查看: 717186|回复: 36
[allegro17.2][8层]英伟达Jetson_AGX_Xavier_Developer_Kit_Carrier_Board B03版本...
发表于 2020-1-20 16:20 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro17.2][8层]英伟达Jetson_AGX_Xavier_Developer_Kit_Carrier_Board B03版本(CON_M2+MOUNTING+CON_PCI)原理图和pcb文件
文件描述:
1. 作品用途:英伟达Jetson_AGX_Xavier_Developer_Kit_Carrier_Board B03版本
2. 软件版本:allegro17.2
3. 层数:8层
4. 用到的主要芯片:CON_M2+MOUNTING+CON_PCI
5. PCB尺寸:103.96*103.72 mm
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
402C_0402-4.7UF,X5R,20%,6.3V,032-0880-000-032-0880-000,4.7UF4.7uFDISCRETE6C1; C3; C530; C663; C711; C792
402C_0402-0.1UF,X5R,10%,16V,039-0124-000-0.1UF,039-0124-0000.1uFDISCRETE22C2; C4; C5; C599; C601; C608; C609; C619; C625; C627; C629; C669; C673; C674; C677; C693; C706; C713; C738; C773; C779; C780
402C_0402-0.1UF,X7R,10%,16V,036-0014-000-0.1UF,036-0014-0000.1uFDISCRETE144C6; C7; C8; C9; C11; C13; C15; C16; C40; C41; C42; C45; C48; C50; C52; C54; C55; C56; C63; C68; C71; C74; C81; C82; C83; C87; C89; C90; C91; C92; C98; C99; C101; C102; C104; C115; C120; C290; C291; C501; C503; C504; C505; C518; C540; C552; C553; C554; C555; C556; C558; C560; C562; C569; C570; C571; C573; C581; C588; C589; C594; C595; C596; C610; C616; C635; C637; C639; C654; C655; C656; C662; C664; C665; C668; C670; C671; C675; C678; C680; C683; C684; C685; C687; C688; C689; C690; C691; C694; C695; C697; C702; C704; C709; C710; C712; C714; C715; C716; C717; C720; C721; C723; C724; C725; C726; C728; C729; C730; C732; C733; C735; C736; C737; C739; C753; C754; C755; C756; C757; C758; C759; C760; C761; C762; C763; C764; C765; C771; C772; C774; C775; C777; C778; C781; C782; C783; C785; C786; C787; C788; C789; C790; C794
402C_0402-1UF,X6S,10%,25V,032-0782-000-032-0782-000,1UF1uFDISCRETE7C12; C14; C17; C30; C46; C93; C632
402C_0402-0.1UF,X7R,10%,50V,032-0687-000-0.1UF,032-0687-0000.1uFDISCRETE43C19; C20; C21; C22; C25; C26; C27; C29; C31; C32; C33; C94; C96; C107; C108; C481; C484; C485; C486; C488; C489; C490; C491; C492; C493; C494; C495; C496; C497; C498; C499; C500; C507; C526; C564; C605; C615; C618; C623; C626; C630; C640; C666
402C_0402-100PF,C0G,5%,50V,035-0012-000-035-0012-000,100PF100pFDISCRETE4C28; C565; C600; C624
402C_0402-6.8PF,C0G,0.5PF,50V,035-0035-000-035-0035-000,6.8PF6.8pFDISCRETE4C34; C35; C57; C58
402C_0402-0.1UF,X5R,10%,10V,039-0017-000-0.1UF,039-0017-0000.1uFDISCRETE12C44; C84; C113; C114; C502; C508; C603; C641; C642; C750; C751; C752
402C_0402-10NF,X7R,10%,25V,036-0019-000-036-0019-000,10NF10nFDISCRETE15C47; C49; C51; C53; C65; C67; C79; C88; C105; C153; C527; C574; C634; C734; C972
402C_0402-1NF,X7R,10%,25V,036-0240-000-036-0240-000,1NF1nFDISCRETE5C69; C621; C718; C719; C722
402C_0402-270PF,C0G,5%,50V,035-0067-000-035-0067-000,270PF270pFDISCRETE1C72
402C_0402-1.5NF,X7R,10%,50V,036-0139-000-036-0139-000,1.5NF1.5nFDISCRETE2C86; C638
402C_0402-10NF,X7R,10%,50V,032-1210-000-032-1210-000,10NF10nFDISCRETE4C95; C152; C194; C628
402C_0402-0.22UF,X7R,10%,6.3V,036-0182-000-0.22UF,036-0182-0000.22uFDISCRETE16C126; C127; C128; C129; C135; C136; C137; C138; C139; C140; C143; C144; C147; C148; C149; C150
402C_0402-10PF,C0G,5%,50V,035-0011-000-035-0011-000,10PF10pFDISCRETE3C151; C482; C483
402C_0402-22PF,C0G,5%,50V,035-0023-000-035-0023-000,22PF22pFDISCRETE3C463; C464; C776
402C_0402-150PF,C0G,5%,50V,035-0018-000-035-0018-000,150PF150pFDISCRETE3C524; C592; C791
402C_0402-12PF,C0G,5%,50V,035-0014-000-035-0014-000,12PF12pFDISCRETE1C542
402C_0402-220PF,C0G,5%,50V,035-0024-000-035-0024-000,220PF220pFDISCRETE2C546; C549
402C_0402-56PF,C0G,5%,50V,035-0034-000-035-0034-000,56PF56pFDISCRETE1C568
402C_0402-0.47UF,X5R,10%,25V,032-0306-000-0.47UF,032-0306-0000.47uFDISCRETE6C576; C577; C579; C580; C584; C707
402C_0402-1UF,X5R,10%,10V,039-0140-000-039-0140-000,1UF1uFDISCRETE3C585; C708; C749
402C_0402-390PF,C0G,5%,50V,035-0293-000-035-0293-000,390PF390pFDISCRETE4C597; C602; C611; C612
402C_0402-2.2UF,X5R,20%,6.3V,039-0136-000-039-0136-000,2.2UF2.2uFDISCRETE7C740; C744; C745; C746; C747; C2186; C2189
402C_0402-1NF,X7R,10%,50V,036-0022-000-036-0022-000,1NF1nFDISCRETE2C970; C2188
402C_0402-0.1UF,X7R,20%,50V,032-0059-000-0.1UF,032-0059-0000.1uFDISCRETE1C2187
402R_0402-1K,1 %,62.5MW,195-0003-000-195-0003-000,1K1kDISCRETE30R1; R2; R3; R4; R5; R6; R7; R8; R9; R10; R11; R12; R13; R14; R546; R669; R675; R679; R680; R681; R686; R687; R688; R715; R716; R718; R719; R721; R722; R967
402R_0402-4.7K,5 %,62.5MW,195-0598-000-195-0598-000,4.7K4.7kDISCRETE6R15; R249; R590; R761; R764; R959
402R_0402-2M,5 %,62.5MW,195-0538-000-195-0538-000,2M2MDISCRETE4R16; R20; R21; R22
402R_0402-0OHM,0.05 OHM,62.5MW,195-2655-000-0OHM,195-2655-0000ohmDISCRETE183R17; R33; R39; R41; R43; R49; R50; R53; R55; R56; R57; R60; R66; R72; R73; R74; R76; R82; R88; R89; R92; R95; R96; R97; R98; R99; R102; R105; R108; R112; R113; R114; R115; R122; R125; R132; R135; R149; R151; R152; R156; R157; R164; R170; R175; R199; R200; R203; R204; R205; R206; R207; R216; R227; R229; R257; R260; R261; R262; R265; R509; R510; R513; R527; R528; R529; R530; R531; R538; R544; R545; R550; R556; R571; R593; R595; R598; R599; R600; R603; R605; R625; R626; R629; R630; R631; R638; R654; R655; R660; R665; R666; R668; R674; R677; R678; R695; R698; R699; R700; R701; R705; R710; R724; R726; R728; R730; R731; R732; R733; R742; R743; R746; R756; R757; R787; R788; R789; R790; R794; R795; R800; R801; R813; R818; R819; R830; R832; R834; R835; R836; R837; R838; R840; R841; R842; R843; R845; R846; R847; R848; R849; R850; R851; R854; R855; R856; R859; R861; R865; R873; R876; R877; R883; R884; R885; R886; R887; R893; R899; R911; R912; R913; R914; R915; R916; R917; R918; R919; R922; R924; R940; R941; R942; R943; R944; R945; R946; R947; R955; R972; R979; R980
402R_0402-49.9K,1 %,62.5MW,195-0340-000-195-0340-000,49.9K49.9kDISCRETE6R18; R38; R47; R78; R86; R110
402R_0402-200K,1 %,62.5MW,195-0151-000-195-0151-000,200K200kDISCRETE2R23; R30
402R_0402-10OHM,5 %,62.5MW,195-0483-000-10OHM,195-0483-00010ohmDISCRETE10R24; R58; R63; R77; R101; R109; R193; R197; R634; R639
402R_0402-51K,5 %,62.5MW,195-0606-000-195-0606-000,51K51kDISCRETE1R25
402R_0402-100K,5 %,62.5MW,195-0487-000-100K,195-0487-000100kDISCRETE41R26; R42; R48; R59; R67; R70; R81; R87; R90; R103; R107; R138; R155; R222; R553; R563; R565; R615; R632; R641; R647; R661; R725; R765; R776; R782; R783; R793; R858; R882; R897; R920; R923; R954; R957; R962; R963; R964; R965; R977; R978
402R_0402-10K,5 %,62.5MW,195-0486-000-10K,195-0486-00010kDISCRETE60R27; R35; R62; R104; R106; R111; R133; R137; R148; R150; R154; R218; R242; R248; R252; R259; R266; R284; R501; R503; R511; R512; R514; R516; R525; R526; R541; R548; R554; R562; R670; R672; R673; R693; R697; R708; R709; R734; R735; R773; R777; R784; R808; R820; R821; R823; R871; R896; R901; R902; R903; R904; R908; R948; R949; R950; R951; R952; R956; R958
402R_0402-100K,1 %,62.5MW,195-0005-000-100K,195-0005-000100kDISCRETE31R28; R31; R32; R119; R129; R130; R136; R139; R153; R250; R263; R507; R508; R577; R586; R611; R613; R618; R623; R633; R711; R712; R723; R729; R812; R814; R822; R825; R857; R909; R1777
402R_0402-10K,1 %,62.5MW,195-0004-000-10K,195-0004-00010kDISCRETE38R34; R161; R176; R178; R213; R612; R614; R621; R637; R642; R649; R651; R652; R653; R758; R759; R760; R762; R763; R767; R771; R772; R774; R779; R780; R781; R797; R803; R805; R806; R807; R824; R852; R853; R862; R878; R900; R974
402R_0402-2.2K,5 %,62.5MW,195-0542-000-195-0542-000,2.2K2.2kDISCRETE28R40; R93; R94; R116; R117; R226; R235; R240; R241; R502; R515; R602; R604; R682; R689; R691; R692; R737; R738; R768; R792; R796; R866; R867; R868; R869; R905; R906
402R_0402-47K,5 %,62.5MW,195-0599-000-195-0599-000,47K47kDISCRETE25R44; R91; R120; R121; R147; R533; R536; R537; R539; R540; R594; R596; R597; R601; R606; R616; R747; R748; R751; R831; R833; R839; R844; R907; R953
402R_0402-1K,5 %,62.5MW,195-0485-000-195-0485-000,1K1kDISCRETE4R51; R582; R610; R925
402R_0402-75OHM,5 %,62.5MW,195-0631-000-195-0631-000,75OHM75ohmDISCRETE4R52; R54; R61; R71
402R_0402-22K,5 %,62.5MW,195-0543-000-195-0543-000,22K22kDISCRETE2R64; R100
402R_0402-4.99K,1 %,62.5MW,195-0339-000-195-0339-000,4.99K4.99kDISCRETE1R65
402R_0402-49.9OHM,1 %,62.5MW,195-0337-000-195-0337-000,49.9OHM49.9ohmDISCRETE2R68; R75
402R_0402-6.04K,1 %,62.5MW,195-0379-000-195-0379-000,6.04K6.04kDISCRETE1R118
402R_0402-2K,5 %,62.5MW,195-0535-000-195-0535-000,2K2kDISCRETE2R126; R146
402R_0402-49.9K,1 %,62.5MW,195-1326-000-195-1326-000,49.9K49.9kDISCRETE1R127
402R_0402-13.3K,1 %,62.5MW,195-0065-000-13.3K,195-0065-00013.3kDISCRETE1R128
402R_0402-1M,5 %,62.5MW,195-0488-000-195-0488-000,1M1MDISCRETE23R131; R144; R145; R159; R165; R166; R167; R168; R169; R171; R174; R181; R182; R183; R184; R185; R186; R187; R188; R215; R667; R684; R864
402R_0402-10M,5 %,62.5MW,195-0489-000-10M,195-0489-00010MDISCRETE1R134
402R_0402-20K,1 %,62.5MW,195-0150-000-195-0150-000,20K20kDISCRETE9R158; R214; R504; R557; R559; R560; R587; R799; R863
402R_0402-499OHM,1 %,62.5MW,195-0338-000-195-0338-000,499OHM499ohmDISCRETE8R160; R162; R173; R180; R189; R192; R194; R198
402R_0402-30.1K,1 %,62.5MW,195-0235-000-195-0235-000,30.1K30.1kDISCRETE1R163
402R_0402-15K,1 %,62.5MW,195-0090-000-15K,195-0090-00015kDISCRETE2R172; R650
402R_0402-732OHM,1 %,62.5MW,195-0418-000-195-0418-000,732OHM732ohmDISCRETE1R190
402R_0402-16.9K,1 %,62.5MW,195-0115-000-16.9K,195-0115-00016.9kDISCRETE2R191; R643
402R_0402-100OHM,1 %,62.5MW,195-0002-000-100OHM,195-0002-000100ohmDISCRETE9R195; R196; R635; R636; R648; R775; R785; R791; R981
402R_0402-10OHM,1 %,62.5MW,195-0001-000-10OHM,195-0001-00010ohmDISCRETE4R201; R202; R645; R646
402R_0402-3.3K,5 %,62.5MW,195-0570-000-195-0570-000,3.3K3.3kDISCRETE3R208; R627; R628
402R_0402-100OHM,5 %,62.5MW,195-0484-000-100OHM,195-0484-000100ohmDISCRETE1R264
402R_0402-121K,1 %,62.5MW,195-0046-000-121K,195-0046-000121kDISCRETE2R542; R966
402R_0402-36.5K,1 %,62.5MW,195-0275-000-195-0275-000,36.5K36.5kDISCRETE1R547
402R_0402-162K,1 %,62.5MW,195-0106-000-162K,195-0106-000162kDISCRETE1R549
402R_0402-32.4K,1 %,62.5MW,195-0250-000-195-0250-000,32.4K32.4kDISCRETE1R552
402R_0402-1OHM,5 %,62.5MW,195-0482-000-195-0482-000,1OHM1ohmDISCRETE2R555; R969
402R_0402-75K,1 %,62.5MW,195-0425-000-195-0425-000,75K75kDISCRETE2R561; R970
402R_0402-6.04OHM,1 %,63MW,195-1921-000-195-1921-000,6.04OHM6.04ohmDISCRETE8R566; R567; R568; R569; R570; R573; R575; R576
402R_0402-16.2K,1 %,62.5MW,195-0105-000-16.2K,195-0105-00016.2kDISCRETE1R580
402R_0402-20OHM,5 %,62.5MW,195-0533-000-195-0533-000,20OHM20ohmDISCRETE1R583
402R_0402-12.7K,1 %,62.5MW,195-0055-000-12.7K,195-0055-00012.7kDISCRETE1R584
402R_0402-24.3K,1 %,62.5MW,195-0190-000-195-0190-000,24.3K24.3kDISCRETE1R608
402R_0402-61.9K,1 %,62.5MW,195-0385-000-195-0385-000,61.9K61.9kDISCRETE1R609
402R_0402-392K,1 %,62.5MW,195-0291-000-195-0291-000,392K392kDISCRETE1R622
402R_0402-1.87K,1 %,62.5MW,195-0134-000-1.87K,195-0134-0001.87kDISCRETE1R640
402R_0402-47.5K,1 %,62.5MW,195-0330-000-195-0330-000,47.5K47.5kDISCRETE2R703; R704
402R_0402-330OHM,5 %,62.5MW,195-0569-000-195-0569-000,330OHM330ohmDISCRETE1R744
402R_0402-12.1K,1 %,62.5MW,195-0045-000-12.1K,195-0045-00012.1kDISCRETE1R766
402R_0402-200OHM,5 %,62.5MW,195-0534-000-195-0534-000,200OHM200ohmDISCRETE2R769; R770
402R_0402-11.5K,1 %,62.5MW,195-0035-000-11.5K,195-0035-00011.5kDISCRETE1R798
402R_0402-19.6K,1 %,62.5MW,195-0145-000-19.6K,195-0145-00019.6kDISCRETE1R828
402R_0402-1.96K,1 %,62.5MW,195-0144-000-1.96K,195-0144-0001.96kDISCRETE1R829
402R_0402-2.49K,1 %,62.5MW,195-0194-000-195-0194-000,2.49K2.49kDISCRETE1R910
402R_0402-18OHM,5 %,62.5MW,195-0526-000-18OHM,195-0526-00018ohmDISCRETE9R926; R927; R928; R931; R932; R936; R937; R938; R939
402R_0402-36OHM,5 %,62.5MW,195-0575-000-195-0575-000,36OHM36ohmDISCRETE5R929; R930; R933; R934; R935
402R_0402-22.1K,1 %,62.5MW,195-0170-000-195-0170-000,22.1K22.1kDISCRETE1R975
402R_0402-309K,1 %,62.5MW,195-0241-000-195-0241-000,309K309kDISCRETE1R1776
603C_0603-10NF,X5R,10%,50V,039-0048-000-039-0048-000,10NF10nFDISCRETE2C10; C38
603C_0603-4.7UF,X5R,10%,16V,039-0227-000-039-0227-000,4.7UF4.7uFDISCRETE10C43; C109; C110; C586; C590; C606; C607; C613; C617; C631
603C_0603-10UF,X5R,20%,6.3V,039-0135-000-039-0135-000,10UF10uFDISCRETE15C59; C62; C64; C73; C80; C559; C563; C567; C582; C645; C646; C658; C660; C679; C703
603C_0603-1UF,X5R,10%,25V,032-0132-000-032-0132-000,1UF1uFDISCRETE1C75
603C_0603-1NF,X7R,10%,16V,036-0032-000-036-0032-000,1NF1nFDISCRETE6C509; C517; C536; C649; C650; C793
603C_0603-4.7UF,X5R,10%,6.3V,039-0037-000-039-0037-000,4.7UF4.7uFDISCRETE4C566; C644; C647; C661
603C_0603-1UF,X5R,10%,6.3V,039-0034-000-039-0034-000,1UF1uFDISCRETE5C598; C614; C651; C652; C667
603C_0603-0.22UF,X7R,10%,16V,036-0037-000-0.22UF,036-0037-0000.22uFDISCRETE1C620
603C_0603-2.2UF,X5R,10%,6.3V,039-0035-000-039-0035-000,2.2UF2.2uFDISCRETE7C648; C672; C686; C696; C698; C699; C700
603R_0603-0OHM,0.05 OHM,0.1W,195-2656-000-0OHM,195-2656-0000ohmDISCRETE8R29; R69; R83; R524; R532; R558; R564; R662
603R_0603-470OHM,5 %,0.1W,195-1247-000-195-1247-000,470OHM470ohmDISCRETE4R123; R124; R522; R523
603R_0603-2.2OHM,5 %,0.1W,195-1189-000-195-1189-000,2.2OHM2.2ohmDISCRETE10R179; R219; R220; R224; R225; R617; R619; R620; R624; R644
603R_0603-1OHM,5 %,0.1W,195-1132-000-195-1132-000,1OHM1ohmDISCRETE2R551; R968
0603_LARGEC_0603W-10UF,X5R,20%,25V,032-0186-000-032-0186-000,10UF10uFDISCRETE3C76; C78; C514
0603_LARGEC_0603W-4.7UF,X5R,10%,35V,032-0193-000-032-0193-000,4.7UF4.7uFDISCRETE1C77
0603_LARGEC_0603W-22UF,X5R,20%,6.3V,039-0223-000-039-0223-000,22UF22uFDISCRETE4C85; C112; C583; C591
805C_0805-22UF,X5R,20%,25V,032-0964-000-032-0964-000,22UF22uFDISCRETE26C18; C39; C60; C61; C506; C511; C513; C515; C520; C523; C525; C531; C533; C534; C535; C538; C544; C545; C636; C643; C657; C659; C676; C682; C692; C705
805C_0805-10UF,X5R,10%,10V,039-0146-000-039-0146-000,10UF10uFDISCRETE9C23; C36; C37; C547; C587; C593; C622; C633; C731
805C_0805-4.7UF,X5R,10%,25V,039-0206-000-039-0206-000,4.7UF4.7uFDISCRETE2C66; C543
805C_0805-0.47UF,X7R,10%,50V,036-0129-000-0.47UF,036-0129-0000.47uFDISCRETE1C70
805C_0805-10UF,X5R,20%,6.3V,039-0128-000-039-0128-000,10UF10uFDISCRETE4C141; C142; C532; C727
805C_0805-10UF,X6S,10%,25V,032-0728-000-032-0728-000,10UF10uFDISCRETE10C145; C146; C411; C412; C413; C414; C510; C519; C557; C561
805C_0805-22UF,X5R,20%,6.3V,032-0887-000-032-0887-000,22UF22uFDISCRETE11C274; C516; C522; C537; C539; C541; C572; C575; C578; C604; C701
805R_0805-300OHM,5 %,0.125W,195-1596-000-195-1596-000,300OHM300ohmDISCRETE8R36; R37; R45; R46; R79; R80; R84; R85
805R_0805-1OHM,5 %,0.125W,195-2666-000-195-2666-000,1OHM1ohmDISCRETE4R519; R534; R663; R664
805R_0805-10OHM,5 %,0.125W,195-1592-000-10OHM,195-1592-00010ohmDISCRETE6R572; R574; R578; R579; R585; R591
4520MMC_1808-1NF,X7R,15%,2000V,032-0166-000-032-0166-000,1NF1nFDISCRETE1C24
BGA_0004_P050_009X009U_SW_LOAD_BGA04-TPS22908,-9999V..9999V,-9999V..9999V,9999A,SWITCH,115-1127-000-115-1127-000IC2U7; U14
CAP_SMD_048X048C_POL_SMD_D48-80000UF,SUPERCAP,10%,3.3V@60DEGC,1OHM,9.999UH,[ ]@[ ],0HZ,060-0002-000-060-0002-000,80000UF80000uFDISCRETE1C512
CAP_SMD_7343C_POL_SMD_7343-100UF,TA-POLYMER,20%,25V@105DEGC,0.04OHM,9.999UH,2.4A@45DEGC,100KHZ,032-0796-000-032-0796-000,100UF100uFDISCRETE4C121; C528; C653; C681
CAP_SMD_7343C_POL_SMD_7343-330UF,TA-POLYMER,20%,6.3V@105DEGC,0.025OHM,9.999UH,2.4A@45DEGC,100KHZ,041-0223-000-041-0223-000,330UF330uFDISCRETE1C548
CAP_SMD_7343C_POL_SMD_7343-100UF,TA-POLYMER,20%,16V@105DEGC,0.05OHM,9.999UH,1.8A@105DEGC,100KHZ,041-0196-000-041-0196-000,100UF100uFDISCRETE2C550; C551
CON_DCPWR_JACK_006_TH_RA_100X130CON_PWR_JACK_CON_6PIN-2DC-G213-B73F,FEMALE,4.7MM,90,NA,YES,NO,NO,NO,N/A,N/A,064-0347-000-064-0347-000IO1J2
CON_EDGE_MJ08_008_SMT_RA_F_CUTOUTCON_RJ45_RJ45_10PIN-G7400CE04-002-H,FEMALE,1.02MM,90,YES,YES,YES,YES,YES,-1.0 V,-1.0 A,080-1332-000-080-1332-000IO1J510
CON_EDGE_USB_005_SMT_RA_F_074X058_CUTOUTCON_USB_MICRO_B_10-2UB2158-001111F,FEMALE,0.65,90,YES,NO,YES,NO,YES,100.0 V,0.5 A,064-0276-000-064-0276-000IO1J501
CON_HDMI_019_SMT_RA_F_P005_DCON_HDMI_HDMI_A_SMD-HDMI_A_SMD_REVERSE,FEMALE,0.5MM,90,YES,YES,NO,NO,YES,N/A,N/A,080-0943-000-080-0943-000IO1J504
CON_HDR_002X004_SMD_ST_M_P025HDR_2X4_NORM-2821-08-02-5.84/3.8-0-PT-HSF,MALE,2.54MM,0,YES,NO,NO,500 V,3 A,080-1647-000-080-1647-000IO1J508
CON_HDR_002X005_SMD_ST_M_P013_CHDR_2X5_NORM-FTSH-105-01-L-DV-K,MALE,1.27MM,0,NO,YES,NO,350 V,3.3 A,064-0203-000-064-0203-000IO1J502
CON_HDR_002X005_SMD_ST_M_P025_KEY8HDR_2X5_KEY8_AUDIO-P0001-01012-001,MALE,2.54MM,0,YES,NO,NO,N/A,N/A,080-1630-000-080-1630-000IO1J511
CON_HDR_002X020_SMD_RA_M_P025HDR_2X20_SMD-G2100CE04C-008-H,MALE,2.54MM,90,N/A,NO,NO,N/A,N/A,080-1659-000-080-1659-000IO1J30
CON_HDR_003_SMD_ST_M_P025HDR_1X3_SMD-2811-03-B1-02-5.84/3.8-PT-HSF,MALE,2.54MM,0,YES,NO,NO,500 V,3 A,080-1641-000-080-1641-000IO1J514
CON_MINIPEX_075_SMT_RA_M2CON_M2_PCI_EXP_SMD77_KEYM-1-2199125-4,FEMALE,0.5,90,N/A,NO,NO,NO,NO,50 V,0.5 A,080-1500-000-080-1500-000IO1J1
CON_MINIPEX_075_SMT_RA_M2CON_M2_PCI_EXP_SMD77_KEYE-2199125-4,FEMALE,0.5MM,90,N/A,NO,NO,NO,NO,N/A,N/A,080-1499-000-080-1499-000IO1J505
CON_MIRMEZ_699_BGA_ST_P009_P013_P015_REVERSECON_B2B_699_CVM_65X11_MIRROR-MIRMEZ_CVM,FEMALE,0.9MM,0,NA,NO,NA,NA,NO,30 V,1.2 A,080-1489-000-080-1489-000IC1J3
CON_MISC_004_SMD_RA_M_P013_WTB_BCON_B2W_1X4_SMD_MT2-50279-0040N-003,MALE,1.25MM,90,YES,YES,NO,NO,NO,0 MV,0 MA,080-1638-000-080-1638-000IO1J9
CON_PEX_098_SMT_ST_P010_P2822CON_PCI_EXPRESS_PHY-X8-SMD-CON_PCIEXP_X8_P2822,FEMALE,1.0MM,0,YES,YES,NO,NO,NO,N/A,N/A,080-1497-000-080-1497-000IO1J28
CON_PEX_164_SMT_ST_P010CON_PCI_EXPRESS_PHY-X16-SMD-10146065-113Y0LF,FEMALE,1.0MM,0,YES,YES,NO,NO,NO,N/A,N/A,080-1496-000-080-1496-000IO1J6
CON_QSH_060_SMT_ST_P005CON_B2B_60_F_NORM-QSH-030-01-L-D-A-K-TR,FEMALE,0.5MM,0,YES,YES,NO,NO,N/A,125.0 V,1.0 A,080-1344-000-080-1344-000IO1J503
CON_QSH_120_SMT_ST_P005CON_B2B_120_F_NORM-CON_QSH_SMT_2X60_P050,FEMALE,0.5MM,0,YES,YES,NO,NO,NO,NA,9999 MA,080-1346-000-080-1346-000IO1J509
CON_SD_UFS_019_SMD_RA_P011_P009_123X135CON_SD_SOCKET_SMD25-1010170469,RECEPTACLE,0.7MM,90,N/A,NO,YES,NO,YES,100 V,0.5 A,220-0134-000-220-0134-000IO1J4
CON_USB_024_SMT_RA_F_089X082CON_USB3_TYPEC_30PIN_B-UT12113-116B2-7H,FEMALE,N/A,90,N/A,N/A,N/A,N/A,YES,N/A,5A,065-0687-000-065-0687-000IO1J512
CON_USB_024_SMT_RA_F_089X108CON_USB3_TYPEC_28PIN_B-MJ8A5A-Y280-412,RECEPTACLE,0.5MM,90,YES,YES,YES,NO,YES,100 V,0.25 A,064-0305-000-064-0305-000IO1J513
CON_USB_ESATA_016_TH_RA_F_187X134CON_SATA_TH_RA_16-1853116-0N025T-H,FEMALE,1.27MM,90,YES,YES,YES,NO,YES,30 V,1.5 A,080-1503-000-080-1503-000IO1J507
DFET_SMD_032X033Q_FET_P_ENH_DFN3X3-AONR21357,-30V,10.7MOHM@10V / 12.3MOHM@4.5V / [ ]@2.5V,-17A,-136A,25V,3.2W,70NC@10V / 35NC@4.5V / [ ]@2.5V,BDISCRETE10Q1; Q7; Q8; Q14; Q15; Q93; Q94; Q95; Q96; Q97
DFN06_P050_015X010U_BUF_3_STATE_DFN06_OEH-NC7SZ126L6X,BUFFER - TRI-STATE,115-0398-000-115-0398-000IC2U60; U64
DFN06_P065_020X020_T016X010_BU_RST_TPS3808_SON6-TPS3808G01QDRVR-Q1,RESET,115-2439-000-115-2439-000IC1U81
DFN06_P065_020X020_TI063X039_BU_LDO_DFN6-NCP705MTADJTCG,LOW DROP OUT,0.35V@0.5A,0.8V..5.15V,2%,0.8V,5.5V,0.5A,1W,315-1067-000-0.8V,315-1067-0000.8VIC1U512
DFN08_P050_020X010U_FLIPFLOP_D_DFN08-74LVC1G74,LOGIC - D-TYPE FLIP FLOP WITH PRESET/CLEAR,115-0967-000-115-0967-000IC1U520
DFN08_P050_020X020_T017X010U_POWER_SW_DFN8_C-TPS22965DSGR,2.5V..5.7V,2.5V..5.7V,6A,SWITCH,315-1082-000-315-1082-000IC1U82
DFN08_P050_030X020_T016X016U_MEM_EE_3WIRE_DFN8-2MHZ,2.5V..5.5V,93LC56CT-I/MNY,174-0188-000-174-0188-000IC1U54
DFN08_P050_030X020_T016X016U_MEM_EE_I2C_DFN08-1MHZ,1.7V..3.6V,AT24C02D-MAHM-T,174-0159-000-174-0159-000IC1U501
DFN08_P127_060X050_T035X044U_MEM_FL_SER_512KX8_SON8-86MHZ,2.7V..3.6V,MX25L4006EZNI-12G,170-0239-000-170-0239-000IC1U5
DFN10_P050_030X030_T026X018U_VREG_NCV59748_DFN10-NCV59748MWADJTBG,LOW DROP OUT,60MV@1.5A,0.8V..3.6V,2%,0.8V,5.5V,1.5A,1W,315-0975-000-0.8V,315-0975-0000.8VIC1U6
DFN12_P050_030X020U_PB_SRC0XXX_TDFN12-SRC0GS22D,-9999V..9999V,-9999V..9999V,9999A,SWITCH,115-2029-000-115-2029-000IC1U521
DFN18_P050_055X015_3XT006X005D_ESD_DFN18-MG2040MUTAG,OTHER,UNI-DIRECTIONAL,5V,1UA,5.5V,11.4V@8A,0.42PF,091-0080-000-091-0080-000IO1D501
DIODE_SMD_010X060D_ESD_NORM-AZ5725-01F,1 LINE,BI-DIRECTIONAL,5V,1UA,5.8V,10V@9999A,10PF,090-0163-000-090-0163-000DISCRETE1D42
DIODE_SMD_034X016_CUTOUTLED_SMD_2PIN-EASRR3216WA1,5V,0.1A,3.15V,25MA,WHITE,092-0241-000-092-0241-000DISCRETE1DS2
DIODE_SMD_SOD323D_SOD323-1N4148,SINGLE,75V,0.3A,0.715V@0.15A,0.3A,090-0075-000-090-0075-000DISCRETE7D48; D49; D504; D505; D506; D509; D510
DIODE_SMD_SOD523_BD_SCHOTTKY_SOD523-RB521S30T1G,SINGLE,30V,1A,0.5V@0.2A,0.2A,090-0102-000-090-0102-000DISCRETE3D4; D47; D507
DIODE_SMD_SOD923D_ESD_SOD923-ESD9X5.0ST5G,1 LINE,UNI-DIRECTIONAL,5V,1UA,6.2V,12.3V@8.7A,65PF,090-0134-000-090-0134-000DISCRETE3D511; D512; D513
IND_NONRKO_SMD_012X010L_CMF_4P_SMDA_012X010-90OHM,[ ],25%,0.2A,0.4OHM,[ ],102-0037-000-102-0037-000,90OHM90ohmDISCRETE5L1; L2; L4; L5; L509
IND_NONRKO_SMD_012X010L_CMF_4P_SMDA_012X010-12OHM,[ ],25%,0.1A,1.5OHM,MCZ1210DH120L2TA0G,102-0066-000-102-0066-000,12OHM12ohmDISCRETE4L503; L504; L505; L506
IND_NONRKO_SMD_076X076L_7_6X7_6-4.7UH,[ ],20%,5.5A,10A,0.04OHM,[ ]@[ ],[ ],[ ],131-0255-000-131-0255-000,4.7UH4.7uHDISCRETE2L3; L513
IND_NONRKO_SMD_076X076L_7_6X7_6-2.2UH,ALLOY CORE,20%,10A,10A,0.0132OHM,[ ]@[ ],[ ],0DECIBEL,130-0436-000-130-0436-000,2.2UH2.2uHDISCRETE1L508
IND_NONRKO_SMD_106X102L_SMD_420X400-2.2UH,[ ],20%,12A,25A,0.009OHM,[ ]@[ ],[ ],[ ],131-0282-000-131-0282-000,2.2UH2.2uHDISCRETE1L502
IND_NONRKO_SMD_115X103L_SMD_420X400-1UH,METAL DUST,20%,14.5A,18A,0.006OHM,0@0HZ,0HZ,0DECIBEL,130-0846-000-130-0846-000,1UH1uHDISCRETE1L507
IND_SMD_0402L_BEAD_0402-30OHM,FERRITE,33.33%,[ ],1.7A,0.05OHM,[ ],N/A,N/A,100-0105-000-100-0105-000,30OHM30ohmDISCRETE3LB1; LB2; LB502
IND_SMD_0402L_BEAD_0402-120OHM,FERRITE,25%,2A,2A,0.1OHM,[ ],N/A,N/A,100-0116-000-100-0116-000,120OHM120ohmDISCRETE5LB3; LB16; LB17; LB503; LB504
IND_SMD_0402L_BEAD_0402-600OHM,FERRITE,25%,0.5A,0.5A,0.39OHM,[ ],N/A,N/A,100-0183-000-100-0183-000,600OHM600ohmDISCRETE8LB4; LB5; LB6; LB7; LB8; LB9; LB10; LB11
IND_SMD_0402L_BEAD_0402-30OHM,FERRITE,25%,[ ],2A,0.1OHM,[ ],N/A,N/A,100-0165-000-100-0165-000,30OHM30ohmDISCRETE1LB501
LED_SMD_0603_STLED_0603-LED_SMD_0603,5V,60MA,2.35V,25MA,GREEN,092-0073-000-092-0073-000DISCRETE1DS701
LTPT28C49PLABTESTPOINT_B28-LABTESTPOINTIO26TP1; TP2; TP3; TP5; TP6; TP7; TP8; TP29; TP30; TP31; TP32; TP33; TP34; TP35; TP38; TP501; TP502; TP503; TP504; TP505; TP506; TP507; TP508; TP509; TP510; TP511
LTPT28C49PLABTESTPOINT_PIN-LABTESTPOINTIO1TP4
MECH_RECT_01050X01050_HOLESMOUNTING_HOLE_X28-P2822_MOUNTING_HOLESIO1MEC1
MEC_STANDOFF_PTH_620C380PMEC_STANDOFF_SMD-SMD MECH STDF_06MM,155-0608-000-155-0608-000IO2MEC2; MEC501
MULTI_DFET_010_SMD_050X060Q_FET_N_ENH_PWR_PHASE-FDPC5030SG,30V / 30V,5MOHM,2.4MOHM@10V / 6.5MOHM,3MOHM@4.5V / [ ],[ ]@2.5V,17A / 25A,227A / 503A,20V / 1BDISCRETE4Q504; Q505; Q521; Q528
MULTI_DFET_010_SMD_050X060Q_FET_N_ENH_PWR_PHASE-AOE6930,30V / 30V,6.2MOHM,1.2MOHM@10V / 7MOHM,1.05MOHM@4.5V / [ ],[ ]@2.5V,19A / 48A,88A / 340A,20V / 12BDISCRETE2Q512; Q520
MULTI_SMD_SOT669_LFPAK_BQ_FET_P_ENH_LFPAK-FDMS6681Z,-30V,3.2MOHM@10V / 5MOHM@4.5V / [ ]@2.5V,-21.1A,-600A,25V,2.5W,241NC@10V / 136NC@4.5V / [ ]@2.5V,3BDISCRETE1Q17
MULTI_SMD_SOT669_LFPAK_BQ_FET_P_ENH_LFPAK-AON6411,-20V,2.1MOHM@10V / 2.5MOHM@4.5V / 3.6MOHM@2.5V,-47A,-340A,12V,7.3W,330NC@10V / 140NC@4.5V / 0NC@2.5VBDISCRETE1Q513
NET_ISO_76X25VIRTUAL_SHORT_25MIL-VIRTUAL_SHORTDISCRETE6VS501; VS502; VS503; VS504; VS505; VS506
QFN008Q_P050_0016X0016U_BUF_FXMA2102_QFN8-FXMA2102L8X,TRANSLATOR,115-2189-000-115-2189-000IC6U3; U16; U66; U71; U72; U80
QFN010R_P040_0018X0014U_SW_ANA_USB_UQFN10-TS3USB30E,SWITCH - ANALOG,115-0655-000-115-0655-000IC5U70; U502; U511; U516; U517
QFN014R_P050_0030X0025_T017X012U_LEVSHFT_FXL5T244_MLP14-FXL5T244BQX,OTHER,115-2537-000-115-2537-000IC1U57
QFN016R_P040_0260X0180U_I2C_EXP_TCA6408_UQFN16-TCA6408ARSVR,I/O EXPANDER,115-1529-000-115-1529-000IC1U63
QFN016R_P050_0040X0035_T026X021U_LEVSHFT_3STATE_QFN16-SN74AVC4T245,LEVEL SHIFTER,115-0710-000-115-0710-000IC1U76
QFN020Q_P050_0030_T018X018U_CPU_EFM8SB1_QFN20-EFM8SB10F8G,OTHER,115-2563-000-115-2563-000IC1U79
QFN020R_P050_0045X0035_T031X021_VIASU_LEVSHFT_TXB0108_QFN20-TXB0108RGYR,LEVEL SHIFTER,115-1921-000-115-1921-000IC3U8; U11; U67
QFN024Q_P050_0042_T025X025U_I2C_EXP_TCA9539_QFN24-TCA9539RTWR,I/O EXPANDER,115-2536-000-115-2536-000IC1U55
QFN032Q_P050_055X055_T038X038U_BUCKBOOST_DRV_1PH_USB_PD_QFN32-NCP81239MNTXG,BUCK/BOOST,1PH,1.2MHZ,I2C,28V..0MV,1%,0.5V,28V,5A,2.1W,316-0604-000-0.5V,316-06A0.5VIC2U9; U514
QFN040Q_P050_0065_T047X047U_USB_C_CCG4_QFN40-CYPD4226-40LQXIT,USB,190-82822-0000-000-190-82822-0000-000IC1U513
QFN040R_P040_0040X0060_T026X046U_USB_TUSB1046_WQFN40-TUSB1046-DCIRNQR,OTHER,115-2448-000-115-2448-000IC2U522; U523
QFN048Q_P040_0065_T047X047U_ACODEC_ALC5658_QFN48-ALC5658,CONVERTER - AUDIO CODEC,115-2054-000-115-2054-000IC1U519
QFN056Q_P040_0075_T041X049_VIASU_PCIE2SATA_88SE9170_QFN56-88SE9171A2,SATA,115-2464-000-115-2464-000IC1U4
QFN056Q_P050_0080_T044X044U_ENET_88E1512P_QFN56-88E1512PB2-NNP2C000,ETHERNET,115-2543-000-115-2543-000IC1U1
QFN064Q_P050_0090_T043X043U_USB_FT4232H_QFN64-FT4232HQ,USB PERIPHERAL,115-2142-000-115-2142-000IC1U56
RES_04_SMD_015X032R_SENSE_4PIN_R_SENSE_4PIN-0.01OHM,1%,1W,200PPM,215-0142-000-0.01OHM,215-0142-0000.01ohmDISCRETE4RS501; RS502; RS505; RS506
SC70_5U_BUF_OD_SC70_5-SN74AUP1G07,BUFFER - OPEN DRAIN,115-0970-000-115-0970-000IC3U12; U85; U508
SC70_5U_AND_2IN_SC70-5-NC7SVL08,GATES - AND - 2 INPUT,115-1345-000-115-1345-000IC3U83; U89; U94
SC70_5U_BUF_3_STATE_SC70_5-74LVC1G126GW,BUFFER - TRI-STATE,115-1821-000-115-1821-000IC5U86; U87; U90; U91; U92
SC70_5U_XOR_2IN_SC70-NL17SG86DFT2G,GATES - XOR - 2 INPUT,115-2514-000-115-2514-000IC1U93
SC70_5U_AND_2IN_SC70-5-SN74LVC1G08,GATES - AND - 2 INPUT,115-0014-000-115-0014-000IC1U518
SC70_6Q_FET_N_ENH_SOT363-2N7002DW-7-F,60V,-1000MOHM@10V / -1000MOHM@4.5V / -1000MOHM@2.5V,0.115A,0.8A,20V,0.2W,[ ]@10V / [ ]@4.5V / BDISCRETE9Q3; Q9; Q16; Q53; Q54; Q67; Q77; Q78; Q79
SC70_6Q_FET_N_ENH_SOT363-NTJD4001N,30V,1500MOHM@10V / 1500MOHM@4.5V / 1500MOHM@2.5V,0.25A,0.25A,20V,0.272W,[ ]@10V / [ ]@4.5V / [ ]@BDISCRETE2Q31; Q98
SC70_6U_LEVSHFT_3STATE_SC70_6-SN74LVC1T45DCKR,LEVEL SHIFTER,115-2544-000-115-2544-000IC3U58; U61; U62
SO08_048X038_T030X026U_VREG_APL5910_SOP8-APL5932AKAI,ULTRA LOW DROP OUT,0.23V@3A,[ ]..5.5V,1.5%,[ ],6V,3A,2W,315-0808-000-315-0808-000,[ ][ ]IC1U506
SOT23Q_FET_N_ENH_SOT23_1G1D1S-AO3402,30V,52MOHM@10V / 65MOHM@4.5V / -1000MOHM@2.5V,3.4A,15A,12V,1W,[ ]@10V / [ ]@4.5V / [ ]@2.5V,30BDISCRETE2Q5; Q10
SOT23Q_FET_N_ENH_SOT23_1G1D1S-2N7002HG,60V,2000MOHM@10V / -1000MOHM@4.5V / -1000MOHM@2.5V,0.3A,0.8A,20V,0.35W,[ ]@10V / 9999NC@4.5VBDISCRETE4Q20; Q21; Q25; Q701
SOT23Q_PNP_SOT23_1B1C1E-MMBT4403,40V,[ ],0.6A,0.6A,5V,0.225W,305-0002-000-305-0002-000DISCRETE1Q26
SOT23Q_FET_N_ENH_SOT23_1G1D1S-NTR4003NT1G,30V,-1000MOHM@10V / 1500MOHM@4.5V / -1000MOHM@2.5V,[ ],1.7A,20V,0.83W,[ ]@10V / [ ]@4.5V BDISCRETE1Q506
SOT23Q_FET_N_ENH_SOT23_1G1D1S-FDV301N,25V,-1000MOHM@10V / 4000MOHM@4.5V / -1000MOHM@2.5V,0.22A,0.5A,8V,0.35W,[ ]@10V / 0.7NC@4.5V /BDISCRETE2Q507; Q508
SOT23Q_NPN_SOT23_1B1C1E-MMBT2222A,40V,[ ],0.6A,[ ],6V,0.3W,305-0005-000-305-0005-000DISCRETE1Q511
SOT23_3_BQ_FET_P_ENH_SOT23_1G1D1S-SM2309PSAC-TRG,-30V,95MOHM@10V / 150MOHM@4.5V / [ ]@2.5V,-3.1A,-12.5A,20V,1.4W,6.8NC@10V / 3.1NC@4.5VBDISCRETE4Q2; Q4; Q11; Q12
SOT23_5U_POWER_SW_SOT23_5C-APL3511DBI-TRG,-9999V..9999V,-9999V..9999V,9999A,SWITCH,115-1238-000-115-1238-000IC1U2
SOT23_5U_VREG_5PIN_SOT23-5-RT9043-GB,LOW DROP OUT,[ ]@[ ],2.2V..5.5V,1%,1.2V,5.5V,0.4A,0.4W,315-0783-000-1.2V,315-0783-0001.2VIC1U65
SOT23_5U_LDO_SOT23_5_NOVR-GS7116S5-ADJ-R,STANDARD,0.45V@0.5A,0.8V..5V,2%,0.8V,6.5V,0.5A,0.4W,315-1022-000-0.8V,315-1022-0000.8VIC1U104
SOT23_5U_POWER_SW_SOT23_5B-APL3511CBI-TRG,-9999V..9999V,-9999V..9999V,9999A,SWITCH,115-0836-000-115-0836-000IC1U505
SOT23_5U_POWER_SW_SOT23_5A-APL3510EBI-TRG,-9999V..9999V,-9999V..9999V,9999A,SWITCH,115-1235-000-115-1235-000IC2U507; U510
SOT23_6D_ESD_DIFFPAIR_SOT23_6-AZC199-04S,2 DIFFPAIR,UNI-DIRECTIONAL,5V,1UA,6V,11V@6A,1.7PF,091-0053-000-091-0053-000IO2D502; D503
SOT23_8U_BUCK_FET_1PH_SOT23_8_NOVR-APW7307AZI-TRG,BUCK,1PH,500KHZ,NONE,0.807V..13V,1%,0.807V,24V,3A,1W,316-0471-000-0.807V,316-0471-0A0.807VIC1U504
SOT89_3U_VREG_3PIN_SOT89_3-AP2204RA-3.3TRG1,STANDARD/FIXED,0.35V@50MA,3.3V..3.3V,2%,1.24V,24V,0.15A,0MW,315-0292-000-1.24V,315-0292-0A1.24VIC1U515
SOT323D_3PIN_CC_SOT323-BAS70W-05,1 PAIR - COMMON CATHODE,70V,0.1A,1V@15MA,70MA,091-0023-000-091-0023-000DISCRETE1CR501
SOT323D_3PIN_CC_SOT323-BAT54CW,1 PAIR - COMMON CATHODE,30V,0.6A,1V@0.1A,0.2A,091-0022-000-091-0022-000DISCRETE3D1; D3; D50
SOT323D_3PIN_AA_SOT323-BAT54AWG,1 PAIR - COMMON ANODE,30V,1A,0.5V@0.3A,0.3A,090-0288-000-090-0288-000DISCRETE1D2
SOT323Q_NPN_SOT323_1B1C1E-MMST3904-7-F,40V,[ ],0.2A,0.2A,6V,0.2W,305-0052-000-305-0052-000DISCRETE1Q6
SOT323Q_FET_N_ENH_SOT323_1G1D1S-NTS4001NT1G,30V,1500MOHM@10V / 1500MOHM@4.5V / 1500MOHM@2.5V,0.27A,0.8A,20V,0.33W,[ ]@10V / [ ]@4.5VBDISCRETE26Q13; Q18; Q19; Q22; Q23; Q24; Q75; Q86; Q87; Q88; Q90; Q91; Q99; Q101; Q510; Q514; Q515; Q516; Q517; Q519; Q522; Q523; Q524; Q525; Q526; Q527
SOT723Q_FET_N_ENH_SOT723-NTK3043N,20V,0MOHM@10V / 3800MOHM@4.5V / 4500MOHM@2.5V,0.155A,0.285A,10V,0.31W,0NC@10V / 9999NC@4.5V / 0NC@BDISCRETE8Q30; Q80; Q81; Q82; Q83; Q84; Q92; Q501
SOT723Q_FET_P_ENH_SOT723-NTK3139P,-20V,950MOHM@10V / 950MOHM@4.5V / 950MOHM@2.5V,-0.78A,-1.2A,6V,0.45W,[ ]@10V / [ ]@4.5V / [ ]@2.5VBDISCRETE2Q502; Q503
SW_04_TH_RA_1XONOFF_085X073SW_SPST_PB_TH4_2GND-2SWNTC304-AE1D-B160B,FEMALE,4.5MM,90,NO,NO,YES,12.0 V,50.0 MA,280-0143-000-280-0143-000IO3S501; S502; S503
TSLP10_P050_025X010D_ESD_DIFFPAIR_DUAL-TPD4E02B04DQAR,2 DIFFPAIR,BI-DIRECTIONAL,6V,0.01UA,6.7V,8V@40A,0.37PF,090-0296-000-090-0296-000IO9D20; D23; D29; D30; D31; D38; D39; D40; D508
TSLP10_P050_025X010D_ESD_DIFFPAIR_DUAL-TPD4E05U06,2 DIFFPAIR,UNI-DIRECTIONAL,5.5V,10UA,6V,10V@1A,0.5PF,090-0231-000-090-0231-000IO3D21; D22; D24
TSLP10_P050_025X010D_ESD_DIFFPAIR_DUAL-AZ1045-04F,2 DIFFPAIR,UNI-DIRECTIONAL,5V,1.5UA,6V,12V@3.5A,0.65PF,091-0054-000-091-0054-000IO1D35
XFMR_SMD_24_151X071TR_ENET_MAGCOM_SOP24-M3295NL,1:1,1500V(RMS),0HZ..100MHZ,50OHM..50OHM,295-0036-000-1:1,295-0036-000
1:01
DISCRETE1T501
XSOP10_P050_030X030U_SWREG_TPS53015_XSOP10-TPS53015,BUCK,1PH,500KHZ,NONE,0.77V..7V,1%,0.773V,28V,10A,50W,316-0314-000-0.773V,316-0314-0000.773VIC2U17; U503
XSOP14_P065_050X044U_LEVSHFT_ADG3304_TSSOP14-ADG3304BRUZ,LEVEL SHIFTER,115-1903-000-115-1903-000IC1U509
XTAL_SMD_4_016X012XTAL_4PIN_SMD_16X12-1ZZHAM25000BC0B,25MHZ,20PPM,2PPM,50PPM,7PF,FUNDAMENTAL,085-0306-000-085-0306-000,25MHZ25MHzDISCRETE2Y1; Y2
XTAL_SMD_4_032X025OSC_4PIN_SMD_32X25-ASHEK4-32.768KHZ-L-T,32.768KHZ,25PPM,5PPM,-1PPM,15PF,086-0179-000-086-0179-000,32.768KHZ32.768KHzDISCRETE2Y3; Y501
XTAL_SMD_4_032X025XTAL_4PIN_SMD_32X25-EXS00A-CG02825,12MHZ,15PPM,5PPM,45PPM,10PF,FUNDAMENTAL,085-0167-000-085-0167-000,12MHZ12MHzDISCRETE1Y4
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
! `, v- N' f9 p! z) c5 {
推荐
发表于 2020-11-19 09:00 | 只看该作者
大哥原理图呢,就是为了原理图的,下了结果只有PCB,浪费我50威望,真的是过分
    难过
    2023-3-2 15:24
  • 签到天数: 25 天
    [LV.4]偶尔看看III
    推荐
    发表于 2021-11-4 11:17 | 只看该作者
    哒哒哒哒哒哒多多多多多多多多多多多多* a1 J! a+ j  R
    推荐
    发表于 2022-10-31 10:28 | 只看该作者
    好好好好好好好好好好好好* C. k+ ?1 y8 R' I" S' g
    发表于 2020-6-1 14:17 | 只看该作者
    学习学习,谢谢楼主
      a+ r4 Q( j3 U3 _0 S9 y* H
    发表于 2020-6-1 14:18 | 只看该作者
    学习学习,谢谢楼主
    . F; n1 Q  N0 q$ f  Y( o* h5 X
    发表于 2020-11-18 22:10 | 只看该作者
    + n; Z) H, K6 T" M& k: _6 \4 ~- T学习学习,谢谢楼主
    发表于 2020-11-19 23:00 | 只看该作者
    文件损坏,文件损坏
    发表于 2021-1-6 21:24 | 只看该作者
    学习一下 感谢分享
    . N; o/ C+ z2 m7 P8 [4 V) F8 Z# o: l. ]+ r4 F: k
    发表于 2021-1-7 11:03 | 只看该作者
    楼主  想咨询一下   我自己设计了这个的载板  现在上电显示启动失败  可以讨论一下吗
    “来自电巢APP”
    2019-11-29 15:00
  • 签到天数: 3 天
    [LV.2]偶尔看看I
    发表于 2021-1-7 16:00 | 只看该作者
    多谢分享 多谢分享4 y2 @* G4 Z, a: ~' x
    13#
    发表于 2021-6-15 14:02 | 只看该作者
    很有用的资料,感谢楼主。
    擦汗
    2021-9-6 15:33
  • 签到天数: 68 天
    [LV.6]常住居民II
    14#
    发表于 2021-6-30 17:11 | 只看该作者
    核心板核心板
    GMT+8, 2025-7-19 05:00 , Processed in 0.187500 second(s), 29 queries , Gzip On.
