作品名:[AD 10][2层] 开发板底板(JR0325A0_QFN64_4_QFN64-9X9_JMB3+CM2020+NB638)PCB源文件. G# i, V+ ^+ X' ~/ G# U! Q$ q; }! G
. f1 W9 ~, l6 g1 L: v文件描述
3 `4 A _1 \- \+ J3 s1. 作品用途:开发板底板
8 Y! O3 [4 [; J o* n" R+ S0 D0 L2. 软件版本:AD 10
& f* U9 L! `" @5 s. }3. 层数:2层板% \# u' \- m7 ^6 D% t
4. 用到的主要芯片:JR0325A0_QFN64_4_QFN64-9X9_JMB3+CM2020+NB638
, {* v9 C3 }; h/ ^$ Q h5. PCB尺寸:190mm*188mm
+ S0 O+ I; A6 U$ T6 }, N* K5 C E; J2 `5 A, f. d' c
作品截图如下:7 W& c. v5 S- T( M( Q* ^( G, C
顶层截图:" k5 q+ K) ?" |# j( Q' D' f; r
* {/ r r0 _2 L8 R8 }; x7 o底层截图: p8 `* A9 I" j! I
% r2 R4 U, }; S# r. K' m
全层截图:4 g2 A+ `, c0 h9 E2 m- q- |
) l- @- `9 D9 }9 K: ]) V' U叠层信息截图如下:$ x2 Y: L+ r" N% G
& M1 U, z* S& a: a0 S* z( I! ^7 K
BOM:/ m) m, R( |8 n. }
Comment(数量) | Designator(位号) | Footprint(封装) | Quantity(数量) | BAT_SOCK-2032_CR2032HE_2032 | BT1 | CR2032HE | 1 | BUZZER_BUZZER_BUZZER | BZT1 | BUZZER | 1 | C_0603C_0603C_0.1UF | C1, C2, C3, C4, C7, C8, C9, C22, C78, C141, C142 | 0603C | 11 | EC_CE20-10_CE10-5_1000UF | C5, C6, C11, C65 | CE10-5 | 4 | D-CE-10UF20%-50V-10/20_CE10-20_ | C10 | CE10-20 | 1 | 10UF+80%/-20%-0805-Y5V-10V_0805 | C12, C13, C15, C16, C17, C20, C28, C36, C37, C38, C135, C137, CT69, CT72 | 0805C | 14 | 100NF10%-0603-X7R-50V_0402C_100 | C14, C19, C23, C24, C25, C26, C31, C32, C33, C34, C39, C40, C42, C43, C44, C45, C47, C50, C52, C53, C55, C56, C57, C61, C62, C63, C64, C66, C67, C68, C69, C70, C72, C73 | 0402C | 34 | 10UF+80%/-20%-0805-Y5V-10V_0402 | C18, C21 | 0402C | 2 | 1UF+80%/-20%-0603-Y5V-16V_0603C | C27, C35, CT2, CT56, CT59, CT63, CT67 | 0603C | 7 | EC_CE20-10_CE10-5_1000UF/16V | C29 | CE10-5 | 1 | D-CE-1000UF20%-16V-20/40_CE20-4 | C30, C71, CE1, CE3, CE5, CE12, CE15 | CE20-40 | 7 | 27PF5%-0603-COG-50V_0603C_27P50 | C41, C46, C54, C60 | 0603C | 4 | 100NF+80-20%-0603-Y5V-50V_0603C | C48, C74, C79, C83, C90, C94, C99, C116, C120, C128, C129, C130, C131, C133, C134, C136, C140, C365, C367, C368, C369, C370, C553, C556, C566, C571, C572, CB2, CB14, CT26, CT44, CT53, CT57, CT58, CT61, CT62, CT64, CT66, CT74, CT78, CT81, CT84, CT87, CT88, CT89, CT90, CT91 | 0603C | 47 | 100NF10%-0603-X7R-50V_0603C_100 | C49, C59, C124, C125, C126, C127, C138 | 0603C | 7 | 10UF+80%/-20%-1206-Y5V-25V_1206 | C51, C58, C81, C92, C97, C98, C115, C117, C118, C380, C381, C384, C385, C565 | 1206C | 14 | 10UF+80%/-20%-1206-Y5V-25V_12_2 | C75, C76 | 1206C | 2 | D-CE-10UF20%-50V-10/20_CE10-2_1 | C77 | CE10-20 | 1 | 100NF+80-20%-0603-Y5V-50V_060_1 | C80, C89, C93, C119, C121, C559 | 0603C | 6 | 10NF10%-X7R-0603-50V_0603C_10N5 | C82, C91, C96, C100, C123, CT3, CT4, CT5, CT6, CT7, CT8, CT9, CT10, CT11, CT12, CT13, CT14, CT15, CT16, CT17, CT18, CT19, CT20, CT21, CT22, CT23, CT24, CT25, CT27, CT28, CT29, CT30, CT31, CT32, CT33, CT34, CT35, CT36, CT37, CT38, CT39, CT40, CT41, CT42, CT43, CT45, CT46, CT47, CT48, CT49, CT50, CT51, CT52, CT86 | 0603C | 54 | 100NF10%-0603-X7R-50V_0603C_N_4 | C84 | 0603C | 1 | 100NF10%-0603-X7R-50V_0603C_N_3 | C85, C568 | 0603C | 2 | 100NF10%-0603-X7R-50V_0603C_N_2 | C86, C564, C569 | 0603C | 3 | 100NF10%-0603-X7R-50V_0603C_NC_ | C87, C561 | 0603C | 2 | 100NF10%-0603-X7R-50V_0603C_N_1 | C88, C563 | 0603C | 2 | 100NF+80-20%-0603-Y5V-50V_060_2 | C95 | 0603C | 1 | 3.3NF10%-0603-X7R-50V_0603C_3.3 | C122, CT70 | 0603C | 2 | 10UF10%-1206-X5R-25V_1206C_10U2 | C132, CB1, CT1, CT54, CT55, CT65, CT68, CT75, CT77 | 1206C | 9 | CAP_0603C_1206C_1000PF/2KV | C139 | 1206C | 1 | 1UF+80%/-20%-0603-Y5V-25V_0603C | C531 | 0603C | 1 | 10UF+80%/-20%-1206-Y5V-25V_12_1 | C570 | 1206C | 1 | 3.3NF10%-0603-X7R-50V_0603C_100 | C906, C907 | 0603C | 2 | 10PF5%-0603-COG-50V_0603C_4.7NF | C908, C913 | 0603C | 2 | 10PF5%-0603-COG-50V_0603C_33P50 | C909, C911 | 0603C | 2 | 10PF5%-0603-COG-50V_0603C_470P5 | C910, C912 | 0603C | 2 | 10PF5%-0603-COG-50V_0603C_10P50 | CB3, CB4, CB5, CB6, CB11 | 0603C | 5 | 100NF+80-20%-0603-Y5V-50V_060_3 | CB13 | 0603C | 1 | D-CE-220UF20%-25V-16/32_CE8-3_5 | CE2 | CE8-3_5 | 1 | D-SCON-6-1.25S_SIP6-1_27S_SIP6- | CN1 | SIP6-1_27S | 1 | D-SATA-DIP7A_0_SATA7-1_27B_SATA | CNT1, CNT2, CNT3, CNT4, CNT5, CNT6, CNT7, CNT8, CNT9, CNT10 | SATA7-1_27B | 10 | D-CE-1000UF20%-25V-20/40_CE10-5 | CT60 | CE10-5 | 1 | 150PF10%-X7R-0603-50V_0603C_150 | CT71 | 0603C | 1 | 2.2UF+80-20%-0603-Y5V-10V_0603C | CT73 | 0603C | 1 | D-CE-1000UF20%-16V-20/40_CE10-5 | CT76 | CE10-5 | 1 | D-CE-1000UF20%-25V-20/40_CE20-4 | CT79 | CE20-40 | 1 | D-CE-100UF20%-16V-10/20_CE10-20 | CT80, CT85 | CE10-20 | 2 | D-CE-10UF20%-50V-10/20_CE10-2_2 | CT83 | CE10-20 | 1 | S-S-DIODE-1N5819-1206_1206D_1N5 | D1, D50, D51, D53, D54, D55, D56, D57, D58, D59, D60, D61, D62, D63, D64, D65, D66 | 1206D | 17 | D_DMMELF_DMMELF_1N4148 | D2, D3 | DMMELF | 2 | S-DIODE-1N4148-1206_DMMELF_1N41 | DT1, DT2, DT3, DT4 | DMMELF | 4 | MARK_MASK1_MARK | FJ1, FJ2, FJ3, FJ4, FJ5, FJ6, FJ7, FJ8 | MASK1 | 8 | HOLE40-8STAR-000_HOLE41-8STAR_H | H1, H2, H3, H4, H5, H6, H7, H8 | HOLE41-8STAR | 8 | CON4_IDEPWR_0_IDEPWR_IDEPWR | J1 | IDEPWR | 1 | D-ATX-2X10-3.5MS_ATX-POWER20A_H | J2 | ATX-POWER20A | 1 | D-SCON-45-2_10.0S_BLOCK_3531T_H | J3 | BLOCK_3531T | 1 | HEADER 8X2_IDC16-2_54AR_IDC16-3 | J4, J5 | IDC16-3_81AR | 2 | RJ45A_RJ45A_RJ45 | J6 | RJ45A | 1 | USBS_0_USB-H-A_USBS_NC | J7 | USB-H-A | 1 | HDMI | J8 | HDMI_RX_CON_SMD | 1 | D-SCON-45-2_9.0S_BLOCK_3531B_HI | J9 | BLOCK_3531B | 1 | D-BNCX1S_BNC-5_BNCX1S | J15 | BNC-5 | 1 | D-RELAY-HLS6-4100-DC5V_HLS6_410 | JK1, JK2, JK3, JK4 | HLS6_4100H | 4 | D-SCON-2-2.54S_SIP2-2_5A_CON2 | JT1, JT3, JT6 | SIP2-2_5A | 3 | D-SCON-10-2.54S_SIP10-2_5A_CON1 | JT2 | SIP10-2_5A | 1 | D-SCON-4-5.08S_IDEPWR_IDEPWR | JT4 | IDEPWR | 1 | D-DHD-2X20-2.54MS_IDC40-2_54A_H | JT5 | IDC40-2_54A | 1 | D-SCON-4-2.54S_SIP4-2_5A_CON4 | JT7 | SIP4-2_5A | 1 | D-SCON-2-7.5S_SIP2-7_5_TERMINAL | JT9 | SIP2-7_5 | 1 | D-SCON-3-2_54S_SIP3-2_5A_CON3_S | JT10 | SIP3-2_5A | 1 | D-CON-USB_SOCKET-AB_USB-H-A_USB | JT11 | USB-H-A | 1 | D-CON-DC005_POWERJACK_POWERJACK | JT12 | POWERJACK | 1 | S-INDUC-0603L-120R_0603L_120R@1 | L1, L2, L7 | 0603L | 3 | S-INDUC-0805L-600R_0805L_600R@1 | L3, L4 | 0805L | 2 | IND_MSS1278_1_LS-SB0560_4UH/20A | L5, L53 | LS-SB0560 | 2 | D-INDUC-LH810-10UH_LD8_5-5_LH81 | L6 | LD8_5-5 | 1 | S-INDUC-0603L-120R_0603L_120R_1 | L8 | 0603L | 1 | S-INDUC-SCDH127-12X12-10UH_SCDH | L9, L11 | SCDH127_6X4 | 2 | S-INDUC-0603L-120R_0603BL_120R@ | LB1, LB3 | 0603BL | 2 | S-INDUC-0805L-600R_0805BL_600R@ | LB2, LB4, LB5, LB6, LB7, LB9 | 0805BL | 6 | S-INDUC-0603L-120R_0603BL_120_1 | LB8 | 0603BL | 1 | S-LED-NLGREEN-0603_0603LED_GREE | LED1, LED2, LED3, LED4, LED5, LED6, LED7, LED8, LED9, LED10 | 0603LED | 10 | S-LED-HLRED-0603_0603LED_RED-06 | LED11 | 0603LED | 1 | S-LED-HLRED-0603_0603LED_NC_RED | LEDT1 | 0603LED | 1 | D-PTC-30V-4A-RAD0.2_PTC-D_10_5_ | PTC1 | PTC-D_10_5 | 1 | D-PTC-250V-0.12A-RAD0.2_RAD2_JK | PTCT1, PTCT2 | RAD2 | 2 | S-NPN-MMBT3904-SOT23_SOT23_MMBT | Q1, Q2, Q3, Q4, Q5, Q6, Q7, Q8, Q9, Q11, Q13, Q14 | SOT23 | 12 | MOSFET_P_SOT23_SOT23_IRLML6401T | Q10 | SOT23 | 1 | MOSFET_P_SOT23_SOT23_IRLML6402P | Q12 | SOT23 | 1 | S-NPN-MMBT3904-SOT23_SOT23_S805 | QT1 | SOT23 | 1 | S-NPN-MMBT3904-SOT23_SOT23_MM_1 | QT2, QT3, QT4, QT5, QT6 | SOT23 | 5 | 330R5%-0603-1/10W_0603R_330R5%1 | R1, R2, R3, R4, R5, R6, R7, R8, R9, R10 | 0603R | 10 | 4.7K5%-0603-1/10W_0603R_4.7K5%1 | R11, R12, R13, R14, R15, R16, R17, R18, R19, R31, R33, R35, R42, R43, R44, R45, R46, R47, R74, R79, R99, R102, RT3, RT35 | 0603R | 24 | R_0603R_0603R_10K | R20, R24, R25, R29 | 0603R | 4 | 0R5%-0603-1/10W_0603R_0R5%1/10W | R21, R26, R73, R126, R145, R146, R149, R392, RT17, RT32 | 0603R | 10 | 10K5%-0603-1/10W_0603R_10K5%1/1 | R22, R27, R30, R32, R106, R107, R108, R109, R165, R786, R789, R791, R793, R795, R797, R799, R801, R803, R805, R807, R809, R811, R813, R815, R817, RT5, RT12, RT34, RT36, RT37 | 0603R | 30 | 1K1%-0603-1/10W_0603R_1K1%1/10W | R23, R28 | 0603R | 2 | 4.7K1%-0603-1/10W_0603R_12K1%1/ | R34, R38 | 0603R | 2 | 0R5%-0603-1/10W_0603R_NC_0R5%1/ | R36, R37, R143, R144, R164, RB1 | 0603R | 6 | 1M5%-0603-1/10W_0603R_1M5%1/10W | R39, R41 | 0603R | 2 | 1K5%-0603-1/10W_0603R_1K5%1/10W | R40, RT1, RT6, RT9, RT10, RT23, RT24, RT25, RT26, RT40 | 0603R | 10 | 22R5%-0603-1/10W_0603R_NC_200K5 | R48, R78 | 0603R | 2 | 22R5%-0603-1/10W_0603R_NC_4.7R5 | R49, R87 | 0603R | 2 | 1K1%-0603-1/10W_0603R_2K1%1/10W | R50 | 0603R | 1 | 4.7K1%-0603-1/10W_0603R_NC_10K1 | R51, R588 | 0603R | 2 | 470R5%-0603-1/10W_0603R_2.1K 1% | R52 | 0603R | 1 | 10K5%-0603-1/10W_0603R_NC_10K5% | R53 | 0603R | 1 | 47K5%-0603-1/10W_0603R_NC_1M5%1 | R55, R583 | 0603R | 2 | 100K5%-0603-1/10W_0603R_NC_100K | R56, R1073 | 0603R | 2 | 4.7K1%-0603-1/10W_0603R_NC_2K1% | R57 | 0603R | 1 | 10K1%-0603-1/10W_0603R_10K1%1/1 | R58, R66, R67, R97 | 0603R | 4 | 51K5%-0603-1/10W_0603R_10K5%1/1 | R59, R93 | 0603R | 2 | 2.2K5%-0603-1/10W_0603R_2.2K5%1 | R60, R61, R62, R64, R98, R161, R162, RT41 | 0603R | 8 | 51K5%-0603-1/10W_0603R_27K5%1/1 | R63 | 0603R | 1 | 6.19K1%-0603-1/10W_0603R_6.19K1 | R65 | 0603R | 1 | 4.7K5%-0603-1/10W_0603R_NC_4.7K | R76, R100, R101, R278 | 0603R | 4 | 4.7K1%-0603-1/10W_0603R_NC_0R%1 | R84 | 0603R | 1 | 51K5%-0603-1/10W_0603R_20K5%1/1 | R94 | 0603R | 1 | 5.6K5%-0603-1/10W_0603R_5.6K5%1 | R95 | 0603R | 1 | 4.7K1%-0603-1/10W_0603R_4.7K1%1 | R96 | 0603R | 1 | R_0603R_0603R_470R | R150 | 0603R | 1 | 100K5%-0603-1/10W_0603R_100K5%1 | R151, RT14, RT15 | 0603R | 3 | 2K5%-0603-1/10W_0603R_2K5%1/10W | R152, R153, RT2, RT11 | 0603R | 4 | R_0603R_0805R_75R | R154, R155, R156, R157 | 0805R | 4 | 47K5%-0603-1/10W_0603R_47K5%1/1 | R158 | 0603R | 1 | 20K5%-0603-1/10W_0603R_27K5%1/1 | R159 | 0603R | 1 | 0R5%-0805-1/8W_0805R_NC_0R5%1/8 | R160 | 0805R | 1 | R_0603R_0603R_330R | R163 | 0603R | 1 | 51K5%-0603-1/10W_0603R_51K5%1/1 | R355, R356 | 0603R | 2 | 0R5%-0603-1/10W_0603R_100K5%1/1 | R393, R394 | 0603R | 2 | 49.9R1%-0603-1/10W_0603R_49.9R1 | R501, R502, R505, R506 | 0603R | 4 | 4.7K1%-0603-1/10W_0603R_NC_41.2 | R586 | 0603R | 1 | 4.7K1%-0603-1/10W_0603R_NC_0R 1 | R589 | 0603R | 1 | 10K5%-0603-1/10W_0603R_100R 1/1 | R787, R788, R790, R792, R794, R796, R798, R800, R802, R804, R806, R808, R810, R812, R814, R816 | 0603R | 16 | 8.06K1%-0603-1/10W_0603R_4.99K1 | R867, R873 | 0603R | 2 | 8.06K1%-0603-1/10W_0603R_2.1K1% | R868 | 0603R | 1 | 20K1%-0603-1/10W_0603R_4.99K1%1 | R869, R871 | 0603R | 2 | 8.06K1%-0603-1/10W_0603R_24.9K1 | R870 | 0603R | 1 | 1.5K1%-0603-1/10W_0603R_1.5K1%1 | R874 | 0603R | 1 | 1.5K1%-0603-1/10W_0603R_12K1%1/ | R875 | 0603R | 1 | 0R5%-0603-1/10W_0603R_100K1%1/1 | R1046, R1047 | 0603R | 2 | 10K5%-0603-1/10W_0603R_15K5%1/1 | R1049 | 0603R | 1 | 680K5%-0603-1/10W_0603R_680K5%1 | RT4 | 0603R | 1 | 120R5%-0603-1/10W_0603R_NC_120R | RT7 | 0603R | 1 | 33R5%-0603-1/10W_0603R_33R5%1/1 | RT8, RT39 | 0603R | 2 | 51K5%-0603-1/10W_0603R_51K5%1_1 | RT13, RT16 | 0603R | 2 | 75R1%-0805-1/8W_0805R_75R1%1/8W | RT18, RT19 | 0805R | 2 | S-RES-NC_0603R_NC | RT20, RT21, RT22 | 0603R | 3 | S-RES-NC_0603R_75R | RT27, RT33 | 0603R | 2 | S-RES0603-NC_0603R_0603-0R | RT28, RT528 | 0603R | 2 | S-RES0805-NC_0805R_75R_NC0805 | RT29, RT30, RT31 | 0805R | 3 | 1K5%-0603-1/10W_0603R_NC_1K5%1/ | RT38 | 0603R | 1 | 100R1%-0603-1/10W_0603R_100R1%1 | RT42, RT43 | 0603R | 2 | PULSE H5007_0_H5007_PULSE H5007 | T1 | H5007 | 1 | S-TRANS-H1102_STFM16-50-285_H11 | TT1 | STFM16-50-285 | 1 | S-PESD0603-140_0603R_NC_PESD | TVS14, TVS15, TVS16, TVS17, TVS18, TVS19, TVS20, TVS21, TVS22, TVS23, TVS24, TVS25, TVS26, TVS27, TVS28, TVS29, TVST5, TVST6 | 0603R | 18 | D-TVS-P6KE6V8-DO15_DO-15_P6KE6V | TVST1, TVST2 | DO-15 | 2 | S-PESD0603-140_0603R_PESD | TVST3, TVST4, TVST7, TVST8 | 0603R | 4 | JR0325A0_QFN64_4_QFN64-9X9_JMB3 | U1, U2 | QFN64-9X9 | 2 | SERIAL FLASH_25LV512/010_SOP8_0 | U3, U4 | SOP8-6_2-1_27 | 2 | S-IC-MP1482DS-SO8_SON8-6_2-1_27 | U6 | SON8-6_2-1_27 | 1 | S-IC-MP1484EN-SO8_SON8-6_2-1_27 | U7, U10 | SON8-6_2-1_27 | 2 | SRV05-4_SOT23-6_SRV05-4 | U11, U12 | SOT23-6 | 2 | CM2020 | U29 | SOP38-20-173A | 1 | NB638 | U45, U46 | QFN20-NB638 | 2 | S-IC-TPS54425_0_S-PVQFN-N14_TPS | U618, U619 | S-PVQFN-N14 | 2 | S-IC-SRV05-4_SOT23-6_SRV05-4 | UB1 | SOT23-6 | 1 | S-IC-L78L05ABUTR-SOT89_SOT-89_L | UT1 | SOT-89 | 1 | S-IC-AP1117-1.8_SOT223_AMC1117- | UT2, UT5 | SOT223 | 2 | S-IC-DS1307Z_SOP8-6_2-1_27_DS13 | UT3 | SOP8-6_2-1_27 | 1 | S-IC-485-SN65LBC184DR_SOP8-6_2- | UT4 | SOP8-6_2-1_27 | 1 | S-IC-LM358AM-SO8_SOP8-6_2-1_27_ | UT6 | SOP8-6_2-1_27 | 1 | S-IC-SGM9115_SOP8-6_2-1_27_SGM9 | UT7 | SOP8-6_2-1_27 | 1 | S-IC-SGM9115_SOP8-6_2-1_27_SG_1 | UT8 | SOP8-6_2-1_27 | 1 | S-IC-LM3526_SOP8-6_2-1_27_MIC20 | UT9 | SOP8-6_2-1_27 | 1 | S-IC-232-MAX232ACSE_SOP16-6_2-1 | UT10 | SOP16-6_2-1_27 | 1 | S-CRYS-25M-XTAL_49M_XTAL-49M_25 | X1, X2 | XTAL-49M | 2 | D-CRYS-32.768KHZ_XTAL-08_32.768 | XT1 | XTAL-08 | 1 | S-GDS-BA301N-4532S_TVS-SMB_SEMI | ZT1, ZT2 | TVS-SMB | 2 | 附件:
$ _" X' i( ` a7 s原理图和PCB源文件如下:" f, i/ W- {, S- ~7 W
! A9 \( Q( O% V. H+ F9 F
" R$ O4 {& [ L
