Bill of Material Report (Condensed) | | | | | |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
HS_2P_DER648A | HS_2P_DER648A_HS_2P_DER648A_HEA | HEATSINK, FAB, DER648, PI CUST | IC | 1 | HS1 |
HS_2P_DER648B | HS_2P_DER648B_HS_2P_DER648B_HEA | HEATSINK, FAB, DER648, PI CUST | IC | 1 | HS2 |
PI14WRESD100LS400D030 | R_PI14WRESD100LS500D030_6.2 M_P | 6.2 M | IC | 1 | R15 |
PI14WRESD100LS400D030 | R_PI14WRESD100LS500D030_4.7_PI1 | 4.7 | IC | 1 | R27 |
PI14WRESD100LS400D030 | R_PI14WRESD100LS400D030_6.81 K_ | 6.81 k | IC | 1 | R28 |
PI14WRESD100LS500D030 | R_PI14WRESD100LS400D030_2.2_PI1 | 2.2 | IC | 1 | R26 |
PI14WVRESD100LS100D030 | R_PI14WVRESD100LS100D030_1_PI14 | 1 | IC | 2 | R29; R30 |
PI18WRESD080LS300D030 | R_PI18WVRESD80LS100D030_10 K_PI | 10 k | IC | 1 | R40 |
PIDAX375X070030DO35 | DIODE_ZENER_PIDAX375X070030DO35 | 1N5259B-T | IC | 1 | VR3 |
PIDAX475X125040DO41 | DIODE_PIDAX475X125040DO41_UF400 | UF4005 | IC | 1 | D9 |
PIDAX800X225060DO15DO201AD | DIODE_PIDV300X200X060DO15D0201A | 1N5407-E3/54 | IC | 1 | D4 |
PIDAXBRIDGEGBU8 | DISCRETE BRIDGE_+~~-_PIDAXBRIDG | GBU8J | IC | 1 | BR1 |
PIDISC610X212LS295X95040 | VARISTOR_PIDISC610X212LS295X950 | 470 VAC | IC | 1 | RV2 |
PIDVITO220FPAC | DIODE SCHOTTKY_PIDVITO220FPAC_ | MBRF10H100-E3/45 | IC | 2 | D10; D11 |
PIDVT0220ACREVA | DIODE_PIDVT0220ACREVA_LXA03T600 | LXA03T600 | IC | 1 | D7 |
PIMTGHOLED156 | POST_CRKT_BRD_6-32_HEX_PIMTGHOL | Post Hex, 6-32, snap, 0.50"L, NYL | IC | 3 | POST-CRKT_BRD_6-32_HEX1; POST-CRKT_BRD_6-32_HEX2; POST-CRKT_BRD_6-32_HEX3 |
PINPCAPRAD200X100200030 | CAP NP_PINPCAPRAD200X100200030_ | 330 nF | IC | 1 | C31 |
PINPCAPRAD370X156250040 | CAP NP_PINPCAPRAD370X156250040_ | 47 pF | IC | 1 | C30 |
PINPXCAPRAD710X430720040 | CAP NP_PINPXCAPRAD710X430720040 | 680 nF | IC | 2 | C3; C4 |
PINPXCAPRAD720X240590040 | CAP NP_PINPXCAPRAD720X240590040 | 12nF | IC | 1 | C29 |
PINPYCAPRAD470X210LS380040 | CAP NP_PINPYCAPRAD470X210LS3800 | 680 pF | IC | 2 | C1; C2 |
PINPYCAPRAD540X290LS400040 | CAP NP_PINPYCAPRAD540X290LS4000 | 2.2 nF | IC | 1 | C20 |
PIPOLCAPCLYD25MMLS10MMD086 | CAP POL_PIPOLCAPCLYD25MMLS10MMD | 100 uF | IC | 1 | C19 |
PIPOLCAPCLYD320LS140030 | CAP POL_PIPOLCAPCLYD320LS140030 | 82 uF | IC | 2 | C32; C33 |
PIPOLCAPCLYD500LS200040 | CAP POL_PIPOLCAPCLYD500LS200040 | 180 uF | IC | 1 | C34 |
PIPOLCAPCYLD250LS100030 | CAP POL_PIPOLCAPCYLD250LS100030 | 220 uF | IC | 1 | C10 |
PIPOLCAPCYLD250LS100030 | CAP POL_PIPOLCAPCYLD250LS1000_1 | 100 uF | IC | 1 | C11 |
PISMC0603 | CAP NP_PISMC0603_100 NF | 100 nF | IC | 3 | C15; C36; C39 |
PISMC0603 | CAP NP_PISMC0603_1 UF | 1 uF | IC | 1 | C16 |
PISMC0805 | CAP NP_PISMC0805_100 NF | 100 nF | IC | 4 | C6; C7; C8; C9 |
PISMC0805 | CAP NP_PISMC0805_3.3 UF | 3.3 uF | IC | 1 | C12 |
PISMC0805 | CAP NP_PISMC0805_1 UF | 1 uF | IC | 1 | C13 |
PISMC0805 | CAP NP_PISMC0805_470 PF | 470 pF | IC | 2 | C14; C18 |
PISMC0805 | CAP NP_PISMC0805_680 NF | 680 nF | IC | 1 | C21 |
PISMC0805 | CAP NP_PISMC0805_22 NF | 22 nF | IC | 1 | C22 |
PISMC0805 | CAP NP_PISMC0805_4.7 NF_10 | 4.7 nF | IC | 2 | C23; C26 |
PISMC0805 | CAP NP_PISMC0805_1 NF_10 | 1 nF | IC | 1 | C27 |
PISMC0805 | CAP NP_PISMC0805_6.8 NF | 6.8 nF | IC | 1 | C35 |
PISMC0805 | CAP NP_PISMC0805_3.3 NF | 3.3 nF | IC | 1 | C38 |
PISMC1206 | CAP NP_PISMC1206_1 UF | 1 uF | IC | 3 | C24; C25; C37 |
PISMDO214AC12 | DIODE_PISMDO214AC12_ES1C-13-F | ES1C-13-F | IC | 4 | D2; D3; D5; D6 |
PISMDO214AC12 | DIODE_PISMDO214AC12_GS1A-LTP | GS1A-LTP | IC | 1 | D14 |
PISMR0603 | R_PISMR0603_2.2 K | 2.2 k | IC | 2 | R10; R52 |
PISMR0603 | R_PISMR0603_30.1 K | 30.1 k | IC | 1 | R12 |
PISMR0603 | R_PISMR0603_143 K | 143 k | IC | 1 | R16 |
PISMR0603 | R_PISMR0603_220 | 220 | IC | 1 | R31 |
PISMR0603 | R_PISMR0603_10 K | 10 k | IC | 2 | R37; R49 |
PISMR0603 | R_PISMR0603_9.09 K | 9.09 k | IC | 1 | R39 |
PISMR0603 | R_PISMR0603_22 K | 22 k | IC | 4 | R43; R45; R50; R51 |
PISMR0603 | R_PISMR0603_39 K | 39 k | IC | 2 | R44; R46 |
PISMR0805 | R_PISMR0805_1.3 M | 1.3 M | IC | 1 | R6 |
PISMR0805 | R_PISMR0805_143 K | 143 k | IC | 1 | R11 |
PISMR0805 | R_PISMR0805_21.0 K | 21.0 k | IC | 1 | R20 |
PISMR0805 | R_PISMR0805_4.7 K_5% | 4.7 k | IC | 1 | R21 |
PISMR0805 | R_PISMR0805_127 K | 127 k | IC | 1 | R22 |
PISMR0805 | R_PISMR0805_90.9 K | 90.9 k | IC | 1 | R23 |
PISMR0805 | R_PISMR0805_1 K | 1 k | IC | 2 | R24; R34 |
PISMR0805 | R_PISMR0805_5.76 K | 5.76 k | IC | 1 | R25 |
PISMR0805 | R_PISMR0805_43 | 43 | IC | 1 | R32 |
PISMR0805 | R_PISMR0805_33 K | 33 k | IC | 1 | R33 |
PISMR0805 | R_PISMR0805_2.2 K | 2.2 k | IC | 1 | R36 |
PISMR1206 | JUMPER_1_PISMR1206_0.0 | 0 | IC | 3 | JP1; JP2; JP3 |
PISMR1206 | R_PISMR1206_150 K | 150 k | IC | 2 | R1; R2 |
PISMR1206 | R_PISMR1206_7.5 K | 7.5 k | IC | 3 | R3; R4; R5 |
PISMR1206 | R_PISMR1206_6.2 M | 6.2 M | IC | 3 | R7; R8; R14 |
PISMR1206 | R_PISMR1206_3.74 M | 3.74 M | IC | 2 | R9; R13 |
PISMR1206 | R_PISMR1206_1.20 M | 1.20 M | IC | 1 | R17 |
PISMR1206 | R_PISMR1206_1.20 M_1% | 1.20 M | IC | 2 | R18; R19 |
PISMR1206 | R_PISMR1206_10 K | 10 k | IC | 1 | R35 |
PISMR1206 | R_PISMR1206_16.2 K | 16.2 k | IC | 1 | R38 |
PISMR1206 | R_PISMR1206_0.05 | 0.05 | IC | 2 | R41; R42 |
PISMR1206 | R_PISMR1206_301 K | 301 k | IC | 1 | R48 |
PISMSOD323 | DIODE_PISMSOD323_BAV19WS | BAV19WS | IC | 4 | D1; D8; D12; D13 |
PISMSOD323 | DIODE_ZENER_PISMSOD323_BZX384-B | BZX384-B13,115 | IC | 1 | VR2 |
PISMSOT235 | LM321_SOT23-5_PISMSOT235_LM321 | LM321 | IC | 1 | U5 |
PISMSOT23123 | TL431/SOT-23_CAR_PISMSOT23123_L | LM431AIM3 | IC | 1 | U6 |
PISMSOT23123_1 | FET_N_GSD_PISMSOT23123_1_BSS126 | BSS126H6327XTSA2 | IC | 1 | Q1 |
PISMSOT23123_1 | NPN_BEC_PISMSOT23123_1_MMBT4401 | MMBT4401LT1G | IC | 3 | Q2; Q4; Q5 |
PISMSOT23123_1 | FET_N_GSD_PISMSOT23123_1_2N7002 | 2N7002 | IC | 1 | Q3 |
PITPKEYSTONE125X125 | TESTPOINT_PITPKEYSTONE125X125_C | CON1 | IC | 5 | TP1; TP2; TP3; TP4; TP5 |
PI_4_SMD | OPTO_A_B_PI_4_SMD_PC357A | PC357A | IC | 2 | U3; U7 |
PI_AXD8XL6MM050V | GDT_PI_AXD8XL6MM050V_GDT 500V | GDT 500V | IC | 1 | GDT1 |
PI_BOBBIN_ETD34_12P_CUTOUT | PI_LLCXFRMR_DER648_0_PI_BOBBIN_ | 490 uH | IC | 1 | T2 |
PI_DISC1100X290LS400X220D050 | VARISTOR_PI_DISC1100X290LS400X2 | 470 VAC | IC | 1 | RV1 |
PI_HDR_4PIN | CON4_PI_HDR_4PIN_CON4 | CON4 | IC | 1 | J3 |
PI_HDR_5PIN_LS156_LCK | CON5_PI_HDR_5PIN_LS156_LCK_CON5 | CON5 | IC | 1 | J1 |
PI_IC_ESIP16-13_OVAL_SLOT | LC_SWITCH_REV03_PI_IC_ESIP16-13 | LCS702HG | IC | 1 | U4 |
PI_IC_ESIP16-13_SLOT_HPII | HIPERPFS-4-ESIP-16G_PI_IC_ESIP1 | PFS7625H | IC | 1 | U2 |
PI_IC_SMD_SO8_CAPZERO | CAPZERO_PI_IC_SMD_SO8_CAPZERO_C | CAP200DG | IC | 1 | U1 |
PI_IND_4P_500X1050LS450D46 | INDUCTOR_4P_REVB_PI_IND_4P_500X | 9 mH | IC | 1 | L1 |
PI_JUMPER200_D020 | JUMPER_1_PI_JUMPER200_D020_J | J | IC | 1 | JP12 |
PI_JUMPER300-18AWG-SLD | JUMPER_1_PI_JUMPER300-18AWG-SLD | J | IC | 1 | JP10 |
PI_JUMPER300_D020 | JUMPER_1_PI_JUMPER300_D020_J | J | IC | 4 | JP6; JP9; JP13; JP19 |
PI_JUMPER400_D020 | JUMPER_1_PI_JUMPER400_D020_J | J | IC | 1 | JP5 |
PI_JUMPER600-18AWG-SLD | JUMPER_1_PI_JUMPER600-18AWG-SLD | J | IC | 2 | JP4; JP16 |
PI_JUMPER600_D020 | JUMPER_1_PI_JUMPER600_D020_J | J | IC | 2 | JP11; JP18 |
PI_JUMPER700_D020 | JUMPER_1_PI_JUMPER700_D020_J | J | IC | 1 | JP20 |
PI_JUMPER800_D020 | JUMPER_1_PI_JUMPER800_D020_J | J | IC | 1 | JP15 |
PI_JUMPER900_D020 | JUMPER_1_PI_JUMPER900_D020_J | J | IC | 1 | JP14 |
PI_JUMPER1000_D020 | JUMPER_1_PI_JUMPER1000_D020_J | J | IC | 1 | JP7 |
PI_JUMPER1200_D020 | JUMPER_1_PI_JUMPER1200_D020_J | J | IC | 1 | JP8 |
PI_MOLEX_2POL | CON2_PI_MOLEX_2POL_CON2 | CON2 | IC | 2 | J2; J6 |
PI_NP395X200LS300D040 | CAP NP_PI_NP395X200LS300D040_47 | 47 nF | IC | 1 | C28 |
PI_NP_CAP250X200LS170D030 | CAP NP_PI_NP_CAP250X200LS170D03 | 10 nF | IC | 1 | C17 |
PI_NP_CAPRAD18P2X10LS15MMD050 | CAP NP_PI_NP_CAPRAD18P2X10LS15M | 0.68 uF | IC | 1 | C5 |
PI_OUT_DER648 | INDUCTOR_PI_OUT_DER648_300 NH | 300 nH | IC | 1 | L3 |
PI_PFC_DER648 | PFC_7P_DER648_0_PI_PFC_DER648_4 | 489 uH | IC | 1 | T1 |
PI_RAD180X395LS235D031 | THERMISTOR_PI_RAD180X395LS235D0 | 2.5 | IC | 1 | RT1 |
PI_RST_MICROFUSE | FUSE_PI_RST_MICROFUSE_3.15 A_PI | 3.15 A | IC | 1 | F1 |
PI_SM_D_SSMINI2P | DIODE_ZENER_PI_SM_D_SSMINI2P_DZ | DZ2S091M0L | IC | 1 | VR1 |
PI_TOROID_2P_550X950_LS480_D050 | INDUCTOR_PI_TOROID_2P_550X950_L | 330 uH | IC | 1 | L2 |
PI_TOROID_DER648CMC | TORRID 4P_12_34_PI_TOROID_DER64 | 120 uH | IC | 1 | L4 |
