作品名:[AD 10][2层] 一款路由器(MT7620N+IT-7652+BTA1664M3)PCB源文件. F& P: k( Q! }
- C* P+ [- m% c. \
文件描述3 u$ ]' l+ e" e: k( f) L3 d
1. 作品用途:路由器
& a2 q/ P. r+ c" M9 z2. 软件版本:AD 105 ^$ F1 K. U! R7 Z
3. 层数:2层板
1 m9 R- x0 E( X; V; y4. 用到的主要芯片:MT7620N+IT-7652+BTA1664M3
, f5 \$ ~1 G, L4 `/ I5. PCB尺寸:170mm*164mm; Y3 n" E+ H6 [8 u5 Z* i+ O% z
p) |8 k& k) F作品截图如下:7 m5 s# B5 Z1 |: r4 o0 R6 M
顶层截图:6 ?* `; R9 V! W% _1 Q- t4 n
( c$ ]# w1 n/ Z# @0 w5 V7 B底层截图:3 o( ]9 c! e6 P/ U4 j5 u% }2 q$ W
" O; l: t# V' Z* I全层截图:1 K! \' A( l0 j" h7 s) l" u* K
5 B* S+ h, s5 M E' v+ B叠层信息截图如下:* z1 X" k; w2 V) _6 i( A) E+ }
. L* U1 @# {( s8 o2 h; k
BOM:6 q+ m l8 E- E0 H9 `( @% c
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 220uF/25V | C1 | C220UF25V/D8H11 | 1 | 1uF/NI | C2 | C0402/FCS | 1 | 4.7uF/NI | C3, C213, C217, C222 | C0603/FCS | 4 | 1uF | C5, C9, C74, C98, C103, C104, C107 | C0402/FCS | 7 | 0.1uF/NI | C6, C17, C22, C29, C43, C50, C55, C69, C106, C135, C137, C168, C169, C170, C171, C172, C173, C174, C178, C212 | C0402/FCS | 20 | 4.7uF/NI | C8, C25, C28, C48, C136 | C0805 | 5 | 10pF | C10, C92, C95, C102, C109, C129, C130, C131, C133, C141, C148, C175, C220, C221, C224 | C0402/FCS | 15 | 220uF | C11, C16 | C220UF25V/D8H11 | 2 | 0.1uF | C14, C19, C36, C39, C40, C44, C51, C54, C70, C72, C75, C77, C91, C111, C112, C114, C115, C121, C134, C166, C179, C180, C211 | C0402/FCS | 23 | 10nF/NI | C15 | C0402/FCS | 1 | 0.1uF/25V/NI | C18 | C0402/FCS | 1 | 8.2nF | C20 | C0402/FCS | 1 | 680pF/NI | C21 | C0402/FCS | 1 | 100pF/NI | C23 | C0603/FCS | 1 | 1uF | C26 | C0603/FCS | 1 | 1uF/NI | C27 | C0603/FCS | 1 | 4.7uF | C30, C73 | C0805 | 2 | 4.7nF | C31 | C0402/FCS | 1 | 10uF | C33, C34 | C0805 | 2 | 3.9nF | C37 | C0402/FCS | 1 | 100pF | C38, C124 | C0402/FCS | 2 | 4.7uF | C41, C53, C56, C93, C110, C126 | C0603/FCS | 6 | 1nF | C58, C132, C167 | C0402/FCS | 3 | NI | C76, C82, C239 | C0402/FCS | 3 | 0.22uF | C78 | C0402/FCS | 1 | 100pF/NI | C83 | C0402/FCS | 1 | 22pF | C84, C89 | C0402/FCS | 2 | 1.2pF | C85, C90 | C0402/FCS | 2 | 0.8pF | C86 | C0402/FCS | 1 | 10nF | C94 | C0402/FCS | 1 | 1.8nH | C96, C105, C140 | C0402/FCS | 3 | 1pF/NI | C101, C235 | C0402/FCS | 2 | 33pF | C108 | C0402/FCS | 1 | 1000pF/2KV/NI | C113, C123 | C1206 | 2 | 0 ohm/SB | C116, C117, C118, C119, C120, C122, C125, C216, L1, R258 | SB/1206 | 10 | 10PF/NI | C127 | C0402/FCS | 1 | 2pF | C143 | C0402/FCS | 1 | 1.5pF | C144, C181, C182, C240 | C0402/FCS | 4 | 1.5pF/NI | C145, C150 | C0402/FCS | 2 | 3.9pF | C147 | C0402/FCS | 1 | 1.8pF/NI | C183, C184 | C0402/FCS | 2 | 10uF | C210, C218 | C0603/FCS | 2 | 0 ohm | C225, C231, C232, C237, C241 | C0402/FCS | 5 | 2.2pF | C226 | C0402/FCS | 1 | 0.3pF/NI | C228, C236 | C0402/FCS | 2 | 1pF | C229 | C0402/FCS | 1 | 2.7pF | C233 | C0402/FCS | 1 | 0 ohm/NI | C238 | C0402/FCS | 1 | TVS SMCJ16A/NI | D1 | D/SMD/P6.9/DO-214AB | 1 | V-PORT/NI | D3, D4 | C0603/FCS | 2 | LED | D6, D7 | D02 | 2 | LED | D8, D9, D10, D11, D12 | LED/2P/SMD/0603/LT8A22-54-UR86-T5 | 5 | 1N4148/NI | D13, D38 | R0402/FCS | 2 | LED/NI | D39, D40 | LED/2P/SMD/0603/LT8A22-54-UR86-T5 | 2 | AP_ANT3 | E0 | ANT/AP/MT7620/2P/T2 | 1 | AP_ANT3 | E1 | ANT/AP/MT7620/3P/T1 | 1 | FD | H1, H2, H3, H8 | FD | 4 | DC JACK/TC18-041-05 | J1 | DCJACK/DIP/3P/TC18-041-05 | 1 | HEADER 4x1 | J2 | DIP4/P2.54 | 1 | SW PUSH-SPDT-dual/NI | J4 | SW/6P/DIP/M-B2PL-A | 1 | 15uH/GDR0810PU150K | L3 | L/IND/DIP/GDR0810 | 1 | 4.7uH/ZAH-5040U | L4 | L/CHOKE/SMD/ZAH-5040U | 1 | 3.9nH | L5, L12 | L0402/FCS | 2 | 1.8nH | L6, L8 | L0402/FCS | 2 | 1.2pF | L9, L11 | L0402/FCS | 2 | 3.3nH | L15, L16 | L0402/FCS | 2 | 1pF | L17, L18 | L0402/FCS | 2 | WBR6HN/NI | L37, L38 | L_D6H14 | 2 | O130 | O2, O3 | O130 | 2 | 0 ohm/NI | R3 | R0805 | 1 | 100K | R6 | R0402/FCS | 1 | 0 ohm | R8, R55, R56, R64, R73, R91, R92, R159, R354, R368 | R0402/FCS | 10 | 39K 1% | R9 | R0402/FCS | 1 | 100 ohm/NI | R10 | R0603/FCS | 1 | 15K 1% | R11 | R0402/FCS | 1 | 3K 1% | R12 | R0402/FCS | 1 | 10pF | R13 | R0402/FCS | 1 | 5pF/NI | R15, UC1, UC2 | R0402/FCS | 3 | 47K | R16 | R0402/FCS | 1 | 22 | R18, SR1 | R0402/FCS | 2 | 51K/NI | R19 | R0402/FCS | 1 | 24K/NI | R20 | R0402/FCS | 1 | 2K 1% | R21, R24 | R0402/FCS | 2 | 68 ohm 1% | R22 | R0402/FCS | 1 | 4.7K 1% | R26 | R0402/FCS | 1 | 0 ohm/SB | R27, R28 | SB/0402 | 2 | 6.19K 1% | R42 | R0402/FCS | 1 | 8.2K 1% | R51 | R0402/FCS | 1 | 4.7K ohm | R52, R53, R126, R127, R130, R131, R132, R135, R136, R137, R140, R149 | R0402/FCS | 12 | 1K ohm | R54 | R0402/FCS | 1 | 22 ohm/NI | R102 | R0402/FCS | 1 | 22 ohm | R103 | R0402/FCS | 1 | 24K 1% | R107 | R0402/FCS | 1 | 100 | R108 | R0402/FCS | 1 | 75 | R109, R112, R115, R118, R121 | R0402/FCS | 5 | 4.7K/NI | R125, R138, R139, R142 | R0402/FCS | 4 | 4.7K | R148, R170 | R0402/FCS | 2 | 120 | R150 | R0402/FCS | 1 | 10K | R151, SR2 | R0402/FCS | 2 | 330 | R155, R158, R160, R163, R165, R166, R167 | R0402/FCS | 7 | 0 ohm/NI | R210, R371, R827 | R0402/FCS | 3 | 0 ohm | R356, R829, R830 | R0805 | 3 | 0 ohm | R366 | R0603/FCS | 1 | 330/NI | R372 | R0402/FCS | 1 | 300 ohm/NI | R824, R826 | R0402/FCS | 2 | 0 ohm | R828 | R1206 | 1 | 4.7uF | RC2 | R0805 | 1 | RN42-0R | RN1, RN2, RN3, RN4, RN5, RN6, RN7, RN8, RN9 | RN0402/SMD | 9 | SW/4P/DIP/TC-1008 | S2, S3 | SW/4P/DIP/TC-1008 | 2 | TP-SMD | TP1, TP2 | TP-SMD | 2 | TP-SMD | TP4, TP5, TP6, TP7 | TP/ANT/RFTP50 | 4 | MT7620N | U1 | MT7620/TMP/DR-QFN/0426 | 1 | IT-7652 | U3 | SOP8/SMD/P1.27/FR9888 | 1 | AP2127/NI | U5 | SOT23-5 | 1 | APM2701AC | U6 | SOT-23-6/SMD/P0.95/APM2701AC | 1 | BTA1664M3 | U8 | SOT89/SMD | 1 | AT24C04A/SB/NI | U9 | SOIC8/SMD/P1.27/S | 1 | XTAL/3.2x2.5/20MHz/NI | U11 | CRYS/SMD/D3.2X2.5/E3SB40/HOSONIC | 1 | HN2066CG | U12, U14 | TRANSFORMER/20P/DIP/HN2066CG | 2 | RJ45/DIP/32P/52-1X4-4C-00 | U13 | RJ45/8X4/DIP/41359-01G091/GLGENT | 1 | RJ45/DIP/8P/52-8P4C-02 | U15 | RJ45/8P/DIP/41349-03G091/GLGENT | 1 | hn1674CG | U16 | TRANSFORMER/16P/DIP/HN1674CG | 1 | 32Mx16,512Mb,TSOP66/NI | U17 | SOP66/11.8/0.65 | 1 | MX25L1606EM2I-12G | U18 | SOP8/SMD/P1.27/MX25L1605D | 1 | G693L_R3132Q/NI | U23 | SOT-143/SMD/G693 | 1 | 20MHZ | U33 | CRYS/DIP/D5X10.6/GB2000025/ECERA | 1 | SDRAM 16MX16 | U34 | TSOP54/SMD/P0.8/M12L64164A | 1 | USB/4P/DIP/A/F/601020041130G | USB1 | USB/4P/DIP/A/F/601020041130G | 1 | 附件:$ s: D3 ?3 S2 k. m
PCB源文件如下:
5 w1 y+ X5 Q' C/ Z
. Z) |8 o. ?* E8 l C7 ^8 F# F8 Y. ] `( h# [; G& @
