1. 作品用途:物联网的 Intel Edison Arduino开发板
2. 软件版本:allegro17.2
3. 层数:4层
5. PCB尺寸:122.22*71.98 mm
Bill of Material Report (Condensed) | | | | | |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
1X6RCPT_2P54_VT_TH | H46111-001 | 6Pin_HDR | IC | 1 | J1A1 |
1X8RCPT_2P54_VT_TH | H46118-001 | CON8_HDR | IC | 2 | J1B1; J2A1 |
1X10RCPT_2P54_VT_TH | CON10,1X10,0.1,0.093,E74918-001 | 1x10 | IC | 1 | J2B1 |
2X35_P4MM_BTB_AXT_SKT_MB | H42241-001 | 70Pin BTB Socket HIROSE DF40 | IC | 1 | J7 |
102276-001 | E81838-001 | CON2_HDR | IC | 4 | J2; J10; J14; J15 |
102276-003 | A91829-001 | CON3_HDR | IC | 3 | J8; J9; J13 |
102276-005 | C88650-001 | 1X5_HDR | IC | 2 | J11; J12 |
BGA6_5MM_37X57 | G42189-001 | 74LVC1T45 CSP | IC | 20 | U4; U6; U8; U10; U12; U14; U18; U19; U20; U21; U23; U24; U26; U27; U28; U29; U30; U31; U32; U33 |
BGA8P_5MG2X4 | LVC2G53 | 74LVC2G53 CSP | IC | 12 | U5; U7; U9; U11; U13; U15; U22; U25; U40; U41; U42; U43 |
BGA20_P4MM_1P96X1P56 | TXS0206 | TXS206-29 | IC | 1 | U35 |
C0201 | CAP_C0201_0.1UF_C83410-027 | 0.1uF | IC | 3 | C3; C56; C57 |
C0201 | CAP_C0201_0.1UF_C83410-014 | 0.1uF | IC | 29 | C6; C9; C10; C12; C14; C15; C16; C17; C18; C19; C20; C21; C22; C23; C24; C25; C26; C27; C28; C29; C30; C31; C32; C33; C48; C49; C50; C51; C52 |
CONN4_D23040001 | D23040-001 | D23040-001 | IC | 1 | J6 |
CONN6_H18587001 | H18587-001 | 2X3HDR | IC | 1 | J4 |
CONN_SDCARD_8P_PP | REQ3437 | SD CONN G46739-001 | IC | 1 | J5 |
DFN6P_65M_2X2M | IC,MIC2039,USBPWRSWTCH_0_DFN6P_ | MIC2039 | IC | 1 | U36 |
JK_3P_RA | G60557-001 | DC_JACK | IC | 1 | J1 |
LCC6_P35MM_SQ1P0_NONC_P5H | H22984-001 | 74AUP1G125 | IC | 1 | U44 |
LCC10_P5MM_EP65X94 | G67765-001 | TS3USB221 | IC | 1 | EU1 |
LCC12_P5MM_3X4MM | G38734-001 | LTC4067 | IC | 1 | U38 |
LCC16_3X3MM_67DIE_39H | TPS62133_0_LCC16_3X3MM_67DIE_39 | TPS62133 | IC | 1 | U1 |
LCC16_3X3MM_67DIE_39H | TPS62133_0_LCC16_3X3MM_67DIE__1 | TPS62130 | IC | 1 | U45 |
LCC25_S41_5DF89X89MA | H31921-001 | PCAL9555 | IC | 2 | U16; U34 |
LCC25_S41_5DF89X89MA | H47895-001 | PCAL9535A | IC | 2 | U17; U39 |
LCC32_P5MM_3P2SQ_NONC | FT232R_0_LCC32_P5MM_3P2SQ_NONC_ | FT232R | IC | 1 | U2 |
NPIN787 | MOUNTING HOLE 787_NPIN787_NPIN7 | NPIN787 | IC | 2 | MTG1; MTG2 |
QFN24P_5M_4X4M | ADS7959_0_QFN24P_5M_4X4M_ADS795 | ADS7951 | IC | 1 | U3 |
R0201 | R_0_R0201_0R_C80792-009 | 0R | IC | 10 | R1; R2; R6; R7; R8; R9; R10; R11; R123; R124 |
R0201 | R0603_R0201_1K_C48657-010 | 1K | IC | 1 | R5 |
RCPT_USB_5P_DIP_SM | G58911-001 | G58911-001 | IC | 2 | J3; J16 |
SCR_27X17MA | H33384-001 | D2BW319000 | IC | 3 | CR2; CR6; CR7 |
SMC0201 | C83410-017 | 33000pF | IC | 2 | C4; C53 |
SMC0201 | D70542-001 | 100pF | IC | 7 | C34; C40; C41; C42; C43; C44; C45 |
SMC0402 | G21049-001 | 10uF | IC | 5 | C5; C8; C11; C13; C46 |
SMC0603_HI_VALUE | 602433-081 | 22UF | IC | 2 | C1; C54 |
SMC0603_HI_VALUE | 602433-091 | 2.2uF | IC | 1 | C36 |
SMC0805 | G27061-002 | 10uF | IC | 2 | C47; C55 |
SMF0402 | A51464-017 | 120 Ohm@100MHz | IC | 1 | FB1 |
SML0805 | G95926-001 | 1uH | IC | 2 | L1; L2 |
SMLED0402 | E54986-003 | GREEN | IC | 3 | DS1; DS2; DS3 |
SMR0201 | C80792-002 | 10K | IC | 46 | R3; R4; R12; R13; R14; R15; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R26; R27; R28; R29; R30; R31; R32; R33; R34; R35; R36; R45; R46; R48; R80; R81; R85; R87; R95; R96; R97; R98; R100; R102; R104; R105; R106; R107; R109; R110 |
SMR0201 | C80792-011 | 100K | IC | 1 | R37 |
SMR0201 | C80792-014 | 4.7K | IC | 11 | R39; R40; R41; R42; R43; R44; R50; R51; R108; R122; R125 |
SMR0201 | C80792-046 | 220 | IC | 2 | R47; R49 |
SMR0201 | C48657-118 | 47K | IC | 33 | R52; R53; R54; R55; R56; R57; R58; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R69; R70; R71; R89; R90; R91; R92; R93; R94; R111; R116; R117; R118; R119; R120; R121 |
SMR0201 | C48657-013 | 2K | IC | 2 | R72; R73 |
SMR0201 | C48657-043 | 33.2 | IC | 6 | R74; R75; R76; R77; R78; R79 |
SMR0201 | C48657-088 | 10.5K | IC | 1 | R112 |
SMR0402 | RESD,0201,1%,1/20W,562_SMR0402_ | 576 | IC | 4 | R38; R86; R88; R114 |
SMR0402 | C65288-008 | 100mOhm | IC | 5 | R82; R83; R84; R113; R115 |
SOD123_67X106 | E58800-001 | RB160M-40 | IC | 3 | CR1; CR8; CR9 |
SOT23 | C81974-001 | BSS138 | IC | 8 | Q2; Q3; Q4; Q5; Q6; Q8; Q9; Q11 |
SOT23_6_SUPER_NOEP_1P22H | FDC6331 | FDC6331L | IC | 5 | Q7; Q10; Q12; Q13; Q14 |
SSW2RPB | D90553-001 | LIGHT TOUCH SWITCH EVQP7J01P | IC | 5 | SW1UI1; SW1UI2; SW1UI3; SW1UI4; SW1UI5 |
SW_SSAJ110100_3P | G99612-001 | Slide switch,SSAJ110100 | IC | 1 | SW1 |
SYMBOL_NPTH125 | SYMBOL_NPTH125_0_SYMBOL_NPTH125 | NPTH125 | IC | 6 | MGT5; MTG3; MTG4; MTG6; MTG7; MTG8 |
TP30S | TESTPAD_30 | 30 MIL TESTPAD | IC | 88 | TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP22; TP23; TP24; TP25; TP26; TP27; TP28; TP29; TP30; TP31; TP32; TP33; TP34; TP35; TP36; TP37; TP38; TP39; TP40; TP41; TP42; TP43; TP44; TP45; TP46; TP47; TP48; TP49; TP50; TP51; TP52; TP53; TP54; TP55; TP56; TP57; TP58; TP59; TP60; TP61; TP62; TP63; TP64; TP65; TP66; TP67; TP68; TP69; TP70; TP71; TP72; TP73; TP74; TP75; TP76; TP77; TP78; TP79; TP80; TP81; TP82; TP83; TP84; TP85; TP86; TP87; TP88 |
