查看: 253|回复: 1
[allegro16.2][4层]DSC MC56F8257电机控制塔式系统模块(SANDYBRIDGE+PATSBURG+36...
发表于 2020-1-20 15:42 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
! M) D0 t1 Z; I
[allegro16.2][4层]DSC MC56F8257电机控制塔式系统模块(SANDYBRIDGE+PATSBURG+36片DDR)原理图和pcb文件
# m: n9 R  M7 \" C$ F5 V; B1 X. X, J* m; y/ i1 l- _5 {
文件描述:1 ]# u4 A0 m& {; y# K! l# k6 l
* X2 E1 n, T8 O& f' s8 L+ A4 L
1. 作品用途:DSC MC56F8257电机控制塔式系统模块
6 H+ t) h( h7 Y9 K2 _2. 软件版本:allegro16.2
/ L. h; Q7 Z) D* y' T+ P! d6 Q3. 层数:4层' V7 O5 v) p3 G# [8 G2 ?' I# s1 @
4. 用到的主要芯片:SANDYBRIDGE+PATSBURG+36片DDR* n3 F) _( y& K8 F& n
5. pcb尺寸: 90*80.65 MM, M. U6 s+ t3 U
' P7 q8 D) T5 A, U0 }6 L2 F" C/ S6 E
作品截图如下:. {$ Q- y5 b& a$ e( o: ]4 S' }
3 d0 \, m4 w* K顶层截图:# F, p6 u2 [  [
7 M5 d8 ?( V  ?! [: b底层截图:
$ [# M: |" I$ m5 p0 u7 m
& K7 s6 j. c& \* ^' p
! I5 H( H0 `; c" J( v2 V2 D9 i, ~全层截图:
3 i! V3 S. _) ^2 Y
# E' U, V& P0 s! n ; k" u/ N! e9 D; {
叠层阻抗信息如下:
: O9 E; p% K- y4 U
# b' i' P$ q9 FBOM:
" ?! o  J1 V; C3 {% h  K
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M2200PFDISCRETE15C502; C504; C507; C512; C517; C518; C519; C521; C522; C523; C524; C525; C526; C527; C528
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UFDISCRETE23C3; C4; C8; C500; C501; C503; C505; C509; C510; C513; C514; C515; C530; C532; C533; C535; C536; C537; C538; C539; C542; C543; C544
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M18PFDISCRETE2C7; C9
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9 M2.2UFDISCRETE2C508; C511
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.871000PFDISCRETE1C534
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M10UFDISCRETE7C1; C2; C506; C516; C520; C540; C541
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4 M22PFDISCRETE2C5; C6
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.47UFDISCRETE2C529; C531
CN2X82_FINGER_ASSCONN_PCI_XPRESS_X16_328P_CN2X82PCI EXPRESS TOWER SYSTEMIO1J500
CON5_MUSB_AB_0P8_RA_SMTUSB_MINI_B_SKT_CON5_MUSB_AB_0P8USB_MINI_B 5IO1J18
CON213_SSMHDR_13X2_CON213_SSM_IO_7.55MM_2CON2X13IO1J502
CON220_SSM_MIRRORED_PLCONN_HDR_20X2_CON220_SSM_MIRRORHDR_2X20IO1J501
FUSE_SMD050FUSE_RESETTABLE_FUSE_SMD050_IC_1AIC1F1
HDR2X4_TSM_SMCONN_HDR_4X2_HDR2X4_TSM_SM_IO_1HDR 2X4IO1J21
HDR5X2CONN_HDR_5X2_HDR5X2_IO_10.51MM_HDR 2X5IO1J13
HDR102CONN_HDR_2X1_HDR102_IO_8.71 MM_HDR 1X2 THIO4J12; J15; J17; J20
HDR103CONN_HDR_3X1_HDR103_IO_8.6MM_21HDR TH 1X3IO4J4; J5; J7; J11
HDR105_STAG_TSM_SM1X5HEADER_HDR105_STAG_TSM_SM_IOHDR_1X5IO2J8; J9
HDR203_TSM_SMCONN_HDR_3X2_HDR203_TSM_SM_IO_1HDR_2X3IO1J22
HDR207_TSM_SMCONN_HDR_7X2_HDR207_TSM_SM_IO_1HDR_2X7IO1J14
HDR_1X1CONN_HDR_1X1_TH_HDR_1X1_IO_8.89HDR_1X1IO2J6; J10
HDR_2X2_100_SM_5X5CONN_HDR_2X2_HDR_2X2_100_SM_5X5HDR 2X2IO5J1; J2; J16; J19; J23
IND_0603INDUCTOR_IND_0603_DISCRETE_0.95600OHMDISCRETE2L500; L501
IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHMDISCRETE2L1; L2
LED_0603LED_LED_0603_IC_1.0MM_370-76472YEL/GRNIC6D1; D3; D5; D7; D10; D12
LED_0603LED_LED_0603_IC_1.0MM_370-76471YELIC5D2; D4; D6; D8; D13
LED_0603LED_LED_0603_IC_1.0MM_370-76470AMBIC1D9
LQFP64MC56F8257VLF_LQFP64_IC_1.6 MM_3MC56F8257VLHIC1U2
MIC_RF_4P82X3P76MINI_MIC_RF_MIC_RF_4P82X3P76_ICSPM0408HE5H-SBIC1U4
QFP64_SOC_0P5_SQ29P6MC56F8257VLF_QFP64_SOC_0P5_SQ29MC56F8257VLF_SKT64LQFPIC1U3
RAPC722DC_POWER_JACK_3_RAPC722_IO_11.0CON_1_PWRIO1J3
RC0402_25RES_RC0402_25_DISCRETE_470-3078270DISCRETE1R1
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0KDISCRETE15R2; R3; R8; R9; R11; R12; R13; R14; R15; R554; R555; R561; R570; R574; R575
RC0402_25RES_RC0402_25_DISCRETE_470-764810MDISCRETE1R16
RC0402_25RES_RC0402_25_DISCRETE_470-7646330DISCRETE9R500; R501; R502; R503; R504; R507; R556; R558; R559
RC0402_25RES_RC0402_25_DISCRETE_470-3108158KDISCRETE2R505; R506
RC0402_25RES_RC0402_25_DISCRETE_470-30914.99KDISCRETE6R508; R509; R562; R569; R571; R576
RC0402_25RES_RC0402_25_DISCRETE_470-3045100DISCRETE41R510; R511; R512; R513; R514; R515; R516; R517; R518; R519; R520; R521; R522; R523; R524; R525; R526; R529; R530; R531; R532; R533; R534; R535; R536; R537; R538; R540; R541; R542; R543; R544; R545; R546; R547; R548; R549; R550; R551; R552; R553
RC0402_25RES_RC0402_25_DISCRETE__470-7601.0KDISCRETE3R527; R528; R563
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0KDISCRETE2R557; R564
RC0402_25RES_RC0402_25_DISCRETE_470-3014120DISCRETE1R560
RC0402_25RES_RC0402_25_DISCRETE_470-78352.2KDISCRETE1R565
RC0402_25RES_RC0402_25_DISCRETE_470-762353.6KDISCRETE2R566; R567
RC0402_25RES_RC0402_25_DISCRETE_470-757933DISCRETE2R572; R573
RC0603_OVTHERMISTOR_RC0603_OV_DISCRETE_410KDISCRETE4RT1; RT2; RT3; RT4
RC0805_OVRES_RC0805_OV_DISCRETE_470-75440DISCRETE5R4; R5; R7; R10; R568
RC0805_OVRES_RC0805_OV_DISCRETE_470-75951.0MDISCRETE1R6
RC0805_OVRES_RC0805_OV_DISCRETE_470-7545100DISCRETE1R539
SO8MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YMIC1U501
SO8PCA82C250A_SO8_IC_1.75MM_315-30PCA82C250TDIC1U503
SOD-123DIODE_TVS_SOD-123_IC_1MM_480-78SMF12AT1GIC1D11
SOD-123DIODE_SCHTKY_SOD-123_IC_1 MM_48MBR130LSFT1GIC1D500
SOIC1474-125_14P_SOIC14_IC_1.75MM_31274HCT125IC1U504
SOT23NPN_SOT23_IC_1.12 MM_480-75173_MMBT3904LT1GIC1Q1
SOT223LT1129CST-3.3_SOT223_IC_1.8MM_33.3VIC1U1
SOT-23BAT721B_SOT-23_IC_1.3MM_480-779BAT54CIC1D501
SOT_143SPB0503_SOT_143_IC_1.22MM_480-7SP0503BIC1U5
SW4_4MMSW_TACT-SPST-2_SM_SW4_4MM_IC_4.PB switchIC3SW1; SW2; SW3
TEST_LOOPTESTLOOP_TEST_LOOP_IO_4.8MM_210TEST POINT BLACKIO8TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8
TQFP44MC9S08JM60CFGE_TQFP44_IC_1.60 MMC9S08JM60CLDIC1U6
TSSOP1474LVC125_TSSOP14_IC_1.2MM_312-774LVC125IC1U505
TSSOP-1474_04_TSSOP-14_IC_1.2MM_312-753SN74LVC04APWE4IC2U500; U502
XTL2_237X79_CSMXTAL_XTL2_237X79_CSM_IC_4.3MM_28MHzIC1Y1
XTL2_ECS_CSM7_SMXTAL_XTL2_ECS_CSM7_SM_IC_4.3MM_4MHzIC1Y2
附件:
8 g; G1 ^: M0 y# E9 e# ^原理图和PCB文件如下:
  @. |2 v+ O+ W
游客,如果您要查看本帖隐藏内容请回复
2 C( B! q( e: d0 y% `" E
/ U! j/ I4 z0 N9 V# e2 k( g4 h6 o
GMT+8, 2025-7-23 14:33 , Processed in 0.125000 second(s), 27 queries , Gzip On.
