1. 作品用途:一款1000W音频放大器(D类)
2. 软件版本:allegro17.2
3. 层数:2层
5. PCB尺寸:250*150 mm
Bill of Material Report (Condensed) | | | | | |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
C295_RAD_POL | CAP_POL_C295_RAD_POL_DISCRETE_2 | 2200UF | DISCRETE | 2 | C1; C2 |
CAP_7P5_12X5 | CAP_1_CAP_7P5_12X5_DISCRETE_1NF | 1nF 400Vdc | DISCRETE | 2 | C29; C31 |
CAP_22P5_26X10MM_TH | CAP_1_CAP_22P5_26X10MM_TH_DISCR | 1.5uF 250Vdc | DISCRETE | 2 | C24; C34 |
CAP_22P5_26X10MM_TH | CAP_NP_CAP_22P5_26X10MM_TH_DISC | 1uF 400V | DISCRETE | 1 | C30 |
CAP_RADIAL_30X50MM | CAP POL_CAP_RADIAL_30X50MM_DISC | 1500uFx200V | DISCRETE | 1 | C3 |
CASE_D_AL | CAP_POL_CASE_D_AL_DISCRETE_8MM_ | 47UF | DISCRETE | 3 | C5; C22; C32 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.0MM | 0.1UF | DISCRETE | 8 | C4; C6; C8; C9; C23; C27; C33; C37 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.35M | 1uF | DISCRETE | 4 | C11; C15; C16; C17 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_0.9MM | 0.082UF | DISCRETE | 1 | C12 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4MM | 1000PF | DISCRETE | 2 | C13; C14 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.40M | 2.2UF | DISCRETE | 2 | C18; C19 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_1.4 M | 220PF | DISCRETE | 1 | C20 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_0.94M | 1000pF | DISCRETE | 1 | C21 |
CC0805_OV | CAP_NP_CC0805_OV_DISCRETE_0.9_1 | 100PF | DISCRETE | 4 | C25; C26; C35; C36 |
CC1206_OV | CAP_NP_CC1206_OV_DISCRETE_1.8MM | 10uF | DISCRETE | 4 | C7; C10; C28; C38 |
CON_JACK_2F_RA_TH_21XX | CONN_AV_1X2_F_CON_JACK_2F_RA_TH | RCJ-21 | IO | 1 | J1 |
CON_PWR_EJ01D15100J0G | POWER CON EJ01D15100J0G_CON_PWR | Power Con EJ01D15100J0G | IC | 5 | CON1; CON2; CON3; CON4; CON5 |
CON_SKT2X20_TH | CONN_RCPT_2X20_CON_SKT2X20_TH_I | CON_2X20 | IO | 1 | J4 |
FILTER-CLASS-D-1KW | TOROID-T-157-2-WIRE-15AWG_FILTE | Toroid-T-157-2-Wire-15AWG | DISCRETE | 2 | L1; L2 |
LED0805 | LED_LED0805_IC_0.9MM_370-75202_ | LGR971 | IC | 1 | D6 |
LED_2P_0805 | LED_LED_2P_0805_IC_0.9MM_370-76 | RED | IC | 1 | D5 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7590 | 10 | DISCRETE | 5 | R1; R2; R3; R4; R46 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-8085 | 1K | DISCRETE | 4 | R5; R11; R14; R15 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-8022 | 39K | DISCRETE | 2 | R6; R10 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-8061 | 10K | DISCRETE | 14 | R7; R8; R13; R17; R20; R21; R23; R25; R26; R27; R45; R49; R52; R55 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7595 | 1.0M | DISCRETE | 2 | R9; R22 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-8051 | 100 | DISCRETE | 1 | R12 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7546 | 15.0K | DISCRETE | 2 | R16; R24 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7596 | 220 | DISCRETE | 2 | R18; R19 |
RC0805_OV | RES_RC0805_OV_DISCRETE_0.7 MM_4 | 0 | DISCRETE | 8 | R28; R29; R30; R31; R32; R33; R34; R35 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7906 | 1.6K | DISCRETE | 3 | R36; R37; R41 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-8019 | 82 | DISCRETE | 1 | R39 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-8073 | 2.2K | DISCRETE | 1 | R40 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7556 | 3.3K | DISCRETE | 1 | R42 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7606 | 4.7 | DISCRETE | 2 | R43; R50 |
RC0805_OV | RES_RC0805_OV_DISCRETE_470-7878 | 47 | DISCRETE | 4 | R44; R47; R51; R54 |
RC2512_A | RES_RC2512_A_DISCRETE_0.89 MM_4 | 0.005 | DISCRETE | 1 | R38 |
RES_5W_RAD | RESISTOR_RES_5W_RAD_DISCRETE_2K | 2k7-5W | DISCRETE | 2 | R48; R53 |
SO8_1P27_4X5 | FAN3227_SO8_1P27_4X5_IC_1.75MM_ | FAN3227TMX | IC | 1 | U1 |
SOD-123 | DIODE_SCHTKY_SOD-123_IC_PMEG301 | PMEG3010ER | IC | 4 | D2; D4; D8; D11 |
SOD-123 | ZENER DIODE_SOD-123_IC_PTVS13VS | PTVS13VS1UR | IC | 1 | D3 |
SOP14 | FAN7391_SOP14_IC_FAN7391 | FAN7391 | IC | 2 | U3; U4 |
SOT23 | BAT54W_SOT23_IC_BAT54W | BAT54W | IC | 5 | D7; D9; D10; D12; D13 |
SOT23-40X40 | BZX84-C3V3_SOT23-40X40_IC_BZX84 | BZX84-C3V3 | IC | 6 | DZ1; DZ2; DZ3; DZ4; DZ5; DZ6 |
SOT23-40X40 | MMBZ15VDL_SOT23-40X40_IC_MMBZ15 | MMBZ15VDL | IC | 6 | DZ7; DZ8; DZ9; DZ10; DZ11; DZ12 |
SOT223 | LD1117AS18_SOT223_IC_1.8MM_312- | NCP1117ST33T3G | IC | 1 | U2 |
SOT-23 | PNP_SOT-23_IC_1.09MM_480-77461_ | MMBTA92 | IC | 2 | Q5; Q6 |
SOT-23 | NPN_SOT-23_IC_1.09MM_480-77458_ | MMBTA42 | IC | 1 | Q8 |
TO-220AB | DIODE DUAL COMMON CATHODE_TO-22 | BYQ28E-200,127 | IC | 1 | D1 |
TO-220AB | MOSFET-TYPE-N_TO-220AB_IC_PSMN1 | PSMN1R9-40PL | IC | 4 | Q1; Q2; Q3; Q4 |
TO-220AB | MOSFET-TYPE-N_TO-220AB_IC_PSMN0 | PSMN057-200P | IC | 4 | Q7; Q9; Q10; Q11 |
TRANSF-1KW-2PRI-2SEC | TRANSFORMER_1KW-2PRI-2SEC_TRANS | Transformer_1kW-2Pri-2Sec | IC | 1 | T1 |
