查看: 1871|回复: 22
[AD 10][6层] 海思方案摄像头(NCP1117-ADJ+RT9183+TLV320AIC23BPW)原理图和PCB资料
发表于 2020-1-17 14:02 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
作品名:[AD 10][6层] 海思方案摄像头(NCP1117-ADJ+RT9183+TLV320AIC23BPW)原理图和PCB资料
8 D" N' x( w6 R# \$ t$ S: ^# o! _1 u, X; T6 a5 E
文件描述
; v6 N6 X# Z0 l$ ~+ L1. 作品用途:海思方案摄像头
% |* r/ |7 ~8 m4 l! r( b, A2. 软件版本:AD 10
* i- A( W. G. A9 Q$ T3. 层数:6层板/ I* `1 M: r( d: F: n
4. 用到的主要芯片:NCP1117-ADJ+RT9183+TLV320AIC23BPW
2 K2 A. d  v: w1 T8 t* I5. PCB尺寸:109.9mm*158.9mm0 K4 {* ^, v) K
  M7 n# u) \0 V+ k. W8 n' N作品截图如下:
% |- {1 f& u  z! R顶层截图:& ?0 y0 C6 @. V
/ \* ]" y* z2 _  Q( w% F
9 U3 o6 r2 V# F" }1 F底层截图:
* ^9 L  ~6 [$ `+ \9 w$ f ( O! F8 s/ L  S
( V4 r- P: \- g. v% [
全层截图:
* u" k, K4 @: c  D, f; J4 d
# `' G  F" O7 u  `, P( b  w6 g% K( D* V
叠层信息截图如下:
! T4 T  k' t6 \$ L0 N+ W
+ t0 b4 M9 k5 P5 C/ P
/ W  m5 @, g$ F9 j3 g! @9 W5 GBOM:
: }9 W4 S! |3 N" |8 R  f2 v
Comment(属性)
Designator(位号)
Footprint(封装)
Quantity(数量)
220uF/25V
C1, C10, C12, C42
CAP-AE6.3
106A
C2, C3, C4, C5, C6,  C7, C8, C9, C61, C62
c1210
10
220uF/16V
C11, C43
CAP-AE6.3
470uF/10V
C13
CAP-AE6.3
476J
C14, C15, C16, C17,  C20, C21, C28, C30, C31, C32, C33, C34, C35, C41, C54, C63, C64
1206C
17
475J
C18, C40, C60
1206C
106J
C22, C23, C24, C25,  C26, C27, C29, C37, C38, C44, C45, C47, C48, C49, C55, C56, C59
1206C
17
NC
C39
1206C
100uF/16V
C50, C51
CAP-AE6.3
225A
C52
1206C
106A
C53
1206C
226A
C57
c1210
陶瓷电容-2000V1000pF
C58
RES200
0.1uF
C100, C101, C102,  C103, C104, C105, C106, C107, C108, C110, C111, C112, C131, C132, C133, C134,  C135, C136, C137, C138, C139, C140, C141, C142, C143, C144, C145, C146, C147,  C148, C149, C150, C151, C152, C153, C156, C157, C158, C159, C160, C161, C162,  C163, C164, C165, C166, C167, C168, C169, C170, C171, C172, C173, C174, C175,  C176, C177, C178, C179, C180, C181, C182, C183, C184, C185, C186, C187, C188,  C189, C190, C191, C192, C193, C194, C195, C196, C197, C198, C199, C200, C201,  C202, C203, C204, C205, C206, C207, C208, C209, C210, C211, C212, C213, C214,  C217, C218, C219, C220, C221, C222, C223, C224, C225, C227, C228, C229, C231,  C232, C233, C234, C235, C236, C237, C238, C239, C240, C241, C242, C243, C244,  C245, C246, C248, C249, C250, C251, C252, C253, C254, C255, C256, C257, C258,  C259, C260, C261, C262, C263
1608[0603]
138
47nF
C300, C305
1608[0603]
1uF
C301, C306, C320,  C321, C322, C323, C326, C335, C338, C340, C341, C343
1608[0603]
12
10nF
C302, C307, C319,  C331, C332, C333, C334, C336, C345
1608[0603]
9
100pF
C303, C308, C337,  C339, C342
1608[0603]
2.2nF
C304, C309
1608[0603]
2.2uF
C310, C315
1608[0603]
27pF
C311, C312, C313,  C314, C329, C330
1608[0603]
47pF
C316, C327
1608[0603]
270PF
C317, C318
1608[0603]
20pF
C324, C325, C346,  C347
1608[0603]
1uF
C348, C349, C350,  C351
2012[0805]
2.2uF/NC
C352, C353, C354,  C355, C358
2012[0805]
22PF
C356
1608[0603]
1uF/NC
C357
1608[0603]
1N5819
D1
1206_DIODE_X
D2, D3, D4, D5, D6
LED_HOLE
D7, D8
LED1206
38kHzIRDA
D9
IR_MODULE
KDZ5V1  / NC
D10, D11
1206_DIODE_X
SSQ12
F1
FUSE_SMT
PWC3_A_0
J1
DCjack
DC12V
J2
HD2X1_2MM
extend
J3
2mmHDR2X12
SW DIP-2 NC
J4
SW-2
Vedio IN
J5, J6
BNC-6-B_SJMA
audio
J7
VF4A
PHONEJACK  STEREO
J8, J9
STEREO_JACK_LOWER
Header 12X2A
J10
HDR2X12_CEN
SIP7M2
J11
HDD-SATA-2.5
SATA_POWER
J12
HDR1X4
USB-4
J13, J14
USB-AF90
MJ8-SL
J15
RJ45_SOCKET_LED
UART0
J16
HD4X1_2MM
UART2
J17
HD4X1_2MM
SD
J18
SD15A
I2C
J19
HD4X1_2MM
AUDIO
J20
HDR1X6
J21, J22, J23, J24,  J25, J26, J27, J28, J29
MA
9
USB2.0
J30
HDR1X4
USB1.1
J31
HDR1X4
AUDIO
J32
HDR1X5
DC5V 单刀双掷
K1, K2
RELAY_12
10uH
L1, L2
SLF12555
1.8UH
L3
2012[0805]
MGLB2012_220T_LF
LB1
2012[0805]
MGLB3216_060T_LF
LB2, LB3, LB4, LB5,  LB6, LB7
3216 Chip
MGGB2012U101HT_LF
LB8, LB18, LB19
2012[0805]
BLM21PG221SN1D
LB9, LB10, LB11, LB12
2012[0805]
MGGB2012D601LT_LF
LB13, LB14, LB15,  LB16, LB17
2012[0805]
HOLE125-8STAR
M1, M3, M4, M5
FIXHOLE
NPN
Q1, Q2, Q6, Q8
SOT23A
FDS6670A
Q3, Q4
so8
BAV99
Q5, Q7
SOT-23
SI2305DS
Q9
sot-23
2K
R10, R18, R25, R28,  R29, R33, R36, R184
1608[0603]
8
51
R11
1608[0603]
1K
R12, R13, R14, R16,  R24, R32, R49, R53, R56, R57, R91, R102, R105, R106, R127, R131, R155, R157,  R167
1608[0603]
19
4.7K
R15, R43, R44, R46,  R47, R58, R59, R89, R90, R111, R123, R124, R125, R126, R128, R132, R135,  R136, R137, R138, R139, R141, R142, R143, R144, R145, R146, R147, R161, R165,  R166, R224, R227, R240, R262
1608[0603]
35
0
R17, R39, R42, R54,  R55, R108, R180, R181, R202, R203, R212, R213, R225, R230, R231, R237, R238,  R239, R260, R267
1608[0603]
20
220
R19, R20, R22, R159,  R160
1608[0603]
R21, R200, R201
1608[0603]
5.1K
R23, R31, R185, R186,  R187, R188, R189, R190, R191, R192, R194, R195, R196, R197, R198, R199
1608[0603]
16
4.02K
R26, R34
1608[0603]
10K
R27, R35, R48, R109,  R110, R163, R172, R173, R175, R221, R253
1608[0603]
11
150
R30
1608[0603]
3.32K
R37
1608[0603]
R38
1608[0603]
1M
R40, R41
1608[0603]
4.7K/nc
R45, R148, R149,  R150, R156, R226, R273, R274, R275, R276, R277, R278, R279, R280, R281, R282
1608[0603]
16
NC
R50, R51, R52, R60,  R61, R62, R107, R121, R209, R210, R261, R266
1608[0603]
12
100
R65, R66, R85, R86,  R87, R88, R103, R104, R122, R171, R215, R216
1608[0603]
12
33
R67, R68, R69, R70,  R71, R72, R73, R74, R75, R76, R77, R78, R79, R80, R81, R82, R83, R84, R101,  R112, R113, R114, R115, R116, R140, R153, R182, R183, R228, R229
1608[0603]
30
22
R92, R176, R177
1608[0603]
12K
R99
1608[0603]
R100, R208, R211,  R234, R235, R268, R269, R270, R271
1608[0603]
9
100k
R117, R118, R119,  R120
1608[0603]
0805/0R
R129, R130, R133,  R134
2012[0805]
0/nc
R151, R232, R233,  R252, R272
1608[0603]
R154
1608[0603]
1K/nc
R162
1608[0603]
R164
1608[0603]
3.48K
R168
1608[0603]
10K/nc
R174
1608[0603]
15K
R178, R179
1608[0603]
1.5K
R193
1608[0603]
R204, R205, R206,  R207
1608[0603]
R214
1608[0603]
47K
R217, R218, R219,  R220, R222, R223
1608[0603]
10K /NC
R236
1608[0603]
R241, R243, R245,  R247
1608[0603]
R242, R244, R246,  R248
1608[0603]
0/NC
R249
2012[0805]
R250
2012[0805]
10M
R251
1608[0603]
100K/NC
R263
1608[0603]
580/NC
R264, R265
1608[0603]
RN1, RN2, RN3, RN4,  RN5, RN6, RN7, RN8, RN9, RN10, RN11, RN12, RN13, RN14, RN15, RN16, RN17,  RN18, RN19, RN20
RES0603*4
20
10K
RN21
RES0603*4
SW-PB
SW1
SD_4
SW-PB
SW2
SW-6-6
000-7090-37R
T1
TFM16-50-285
TEST
TS2, TS3, TS4, TS5,  TS16, TS17, TS18, TS19, TS20, TS21, TS22
tp
11
TEST
TS10, TS11, TS13,  TS14, TS15
tp2
TPS54350
U1, U2
SOP65P780-16L
NCP1117-ADJ
U3, U4, U5, U29
SOT223
RT9183
U6
so8
HI3511_DDR2
U7
BGA80P22X22-484
TLV320AIC23BPW
U8
TSOP65P640-28AN
BATTERY
U9
BATTERY/FIG2_1
K4T1G164QA-ZCE6000
U10
BGA80P9X9-54
HY5PS1G1631CLFP_Y5
U11
BGA80P9X9-54
ADM706SAR
U12
SO8
SN74LVC1G125DBVR
U13, U14
SOT23-5
M29W128GH
U15
TSSO14x20-G56
TW2865
U16
SQFP40P1600X1600-128L
74LVC245
U18
TSOP-20-2
SII3112_MISC
U20
SQFP40P1600X1600-128L-METALLAND
AT24C64/NC
U21
so8
MIC2505
U22
so8
SRV05-4
U23
SOT23-6
RTL8201CP
U24
TSQFP50P900X900-48M
MAX3232E
U25
TSOP65P640-16AL
MAX3485E
U26
so8
AT88SC0104C
U27
SO8
DS1307
U28
so8
32.768k
Y1
XTAL/C-2-TYPE
27MHz
Y2
XTTH_HC-49-US
24MHz
Y3
XTTH_HC-49-US
54MHz
Y4
XTAL4
12.288M
Y5
XTTH_HC-49-US
25MHz
Y6, Y7
XTTH_HC-49-US
' \9 o+ \# B+ g4 R/ R- F
附件:& D7 Z* x) ]( z: E- Q, q$ I
原理图和PCB源文件如下:3 k1 T' t6 L$ c# y0 i1 {
游客,如果您要查看本帖隐藏内容请回复
5 W$ f, i' n3 S' t. ~1 i% }) s. M5 p
+ \3 \* F3 Q" P
推荐
发表于 2023-2-2 15:23 | 只看该作者
最近正好在找摄像头的资料,刚好#
    奋斗
    2021-9-16 15:15
  • 签到天数: 7 天
    [LV.3]偶尔看看II
    推荐
    发表于 2021-7-20 17:55 | 只看该作者
    最近正好在找摄像头的资料,刚好
    1 u: U( x+ `; s. @
    无聊
    2022-2-23 15:49
  • 签到天数: 20 天
    [LV.4]偶尔看看III
    推荐
    发表于 2021-7-26 12:41 | 只看该作者
    最近正好在找摄像头的资料
    发表于 2021-7-15 17:46 | 只看该作者
    发表于 2021-7-26 13:09 | 只看该作者
    感谢,学习一下; `4 |# w1 H* H" E
    发表于 2021-10-8 00:30 | 只看该作者
    dddddddddddd
    郁闷
    2023-9-28 15:01
  • 签到天数: 16 天
    [LV.4]偶尔看看III
    发表于 2022-8-2 13:15 | 只看该作者
    谢谢共享,感谢
    发表于 2022-8-4 11:34 | 只看该作者
    求下载 求下载
    * L+ x0 L" R- C! \" p* i; }# ^& p
    2025-8-18 15:03
  • 签到天数: 98 天
    [LV.6]常住居民II
    发表于 2022-8-4 14:31 | 只看该作者
    相互学习,感谢分享!
    13#
    发表于 2022-9-21 10:58 | 只看该作者
    #在这里打卡快速回复#
    15#
    发表于 2022-10-9 17:44 | 只看该作者
    感谢,学习一下
    GMT+8, 2025-8-19 18:56 , Processed in 0.171875 second(s), 29 queries , Gzip On.
