25; Q26; Q28; Q30; Q31; Q35; Q37; Q41; Q43; Q44; Q46; Q47 |
SOT23_5 | SOT23_5 | sot23_5 | IC | 6 | PU5; U5; U9; U10; U11; U12 |
SOT23_6 | SOT23_6 | sot23_6 | IC | 5 | U19; U20; U25; U44; U45 |
SOT363 | SOT363 | sot363 | IC | 13 | Q11; Q27; Q29; Q32; Q33; Q34; Q36; Q38; Q39; Q40; Q42; Q45; U30 |
SSOP24_0R65_8 | SSOP24_0R65_8 | | IC | 1 | U62 |
SSOP28-25P6X278 | SSOP28-25P6X278 | ssop28-25p6x278 | IC | 1 | U36 |
SSOP28-26-209 | SSOP28-26-209 | ssop28-26-209 | IC | 6 | U27; U28; U39; U40; U41; U42 |
TEST20 | TEST20 | | IC | 24 | SUSCLK1; TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24 |
TSSOP20-0_65-6_5X4_4X1_2MM | TSSOP20-0_65-6_5X4_4X1_2MM | | IC | 1 | U35 |
USB3-USB2 | USB3-USB2 | | IO | 1 | USB1 |
VGA | VGA | vga | IC | 1 | VGA1 |
VHR-2N | VHR-2N | | IC | 1 | DC_IN1 |
WAFER-6PIN-2MM | WAFER-6PIN-2MM | | DISCRETE | 1 | INVT1 |
WAFER-12PIN-2MM | WAFER-12PIN-2MM | | IC | 1 | VGA2 |
XTAL3225-4 | XTAL3225-4 | xtal3225-4 | IC | 6 | OSC1; Y1; Y3; Y4; Y5; Y6 |
附件:
