查看: 365|回复: 2
[allegro17.2][4层]一款多层板分享(RTL8365MB-CG+CS8030+G2P109N LF)原理图和pcb...
发表于 2020-1-17 17:48 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro17.2][4层]一款多层板分享(RTL8365MB-CG+CS8030+G2P109N LF)原理图和pcb文件
文件描述:
1. 作品用途:一款多层板分享
2. 软件版本:allegro17.2
3. 层数:4层
4. 用到的主要芯片:RTL8365MB-CG+CS8030+G2P109N LF
5. PCB尺寸:5826*4136 mil
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BGA-13X13-225P-0_8CS8030_BGA-13X13-225P-0_8_CS803CS8030IC1U1
C0402CAP NP_0_C0402_104/K/1608104/K/1608IC4C1; C2; C54; C128
C0402CAP NP_0_C0402_105/Z/1005105/Z/1005IC29C5; C6; C7; C24; C25; C34; C46; C47; C105; C106; C112; C119; C122; C123; C144; C151; C155; C166; C167; C168; C169; C170; C172; C173; C192; C194; C195; C196; C198
C0402CAP NP_0_C0402_104/K/1005104/K/1005IC26C8; C9; C10; C11; C12; C13; C14; C15; C26; C27; C28; C32; C35; C36; C37; C48; C49; C50; C51; C90; C91; C94; C96; C97; C99; C135
C0402CAP NP_0_C0402_103/K/1005103/K/1005IC33C16; C17; C18; C19; C20; C21; C22; C23; C29; C30; C31; C38; C39; C40; C41; C42; C43; C44; C52; C93; C101; C102; C103; C107; C108; C109; C110; C111; C140; C159; C171; C190; C191
C0402CAP NP_5_C0402_NIL/C/47PF/NPO/0NIL/C/47pF/NPO/0402IC2C56; C70
C0402CAP NP_4_C0402_C/103K/25V/X7R/0C/103K/25V/X7R/0402IC2C58; C72
C0402CAP NP_5_C0402_C/3.3NF/6.3V/NPOC/3.3nF/6.3V/NPO/0402IC1C59
C0402CAP_NP_C0402_C/103K/16V/X7R/040C/103K/16V/X7R/0402IC6C60; C63; C64; C74; C77; C79
C0402CAP NP_5_C0402_C/104M/10V/X5R/0C/104M/10V/X5R/0402IC3C65; C66; C80
C0402CAP NP_5_C0402_C/104K/6.3V/X7R/C/104K/6.3V/X7R/0402IC1C78
C0402C_0402_C0402_0.1UF0.1uFIC6C84; C85; C86; C87; C254; C256
C0402CAP NP_0_C0402_C104K/16VC104K/16VIC16C113; C114; C115; C116; C117; C118; C201; C202; C203; C205; C206; C208; C209; C210; C211; C212
C0402CAP NP_0_C0402_104/Z/1608104/Z/1608IC1C150
C0402CAP NP_0_C0402_105/Z/1608105/Z/1608IC3C153; C154; C156
C0402CAP NP_0_C0402_104/K/1608_NC104/K/1608_NCIC1C158
C0402CAP NP_0_C0402_27PF/J/1005/NI27pF/J/1005/NIIC2C161; C200
C0402CAP NP_0_C0402_104/K/1005/NI104/K/1005/NIIC1C162
C0402CAP_0_C0402_0.1UF/NC0.1uF/ncIC5C181; C184; C185; C186; C187
C0402CAP NP_0_C0402_27PF/J/100527pF/J/1005IC2C193; C197
C0402CAP NP_0_C0402_10PF/NI10pF/NIIC32C213; C214; C215; C216; C217; C218; C219; C220; C221; C222; C223; C224; C225; C226; C227; C234; C235; C236; C237; C238; C239; C240; C241; C242; C243; C244; C245; C246; C247; C248; C249; C250
C0402C_0402_C0402_C/104K/25V/X5R/040C/104K/25V/X5R/0402IC1C257
C0603CAP NP_5_C0603_C/104M/10V/X5R/0C/104M/10V/X5R/0603IC2C55; C69
C0603CAP NP_3_C0603_C/104Z/25V/Y5V/0C/104Z/25V/Y5V/0603IC2C57; C68
C0603CAP NP_3_C0603_C/104K/16V/X7R/0C/104K/16V/X7R/0603IC1C71
C0603CAP NP_5_C0603_C/3.3NF/6.3V/X7RC/3.3nF/6.3V/X7R/0603IC1C73
C0603CAP NP_5_C0603_NIL/C/105M/10V/XNIL/C/105M/10V/X5R/0603IC2C120; C124
C0603CAP NP_0_C0603_105105IC1C149
C0805CAP NP_0_C0805_10UF/10VK/321610uF/10VK/3216IC12C3; C4; C33; C45; C53; C95; C98; C126; C152; C163; C164; C199
C0805CAP NP_C0805_C/106K/10V/0805C/106K/10V/0805IC4C62; C67; C76; C81
C0805CAP NP_C0805_10UF10uFIC1C127
C-7_62X2_54-5_08CAP NP_0_C-7_62X2_54-5_08_1000P1000pF/2K/3216IC5C104; C121; C160; C204; C207
C-7_62X2_54-5_08CAP NP_3_C-7_62X2_54-5_08_1000P1000pF/2K/3216IC3C230; C232; C251
C-D6-2_54CAPACITOR POL_0_C-D6-2_54_220UF220uF,±20%,16V,LowESRIC3C61; C75; C231
C-D6-2_54CAPACITOR POL_0_C-D6-2_54_NI/22NI/220uF,±20%,16V,LowESRIC2C82; C83
C-D10XH16-5CAPACITOR POL_0_C-D10XH16-5_NC/NC/1000uF/16VIC1C233
C-H25X13-5CAPACITOR POL_0_C-H25X13-5_33003300UF/16VIC1C125
CN-3P-2_54S1CN_3P-2_0_CN-3P-2_54S1_J/3PIN,2J/3Pin,2.54mmIC1J7
CN-4P-2_54HDR1X4_CN-4P-2_54_KPA1X4A1KPA1X4A1IC1J1
FILDMC_40MARK_FILDMC_40_MARKMARKIC6M1; M2; M3; M4; M5; M6
GMPTH120R276HOLE1_GMPTH120R276_GND_TERMINALgnd_terminalIC4H1; H2; H3; H4
JACK-14_9X9-3PCON-RCA-VERT-J_JACK-14_9X9-3P_JJ/DCJack/2.0IC1J3
L0603BEAD FILTER_0_L0603_600 OHM600 OHMIC3BF1; BF6; BF8
L0603BEAD FILTER_0_L0603_300/1608300/1608IC4BF11; BF12; BF13; BF14
L0805BEAD FILTER_0_L0805_600 OHM600 OHMIC1BF7
L0805BEAD FILTER_0_L0805_0 OHM0 OHMIC1BF9
L-11_5X6-2PINDUCTOR IRON_L-11_5X6-2P_L/10UL/10uH/10%/2AIC2L4; L5
L-D7_5-5INDUCTOR_L-D7_5-5_NI/BEAD/DIPNI/BEAD/DIPIC2L29; L31
LED0603LED_1X_CATH1_AN2_HTMAX7-5_0_L_3LED/RED/207123000004LIC1D23
LED-D4_2-2_54LED_1X_CATH1_AN2_HTMAX7-5_0_LEDLED/GREEN/207123000004LIC6D15; D16; D17; D18; D19; D20
LED-D4_2-2_54LED_1X_CATH1_AN2_HTMAX7-5_0_L_1LED/RED/207123000004LIC1D21
LED-D4_2-2_54LED_1X_CATH1_AN2_HTMAX7-5_0_L_2NI_LED/GREEN/207123000004LIC1D22
OSC-7_5X5-4POSC-HALF_OSC-7_5X5-4P_25MHZ25MHzIC1U5
OSC-11_4X5-3PCRYSTAL_1_OSC-11_4X5-3P_25MHZ 125MHz 18pFIC1Y2
QFP-16X16-128P-0_4-ARTL8365MB_3_QFP-16X16-128P-0_4-RTL8365MB-CGIC1U10
R0402R_0_R0402_4.7K/J/10054.7K/J/1005IC32R1; R2; R3; R6; R13; R14; R15; R17; R18; R39; R40; R76; R78; R90; R91; R95; R97; R99; R100; R145; R161; R164; R181; R182; R184; R186; R188; R195; R196; R198; R199; R201
R0402R_1224_R0402_4K74K7IC12R4; R49; R50; R51; R52; R53; R58; R59; R60; R143; R158; R209
R0402R_0_R0402_22/J/100522/J/1005IC13R5; R7; R8; R9; R10; R11; R12; R16; R20; R22; R37; R38; R179
R0402R_0_R0402_2.8K/F/10052.8K/F/1005IC1R19
R0402R_0_R0402_5.76K/F/10055.76K/F/1005IC1R21
R0402R_0_R0402_100/F/1005100/F/1005IC1R23
R0402R_0_R0402_R/22R/1%/0402R/22R/1%/0402IC14R24; R25; R57; R61; R73; R75; R87; R89; R93; R103; R104; R109; R110; R111
R0402R_0_R0402_0R/NC0R/NCIC1R26
R0402R_0_R0402_R/10K/1%/0402R/10K/1%/0402IC1R27
R0402R_0_R0402_R/26.1K/1%/0402R/26.1K/1%/0402IC1R28
R0402R_0_R0402_R/100K/5%/0402R/100K/5%/0402IC2R29; R46
R0402R_0_R0402_R/6.98K/0402/1%R/6.98K/0402/1%IC1R30
R0402R_0_R0402_R/12K/1%/0402R/12K/1%/0402IC1R32
R0402R_0_R0402_R/1K/1%/0402R/1K/1%/0402IC1R33
R0402R_0_R0402_0 OHM0 ohmIC1R34
R0402R_0_R0402_R/2.2K/0402/1%R/2.2K/0402/1%IC1R35
R0402R_1224_R0402_00IC3R43; R44; R55
R0402R_0_R0402_NI/R/100K/5%/0402NI/R/100K/5%/0402IC1R45
R0402R_1224_R0402_NI_0NI_0IC2R47; R54
R0402R_1224_R0402_30K30KIC2R48; R228
R0402R_1224_R0402_2222IC2R56; R159
R0402R_0_R0402_10K/J/100510K/J/1005IC5R66; R67; R106; R146; R162
R0402R_0_R0402_33/J/160833/J/1608IC1R69
R0402R_0_R0402_220220IC6R72; R74; R77; R88; R101; R105
R0402R_0_R0402_NC/1005NC/1005IC20R79; R80; R81; R82; R85; R86; R96; R114; R115; R116; R117; R173; R180; R183; R185; R187; R191; R200; R202; R203
R0402R_0_R0402_4.7K/J/1005/NC4.7K/J/1005/NCIC3R83; R92; R112
R0402R_0_R0402_4.7K/10054.7K/1005IC2R84; R98
R0402R_0_R0402_4.7K/1005/NC4.7K/1005/NCIC1R94
R0402R_0_R0402_249/J/1005249/J/1005IC1R102
R0402R_0_R0402_1K/J/10051K/J/1005IC7R107; R172; R175; R176; R177; R193; R197
R0402R_0_R0402_10K10KIC1R108
R0402R_0_R0402_130/F/1005/NC130/F/1005/NCIC2R118; R119
R0402R_0_R0402_22/J/1005/NC22/J/1005/NCIC2R120; R151
R0402R_0_R0402_47K/J/100547K/J/1005IC1R121
R0402R_0_R0402_82/F/1005/NC82/F/1005/NCIC2R122; R123
R0402R_0_R0402_33/J/100533/J/1005IC7R139; R163; R165; R166; R189; R190; R194
R0402R_1224_R0402_47K47KIC1R142
R0402R_1224_R0402_0R/NC0R/NCIC2R144; R147
R0402R_0_R0402_10K/NC10K/NCIC1R148
R0402R_1_R0402_100K/J/1608100K/J/1608IC1R149
R0402R_1224_R0402_220220IC3R150; R168; R211
R0402R_0_R0402_2.4K2.4kIC1R153
R0402R_0_R0402_5.1K5.1kIC1R154
R0402R_0_R0402_4K7/J/10054K7/J/1005IC1R160
R0402R_0_R0402_NC/4K7/J/1005NC/4K7/J/1005IC1R167
R0402R_0_R0402_NC/4.7KNC/4.7KIC1R174
R0402R_0_R0402_4.7K4.7KIC1R178
R0402R_0_R0402_2.49K/F/10052.49K/F/1005IC1R192
R0402R_0_R0402_0/J/10050/J/1005IC2R204; R205
R0402R_0_R0402_10K/J/1005/NC10K/J/1005/NCIC1R206
R0402R_0_R0402_NC/0/J/1005NC/0/J/1005IC2R207; R208
R0402R_1224_R0402_NCNCIC1R210
R0402R_1224_R0402_20K20KIC1R314
R0402R_1224_R0402_1K1KIC1R321
R0402RES_0_R0402_NIL/R/270/1%/0402NIL/R/270/1%/0402IC4R337; R338; R343; R344
R0603R_0_R0603_75/F/100575/F/1005IC16R124; R125; R126; R127; R128; R129; R130; R131; R132; R133; R134; R135; R152; R155; R156; R157
R0603R_0_R0603_NC/0RNC/0RIC1R140
R0603R_0_R0603_0R0RIC1R141
R1206R_0_R1206_R/0/5%/1206R/0/5%/1206IC4R31; R36; R41; R42
RJ45-37P-59_1X18_4RJ45_1_RJ45-37P-59_1X18_4_RJ45-RJ45-1X4H-59X20_5IC1RJ1
SC70-5NC7SZ08P5X_AND_SC70_5_SC70-5_7474LVC1G08DCKIC1U19
SO-6X4_9-9P-1_27-AMC34063A_0_SO-6X4_9-9P-1_27-A_LLV7182SNIC2U2; U6
SO-6X5-8P-1_27MAX708PCSA_3_SO-6X5-8P-1_27_MAXMAX706RESRIC1U7
SO-7_9X5_2-8P-1_27MX25L3235D_SO-7_9X5_2-8P-1_27_MMX25L3206EM2I-12GIC1U4
SOD123DIODE_2_SOD123_DIODEDIODEIC3D7; D8; D9
SOT23-5PAM3103_SOT23-5_AP133-WG-7AP133-WG-7IC1U8
SOT-23-3PMOSFET P_0_SOT-23-3P_KRLML6401KRLML6401IC1Q1
SOT-23-3PTR_NPN_BASEBIAS_0_SOT-23-3P_KMBKMBT3904IC1Q2
SOT-23-3P2N1069_0_SOT-23-3P_BC846ALT1BC846ALT1IC1Q7
SOT-23-6PSPD6PIN_SOT-23-6P_SPD6PINSPD6PINIC8U38; U39; U40; U41; U42; U43; U44; U45
SOT-353-5P74LVC1G32_SOT-353-5P_74LVC1G32G74LVC1G32GWIC1U57
SOT-353-5P74LVC1G125_SOT-353-5P_74LVC1G1274lvc1g125GWIC1U58
SW-7_5X6_5-4PS1SW-PB-SPST-GG_2_SW-7_5X6_5-4PS1SW/PUSHBUTTON-SWITCH/DIP/4PINIC1SW7
SW-12_4X7_8-8PS1SW-DPDT-OXC-OXC-NN_0_SW-12_4X7_SW/POWER-PushIC1SW1
T-28X12-48P-2XFMR-G2PM109N_T-28X12-48P-2_G2PG2P109N LFIC2TF1; TF2
TAN-ACAP TANTALUM_0_TAN-A_10UF/16V10uF/16VIC2CT2; CT3
TAN-ACAP TANTALUM_0_TAN-A_10UF/10VK/10uF/10VK/3216IC1CT5
TP_30TP_30_TP_30_TP_30TP_30IC5TP1; TP2; TP3; TP4; TP5
TP_30TP_1P_TP_30_3.3V3.3VIC1TP6
TP_30TP_1P_TP_30_1.0V1.0VIC1TP7
TV-PTB3I79-26PS1LTD34D3_TV-PTB3I79-26PS1_LTD34DLTD34D3-SC+IC1U50
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
; Q" J' G7 n  W
    无聊
    2023-9-5 15:54
    发表于 2021-10-21 13:33 | 只看该作者
    非常好,正需要RTL8365MB资料,谢谢;
    3 j2 E7 ^' G' Z& }. O
    发表于 2021-10-21 14:30 | 只看该作者
    正需要RTL8365MB资料, 學習學習
    GMT+8, 2025-9-13 16:16 , Processed in 0.156250 second(s), 27 queries , Gzip On.
