作品名:[AD 10][2层]检测商场标签信号功率控制板(L6388D+PC4D10SNIP0F+LM78L05) 原理图+PCB分享5 r. f1 Y; A0 ~
6 g: \$ e" B g) y文件描述 N/ h5 L( N* C' D$ s! w
1. 作品用途:检测商场标签信号功率控制板 / b+ K3 X- s( o# |) E
2. 软件版本:AD 10
6 B, L# {/ m+ {5 w8 q( M" `3. 层数:2层板
4 N0 d# W- t$ ^& p( m4. 用到的主要芯片:L6388D+PC4D10SNIP0F+LM78L05$ ?5 z/ }( y4 f# F' l
5. PCB尺寸:100mm*100mm
6 F& Z, t1 {7 U9 [+ @5 T/ A4 n( W# i! C/ a6 I. V
作品截图如下:" L/ F& K& N/ M3 X
顶层截图:/ T7 }! G, z- b# r3 w- z" w# E. y
- V0 ?4 F& {1 v1 g2 D2 a$ b
- ?( D4 }" Z$ d( ^+ @底层截图:
- h6 X- o N5 U# F! f' E
4 d A/ _* k8 a. g( d
. r7 Y* x) v% {7 ~( n* |
全层截图:0 n( y+ }1 ^6 y5 \
2 V0 r/ ^5 @- [3 t! ?$ Q' o6 A$ b
u! V, w' L7 I叠层信息截图如下:& `" j) e$ c7 V$ h" G1 B
. j! Y/ W; m* m0 o6 k; n
1 a4 ^- t% a2 _; q4 rBOM:" I' a* i$ P \# c
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 472J/2000V | C1, C5 | 472J/2000V | 2 | 101J/2000V | C2, C6 | 101J/2000V | 2 | 30pF/2000V | C3, C4, C7, C8 | CAP 5MM | 4 | 100nF | C9, C11, C13, C15, C16, C18, C19, C20, C27, C28, C29, C30, C31, C33, C39, C40, C42 | 0805C | 17 | 10nF | C10, C12, C14, C17 | 0805C | 4 | 1nF | C21, C22, C23, C24 | 0805C | 4 | 100uF/50V | C25 | CAPE5.0mm | 1 | 470uF/16V | C26, C41, C43, C45 | CAPE5.0mm | 4 | 100uF/16V | C32 | 7343C+ | 1 | 100nF/100V | C34 | CAP 5MM - F | 1 | 10nF/100V | C35 | CAP 5MM - F | 1 | 1nF/100V | C36 | CAP 5MM - F | 1 | 220uF/100V | C37 | CAPE 8MM | 1 | 1000uF/25V | C38 | CAPE 6.5MM | 1 | 100nF | C44 | 0603C | 1 | 1nF | C46 | 0603C | 1 | 0.1uF | C47 | 0603C | 1 | 1N4148 | D1, D2 | SOD-123 | 2 | STTH1L06A | D3, D4 | SMA-(DO-214AC) | 2 | 1N4007 | D5, D24, D27, D32 | SMA-(DO-214AC) | 4 | 1N5363B/30V/5W | D6 | SMC-(DO-214AB) | 1 | 1N5360B/25V/5W | D7 | SMB-(DO-214AA) | 1 | LED | D8, D9, D10, D11, D12, D13, D14, D15, D16, D17, D18, D19, D20, D21, D22, D23 | 0805D | 16 | SK34 | D25, D29 | SMA-(DO-214AC) | 2 | +5V | D26, D28, D30, D31, D33, D34 | 0805D | 6 | Comment | Designator63 | logo | 1 | ISP_10 | ISP1 | HEADER_5x2 | 1 | JP2 | JP1, JP2 | HEADER_2 | 2 | HEADER_3 | P1, P2 | KF-5.08-3P | 2 | Header 7X2A | P3 | HDR2X7_CEN | 1 | Header 7 | P4 | KF-5.08-7P | 1 | G40N60 | Q1, Q2, Q3, Q4 | IGBT_OP | 4 | 0.2R/10W | R1, R2 | 0R1*2/5W | 2 | 150K | R3, R4, R5, R6, R7, R8, R9, R10, R11, R12 | 1206 | 10 | 8.2K | R13, R15 | 1206 | 2 | 1M | R14, R16, R17, R26 | 0805R | 4 | 2.2K | R18, R19, R20, R21, R22, R23, R24, R25, R28, R29, R30, R31, R32, R33, R34, R35 | 1206 | 16 | 12R | R27, R37 | 0805R | 2 | 10K | R36, R38, R65, R73 | 0805R | 4 | 300R | R39, R40, R41, R42, R43, R44, R45, R46 | 0805R | 8 | 0R | R47 | 1206 | 1 | 100R | R48, R67, R69 | 1206 | 3 | 2K | R49, R50, R51, R52, R53, R54, R55, R56, R57, R58, R59, R60, R61, R62, R63, R64, R70, R71 | 0805R | 18 | 0R | R66 | 0805R | 1 | 1K | R68 | 0805R | 1 | 4K7 | R72 | 0805R | 1 | 20K | R74 | 0805R | 1 | 10K | R75, R76, R77, R79 | 0603R | 4 | 1K | R78 | 0603R | 1 | TP(no pop) | TP1, TP2, TP3, TP4 | 定位孔3.2MM | 4 | L6388D | U1, U2 | SOIC-8N | 2 | PC4D10SNIP0F | U3, U4 | SO8 | 2 | LM78L05 | U5 | SOIC-8-L | 1 | ATmega48V-10AU | U6 | LQFP-32 | 1 | LM7805 | U7, U8 | TO-263-2 | 2 | AMS1117 | U9 | SOT-223 | 1 | LM358_B | U10 | SOIC-8N | 1 | TLC5615C | U11 | SOIC-8N | 1 |
! U# J3 Q5 k s. x+ t附件:, W! }# J$ m. r1 M4 [/ O( t
原理图和PCB源文件如下:
* P& j1 e3 v. R: E4 Z0 H9 B
+ R( x1 M! |6 S- m0 e, M- `; X( I' ]( p7 v, t
