Bill of Material Report (Condensed) |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
BGA100P22X22_23X23X248-376 | TMS320DM6437ZDUQ6_BGA100P22X22_ | TMS320DM6437ZDUQ6 | IC | 1 | U2 |
C402-25 | CAP_C402-25_0.1UF/16V | 0.1uF/16V | IC | 160 | C33; C59; C60; C70; C72; C78; C92; C93; C98; C99; C112; C113; C114; C115; C119; C120; C122; C123; C124; C125; C126; C127; C128; C129; C130; C132; C134; C135; C136; C138; C140; C142; C143; C148; C150; C151; C153; C154; C162; C166; C167; C168; C169; C170; C171; C172; C174; C175; C177; C183; C185; C186; C187; C188; C189; C190; C200; C201; C202; C203; C204; C205; C206; C212; C213; C214; C215; C217; C220; C221; C222; C225; C232; C234; C238; C262; C270; C297; C308; C317; C350; C352; C355; C357; C358; C359; C363; C364; C366; C381; C382; C388; C389; C391; C392; C393; C406; C407; C408; C410; C412; C413; C414; C493; C504; C507; C511; C512; C513; C516; C517; C518; C519; C520; C521; C522; C523; C524; C530; C533; C534; C535; C536; C537; C538; C539; C540; C541; C542; C543; C544; C545; C548; C549; C551; C553; C554; C798; C800; C801; C802; C814; C820; C821; C822; C823; C828; C836; C837; C838; C844; C847; C852; C855; C858; C860; C862; C864; C865; C866 |
C402-25 | CAP_C402-25_27PF/50V | 27pF/50V | IC | 1 | C48 |
C402-25 | CAP_C402-25_0.01UF/16V | 0.01uF/16V | IC | 14 | C74; C76; C77; C79; C83; C552; C799; C829; C830; C831; C832; C833; C834; C849 |
C402-25 | CAP_C402-25_1000PF/50V | 1000pF/50V | IC | 3 | C91; C100; C101 |
C402-25 | CAP_C402-25_180PF/16V | 180pF/16V | IC | 8 | C216; C233; C242; C259; C263; C269; C274; C285 |
C603-35X45 | CAP_C603-35X45_1UF/16V | 1uF/16V | IC | 3 | C26; C90; C797 |
C603-35X45 | CAP_C603-35X45_10UF/10V | 10uF/10V | IC | 11 | C80; C82; C219; C229; C230; C235; C237; C239; C415; C416; C417 |
C603-35X45 | CAP_C603-35X45_0.1UF/50V | 0.1uF/50V | IC | 1 | C102 |
C603-35X45 | CAP_C603-35X45_10NF/100V | 10nF/100V | IC | 3 | C107; C108; C109 |
C603-35X45 | CAP_C603-35X45_0.01UF/50V | 0.01uF/50V | IC | 6 | C173; C184; C240; C241; C243; C244 |
C603-35X45 | CAP_C603-35X45_4.7NF/50V | 4.7nF/50V | IC | 1 | C176 |
C603-35X45 | CAP_C603-35X45_0.01UF/50V/NC | 0.01uF/50V/NC | IC | 1 | C182 |
C603-35X45 | CAP_C603-35X45_2.2UF/16V | 2.2uF/16V | IC | 5 | C191; C208; C271; C272; C298 |
C603-35X45 | CAP_C603-35X45_1UF/50V | 1uF/50V | IC | 4 | C397; C399; C795; C796 |
C603-35X45 | CAP_C603-35X45_0.22UF/16V | 0.22uF/16V | IC | 1 | C550 |
C603-35X45 | CAP_C603-35X45_4.7UF/6.3V | 4.7uF/6.3V | IC | 4 | C840; C841; C842; C843 |
CAPAE_DN | CAP_POL_CAPAE_DN_100UF/16V/10%/ | 100uF/16V/10%/105C | IC | 1 | C54 |
CAPAE_GN | CAP2_CAPAE_GN_100UF/63V/20%/105 | 100uF/63V/20%/105C | IC | 1 | C803 |
CAPC2_200_D500 | CAP_POL_CAPC2_200_D500_470UF/63 | 470uF/63V/20%/105C | IC | 2 | C1; C2 |
CHOKE4-59X34-ACM4528H | FILTER_TCE1210_SMD4_CHOKE4-59X3 | ACT45B-510-2P/NC | IC | 1 | FL3 |
CONN2X3-SMD-2D54 | CON3X2_CONN2X3-SMD-2D54_2X3PIN/ | 2X3PIN/2.54mm | IC | 1 | J13 |
CONN2X7-40X100-TSM | JUMP_0_CONN2X7-40X100-TSM_2X7PI | 2X7PIN/2.54mm/TSM-107-01-S-DV | IC | 1 | J4 |
CON_DJ7406 | DJ7406_CON_DJ7406_DJ7406S | DJ7406S | IC | 1 | J2 |
CON_SIP6_2D54MM | CON6_CON_SIP6_2D54MM_CON_1X6P_2 | CON_1x6P_2.54MM | IC | 1 | J20 |
DO-214AC_SMA | DIODE_SCHOTTKY_DO-214AC_SMA_B36 | B360A-13/3A/40V | IC | 1 | D19 |
FBGA84 | MT47H32M16_FBGA84_K4T1G164QF-BI | K4T1G164QF-BIE6 | IC | 2 | U112; U113 |
HOLE_3_8_MM | TP_0_HOLE_3_8_MM_3MMHOLE/NC | 3mmHOLE/NC | IC | 4 | HOLE1; HOLE2; HOLE3; HOLE4 |
L805-35X60 | INDUCTOR_L805-35X60_220/3A | 220/3A | IC | 10 | L14; L15; L16; L17; L18; L19; L20; L28; L29; L30 |
MSOP-10 | TPS54260_MSOP-10_TPS54260 | TPS54260 | IC | 1 | U28 |
PW16-14X70 | MAX3221_0_PW16-14X70_MAX3221IPW | MAX3221IPW/NC | IC | 1 | U65 |
QFN40P16X16X120-128 | TVP5158_QFN40P16X16X120-128_(S1 | TVP5158IPNP | IC | 1 | U96 |
QFN40_05MM_0606MMLTS_A | TPS65251_QFN40_05MM_0606MMLTS_A | TPS65251RHAR | IC | 1 | U3 |
QFP48_05MM_0707MML | KS8001_0_QFP48_05MM_0707MML_KSZ | KSZ8001LI | IC | 1 | U30 |
R402-25 | RES_R402-25_22_5% | 22_5% | DISCRETE | 87 | R13; R16; R17; R32; R37; R38; R39; R40; R41; R42; R43; R44; R45; R46; R47; R49; R54; R57; R58; R61; R64; R65; R66; R67; R68; R69; R70; R71; R72; R73; R74; R75; R76; R77; R78; R79; R80; R81; R82; R102; R103; R104; R105; R106; R107; R108; R351; R352; R353; R354; R355; R356; R357; R358; R359; R360; R361; R362; R363; R364; R365; R366; R367; R368; R369; R370; R371; R372; R373; R374; R375; R376; R377; R378; R379; R380; R381; R382; R383; R384; R385; R386; R663; R725; R726; R727; R728 |
R402-25 | RES_R402-25_200_5% | 200_5% | IC | 2 | R50; R51 |
R402-25 | RES_R402-25_1K_1% | 1K_1% | IC | 3 | R52; R241; R242 |
R402-25 | RES_R402-25_10K_5% | 10K_5% | IC | 20 | R53; R55; R60; R62; R63; R83; R89; R93; R94; R95; R264; R266; R322; R492; R684; R729; R730; R731; R732; R763 |
R402-25 | RES_R402-25_1K_5% | 1K_5% | IC | 6 | R59; R90; R91; R92; R117; R122 |
R402-25 | RES_R402-25_10K_5%/NC | 10K_5%/NC | IC | 17 | R85; R86; R119; R120; R123; R125; R126; R668; R669; R670; R679; R680; R681; R682; R683; R685; R686 |
R402-25 | RES_R402-25_2.2K_5% | 2.2K_5% | IC | 2 | R96; R97 |
R402-25 | RES_R402-25_0_5%/NC | 0_5%/NC | IC | 3 | R118; R121; R549 |
R402-25 | RES_R402-25_1K_5%/NC | 1K_5%/NC | IC | 6 | R124; R127; R128; R129; R130; R131 |
R402-25 | RES_R402-25_37.4_1% | 37.4_1% | IC | 4 | R184; R189; R191; R192 |
R402-25 | RES_R402-25_4.7K_5% | 4.7K_5% | IC | 7 | R269; R533; R537; R541; R551; R704; R705 |
R402-25 | RES_R402-25_4.7K_5%/NC | 4.7K_5%/NC | IC | 4 | R270; R271; R543; R550 |
R402-25 | RES_R402-25_22_5%/NC | 22_5%/NC | IC | 4 | R387; R388; R389; R390 |
R402-25 | RES_R402-25_0_5% | 0_5% | IC | 1 | R542 |
R402-25 | RES_R402-25_10_5% | 10_5% | DISCRETE | 1 | R664 |
R402-25 | RES_R402-25_1.5K_5% | 1.5K_5% | IC | 1 | R721 |
R402-25 | RES_R402-25_6.65K_1% | 6.65K_1% | IC | 1 | R722 |
R402-25 | RES_R402-25_330_5% | 330_5% | IC | 2 | R723; R724 |
R603-35X45 | DIODE BI-DIR TRIG_R603-35X45_SF | SFI0603-EA240-HSP | IC | 2 | D22; D23 |
R603-35X45 | RES_R603-35X45_0_5%/NC | 0_5%/NC | IC | 15 | R14; R204; R206; R654; R741; R742; R761; R762; R764; R765; R766; R767; R768; R769; R770 |
R603-35X45 | RES_R603-35X45_1.5K_1% | 1.5K_1% | IC | 1 | R48 |
R603-35X45 | RES_R603-35X45_51K_1% | 51K_1% | IC | 1 | R84 |
R603-35X45 | RES_R603-35X45_10K_1% | 10K_1% | IC | 1 | R87 |
R603-35X45 | RES_R603-35X45_4.7K_5% | 4.7K_5% | IC | 11 | R88; R194; R651; R707; R710; R716; R735; R736; R743; R749; R755 |
R603-35X45 | RES_R603-35X45_20K_5% | 20K_5% | IC | 1 | R110 |
R603-35X45 | RES_R603-35X45_240K_5% | 240K_5% | IC | 1 | R111 |
R603-35X45 | RES_R603-35X45_2K_5% | 2K_5% | IC | 4 | R205; R746; R752; R758 |
R603-35X45 | RES_R603-35X45_100_5% | 100_5% | IC | 8 | R213; R292; R298; R301; R304; R748; R754; R760 |
R603-35X45 | RES_R603-35X45_1K_5% | 1K_5% | IC | 11 | R231; R291; R297; R300; R302; R708; R715; R717; R747; R753; R759 |
R603-35X45 | RES_R603-35X45_3K_1% | 3K_1% | IC | 1 | R246 |
R603-35X45 | RES_R603-35X45_2K_1% | 2K_1% | IC | 2 | R247; R303 |
R603-35X45 | RES_R603-35X45_75_1% | 75_1% | IC | 5 | R263; R273; R276; R281; R538 |
R603-35X45 | RES_R603-35X45_0_5% | 0_5% | IC | 7 | R274; R305; R325; R326; R655; R659; R712 |
R603-35X45 | RES_R603-35X45_150K_1% | 150K_1% | IC | 1 | R336 |
R603-35X45 | RES_R603-35X45_180K_1% | 180K_1% | IC | 1 | R337 |
R603-35X45 | RES_R603-35X45_1.8K_1% | 1.8K_1% | IC | 1 | R627 |
R603-35X45 | RES_R603-35X45_18K_5% | 18K_5% | IC | 1 | R647 |
R603-35X45 | RES_R603-35X45_4.7K_5%/NC | 4.7K_5%/NC | IC | 2 | R653; R719 |
R603-35X45 | RES_R603-35X45_1K_5%/NC | 1K_5%/NC | IC | 1 | R711 |
R603-35X45 | RES_R603-35X45_2.4K_5% | 2.4K_5% | IC | 1 | R714 |
R603-35X45 | RES_R603-35X45_10K_5%/NC | 10K_5%/NC | IC | 2 | R718; R720 |
R1206-40X70 | RES_R1206-40X70_62_1% | 62_1% | IC | 2 | R539; R540 |
SC70-6 | OPA361A_0_SC70-6_OPA361-Q1 | OPA361-Q1 | IC | 1 | U110 |
SC0402 | CAP_SC0402_100PF/50V/NC | 100pF/50V/NC | IC | 3 | C5; C7; C45 |
SC0402 | CAP_SC0402_4700PF/50V | 4700pF/50V | IC | 3 | C6; C11; C31 |
SC0402 | CAP_SC0402_5600PF/50V | 5600pF/50V | IC | 3 | C8; C10; C28 |
SC0402 | CAP_SC0402_5600PF/50V/NC | 5600pF/50V/NC | IC | 3 | C12; C20; C24 |
SC0402 | CAP_SC0402_0.1UF/16V | 0.1uF/16V | IC | 5 | C13; C19; C27; C195; C226 |
SC0402 | CAP_SC0402_0.1UF/16V/NC | 0.1uF/16V/NC | IC | 2 | C228; C848 |
SC0603 | CAP_SC0603_10UF/10V | 10uF/10V | IC | 4 | C14; C32; C47; C313 |
SC0603 | CAP_SC0603_0.047UF/50V | 0.047uF/50V | IC | 4 | C15; C16; C22; C25 |
SC0603 | CAP_SC0603_0.01UF/50V | 0.01uF/50V | IC | 1 | C17 |
SC0603 | CAP_SC0603_0.022UF/50V | 0.022uF/50V | IC | 1 | C23 |
SC0603 | CAP_SC0603_0.1UF/50V | 0.1uF/50V | IC | 7 | C37; C39; C40; C41; C42; C43; C196 |
SC0603 | CAP_SC0603_0.01UF/50V/NC | 0.01uF/50V/NC | IC | 3 | C104; C111; C117 |
SC0603 | CAP_SC0603_10NF/100V | 10nF/100V | IC | 1 | C110 |
SC0805 | CAP_SC0805_10UF/16V | 10uF/16V | IC | 25 | C36; C38; C50; C51; C133; C178; C179; C180; C181; C192; C193; C194; C197; C198; C199; C207; C209; C210; C211; C850; C851; C853; C854; C856; C857 |
SC0805 | CAP_SC0805_10UF/16V/NC | 10uF/16V/NC | IC | 2 | C845; C846 |
SC1206 | CAP_SC1206_10UF/16V | 10uF/16V | IC | 11 | C18; C30; C35; C44; C46; C103; C105; C398; C859; C861; C863 |
SC1206 | CAP_SC1206_22UF/10V | 22uF/10V | IC | 3 | C21; C224; C227 |
SC1206 | CAP_SC1206_4700PF/50V | 4700pF/50V | IC | 1 | C218 |
SC1206 | CAP_SC1206_22UF/10V/NC | 22uF/10V/NC | IC | 1 | C223 |
SC1206 | CAP_SC1206_1000PF/2000V | 1000pF/2000V | IC | 2 | C817; C819 |
SL0603 | INDUCTOR_SL0603_1000/0.4A | 1000/0.4A | IC | 6 | L22; L23; L24; L25; L26; L33 |
SL0603 | INDUCTOR_SL0603_1000/0.4A/NC | 1000/0.4A/NC | IC | 2 | L31; L32 |
SLED0603 | LED_SLED0603_LED_GREEN_NORMAL_0 | LED_GREEN_NORMAL_0603 | IC | 4 | D10; D40; D41; D42 |
SO-8 | TMP75AIDR_SO-8_TMP75AIDR/NC | TMP75AIDR/NC | IC | 1 | U119 |
SOD323 | DIODE_DUAL_CA_JKK_2_SOD323_SED3 | SED323-3R30D0R4-A-11-LF/NC | IC | 2 | D1; D2 |
SOD323 | BTSS-2P_SOD323_TESD05FB | TESD05FB | IC | 11 | D12; D13; D14; D15; D47; D49; D50; D51; D57; D58; D59 |
SOD323 | BTSS-2P_SOD323_TESD05FB/NC | TESD05FB/NC | IC | 6 | D18; D43; D44; D45; D46; D48 |
SOD323 | BTSS-2P_SOD323_TESD03FB | TESD03FB | IC | 1 | D21 |
SOD323 | BTSS-2P_SOD323_TESD36FB | TESD36FB | IC | 2 | D52; D53 |
SOD323 | BTSS-2P_SOD323_TESD05FB_1 | TESD05FB | IC | 1 | D54 |
SOD323 | BTSS-2P_SOD323_TESD24FB/NC | TESD24FB/NC | IC | 2 | D55; D56 |
SOP8_50_150 | TJA1051_SOP8_50_150_TJA1042T/3 | TJA1042T/3 | IC | 1 | U111 |
SOP48_20_720A | K9F1G08_SOP48_20_720A_K9F1G08U0 | K9F1G08U0A-PCB0 | IC | 1 | U109 |
SOT23-3 | DS2411R_0_SOT23-3_DS2411R | DS2411R | IC | 1 | U98 |
SOT23_3 | BAS21_SOT23_3_BAS21 | BAS21 | IC | 3 | D27; D29; D34 |
SOT23_3 | BAS21_SOT23_3_BAS21/NC | BAS21/NC | IC | 2 | D30; D39 |
SOT23_3 | ESDA14V2L_SOT23_3_TESD05G2U/NC | TESD05G2U/NC | IC | 2 | DN1; DN2 |
SOT23_3 | NPN_SOT23_3_S9014 | S9014 | IC | 9 | Q5; Q13; Q14; Q16; Q17; Q19; Q21; Q23; Q25 |
SOT23_3 | PNP_SOT23_3_S9012 | S9012 | IC | 3 | Q6; Q15; Q18 |
SOT23_3A | NDS8434_0_SOT23_3A_IRLML5203TR | IRLML5203TR | IC | 4 | Q8; Q22; Q24; Q26 |
SOT23_3 | PNP_SOT23_3_S9012/NC | S9012/NC | IC | 1 | Q20 |
SOT23_5C | XM5081-ADJ_2_SOT23_5C_TPS62260T | TPS62260TDDCRQ1 | IC | 1 | U10 |
SOT23_5C | XM5081-ADJ_3_SOT23_5C_TPS79318D | TPS79318DBVRQ1 | IC | 1 | U12 |
SOT23_5C | 1G08_SOT23_5C_SN74LVC1G08DBVT | SN74LVC1G08DBVT | IC | 1 | U56 |
SOT23_5C | TLV431AIDBVR_0_SOT23_5C_TLV431A | TLV431AIDBVR | IC | 1 | U115 |
SOT23_5C | XM5081-ADJ_3_SOT23_5C_TPS7931_1 | TPS79318DBVRQ1/NC | IC | 1 | U129 |
SOT23_6 | SRV05-4_SOT23_6_TLSD05H4U | TLSD05H4U | IC | 1 | U127 |
SOT143 | MAX811_SOT143_MIC811TU | MIC811TU | IC | 1 | U128 |
SPL0303MM | IND_PWR_SPL0303MM_2.7UH-30%/1A | 2.7uH-30%/1A | IC | 1 | L8 |
SPL0707MM | IND_PWR_SPL0707MM_3.3UH/2.8A | 3.3uH/2.8A | IC | 3 | L1; L5; L6 |
SPL1212MMB | IND_PWR_SPL1212MMB_100UH/1.7A | 100uH/1.7A | IC | 2 | L2; L3 |
SPL_8_8_4P5 | IND_PWR_SPL_8_8_4P5_10UH/3.2A | 10uH/3.2A | IC | 1 | L7 |
SR0402 | RES_SR0402_20K_5% | 20K_5% | IC | 3 | R1; R3; R23 |
SR0402 | RES_SR0402_220K_5% | 220K_5% | IC | 1 | R2 |
SR0402 | RES_SR0402_120K_1% | 120K_1% | IC | 3 | R4; R5; R31 |
SR0402 | RES_SR0402_100K_5%/NC | 100K_5%/NC | IC | 1 | R20 |
SR0402 | RES_SR0402_10K_5% | 10K_5% | IC | 9 | R26; R36; R640; R642; R645; R649; R650; R709; R733 |
SR0402 | RES_SR0402_15K_5% | 15K_5% | IC | 1 | R27 |
SR0402 | RES_SR0402_0_5% | 0_5% | IC | 4 | R30; R132; R135; R138 |
SR0402 | RES_SR0402_33_5%/NC | 33_5%/NC | IC | 1 | R133 |
SR0402 | RES_SR0402_0_5%/NC | 0_5%/NC | IC | 1 | R142 |
SR0402 | RES_SR0402_2.2K_5% | 2.2K_5% | IC | 3 | R643; R706; R713 |
SR0603 | RES_SR0603_40.2K_1% | 40.2K_1% | IC | 3 | R8; R18; R22 |
SR0603 | RES_SR0603_29.4K_1% | 29.4K_1% | IC | 1 | R19 |
SR0603 | RES_SR0603_51K_1% | 51K_1% | IC | 1 | R21 |
SR0603 | RES_SR0603_12.7K_1% | 12.7K_1% | IC | 1 | R24 |
SR0603 | RES_SR0603_160_1% | 160_1% | IC | 1 | R25 |
SR0603 | RES_SR0603_30.1K_1% | 30.1K_1% | IC | 1 | R28 |
SR0603 | RES_SR0603_2K_1% | 2K_1% | IC | 1 | R29 |
SR0603 | RES_SR0603_33_1%/NC | 33_1%/NC | IC | 2 | R134; R137 |
SR0603 | RES_SR0603_49.9_1% | 49.9_1% | IC | 4 | R692; R693; R696; R697 |
SR0603 | RES_SR0603_75_1% | 75_1% | IC | 2 | R694; R695 |
SR1210 | RES_SR1210_0_5%/NC | 0_5%/NC | IC | 4 | R11; R745; R751; R757 |
SR1210 | RES_SR1210_0_5% | 0_5% | IC | 8 | R12; R737; R738; R739; R740; R744; R750; R756 |
SR2220 | DIODE BI-DIR TRIG_SR2220_SFI222 | SFI2220SA240-500J | IC | 2 | D31; D35 |
STC7343 | CAP_POL_STC7343_100UF/10V/10%/N | 100uF/10V/10%/NC | IC | 1 | C131 |
STFM16_50_280 | H1102_STFM16_50_280_11FB_05NL | 11FB_05NL | IC | 1 | U126 |
SX4_3225MM | CRYSTAL_22.5792MHZ_SX4_3225MM_2 | 25MHz | IC | 1 | Y4 |
SX4_3225MM | XO75NACU_SX4_3225MM_27.000000MH | 27.000000MHz | IC | 2 | Y8; Y9 |
TO-277A | BAS21_TO-277A_SS10PH10/10A/100V | SS10PH10/10A/100V | IC | 2 | D32; D33 |
TP_SMT | TP_TP_SMT_TP_SMT | TP_SMT | IC | 8 | 1V8_C; 1V1; 1V2; 1V8; 3V3; 5V; 12V; TP12 |
VQG64 | XC9572XL-7VQG64I_3_VQG64_XC9572 | XC9572XL-7VQG64I | IC | 1 | U123 |
附件:
