查看: 199|回复: 0
[allegro17.2][6层]基于i.MX6系列的车载信息娱乐系统SABRE-AI-BASE_BOARD原理图PCB...
发表于 2020-1-16 19:35 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro17.2][6层]基于i.MX6系列的车载信息娱乐系统SABRE-AI-BASE_BOARD原理图PCB(CON_2X30+ADV7180+CON SKT 281)原理图和pcb文件
文件描述:
1. 作品用途:基于i.MX6系列的车载信息娱乐系统SABRE-AI-BASE_BOARD原理图PCB
2. 软件版本:allegro17.2
3. 层数:6层
4. 用到的主要芯片:CON_2X30+ADV7180+CON SKT 281
5. PCB尺寸:7204*6417 mil
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
0402_MLPDIODE_TVS_BIDIR_0402_MLP_IC_0.40402ESDA-MLPIC2D57; D58
C035STEST PAD_C035S_IC_0.1 MM_280-75TEST POINTIC52DCLK1; DFS1; DOUT1; EEPROM_SCK1; EEPROM_SDA1; TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP14; TP20; TP21; TP22; TP23; TP24; TP26; TP28; TP29; TP30; TP31; TP35; TP36; TP40; TP41; TP42; TP43; TP44; TP45; TP46; TP47; TP48; TP49; TP50; TP51; TP52; TP53; TP54; TP55; TP56; TP_BLEND_IBOC1; TP_IOUT_IBOC1; TP_IQCLK_IBOC1; TP_IQFS_IBOC1; TP_QOUT_IBOC1
CASE403D_02DIODE_CASE403D_02_IC_2.41MM_480MURA160T3GIC1D36
CASE_ACAP_POL_CASE_A_DISCRETE_1.8MM_14.7UFDISCRETE2C54; C68
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6350.1UFDISCRETE60C10; C40; C48; C50; C52; C59; C60; C65; C66; C70; C73; C74; C76; C77; C88; C118; C119; C121; C122; C124; C125; C127; C128; C130; C131; C133; C134; C135; C136; C137; C139; C140; C142; C143; C145; C146; C148; C149; C150; C151; C152; C153; C156; C159; C160; C161; C163; C165; C167; C170; C171; C172; C173; C174; C175; C176; C177; C195; C196; C197
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6MM1.0UFDISCRETE6C15; C16; C85; C105; C116; C117
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_10.1uFDISCRETE6C17; C18; C21; C24; C29; C30
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_22200PFDISCRETE10C20; C28; C34; C36; C38; C42; C44; C46; C55; C62
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_30.01uFDISCRETE10C57; C58; C63; C64; C71; C155; C162; C164; C166; C168
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UFDISCRETE7C79; C80; C84; C106; C107; C111; C112
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.740.01UFDISCRETE1C82
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5556PFDISCRETE5C90; C96; C97; C103; C104
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M0.1uFDISCRETE4C93; C100; C109; C113
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_11000PFDISCRETE2C95; C102
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_20.082UFDISCRETE1C154
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.59M18PFDISCRETE2C157; C158
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5MM0.22UFDISCRETE2C178; C179
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_10.47UFDISCRETE5C1; C5; C9; C189; C190
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM680PFDISCRETE3C3; C6; C12
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.0MM10UFDISCRETE8C11; C39; C69; C75; C78; C141; C144; C147
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_14.7uFDISCRETE2C31; C32
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_21UFDISCRETE1C72
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9 M2.2uFDISCRETE4C94; C101; C108; C110
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.95M0.22UFDISCRETE3C188; C201; C202
CC0805CAP_NP_CC0805_DISCRETE_1.27MM_14.7uFDISCRETE2C51; C169
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.33UFDISCRETE4C181; C182; C183; C184
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4MM2.2UFDISCRETE5C191; C192; C203; C204; C205
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_110UFDISCRETE11C193; C194; C198; C199; C200; C206; C207; C208; C209; C210; C211
CC1210CAP_NP_CC1210_DISCRETE_2.413MM_100UFDISCRETE2C47; C49
CC1210CAP_NP_CC1210_DISCRETE_2.42 MM_47uFDISCRETE1C212
CC3216CAP_POL_CC3216_DISCRETE_1.8 MM_3.3uFDISCRETE8C19; C27; C33; C35; C37; C41; C43; C53
CC3216CAP_POL_CC3216_DISCRETE_1.8MM_110UFDISCRETE2C45; C56
CC3528-21CAP_POL_CC3528-21_DISCRETE_2.1M22uFDISCRETE3C4; C8; C14
CC7343ACAP_POL_CC7343A_DISCRETE_3.1MM_4.7UFDISCRETE3C2; C7; C13
CCE10_3X10_3CAP_POL_CCE10_3X10_3_DISCRETE_8150UFDISCRETE2C81; C83
CON2_RCA_VERT_THKLPX0848A_CON2_RCA_VERT_TH_IO_1RCA 2 CONNIO3J29; J42; J43
CON6_RCA_9F_14_THAV6_8_4_7_CON6_RCA_9F_14_TH_IO_6XRCAIO2J26; J27
CON19_SDCARD_28X16_SMCONN_SDC013_19P_CON19_SDCARD_28CONN CRD 19IO1U25
CON_DB_9F_2P74_THCONN_DB9F_MTGTABS_CON_DB_9F_2P7DB9IO1J34
CON_DF_30F_1MM_SM_RACON30_DF19G-30P-1H_CON_DF_30F_1CON 30IO1J38
CON_SKT_10F_100_THCONN_HDR_5X2_CON_SKT_10F_100_THCON_2X5IO1J46
CON_SKT_44_0P5_SMTCONN_SKT_44P_CON_SKT_44_0P5_SMTQSH-020-01-L-D-DP-AIO1J40
CON_SKT_270F_0P5_SM_RA_NSPCONN_281P_CON_SKT_270F_0P5_SM_RCON SKT 281IO1J44
CON_TFM_60M_50_SMHDR_2X30_M_CON_TFM_60M_50_SM_IOCON 2X30 PLUGIO1J41
CON_USCAR_5F_32_THUSCAR_TYPE_A_CON_USCAR_5F_32_THUSCAR_TYPE_AIO3J30; J31; J37
CON_ZF5_15F_0P5_SMZF5_15_CON_ZF5_15F_0P5_SM_IO_2.ZF5_15IO1CN1
DFN_6_0P65_2P1X2ISL29023_DFN_6_0P65_2P1X2_IC_0.ISL29023IC1U30
DFN_10_0P4_2X2MAG3112_DFN_10P_DFN_10_0P4_2X2_MAG3110IC1U31
HDR1X2_1P25_SMHDR_1X2_M_HDR1X2_1P25_SM_IO_3.653261-0219IO2J5; J6
HDR2X4_TSM_SMCONN_HDR_4X2_HDR2X4_TSM_SM_IO_1HDR 2X4IO1J45
HDR2X30_650W_SMCONN_2X30_HDR2X30_650W_SM_IO_11CON_2X30IO1J36
HDR102CONN_HDR_2X1_HDR102_IO_8.71 MM_HDR 1X2 THIO1J33
HDR103CONN_HDR_3X1_HDR103_IO_11.29MM_TSW-103-07-G-S+SNT-100-BK-TIO1J1000
HDR205CONN_HDR_5X2_HDR205_IO_8.38 MM_HDR 2X5IO1J35
HDR205HEADER5X2_HDR205_IO_9.5MM_210-7HDR_2X5IO1P1
HDR215_ACONN_HDR_15X2_HDR215_A_IO_10.69HDR_2X15_MIO1J32
HDR_1X4_200_THCONN_HDR_4X1_HDR_1X4_200_TH_IO_HDR_1X4IO1J2
IND_0603BEAD_IND_0603_DISCRETE_0.95MM_1120OHMDISCRETE13L4; L5; L6; L7; L10; L11; L12; L13; L14; L15; L16; L17; L18
IND_0805BEAD_IND_0805_DISCRETE_1.05MM_1330OHMDISCRETE2L8; L9
IND_2220INDUCTOR_A_IND_2220_DISCRETE_5.LQH55DN2R2M03LDISCRETE3L1; L2; L3
JACK_PWR_3M_393_TH_PJ028AHDC POWER JACK_JACK_PWR_3M_393_TPJ-028AHIO1J1
LED_0603LED_LED_0603_IC_0.8MM_370-75077LED_GREENIC3D31; D32; D56
LED_0603LED_LED_0603_IC_0.9MM_370-75079REDIC2D33; D34
LQFP64ADV7180BSTZ_LQFP64_IC_1.6MM_312ADV7180IC1U29
LQFP64_0P5_10X10CS42888_LQFP64_0P5_10X10_IC_1.6CS42888IC1U7
LQFP64_0P5_10X10DS90UR124_TQFP_64P_LQFP64_0P5_1DS90UR124QVSIC1U15
MODULE28_2_71P1X40P7SX78000150_28P_MODULE28_2_71P1XSX-7800-0150IC1U28
MSOP10_0P5_3P1X3P1LT3680_MSOP_10P_MSOP10_0P5_3P1XLT3680IC3U1; U2; U4
OSC_ECS_2532HSECS-2532HS-260-3_OSC_ECS_2532HS26MHzIC1Y1
QFN5X3_0P5_3X3MMA8451Q_16P_A_QFN5X3_0P5_3X3_IMMA8451QIC1U33
QFN24_4X4MM_SLUGUSB3317_QFN24_4X4MM_SLUG_IC_1.0USB3317IC1U23
RC0402_25RES_RC0402_25_DISCRETE_470-309512.7KDISCRETE3R3; R7; R11
RC0402_25RES_RC0402_25_DISCRETE_470-3111324KDISCRETE1R10
RC0402_25RES_RC0402_25_DISCRETE_470-75390DISCRETE50R13; R15; R16; R19; R21; R22; R26; R27; R166; R175; R182; R184; R185; R186; R187; R191; R197; R199; R200; R217; R220; R223; R234; R235; R250; R256; R258; R266; R267; R270; R271; R281; R283; R291; R296; R297; R298; R299; R300; R301; R302; R303; R304; R305; R306; R307; R308; R311; R312; R319
RC0402_25RES_RC0402_25_DISCRETE_470-7560150KDISCRETE3R14; R20; R225
RC0402_25RES_RC0402_25_DISCRETE_470-78352.2KDISCRETE2R17; R18
RC0402_25RES_RC0402_25_DISCRETE_470-7559100KDISCRETE2R23; R24
RC0402_25RES_RC0402_25_DISCRETE_470-7646470DISCRETE8R25; R29; R31; R33; R168; R170; R172; R177
RC0402_25RES_RC0402_25_DISCRETE_470-754110.0KDISCRETE11R28; R30; R32; R34; R169; R171; R173; R178; R179; R180; R293
RC0402_25RES_RC0402_25_DISCRETE_470-3113499KDISCRETE1R57
RC0402_25RES_RC0402_25_DISCRETE_470-75_3100DISCRETE7R88; R248; R249; R251; R252; R257; R272
RC0402_25RES_RC0402_25_DISCRETE_470-755510KDISCRETE45R129; R167; R201; R202; R203; R204; R205; R206; R207; R208; R209; R210; R211; R213; R214; R215; R219; R221; R226; R227; R228; R229; R230; R231; R232; R233; R236; R237; R238; R239; R240; R241; R242; R243; R244; R245; R246; R260; R268; R269; R274; R282; R288; R292; R313
RC0402_25RES_RC0402_25_DISCRETE_470-30861.8KDISCRETE4R164; R165; R247; R315
RC0402_25RES_RC0402_25_DISCRETE_470-75_14.7KDISCRETE6R188; R279; R280; R286; R294; R314
RC0402_25RES_RC0402_25_DISCRETE_470-76031.0KDISCRETE2R189; R310
RC0402_25RES_RC0402_25_DISCRETE_470-3074110DISCRETE1R190
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710.0KDISCRETE2R192; R193
RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_820DISCRETE2R194; R196
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_18.06KDISCRETE1R195
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__10DISCRETE1R198
RC0402_25RES_RC0402_25_DISCRETE_470-75_222KDISCRETE2R212; R320
RC0402_25RES_RC0402_25_DISCRETE_470-306830DISCRETE4R216; R218; R222; R224
RC0402_25RES_RC0402_25_DISCRETE_470-79960DISCRETE1R265
RC0402_25RES_RC0402_25_DISCRETE_470-306939DISCRETE4R275; R276; R277; R278
RC0402_25RES_RC0402_25_DISCRETE_470-30841.2KDISCRETE2R284; R285
RC0402_25RES_RC0402_25_DISCRETE_470-30851.69KDISCRETE1R287
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_23.3KDISCRETE1R309
RC0603_OVRES_RC0603_OV_DISCRETE_470-301515KDISCRETE6R1; R5; R9; R35; R36; R290
RC0603_OVRES_RC0603_OV_DISCRETE_470-7815536.0KDISCRETE2R2; R6
RC0603_OVRES_RC0603_OV_DISCRETE_470-7542100KDISCRETE3R4; R8; R12
RC0603_OVRES_RC0603_OV_DISCRETE_470-75400DISCRETE2R37; R38
RC0603_OVRES_RC0603_OV_DISCRETE_470-75562.49KDISCRETE4R174; R176; R181; R183
RC0603_OVRES_RC0603_OV_DISCRETE_470-76241.0MDISCRETE1R289
SC70-51G126_SC70-5_IC_1.1MM_312-79761NC7SP126IC4U35; U1036; U1037; U1038
SC82_4NCP562_SC82_4_IC_1.1MM_312-7732NCP562IC1U16
SH0402RES_SHORT-2_SH0402_DISCRETE_4700DISCRETE132SH121; SH124; SH125; SH126; SH127; SH128; SH129; SH130; SH131; SH132; SH133; SH134; SH135; SH136; SH137; SH138; SH139; SH140; SH141; SH142; SH143; SH144; SH145; SH146; SH147; SH148; SH149; SH150; SH151; SH152; SH153; SH154; SH155; SH156; SH157; SH158; SH159; SH160; SH161; SH162; SH163; SH164; SH165; SH166; SH167; SH168; SH169; SH170; SH171; SH172; SH173; SH174; SH176; SH177; SH178; SH179; SH180; SH181; SH182; SH183; SH184; SH185; SH186; SH187; SH188; SH208; SH209; SH210; SH211; SH212; SH213; SH214; SH215; SH216; SH217; SH218; SH219; SH220; SH221; SH222; SH223; SH224; SH225; SH226; SH227; SH228; SH229; SH230; SH231; SH232; SH233; SH234; SH235; SH236; SH237; SH238; SH239; SH240; SH241; SH242; SH243; SH244; SH245; SH246; SH247; SH248; SH249; SH250; SH251; SH252; SH253; SH254; SH255; SH256; SH257; SH260; SH261; SH262; SH263; SH264; SH265; SH266; SH267; SH268; SH269; SH270; SH271; SH272; SH273; SH275; SH276; SH277
SH0603RES_SHORT-2_SH0603_DISCRETE_4700DISCRETE1SH274
SMC_CASE403DIODE_SCHTKY_SMC_CASE403_IC_2.5MBRS340T3GIC6D1; D2; D3; D4; D5; D6
SO8-25X75MIC2025_SO8-25X75_IC_1.73MM_315MIC2025-1YMIC2U22; U24
SO14MC33902_SO14_IC_1.75 MM_312-805TJA1041ATIC2U26; U27
SOD323DIODE_SCHTKY_SOD323_IC_1.1MM_48NSR0320IC18D35; D37; D38; D39; D40; D41; D42; D43; D44; D45; D46; D47; D48; D49; D50; D51; D52; D53
SOD-923_NPDIODE_TVS_BIDIR_SOD-923_NP_IC_0ESD9B5.0ST5GIC1TVS1
SOIC1474_04_SOIC14_IC_1.75MM_312-7529MC74HCU04IC1U19
SOT23_S6SRV05-4_SOT23_S6_IC_1.45MM_480-SRV05-4IC1U21
SOT223LD1117AS18_SOT223_IC_1.9MM_315-LD1117AS18IC1U3
SW4_SKRPSW_TC_SPST_4P_SW4_SKRP_IC_2.5MMSKRPABE010IC7SW1; SW2; SW3; SW4; SW5; SW6; SW7
TDFN14_0P4_3P1X3P1MAX9814_TDFN14_TDFN14_0P4_3P1X3MAX9814ETD+TIC2U5; U6
TESTPOINT_35MILTEST PAD_TESTPOINT_35MIL_IC_0.135 MILIC4TP13; TP38; TP39; TP57
TP_TH_063TESTLOOP_TP_TH_063_IO_8.13MM_21TESTLOOP_BLACKIO2TP_GND1; TP_GND2
XFMR6_6P6X6P2XFMR_XFMR6_6P6X6P2_DISCRETE_4.8TTWB1010LDISCRETE1T1
XTLOSC4_5X3MM_SMCRYSTAL_JXS63_XTLOSC4_5X3MM_SM_28.63636MHZIC1Y2
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
: r6 K1 S9 u5 h9 v: k1 A
GMT+8, 2025-7-23 04:53 , Processed in 0.140625 second(s), 28 queries , Gzip On.
