查看: 275|回复: 0
[allegro16.3][12层] Cyclone_V_E_FPGA_Development_Kit Cyclone V E FPGA 开发套...
发表于 2020-1-16 18:52 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
9 G' n, n* N0 s/ O  [
[allegro16.3][12层] Cyclone_V_E_FPGA_Development_Kit Cyclone V E FPGA 开发套件 (5CEFA7F31+MAX V, 5M2210ZF256+2片DDR)原理图和pcb文件, x. H/ O- ^1 L" h8 _- C, L
( Y: ?$ c: k2 J文件描述:' A% b1 `' V# |4 ]8 @
1 v( k. t7 Q6 e" Y6 a5 A7 q1. 作品用途:Cyclone_V_E_FPGA_Development_Kit Cyclone V E FPGA 开发套件
4 |7 b/ p5 l" ]5 h& l* F( W2. 软件版本:allegro16.3
' f- h2 \& O3 x# V3. 层数:12层
5 E) I' U$ H; A( f4. 用到的主要芯片:5CEFA7F31+MAX V, 5M2210ZF256+2片DDR0 ]# Q4 S. h  ~  N
5. pcb尺寸: 165.1*127.03 MM
$ }: l% N3 V4 u7 e* G6 t. l6 W' F' L- G/ F
作品截图如下:4 `4 `9 E& b3 o4 l  D
/ P, Z6 V& i) _; _2 a) Y
顶层截图:
  [1 }$ T- H# G  | * _: u: Y: S7 Q0 `0 d9 {
底层截图:
! M" d! T$ n& @  D 9 j) h$ b0 A) Q: ]- p; _. m" `# V
" C" g: _& |& \
全层截图:
4 l( e+ r. {4 }, K2 p- ~9 Q9 r0 r* M) n% H6 }- f
# O4 L' |- F% S叠层阻抗信息如下:
% @& r8 v/ U4 z 2 B" d8 p& K. e) |0 k. j! z
BOM:8 c  R, Q; D8 {5 `$ Y& m/ j- U1 ^
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
402CAP 0.1UF 25VDC 0402_0402_DNIDNIIC1C1
402CAP 0.1UF +/-10% 10V 0402_0402_0.1uFIC132C3; C4; C5; C7; C9; C11; C12; C14; C16; C17; C18; C19; C34; C35; C36; C42; C43; C44; C51; C52; C53; C63; C64; C65; C66; C67; C68; C69; C70; C73; C74; C75; C76; C77; C78; C79; C80; C81; C83; C84; C85; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C98; C99; C100; C101; C102; C110; C111; C112; C113; C114; C115; C116; C117; C118; C119; C120; C121; C122; C128; C129; C130; C131; C132; C133; C134; C135; C136; C137; C138; C139; C140; C141; C142; C143; C145; C148; C149; C150; C151; C152; C153; C154; C155; C156; C157; C158; C159; C160; C161; C166; C168; C246; C249; C250; C251; C260; C261; C262; C267; C268; C269; C270; C286; C287; C288; C289; C315; C317; C318; C320; C324; C333; C334; C335; C336; C339; C347; C353; C355
402CAP 2.2UF +/-20% 6.3V 0402_04022.2uFIC4C6; C10; C13; C230
402CAP 0.1UF +/-10% 10V 0402_040_1DNIIC1C15
402CAP 4.7NF 10% 50V 0402_0402_4.74.7nFIC23C20; C26; C58; C59; C82; C144; C305; C306; C307; C308; C309; C310; C311; C312; C313; C314; C316; C319; C321; C329; C330; C344; C345
402CAP 3300PF 10% 50V 0402_0402_333300pFIC3C21; C27; C216
402CAP 2200PF 10% 50V 0402_0402_222200pFIC14C22; C23; C24; C25; C28; C29; C30; C31; C60; C61; C225; C331; C332; C346
402CAP 0.47UF -20%+80% 10V 0402_040.47uFIC6C32; C33; C40; C41; C257; C350
402CAP 0.01UF 16V X7R 0402_0402_0.0.01uFIC42C37; C38; C39; C45; C46; C47; C56; C57; C105; C106; C107; C108; C109; C123; C124; C125; C126; C127; C283; C284; C285; C290; C291; C292; C293; C294; C295; C296; C297; C298; C299; C300; C301; C302; C303; C304; C327; C328; C342; C343; C351; C354
402CAP 4.7UF 10% 6.3V X5R 0402 _044.7UFIC6C50; C62; C169; C175; C237; C255
402CAP 22NF 10% 16V 0402_0402_22NF22nFIC3C54; C55; C218
402CAP 12PF +/-5% 50V 0402_0402_1212pFIC3C146; C147; C219
402CAP 1.0UF 10% 10V 0402_0402_1.01.0UFIC16C162; C198; C210; C224; C228; C231; C232; C234; C236; C245; C248; C256; C323; C338; C348; C352
402CAP 0.1UF 10% 16V 0402_0402_0.10.1uFIC2C179; C193
402CAP 1000PF 10% 50V 0402_0402_101000pFIC2C180; C181
402CAP 100PF 5% 50VDC 0402_0402_10100pFIC1C183
402CAP 27PF 5% 50V NP0 0402_0402_227pFIC1C184
402CAP 22PF 5% 50V 0402_0402_22PF22pFIC2C188; C203
402CAP 10PF 5% 50V C0G/NP0 0402_0410pFIC1C189
402CAP 0.22UF 10% 10V 0402_0402_0.0.22uFIC4C197; C209; C258; C259
402CAP 270PF 5% 50V 0402_0402_270P270pFIC1C204
402CAP 180PF 10% 50V 0402 X7R_0402180pFIC1C215
402CAP 47000PF 25V 0402_0402_47NF47nFIC7C263; C264; C265; C266; C325; C340; C349
402CAP 22000PF 16V 0402_0402_22NF22nFIC14C271; C272; C273; C274; C275; C276; C277; C278; C279; C280; C281; C282; C326; C341
402RES 100 OHM 1.0% 1/16W 0402_040100IC11R1; R3; R27; R29; R31; R32; R37; R42; R57; R173; R186
402RES 240 OHM 1% 1/16W 0402 SMD_0240IC1R2
402RES 10K OHM 5% 1/16W 0402 SMD_1DNIIC1R4
402RES 1.00K OHMS, 1.0%,1/16W,0402DNIIC8R5; R6; R11; R89; R90; R91; R92; R161
402RES 10K OHM 5% 1/16W 0402 SMD_010KIC46R7; R8; R9; R10; R12; R13; R14; R45; R73; R74; R76; R77; R78; R79; R80; R81; R82; R83; R84; R85; R86; R87; R88; R108; R130; R174; R175; R177; R179; R181; R182; R184; R185; R188; R190; R191; R192; R196; R197; R198; R199; R272; R274; R284; R296; R297
402RES 0 OHM 5% 1/16W 0402 SMD_0400IC26R15; R16; R22; R26; R28; R41; R113; R135; R144; R147; R148; R149; R150; R151; R156; R158; R159; R160; R168; R208; R228; R250; R253; R269; R276; R278
402RES 0 OHM 5% 1/16W 0402 SMD_0_1DNIIC19R17; R18; R19; R23; R54; R75; R114; R136; R172; R204; R205; R210; R227; R230; R241; R246; R254; R267; R277
402RES 1.00K OHMS, 1.0%,1/16W,04_11kIC35R20; R21; R24; R25; R39; R40; R43; R44; R46; R47; R48; R49; R50; R51; R53; R55; R56; R62; R63; R66; R67; R70; R71; R93; R94; R95; R152; R153; R154; R155; R157; R164; R166; R220; R293
402RES 100 OHM 1.0% 1/16W 0402_0_1DNIIC2R30; R292
402RES 4.7K OHM 5% 1/16W 0402_04024.7kIC19R33; R34; R35; R36; R38; R59; R96; R97; R98; R99; R110; R118; R119; R120; R121; R132; R169; R285; R291
402RES 10.0K OHM 1.0% 1/16W 0402_1DNIIC1R52
402RES 51 OHM 5% 1/10W 0402 SMD_04DNIIC1R58
402RES 240 OHM 5% 1/10W 0402 SMD_0240IC3R60; R61; R72
402RES 2.1K OHM 1/16W 0.1% 0402_042.1KIC4R64; R65; R68; R69
402RES 49.9 OHM 1% 1/16W 0402_040249.9IC16R100; R101; R102; R103; R104; R105; R106; R107; R122; R123; R124; R125; R126; R127; R128; R129
402RES 4.99K OHM 1.0% 1/16W 0402_04.99KIC2R109; R131
402RES 220 OHM 5% 1/16W 0402_0402_220IC10R111; R112; R115; R116; R117; R133; R134; R137; R138; R139
402RES 10.0K OHM 1.0% 1/16W 0402_010.0KIC13R140; R234; R245; R271; R279; R280; R281; R282; R283; R287; R288; R289; R290
402RES 1 MEG OHM 1% 1/10W 0402_0401MIC2R141; R248
402RES 20K OHM 1.0% 1/16W 0402_04020KIC3R142; R224; R225
402RES 100K OHM 1.0% 1/16W 0402_04100KIC9R143; R219; R221; R222; R223; R229; R240; R251; R259
402RES 2.0K OHM 1/16W 1% 0402 SMD_2.0KIC5R145; R146; R286; R294; R295
402RES 56.2 OHM 1.0% 1/16W 0402_0456.2IC19R162; R163; R165; R167; R170; R171; R176; R178; R180; R183; R187; R189; R193; R194; R195; R200; R201; R202; R203
402RES 2.43K OHM 1% 1/16W 0402 SMD2.43KIC1R206
402RES 6.49K OHM 1% 1/16W 0402 SMD6.49KIC1R207
402RES 11.5K OHM 1% 1/16W 0402 SMD11.5KIC2R209; R264
402RES 2.55K OHM 1% 1/16W 0402_0402.55KIC1R211
402RES 137K OHM 1% 1/10W 0402_0402137.0KIC1R212
402RES 71.5K OHM 1% 1/16W 0402 SMD71.5KIC1R213
402RES 215K OHM 1% 1/16W 0402_0402215.0KIC2R214; R215
402RES 4.64K OHM 1% 1/16W 0402_0404.64KIC1R216
402RES 11.3K OHM 1% 1/16W 0402_04011.3KIC2R217; R232
402RES 3.24K OHM 1% 1/16W 0402_0403.24KIC1R218
402RES 75K OHM 1% 1/16W 0402 SMD_075KIC1R226
402RES 30.1K OHM 1% 1/16W 0402 SMD30.1KIC2R231; R258
402RES 9.53K OHMS 1% 1/16W 0402_049.53KIC1R233
402RES 143K OHM 1/16W 1% 0402 SMD_143KIC1R238
402RES 13.7K OHM, 1/16W, 1%, 0402_13.7KIC1R242
402RES 2.32K OHM 1.0% 1/10W 0402_02.32KIC1R243
402RES 16.5K OHM 1/10W 1% 0402_04016.5KIC1R244
402RES 221K OHM 1% 1/16W 0402 SMD_221KIC1R252
402RES 47.5K OHM 1% 1/16W 0402 SMD47.5KIC1R256
402RES 31.6K OHM 1% 1/16W 0402 SMD31.6KIC1R257
402RES 17.8K OHM 1% 1/16W 0402_04017.8KIC1R260
402RES 4.02K OHM 1% 1/16W 0402 SMD4.02KIC2R261; R270
402RES 90.9K OHM 1% 1/16W 0402 SMD90.9KIC1R262
402RES 1.15K OHM 1% 1/16W 0402_0401.15KIC1R263
402RES 15K OHM 1% 1/16W 0402_0402_15KIC2R266; R275
402RES 8.06K OHM 1.0% 1/16W 0402_08.06KIC1R268
402RES 110K OHM 1% 1/16W 0402 SMD_110KIC1R273
603CAP 0.22UF +/-10% 25V 0603_06030.22UFIC1C163
603CAP 1UF +/-10% 25V 0603_0603_1U1UFIC3C164; C165; C220
603CAP 2.2UF 10% 10V 0603_0603_2.22.2UFIC1C167
603CAP 0.1UF 50V 0603_0603_0.1UF0.1UFIC5C170; C171; C176; C185; C223
603CAP 2.2UF 10% 10VDC 0603_0603_22.2UFIC2C233; C244
805CAP 10UF +/-10% 6.3V 0805_0805_10uFIC13C2; C8; C48; C49; C71; C72; C205; C238; C239; C240; C242; C243; C322
805CAP 10UF +/-10% 10V 0805_0805_110uFIC2C104; C247
805CAP 4.7UF +/-10% 16V 0805_0805_4.7uFIC3C196; C208; C235
805CAP 22UF +/-10% 6.3V 0805_0805_22uFIC3C226; C227; C337
805CAP 2.2UF +/-10% 25V X7R 0805_02.2uFIC2C229; C241
806IND 10UH 245MA 0.82OHM 0806 SMD10uHIC1L1
1206CAP 10UF +/-10% 25V X5R 1206_1210uFIC2C103; C217
1206CAP 100UF +/-20% 6.3V 1206_1206100UFIC4C177; C252; C253; C254
1206CAP 47UF +/-20% 6.3V 1206_1206_47UFIC8C199; C200; C201; C202; C211; C212; C213; C214
1210CAP 22UF +/-10% 25V 1210_1210_222uFIC10C172; C173; C174; C186; C194; C195; C206; C207; C221; C222
7260CAP-TANT 100UF 7260 10% 25V CAS100UFIC2C190; C191
7343-XCAP-TANT 47UF 7343 20% 35V_734347uFIC2C182; C187
7343PCAP-TANT 330UF 7343 20% 6.3V _7330uFIC1C178
7343PCAP-TANT 220UF 7343 10% 16V_734220uFIC1C192
BCC96ETHERNET PHY, 88E1111_BCC96_ETHEthernet PHY, 88E1111IC2U14; U15
CAP_PACK_4_1206CAP, ARRAY 0.1UF_CAP_PACK_4_1200.1uFIC3CN1; CN2; CN3
CONN_TSW_103_07_L_SHEADER, 1X3-PIN_CONN_TSW_103_07HEADER, 1x3-PINIC1J5
DFM10-EPADREGULATOR, LTC3103_DFM10-EPAD_LLTC3103IC1U27
DFM10-EPADREGULATOR, LTC3026_EDD_DFM10-EPLTC3026IC2U31; U32
DFN6-2X2_EPADREGULATOR, LTC3025-1_DFN6-2X2_ELTC3025-1IC1U29
DFN6-2X2_EPADREGULATOR, LT3009EDC_DFN6-2X2_ELT3009xDCIC2U30; U34
DFN6_EPADDIODE CONTROLLER, LTC4357_DFN6_LTC4357IC1U23
DFN12_EPAD_3X3REG SWITCHING, LTC3600EDD_DFN12LTC3600IC1U28
DIPSWITCH_SMT_QUADSWITCH, DIP X4, TDA04H0SB1_DIPSSwitch, DIP x4, TDA04H0SB1IC4SW1; SW2; SW3; SW4
DRTDIODE, ESD TPD2EUSB30_DRT_TPD2ETPD2EUSB30IC1U19
DRY6_1MMX1P5MMDIODE, 4-CH ESD, TPD4S012DRYR_DDIODE, 4-Ch ESD, TPD4S012DRYRIC1U22
EG2201ASWITCH, SLIDE EE2201A_EG2201A_SSwitch, SLIDE EE2201AIC1SW5
F64_10X8FLASH, PC28F512P30BF_F64_10X8_FFlash, PC28F512P30BFIC1U10
F100MAX II, EPM570GF100I5N_F100_EPMEPM570GF100IC1U16
F256MAX V, 5M2210ZF256I5N_F256_MAXMAX V, 5M2210ZF256IC1U13
FBGA8965CEFA7F31C7NES_F896_FBGA896_(S15CEFA7F31IC1U1
FDMC8878MOSFET N-CHANNEL, FDMC8878_FDMCFDMC8878IC1Q1
HDR2X5_100MIL_SMTHEADER, 2X5-PIN_HDR2X5_100MIL_SDNIIC2J6; J11
HDR2X7_100MILHDR 2X7, VT, THM, TSW-107-07_HDHDR 2X7, VT, THM, TSW-107-07IC1J14
HDR2X8_100MIL_SMTHEADER, 2X8-PIN_HDR2X8_100MIL_S2X8IC2J15; J16
IND_0805IND FERRITE 0805 4A/33 OHMS_IND4A, 33 Ohm FBIC1L5
IND_WURTH_744031100IND 10UH ISAT=560MA 0.205OHM_IN10uHIC1L7
IND_WURTH_744311330IND 3.3UH ISAT=11A 17.2MOHM_IND3.3uHIC1L3
IND_WURTH_744311470IND 2.2UH IR=9A 7040 SMD _IND_W2.2uHIC1L2
IND_WURTH_744314047IND 0.47UH IR=18A ISAT=20A SMD_0.47uHIC2L4; L6
IND_WURTH_74402500047IND 0.47UH IR=3.3A SMD_IND_WURT0.47uHIC1L8
KEYSTONE_BT1_1060CONN, BATTERY HOLDER GOLD_KEYSTBattery HolderIC1BT1
LUMEX_LED0805LED, GREEN 0805 LUMEX_LUMEX_LEDGreen_LEDIC30D1; D2; D3; D4; D5; D6; D7; D8; D9; D10; D11; D12; D13; D14; D15; D16; D18; D19; D20; D21; D22; D23; D24; D25; D26; D27; D28; D29; D30; D31
LUMEX_LED0805LED, RED 0805 LUMEX_LUMEX_LED08RED_LEDIC1D17
LUMEX_LED0805LED, BLUE 0805 LUMEX_LUMEX_LED0BLUE LEDIC1D35
MICRON_DDR3_96_8X14DDR3 SDRAM, MT41J128M16JT-125D_MT41J128M16JT-125IC2U7; U8
MLX_22_23_2021_VRT_HDR_2PHDR 1X2, VT, THM, MOLEX, FAN_ML22_23_2021IC1J18
MLX_SHROUD_VRT_HDR_10PINHDR 2X5, VERTICAL_MLX_SHROUD_VRHDR 2X5, VERTICALIC1J4
MSOP8EEPROM, 24AA64, MSOP, 8-LEAD_MS24AA64-I/MSIC1U12
MSOP10DUAL 10 OHM SPDT, TS5A23157_MSOTS5A23157IC2U5; U6
PSOP-DGQ10REGULATOR, TPS51100DGQ_PSOP-DGQTPS51100DGQIC1U33
PUSHBUTTON_EVQSWITCH, PUSH BUTTON_PUSHBUTTON_Switch, Push ButtonIC8S1; S2; S3; S4; S5; S6; S7; S8
QFN24USB-TO-UART BRIDGE, CP2104_QFN2CP2104IC1U21
QFN40REG SWITCHING, LTC3855_QFN40_LTLTC3855EUH-1IC1U24
QFN52_3EPADREG SWITCHING, LTC3608_QFN52_3ELTC3608IC2U25; U26
RAPC712CONN, DC JACK RAPC712_RAPC712_CCONN JACK PWRIC1J17
RES_PACK_8RES, 51 OHM RES_PAK_8_RES_PACK_51IC3RN1; RN2; RN3
RES_PACK_8RES, 1K OHM RES_PACK_8_RES_PACKDNIIC2RN4; RN5
RJ45_ACONN RJ45 1-PORT TSE BASE-T_RJ47499111001AIC2J8; J9
SAMTEC_QSHDP120CUSTOMCONN, HSMC_MALE_SAMTEC_QSHDP120HSMCIC1J7
SENSESENSE PAD_SENSE_SENSE_PADSENSE_PADIC16V34; V35; V36; V37; V38; V39; V40; V41; V42; V43; V44; V45; V46; V47; V48; V49
SMA_LTI-SASF546-P26-X1CONN, SMA_SMA_LTI-SASF546-P26-XSMAIC3J1; J2; J3
SMY3X5_4PXO, 50MHZ CMOS, 3.2X5MM, SI510_Si510 - 50MHzIC1X2
SMY3X5_4POSC, 100MHZ 2.5V X1 CMOS, SI510Si510 - 100MHzIC1X3
SO8MOSFET N-CHANNEL HILO SI4816BDYSI4816BDYIC2Q2; Q3
SO16_WIDEEPCQ256_SO16_WIDE_EPCQ256EPCQ256IC1U2
SOD323DIODE, SCHOTTKY CMDSH-3_SOD323_CMDSH-3IC4D33; D34; D36; D37
SOD-123DIODE, SCHOTKKY 1N6263W-7-F_SOD1N6263W-7-FIC2D38; D39
SOT23DIODE PACK 100V 200MA MMBD1205_MMBD1205IC1D32
SOT23MOSFET, N-CHANNEL, FDV305N_SOT2FDV305NIC1Q4
SOT-143RESET, MAX811_SOT-143_RESET, MARESET, MAX811IC1U17
SSOP16RS-232 TRANSCEIVER, LTC2803-1_SLTC2803-1IC1U20
SSOP28_NARADC, LTC2418 16-CH_SSOP28_NAR_AADC, LTC2418 16-ChIC1U35
STAR_VIATP_18_8_MIL, PTH_STAR_VIA_VIA_1VIA_1IC7V27; V28; V29; V30; V31; V32; V33
TDFN-10CLK BUFFER 1TO3 LVCMOS SL18860_SL18860DCIC1U4
TQFP100PSRAM, IS61VPS102418A-250TQL_TQFSRAM, IS61VPS102418A-250TQLIC1U11
TSSOP14LEVEL SHIFTER, MAX3378_TSSOP14_Level Shifter, MAX3378IC1U36
TSSOP20CLOCK BUFFER, ICS8543_TSSOP20_IICS8543IC1U3
USB2_0-RACONN, USB TYPE B_USB2_0-RA_USBUSB Type BIC1J10
USB2_H_FEMALE_TYPE-ACONN, USB HORIZONTAL, TYPE A_USUSB Type AIC1J13
VFBGA56USB MICROCONTROLLER, CY7C68013AUSB Microcontroller, CY7C68013AIC1U18
VIA_017RD010VIA, 017RD010_PTH_VIA_017RD010_VIAIC26V1; V2; V3; V4; V5; V6; V7; V8; V9; V10; V11; V12; V13; V14; V15; V16; V17; V18; V19; V20; V21; V22; V23; V24; V25; V26
WFBGA168LPDDR2, MT42L128M32D1LF-25WT_WFMT42L128M32D1LF-25WTIC1U9
WSL2010RES 0.003 OHM 1% 1/2W 2010_WSL20.003IC7R235; R236; R237; R247; R249; R255; R265
WSL2010RES 0.001 OHM 1% 1W 2010_WSL2010.001IC1R239
WURTH_DB9_9_FEMALECONN, DB9 FEMALE RIGHT ANGLE_WUDSUB9 FEMALEIC1J12
XTAL_FA-128OSC, CRYSTAL 24MHZ MINI XTL_XTA24MHzIC1Y1
XTAL_SG310OSC, 25MHZ 2.5V_XTAL_SG310_25.025.00MHzIC2X4; X5
XTAL_SI570XO, I2C PROGRAMMABLE 2.5V SI570Si570IC1X1
附件:; J- r: l, K6 i0 z
原理图和PCB文件如下:! L$ W7 ]; q: D& F* Q2 N! M4 F# P3 {
游客,如果您要查看本帖隐藏内容请回复
7 J0 c6 M2 B. U: _3 H& H* g
' N$ R- m9 a: @
GMT+8, 2025-7-23 04:51 , Processed in 0.140625 second(s), 28 queries , Gzip On.
