查看: 257|回复: 0
[AD 10][4层] 一个工控主板PCB共享(ASIC4+74HC245+UPC1241)PCB源文件
发表于 2020-1-19 19:07 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
作品名:[AD 10][4层] 一个工控主板PCB共享(ASIC4+74HC245+UPC1241)PCB源文件
/ `! w& O" e: d8 a/ w" \+ Q5 ^) x* l$ T5 L( H1 o
文件描述
; J4 S$ y+ {" r* u7 ]' |1. 作品用途:工控主板P
& D/ t! W) M9 _, i1 @. A  Q$ A2. 软件版本:AD 10& y! n9 P& ~8 L: P! R% @- D# w0 \
3. 层数:4层板$ s$ i9 a3 }6 S5 G+ y8 ^$ L. p
4. 用到的主要芯片:ASIC4+74HC245+UPC1241. M0 S, ^. \1 o" T/ R: k( E5 Z5 |! S
5. PCB尺寸:224mm*188mm
+ j9 X5 {* I4 K% @. Q. S5 a5 d5 u
9 J" M- Z2 ?) x& M* [/ i作品截图如下:2 T* a9 `1 |, y. k& u
顶层截图:
9 W5 _; s( C, a* M: P3 v; u, ~8 e
# n' x' G% q$ b底层截图:
# v! C4 w! e9 ?
! D. }. ]" A( f: N4 }! `全层截图:- Y. r$ d8 M* f. t
1 B% L. [' N2 E) Y% v' a# J叠层信息截图如下:/ O& m  E# }: w* Q
: v: x( }- X% N* @& H! |( t& [
BOM:
1 q; L  N4 v/ o1 [. n
Comment(属性)Designator(位号)Footprint(封装)Quantity(数量)
6PSOT23-6
RES12K2, 150AXIAL0.4
A1A1
CommentA3A3
ASIC1SQFP20X20-144(N)
QFP-208ASIC2QFP-208
ASIC-44P-2ASIC3qfp44-3
104C1, C3, C4, C6, C26, C42, C106S, C108, C202, C301, C303, CR101, CR101S, CR102, CR102_1, CR106S, CU1, CU2, CU3, CU4, CU5, CU6, CU7, CU7S, CU51, CU52, CU101, CU102, CU103, CU104, CU105, CU106, CU107, CU108, CU109, CU110, CU111, CU112, CU113, CU114, CU115, CU116, CU117, CU118, CU119, CU120, CU121, CU122, CU123, CU201, CU203, CU204, CU205, CU206, CU207, CU402, CU403, CUD1, CUD2C104A
59
100ufC2, C5, C10, C11, C12, C25, C41, C44CAP2
8
820pfC7, C43RAD0.1
2200pfC45, C46RAD0.1
470pfC47, C48, C49RAD0.1
220ufC302, C304CAP2
470ufCS1100uf
4.7ufCS2, CT1CAP2
47ufCS3, CS6, CS44CAP2
1ufCS4CAP2
220ufCS5, CVCC100uf
LEDD5LED
CommentDesignator137, Designator138, Designator140, Designator141PO1
1N4148DL1, DL2, DL3DIODE0.4S
1N4148DP11, DP12, DP13, DP14, DP15, DP16, DP17, DP18, DP21, DP22, DP23, DP24, DP25, DP26, DP27, DP28, DP31, DP32, DP33, DP34, DP35, DP36, DP37, DP38DIODE0.3S
24
DIODEDW1DIODE0.4
3PJR1, JR2, JR3, JT1, JT2, JT3, JT4JP-3P
4PK1SW-4
8PLINK1, LINK2link2
3PQ1TO-126
9013Q2, Q4, Q6TO92B
9012Q3, Q5, Q7TO92B
2.2kR6AXIAL0.4
1KR7, R18, R102, R108, R114, RL5AXIAL0.4
22R8AXIAL0.4
2.4KR9, R10AXIAL0.4
10R14, R22AXIAL0.4
47R17, R106, R112, R118AXIAL0.4
3PR24vr
270KR25, R26AXIAL0.4
4.7KR101, R107, R113, RTA3, RTA4, RTA5, RTA6, RTESTAXIAL0.4
8
560R103, R109, R115AXIAL0.4
150R104, R110, R116AXIAL0.4
270R105, R111, R117AXIAL0.4
RAM1, U6, U7TSOPII-54P-T
28PRAM2SOP28
8PRAM3, RAM4SO-8
471RC1, RC3, RC5, RL2, RL4AXIAL0.4
100RL6AXIAL0.4
42PROM1, ROM2, ROM4DIP-42
46PROM3DIP46
44PROMASOP-44
RPAXIAL1.0
10KRP11, RP12, RP13, RP14, RP15, RP16, RP17, RP18, RP21, RP22, RP23, RP24, RP25, RP26, RP27, RP28, RP31, RP32, RP33, RP34, RP35, RP36, RP37, RP38AXIAL0.4
24
4.7kRS1, RS2, RS3SIP-9
4.7kRS31, RS31SSIP9
2.7kRTA0, RTA1, RTA2AXIAL0.4
1KRUA1, RUA2, RUA3, RUA4, RUA5, RUA6, RUA7, RUA9SIP-9
8
ASIC4U1SOP-20
U14, U204DIP14
U16P3.3A
U20SO-8
U201, U202dip16
74HC245UA1, UA3, UD1, UD2DIP20
UPC1241US11241
TA7252US1SSIP7
3PVR302RW2
Y1, Y2CRY-4
附件:# U" m/ u/ x8 u7 D, G# w8 B4 {. c
原理图和PCB源文件如下:
9 Z) f" C1 n; F7 d* a/ ?  J& ]
游客,如果您要查看本帖隐藏内容请回复
* f; l1 G6 B8 b5 h4 i- V
* ?4 a; {( v3 V
GMT+8, 2025-7-23 04:59 , Processed in 0.125000 second(s), 28 queries , Gzip On.
