SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
CAPALE_6D3PI_2SP_6D6WX7D8L | CAP_NP_0_CAPALE_6D3PI_2SP_6D6WX | 22uF | DISCRETE | 1 | C2 |
CAPCRMIC_5D1_2DP_4D6WX11L | MZ21-500RM_0_CAPCRMIC_5D1_2DP_4 | 4ohm | IC | 1 | PTC1 |
CAPCRMIC_5D1_2DP_4D6WX11L | MZ21-500RM_CAPCRMIC_5D1_2DP_4D6 | 4ohm | IC | 47 | PTC2,PTC3,PTC4,PTC5,PTC6,PTC7,PTC8,PTC9,PTC10,PTC11,PTC12,PTC13,PTC14,PTC15,PTC16,PTC17,PTC18,PTC19,PTC20,PTC21,PTC22,PTC23,PTC24,PTC25,PTC26,PTC27,PTC28,PTC29,PTC30,PTC31,PTC32,PTC33,PTC34,PTC35,PTC36,PTC37,PTC38,PTC39,PTC40,PTC41,PTC42,PTC43,PTC44,PTC45,PTC46,PTC47,PTC48 |
CAPE_5PI_2D_2DP | CAP-POL_0_CAPE_5PI_2D_2DP_DISCR | *100uF | DISCRETE | 1 | C17 |
CC0402 | CAP_NP_CC0402_DISCRETE_0.1UF | 0.1uF | DISCRETE | 15 | C4,C5,C11,C14,C20,C21,C22,C24,C25,C26,C27,C28,C29,C30,C31 |
CC0402 | 0_0.1U-50-M-S6_CC0402_DISCRETE_ | 10nF | DISCRETE | 2 | C9,C10 |
CC0402 | 0_0.1U-50-M-S6_CC0402_DISCRET_1 | 3.3nF | DISCRETE | 1 | C12 |
CC0402 | 0_0.1U-50-M-S6_CC0402_DISCRET_2 | 1000pF | DISCRETE | 1 | C13 |
CC0402 | 0_0.1U-50-M-S6_CC0402_DISCRET_3 | *4.7nF | DISCRETE | 1 | C18 |
CC0402 | CAP_NP_CC0402_DISCRETE_0.01UF | 0.01uF | DISCRETE | 1 | C19 |
CC0402 | CAP_CC0402_DISCRETE_100PF | 100pF | DISCRETE | 1 | C23 |
CC0603 | CAP_NP_CC0603_DISCRETE_0.1UF | 0.1uF | DISCRETE | 1 | C6 |
CC0805 | CAPACITOR_1_CC0805_DISCRETE_22U | 22uF | DISCRETE | 2 | C15,C16 |
CC1206 | CAP_NP_0_CC1206_DISCRETE_*10UF | *10uF | DISCRETE | 1 | C1 |
CC1206 | CAP_NP_0_CC1206_DISCRETE_10UF | 10uF | DISCRETE | 1 | C3 |
CC1206 | CAP_NP_CC1206_DISCRETE_10UF | 10uF | DISCRETE | 2 | C7,C8 |
CHOCK_5D54_2SP | INDUCTOR_0_CHOCK_5D54_2SP_DISCR | 10uH 2.5A | DISCRETE | 1 | L1 |
CONNF_85X169MIL_50SP | TELCO 25X2/SM_0_CONNF_85X169MI | Telco 25x2/SM_0 FEMALE | IC | 2 | J1,J2 |
CONNM_85X151MIL_50DP | TELCO 25X2/SM_0_CONNM_85X151MI | Telco 25x2/SM_0 MALE | IC | 1 | J3 |
DIO214AB_2SP_12_6WX6D85L_AC | DIODE_0_DIO214AB_2SP_12_6WX6D85 | SK54 | IC | 1 | D49 |
DIO_4D3_2SP_2D5W5D2L1D8H | DIODE_0_DIO_4D3_2SP_2D5W5D2L1D8 | SK14 | IC | 24 | D50,D51,D52,D53,D54,D55,D56,D57,D58,D59,D60,D61,D62,D63,D64,D65,D66,D67,D68,D69,D70,D71,D72,D73 |
FUSE_4D91_2SP_2D69W6D1L | FUSE_FUSE_4D91_2SP_2D69W6D1L_DI | 1A/125V | DISCRETE | 1 | F1 |
LC0805 | BEAD_LC0805_100MHZ | 100MHZ | IC | 2 | L2,L3 |
RC0402 | RES SMD_RC0402_DISCRETE_3.9OHM | 3.9ohm | DISCRETE | 24 | R1,R2,R3,R4,R5,R6,R7,R8,R9,R10,R11,R12,R13,R14,R15,R16,R17,R18,R19,R20,R21,R22,R23,R24 |
RC0402 | RES SMD_RC0402_DISCRETE_100K | 100K | DISCRETE | 1 | R26 |
RC0402 | R_RC0402_DISCRETE_10K | 10K | DISCRETE | 1 | R27 |
RC0402 | RES SMD_RC0402_DISCRETE_1K | 1K | DISCRETE | 38 | R28,R44,R45,R46,R55,R56,R57,R59,R60,R69,R71,R73,R74,R75,R83,R85,R87,R89,R91,R93,R101,R103,R105,R107,R109,R111,R119,R121,R123,R125,R127,R129,R137,R139,R141,R143,R145,R147 |
RC0402 | R_STANDARD_1_RC0402_DISCRETE_*1 | *10 | DISCRETE | 1 | R31 |
RC0402 | R_STANDARD_0_RC0402_DISCRETE_39 | 39K | DISCRETE | 1 | R34 |
RC0402 | RES SMD_RC0402_DISCRETE_4.7K | 4.7K | DISCRETE | 11 | R35,R39,R40,R41,R42,R43,R48,R52,R62,R64,R68 |
RC0402 | RES SMD_RC0402_DISCRETE_*4.7K | *4.7K | DISCRETE | 37 | R36,R37,R38,R49,R50,R51,R53,R54,R61,R63,R65,R66,R67,R84,R86,R88,R90,R92,R94,R102,R104,R106,R108,R110,R112,R120,R122,R124,R126,R128,R130,R138,R140,R142,R144,R146,R148 |
RC0402 | RES SMD_RC0402_DISCRETE_*1K | *1K | DISCRETE | 5 | R47,R58,R70,R72,R76 |
RC0402 | RES SMD_RC0402_DISCRETE_10K | 10K | DISCRETE | 24 | R77,R78,R79,R80,R81,R82,R95,R96,R97,R98,R99,R100,R113,R114,R115,R116,R117,R118,R131,R132,R133,R134,R135,R136 |
RC0402 | RES SMD_RC0402_DISCRETE_200 | 200 | DISCRETE | 6 | R149,R151,R153,R154,R155,R156 |
RC0402 | RES SMD_RC0402_DISCRETE_33 | 33 | DISCRETE | 2 | R150,R152 |
RC0603 | RES SMD_RC0603_DISCRETE_100K | 100K | DISCRETE | 1 | R30 |
RC0603 | RES SMD_RC0603_DISCRETE_26.1K | 26.1K | DISCRETE | 1 | R32 |
RC0603 | R_STANDARD_6_RC0603_DISCRETE_10 | 10K | DISCRETE | 1 | R33 |
RJ45FS_1D27_1X1X8DP_S | RJ45_0_RJ45FS_1D27_1X1X8DP_S_IO | RJ45_3 | IO | 1 | SK1 |
SOIC_1D27X5D16_8SP_5D1L | AT24C02_0_SOIC_1D27X5D16_8SP_5D | AT24C64CN | IC | 1 | IC2 |
SOIC_1D27X5D28_8SP_4W5L_G1 | AIC1563_0_SOIC_1D27X5D28_8SP_4W | MP1484 | IC | 1 | IC1 |
SOP_3D6_3SP_123 | SIDAC_1_SOP_3D6_3SP_123_DISCRET | SIDAC_0 | DISCRETE | 24 | AR1,AR2,AR3,AR4,AR5,AR6,AR7,AR8,AR9,AR10,AR11,AR12,AR13,AR14,AR15,AR16,AR17,AR18,AR19,AR20,AR21,AR22,AR23,AR24 |
SOT23_3SP_123 | PMBT3904_SOT23_3SP_123_IC_PMBT3 | PMBT3904 | IC | 24 | Q2,Q3,Q4,Q5,Q6,Q7,Q8,Q9,Q10,Q11,Q12,Q13,Q14,Q15,Q16,Q17,Q18,Q19,Q20,Q21,Q22,Q23,Q24,Q25 |
SOT23_D95_3SP | P-MOS_SOT_2_SOT23_D95_3SP_IC_FD | FDN338P | IC | 1 | Q1 |
TCUR_12_4DP | FILTER_10_TCUR_12_4DP_*B8845NL | *B8845NL | IC | 24 | U3,U6,U9,U12,U15,U18,U21,U24,U27,U30,U33,U36,U39,U42,U45,U48,U51,U54,U57,U60,U63,U66,U69,U72 |
TCUR_12_4DP_TSE | FILTER_10_TCUR_12_4DP_TSE_TSE01 | TSE016025 | IC | 24 | U2,U5,U8,U11,U14,U17,U20,U23,U26,U29,U32,U35,U38,U41,U44,U47,U50,U53,U56,U59,U62,U65,U68,U71 |
TF_2D2X5D3_8SP | RELAY_1_TF_2D2X5D3_8SP_G6J-2P-Y | G6J-2P-Y-TR 3VDC | IC | 24 | U1,U4,U7,U10,U13,U16,U19,U22,U25,U28,U31,U34,U37,U40,U43,U46,U49,U52,U55,U58,U61,U64,U67,U70 |
TF_D65_1D5_D3X_24SP | PCA9555PW_0_TF_D65_1D5_D3X_24SP | TCA9555PWR | IC | 2 | U74,U75 |
TSSOP_D4D75_8SP_3D1L_IDT | PCA9511_0_TSSOP_D4D75_8SP_3D1L_ | TCA4311DGKR | IC | 1 | U73 |
TSSOP_D5X7D48_48SP_12D6L | SN74LVC16244ADGGR_0_TSSOP_D5X7D | SN74LVCH16244ADGGR | IC | 2 | U76,U77 |
PJ_002A_3P | 22HP037A_PJ_002A_3P_PJ-002A | PJ-002A | 1 | J37 | |
R0402 | R_R0402_0 | 0 | 2 | R4,R6 | |
R0402 | RES_10K_1W16_0402_5P_R0402_100 | 100 | 1 | R180 | |
R0603 | 5K1_0402_R0603_DISCRETE_4.7K | 4.7K | 3 | R1,R2,R3 | |
R0603 | 5K1_0402_R0603_DISCRETE_2.2K | 2.2K | 2 | R5,R12 | |
R0603 | 0R_0603_R0603_DISCRETE_0 | 0 | 18 | R7,R8,R9,R11,R22,R23,R24,R25,R26,R27,R32,R33,R34,R35,R38,R39,R40,R41 | |
R0603 | R_R0603_100K | 100K | 1 | R10 | |
R0603 | RES_10K_1W16_0402_5P_R0603_10K | 10K | 3 | R13,R14,R15 | |
R0603 | 10K_0402_R0603_DISCRETE_12K | 12K | 2 | R16,R20 | |
R0603 | RES_10K_1W16_0402_5P_R0603_10 | 10 | 2 | R45,R46 | |
R0603 | 5K1_0402_R0603_DISCRETE_2.2K-DN | 2.2K-DNI | 1 | R52 | |
R0603 | RES_10K_1W16_0402_5P_R0603_100K | 100K-DNI | 2 | R53,R54 | |
R0603 | RES_10K_1W16_0402_5P_R0603_22 | 22 | 1 | R60 | |
R0603 | 1R_0.25W_0603_R0603_DISCRETE_0 | 0 | 12 | R97,R98,R99,R100,R101,R102,R103,R104,R105,R106,R107,R108 | |
R0603 | RES_10K_1W16_0402_5P_R0603_1K | 1K | 2 | R111,R113 | |
RLP-100 | R_RLP-100_10K-0402SMT | 10K-0402SMT | 3 | R44,R92,R93 | |
RLP-100 | R_RLP-100_0R-0402SMT | 0R-0402SMT | 4 | R85,R86,R87,R88 | |
RLP-100 | RES_0_RLP-100_10K-0402SMT | 10K-0402SMT | 3 | R89,R90,R91 | |
RLP-100 | R_RLP-100_51K-0402SMT | 51K-0402SMT | 4 | R116,R121,R123,R125 | |
RLP-100 | R_RLP-100_34K-0402SMT | 34K-0402SMT | 1 | R122 | |
RLP-100 | R_RLP-100_30_1K-0402SMT | 30_1K-0402SMT | 1 | R130 | |
RLP-100 | R_RLP-100_63_4K-0402SMT | 63_4K-0402SMT | 1 | R131 | |
RLP-100 | R_RLP-100_20K-0402SMT | 20K-0402SMT | 1 | R132 | |
RLP-101 | RES_0_RLP-101_2_2K-0603SMT | 2_2K-0603SMT | 4 | R17,R94,R95,R135 | |
RLP-101 | RESISTOR_RLP-101_2_2K-0603SMT | 2_2K-0603SMT | 2 | R18,R19 | |
RLP-101 | RESISTOR_RLP-101_0R-0603SMT-DNI | 0R-0603SMT-DNI | 1 | R21 | |
RLP-101 | RES_0_RLP-101_0R-0603SMT | 0R-0603SMT | 2 | R49,R51 | |
RLP-101 | RES_0_RLP-101_0R-0603SMT- DNI | 0R-0603SMT- DNI | 1 | R50 | |
RLP-101 | RESISTOR_RLP-101_4_7K-0603SMT | 4_7K-0603SMT | 3 | R73,R74,R75 | |
RLP-101 | R_RLP-101_1K-0603SMT | 1K-0603SMT | 4 | R76,R77,R78,R82 | |
RLP-101 | R_RLP-101_50R-0603SMT | 50R-0603SMT | 1 | R79 | |
RLP-101 | R_RLP-101_4_7K-0603SMT | 4_7K-0603SMT | 3 | R80,R81,R83 | |
RLP-101 | RES_0_RLP-101_10K-0603SMT | 10K-0603SMT | 1 | R96 | |
RLP-101 | R_RLP-101_121K-0603SMT | 121K-0603SMT | 2 | R112,R114 | |
RLP-101 | R_RLP-101_21_5K-0603SMT | 21_5K-0603SMT | 1 | R118 | |
RLP-101 | R_RLP-101_10_7K-0603SMT | 10_7K-0603SMT | 1 | R119 | |
RLP-101 | R_RLP-101_10K-0603SMT | 10K-0603SMT | 2 | R120,R133 | |
RLP-101 | R_RLP-101_3_4K-0603SMT | 3_4K-0603SMT | 1 | R124 | |
RLP-101 | R_RLP-101_5_11K-0603SMT | 5_11K-0603SMT | 1 | R128 | |
RLP-101 | R_RLP-101_15K-0603SMT | 15K-0603SMT | 1 | R129 | |
RLP-101 | R_RLP-101_16_9K-0603SMT | 16_9K-0603SMT | 1 | R134 | |
RLP-101 | RES_0_RLP-101_4.7K-0603SMT | 4.7K-0603SMT | 3 | R138,R140,R141 | |
RLP-101 | RES_0_RLP-101_470R-0603SMT | 470R-0603SMT | 1 | R179 | |
RLP-103 | RES_0_RLP-103_24K-1206SMT | 24K-1206SMT | 3 | R136,R137,R139 | |
RLP-103 | RES_0_RLP-103_1_8K-1206SMT | 1_8K-1206SMT | 1 | R142 | |
RLP-130-A | CAP NP_0_RLP-130-A_100NF-0402SM | 100NF-0402SMT | 8 | C19,C20,C25,C26,C28,C29,C46,C48 | |
RLP-130-A | C_RLP-130-A_100NF-0402SMT | 100NF-0402SMT | 1 | C32 | |
RLP-130-A | CAP_1_RLP-130-A_10NF-0402SMT | 10NF-0402SMT | 1 | C35 | |
RLP-130-A | CAP NP_RLP-130-A_100NFX5R-0402S | 100NFX5R-0402SMT | 1 | C36 | |
RLP-130-A | CAP_1_RLP-130-A_100NF-0402SMT | 100NF-0402SMT | 6 | C40,C41,C42,C43,C60,C62 | |
RLP-130-A | CAP NP_0_RLP-130-A_1UF-0402SMT | 1UF-0402SMT | 2 | C45,C49 | |
RLP-130-A | CAP NP_RLP-130-A_10NFX5R-0402SM | 10NFX5R-0402SMT | 2 | C101,C102 | |
RLP-130-A | CAP-NP_RLP-130-A_220NF-0402SMT | 220NF-0402SMT | 4 | C112,C113,C126,C127 | |
RLP-130-A | CAP-NP_RLP-130-A_1000PF-0402SMT | 1000pF-0402SMT | 4 | C114,C115,C128,C129 | |
RLP-130-A | CAP-NP_RLP-130-A_330PF-0402SMT | 330pF-0402SMT | 4 | C116,C119,C130,C133 | |
RLP-130-A | CAP-NP_RLP-130-A_10PF-0402SMT | 10pF-0402SMT | 6 | C117,C118,C131,C132,C134,C137 | |
RLP-130-A | CAP NP_0_RLP-130-A_1UF-16V-0402 | 1UF-16V-0402SMT | 3 | C143,C145,C146 | |
RLP-132 | CAP NP_RLP-132_20PF-0603SMT | 20pF-0603SMT | 3 | C37,C38,C39 | |
RLP-133 | CAP_SMT_0805_RLP-133_1UF-16V-08 | 1UF-16V-0805SMT | 8 | C31,C63,C94,C100,C104,C106,C108,C111 | |
RLP-133 | CAP NP_RLP-133_1UF-16V-0805SMT | 1UF-16V-0805SMT | 2 | C95,C97 | |
RLP-133 | CAP NP_RLP-133_10UF-6.3V-0805SM | 10uF-6.3V-0805SMT | 2 | C96,C98 | |
RLP-133 | CAP-NP_RLP-133_22UF,6.3V-0805SM | 22uF,6.3V-0805SMT | 10 | C120,C121,C122,C123,C124,C135,C136,C138,C139,C140 | |
RLP-133 | CAP NP_RLP-133_22UF-6.3V-0805SM | 22uF-6.3V-0805SMT | 7 | C147,C148,C149,C150,C151,C152,C153 | |
RLP-134 | CAP-NP_RLP-134_10UF,25V-1206SMT | 10uF,25V-1206SMT | 2 | C109,C125 | |
SKT_SULLINS_PPPC062_2X6_100 | SKT2X6_PPPC062LFBN-RC_SKT_SULLI | PMOD 2x6 | 1 | J31 | |
SO16W | N25QXXXA13XSF_SO16W_MX25L12833F | MX25L12833FMI-10G | 1 | U4 | |
SO8_50_244 | 93LC56_SO8_0_SO8_50_244_IC_93LC | 93LC56C-I/SN | 1 | U2 | |
SPD62R | IND_SPD62R_4.7UH-SPD62R-472M | 4.7uH-SPD62R-472M | 4 | L4,L5,L6,L7 | |
SW_SP_ST_CK_PTS645_SM | EVQP0_0_SW_SP_ST_CK_PTS645_SM_4 | 4.30182E+11 | 3 | SW2,SW3,SW4 | |
TDA08H0SB1 | SW DIP-8_TDA08H0SB1_TDA DIP-8 | TDA DIP-8 | 1 | SW5 | |
TP | T POINT R_0_TP_T POINT R | T POINT R | 77 | AA1,AA2,AA3,AA4,AA5,AA6,AA7,AA8,AA9,AA10,AA11,AB1,AB2,AB3,AB4,AB5,AB6,AB7,AB8,AB9,AB10,AB11,AC1,AC2,AC3,AC4,AC5,AC6,AC7,AC8,AC9,AC10,AC11,AD1,AD2,AD3,AD4,AD5,AD6,AD7,AD8,AD9,AD10,AD11,AE1,AE2,AE3,AE4,AE5,AE6,AE7,AE8,AE9,AE10,AE11,AF1,AF2,AF3,AF4,AF5,AF6,AF7,AF8,AF9,AF10,AF11,AG1,AG2,AG3,AG4,AG5,AG6,AG7,AG8,AG9,AG10,AG11 | |
TP | TP_S_40_63_TP_IO_TP_S_40_63 | TP_S_40_63 | 22 | TP1,TP2,TP24,TP25,TP26,TP27,TP28,TP29,TP30,TP31,TP32,TP33,TP34,TP35,TP36,TP37,TP38,TP39,TP40,TP55,TP56,TP57 | |
TP50 | T POINT R_TP50_TESTPOINT | TestPoint | 35 | TP3,TP4,TP5,TP6,TP7,TP8,TP9,TP10,TP11,TP12,TP13,TP14,TP15,TP16,TP17,TP18,TP19,TP20,TP21,TP22,TP23,TP41,TP42,TP43,TP44,TP45,TP46,TP47,TP48,TP49,TP50,TP51,TP52,TP53,TP54 | |
TQFP64_0P5_12P2X12P2_H1P6 | FT2232HL_TQFP64_0P5_12P2X12P2_H | FT2232HL | 1 | U1 | |
UDFN6_040 | ESDR0502_UDFN6_040_IC_ESDR0502N | ESDR0502N-UDFN6 | 1 | D2 | |
USB2-0-REC-240-0001-9 | USB_MINI_B_0_USB2-0-REC-240-000 | USB_MINI_AB | 1 | J2 | |
V12P10 | DIODE SCHOTTKY21_V12P10_SCHOTTK | SCHOTTKY/VISHAY-V12P10 | 1 | D13 | |
XTAL_4P_7M | CRYSTAL-3P2X2P5_XTAL_4P_7M_IC_7 | 7M-12.000MAAJ | 1 | X1 | |
