查看: 175|回复: 0
[allegro16.5][4层] CY8CKIT-042, Programmable System-on-Chip (PSoC) 4 Pioneer ...
发表于 2020-1-19 13:46 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.5][4层] CY8CKIT-042, Programmable System-on-Chip (PSoC) 4 Pioneer Kit 使用CY8C5868LTI-LP039 的参考板(CY8C5868LTI-LP039+CY8C4245AXI-483+USB)原理图和pcb文件: x0 p3 a* g4 Y$ M! V
% e3 V" {  l6 {1 D! S" {
文件描述:
& k) E& E1 v- D- E' M- }6 z) K; w0 z+ ~( s. n* w% K
1. 作品用途:CY8CKIT-042, Programmable System-on-Chip (PSoC) 4 Pioneer Kit 使用CY8C5868LTI-LP039 的参考板
5 h/ u2 c$ ~$ u, C0 h& h6 G2. 软件版本:allegro16.5
: J; n& Q% \0 A9 Z. s) S' E3. 层数:4层
% s' }5 U# [$ H8 b$ ~4. 用到的主要芯片:CY8C5868LTI-LP039+CY8C4245AXI-483+USB
" f& W& e4 b5 I! Z5. pcb尺寸: 3375*2050 MIL4 O) E9 Y( m# p- t: a% J
6 Z7 y# N" J1 r+ j3 o* |  o
作品截图如下:
0 I* D/ U# [- c8 C7 v$ G2 ?' p# z$ O; z6 u/ t9 ~5 E
顶层截图:6 g1 F% o( e( s1 j9 k
' t# t' N( l' v3 D/ z* U底层截图:
0 x, [$ ?* t* ]% N% k
: f( j6 m( E5 v/ Q3 [* s8 k+ X) d3 ]+ a3 @/ q0 y! A
全层截图:2 b# f% s- v/ b9 B
3 G2 M9 W* A" k: d3 ^
8 I- I2 l* k& Z4 X* z4 z叠层阻抗信息如下:
2 }& I0 e+ @3 m
8 l! t( M: k& X5 W2 SBOM:/ x/ [3 c; @& g6 M  B% f6 R
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
805RESISTOR_0805_1K OHM1K ohmIC1R42
C-CC04020P1UFD_04020.1 uFDISCRETE12C2; C7; C12; C14; C15; C17; C20; C21; C22; C24; C25; C27
C-CC04020P01UFD_04020.01 uFIC1C16
C-CC06031P0UFD_0603_25V1.0 uFDISCRETE12C3; C5; C8; C10; C11; C13; C18; C19; C23; C26; C28; C29
C-CC0805CAP_C-CC0805_DISCRETE_2200 PF_2200 pFDISCRETE1C1
C-CC0805CAP_C-CC0805_DISCRETE_2200 PF_C2200 pFDISCRETE1C9
C-PCC352810UFD_TANT_25V10 uFd 25vIC1C4
C-PCC352822UFD_TANT_16V22 uFd 16vIC1C6
CR-LED06030603_LEDESD 5VDCIC3D6; D7; D8
CR-LED0805PWR_LEDPower LEDIC1D3
CR-LED0805LED_GREEN0805Status LED GreenIC1D10
CSS5A-300MIL_4MMSHAPECAPSENSE SLIDER 5 SEG EXTEND_CSCapSense Slider 5 SegIC1CSS1
DPAK_4PINNCP1117DTARKGNCP1117DTARKGIC1U1
FTSH-105-XX-X-DV-KHDR5X2X50KS50MIL KEYED SMDIO2J6; J7
FUSE_MF-MSMF050-2FUSEPTC Resettable FuseIC1F1
HDR22 PIN HDR2 PIN HDRIO1J11
HDR2103185_22 PIN HDRIO1J13
HDR3X13P JUMPER3p_jumperIC1J9
J-ACON-MINIABSMTJ-MINIABSMTUSB MINI BIC1J10
LED_PLCC4_SMDRGB_LEDRGB LEDIC1D9
QFN68_8X8MMCY8C5667LTI-LP008_QFN68CY8C5868LTI-LP039 QFN68IC1U3
R-CR0402100K_0402100KDISCRETE1R13
R-CR06030_0603ZERODISCRETE16R2; R4; R7; R11; R12; R14; R15; R16; R24; R25; R32; R33; R34; R44; R45; R46
R-CR06032P2K_06032.2KDISCRETE4R8; R9; R22; R23
R-CR06034P7_06034.7KDISCRETE2R10; R41
R-CR0603560_0603560 ohmDISCRETE5R17; R18; R19; R20; R21
R-CR060322_060322EIC2R26; R27
R-CR0603240_0603240 ohmDISCRETE1R35
R-CR0603120_0603120 ohmDISCRETE1R36
R-CR0603RESISTOR_R-CR0603_1.5K1.5KIC2R37; R39
R-CR0603RESISTOR_R-CR0603_3K3KIC2R38; R40
R-CR0603RESISTOR_R-CR0603_442 OHM442 ohmIC1R43
R-CR0805330 OHM 5% 0805_0_R-CR0805_DISC330 ohmDISCRETE2R3; R31
R-CR0805330 OHM 5% 0805_1_R-CR0805_DISCZERODISCRETE2R5; R6
R-CR08052.2K_08052.2KDISCRETE1R28
R-CR0805560_0805560 ohmDISCRETE2R29; R30
RECEPT_9X2_100MIRECEPT2X99x2 RECPIO1J2
RECP6X1-RA6X1CONN_FEMALE6X1 CONN FEMALEIO1J5
RECP8X1-VERTRECP8X18x1 RECPIO2J1; J4
RECP10X1-VERT929850-01-12-RA10X1 RECPIO1J3
RECPT3X2_1003X2_RECPT_100MIL3x2 RECPTIO1J12
RECPT6X2_1006X2_RECPT_100MIL6x2 RECPTIO1J8
RESC1608X50ANRES_RESC1608X50AN_DISCRETE_NO LNO LOADDISCRETE1R1
SOD323SD05-75V 350WDISCRETE3TVS1; TVS2; TVS3
SOD323CDSOD323-T1818V 350WDISCRETE1TVS4
SOD-123MBR0520L-SOD123MBR0520LDISCRETE6D1; D2; D4; D11; D12; D13
SOD-123-RDIODE BREAKDOWN_SOD-123-R_VZ=2VVz=2V(BZT52C2V0-7-F)IC1D5
SOT23-3098LP DGS_1_SOT23-3098L_PMOS( DMP30PMOS( DMP3098L-7)IC1Q1
SOT23-3098LP DGS_2_SOT23-3098L_PMOS( DMP30PMOS( DMP3098L-7)IC1Q2
SOT23-3098LP DGS_2_SOT23-3098L_PMOS( DMP_1PMOS( DMP3098L-7)IC1Q3
SWITCH-EVQ-PE105K_5MMEVQPEEVQ-PE105KIO2SW1; SW2
TP-43R_STP-43R_RREDDISCRETE2TP1; TP2
TP-43R_STP-43R_BBLACKDISCRETE4TP3; TP4; TP5; TP6
TQFP44PSOC4A_44_TQFP_1_TQFP44_IC_CY8CCY8C4245AXI-483 44TQFPIC1U2
附件:
' T- c: |; b/ [/ ^5 c原理图和PCB文件如下:
6 _" d5 Q) h- Q" A
游客,如果您要查看本帖隐藏内容请回复
6 [/ @" Q$ m! {4 C
GMT+8, 2025-7-23 04:08 , Processed in 0.140625 second(s), 29 queries , Gzip On.
